[petsc-users] Build error with slepc: Unable to locate PETSc BAMG dynamic library
Thu Nov 17 09:23:07 CST 2022
Ah - so --have-petsc4py=1 disables this check in slepc? Ok - tried that - and it works for me.
[balay at pj01 petsc]$ ./configure --download-bamg --download-slepc --download-petsc4py --download-slepc-configure-arguments="--with-slepc4py=1 --have-petsc4py=1"
Satish
On Thu, 17 Nov 2022, Pierre Jolivet wrote:
> That’s a fun one.
> BAMG is built after PETSc and SLEPc.
> But slepc4py tries to import PETSc before BAMG has been built, so it’s chocking.
> Could you please try to change --download-slepc-configure-arguments=--with-slepc4py=1 to --download-slepc-configure-arguments=--with-slepc4py=1\ --have-petsc4py=1
> Thanks,
> Pierre
> > On 17 Nov 2022, at 3:19 PM, Zongze Yang <yangzongze at gmail.com> wrote:
> > Hello, I tried to build petsc with slepc. `make` give the following error information. How can I figure out the problem?  The configure.log and make.log are attached.
> > *** Building SLEPc ***
> > Checking environment... done
> > Checking PETSc installation... done
> > Processing slepc4py... [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [0]PETSC ERROR: Unable to open file
> > [0]PETSC ERROR: Unable to locate PETSc BAMG dynamic library
> >  You cannot move the dynamic libraries!
> > [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.18.1-291-g89fba64eb45  GIT Date: 2022-11-15 14:31:39 +0000
> > [0]PETSC ERROR: Unknown Name on a arch-main-debug named ws6 by z2yang Thu Nov 17 21:59:09 2022
> > [0]PETSC ERROR: Configure options PETSC_ARCH=arch-main-debug --download-bamg --download-bison --download-chaco --download-ctetgen --download-egads --download-eigen --download-exodusii --download-fftw --download-hpddm --download-ks --download-libceed --download-metis --download-ml --download-mmg --download-mumps --download-netcdf --download-opencascade --download-p4est --download-parmetis --download-parmmg --download-pnetcdf --download-pragmatic --download-ptscotch --download-scalapack --download-slepc --download-slepc-configure-arguments=--with-slepc4py=1 --download-suitesparse --download-superlu_dist --download-tetgen --download-triangle --download-cmake --download-hdf5 --download-mpich --download-mpi4py --download-slepc --download-zlib --download-libpng --download-muparser --with-petsc4py=1 --with-shared-libraries --with-x=1 --with-x-include="[/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libx11-1.7.0-5c4ah77x6u7zfm6msg6hbkt23vmwjgkz/include,
 /home/z2
 yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/xproto-7.0.31-z33ate5bew7b7xrpj3pv6nb3towcfimo/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/kbproto-1.0.7-ea2l5e2kp43i2b423eotqxseywjvqis6/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxcb-1.14-e2ea2x3zga5xipq5wvcgsw25ilq5yo63/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxau-1.0.8-gmwxeffxcbkmxvwawtndhutiwficmxwv/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxdmcp-1.1.2-bsggzn5pf6pu5guwbooi3riu5uhaqgee/include]" --with-x-lib="-L/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libx11-1.7.0-5c4ah77x6u7zfm6msg6hbkt23vmwjgkz/lib -lX11" --force
> > [0]PETSC ERROR: #1 PetscInitialize_DynamicLibraries() at /home/z2yang/repos/petsc/src/sys/dll/reg.c:135
> > [0]PETSC ERROR: #2 PetscInitialize_Common() at /home/z2yang/repos/petsc/src/sys/objects/pinit.c:1025
> > [0]PETSC ERROR: #3 PetscInitialize() at /home/z2yang/repos/petsc/src/sys/objects/pinit.c:1267
> > Traceback (most recent call last):
> >   File "/home/z2yang/repos/petsc/arch-main-debug/externalpackages/git.slepc/./configure", line 11, in <module>
> >     exec(open(os.path.join(os.path.dirname(__file__), 'config', 'configure.py')).read())
> >   File "<string>", line 215, in <module>
> >   File "/home/z2yang/repos/petsc/arch-main-debug/externalpackages/git.slepc/config/packages/slepc4py.py", line 53, in Process
> >     from petsc4py import PETSc
> >   File "/home/z2yang/repos/petsc/arch-main-debug/lib/petsc4py/PETSc.py", line 4, in <module>
> >     PETSc._initialize()
> >   File "PETSc/PETSc.pyx", line 509, in petsc4py.PETSc._initialize
> >   File "PETSc/PETSc.pyx", line 402, in petsc4py.PETSc.initialize
> > petsc4py.PETSc.Error: error code 65
> > **************************ERROR*************************************
> > Error building SLEPc.
> > gmake[2]: *** [/home/z2yang/repos/petsc/arch-main-debug/lib/petsc/conf/petscrules:29: slepcbuild] Error 1
> >   Error during compile, check arch-main-debug/lib/petsc/conf/make.log
> >   Send it and arch-main-debug/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
> > Finishing make run at Thu, 17 Nov 2022 21:59:09 +0800
> > <make.log><configure.log>
