[petsc-users] Different solution while running in parallel
    Karthikeyan Chockalingam - STFC UKRI
    karthikeyan.chockalingam at stfc.ac.uk
    Thu Nov 17 08:40:04 CST 2022
I also get the following bit get the converged reason.
   KSPConvergedReason reason;
    KSPGetConvergedReason(ksp, &reason);
    if (reason == KSP_DIVERGED_INDEFINITE_PC) {
        PetscPrintf(PETSC_COMM_WORLD, "\nDivergence because of indefinite preconditioner;\n");
        PetscPrintf(PETSC_COMM_WORLD, "Run the executable again but with '-pc_factor_shift_type POSITIVE_DEFINITE' option.\n");
       } else if (reason < 0) {
         PetscPrintf(PETSC_COMM_WORLD, "\nOther kind of divergence: this should not happen.\n");
       } else {
         KSPGetIterationNumber(ksp, &its);
         PetscPrintf(PETSC_COMM_WORLD,"\nConvergence in %d iterations.\n",(int)its);
Best,
Karthik.
From: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>
Date: Thursday, 17 November 2022 at 14:37
To: Matthew Knepley <knepley at gmail.com>, Zhang, Hong <hzhang at mcs.anl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Different solution while running in parallel
Hi Matt and Hong,
Thank you for your response.
I made the following changes, to get the desired output
    PetscReal norm; /* norm of solution error */
    PetscInt  its;
    PetscViewerAndFormat *vf;
    PetscViewerAndFormatCreate(PETSC_VIEWER_STDOUT_WORLD, PETSC_VIEWER_DEFAULT, &vf);
    ierr = KSPView(ksp, PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
    KSPSolve(ksp, b, x);
    ierr = KSPMonitorTrueResidual(ksp,its,norm,vf);CHKERRQ(ierr);
    ierr = KSPMonitorSingularValue(ksp, its, norm, vf);CHKERRQ(ierr);
I have attached the outputs from both the runs. As before, I am also printing A, b, and x.
I wonder if it is a memory issue related to mpi library employed. I am currently using openmpi – should I instead use mpich?
Kind regards,
Karthik.
Date: Thursday, 17 November 2022 at 12:19
To: Zhang, Hong <hzhang at mcs.anl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>, Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>
On Wed, Nov 16, 2022 at 9:07 PM Zhang, Hong via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Karhik,
Can you find out the condition number of your matrix?
Also, run using
  -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
and send the two outputs.
      Matt
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Sent: Wednesday, November 16, 2022 6:04 PM
To: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: [petsc-users] Different solution while running in parallel
  Hello,
   I tried to solve a (FE discretized) Poisson equation using PCLU. For some reason I am getting different solutions while running the problem on one and two cores. I have attached the output file (out.txt) from both the runs. I am printing A, b and x from both the runs – while A and b are the same but the solution seems is different.
I am not sure what I doing wrong.
Below is my matrix, vector, and solve setup.
    Mat A;
    Vec b, x;
    ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
    ierr = MatSetType(A, MATMPIAIJ); CHKERRQ(ierr);
    ierr = MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, N, N); CHKERRQ(ierr);
    ierr = MatMPIAIJSetPreallocation(A,d_nz, NULL, o_nz, NULL); CHKERRQ(ierr);
    ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE); CHKERRQ(ierr);
    ierr = MatCreateVecs(A, &b, &x); CHKERRQ(ierr);
    KSP           ksp;
    PC            pc;
    KSPCreate(PETSC_COMM_WORLD, &ksp);
    KSPSetOperators(ksp, A, A);
    ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
    ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
    ierr = PCSetType(pc,PCLU);CHKERRQ(ierr);
    ierr = PCFactorSetMatSolverType(pc,MATSOLVERMUMPS);CHKERRQ(ierr);
Thank you for your help.
Karhik.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221117/f76fe73f/attachment-0001.html>
