[petsc-users] Build error with slepc: Unable to locate PETSc BAMG dynamic library
Zongze Yang yangzongze at gmail.com
Thu Nov 17 08:19:06 CST 2022
Hello, I tried to build petsc with slepc. `make` give the following error
information. How can I figure out the problem?  The configure.log and
make.log are attached.
*** Building SLEPc ***
Checking environment... done
Checking PETSc installation... done
Processing slepc4py... [0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Unable to open file
[0]PETSC ERROR: Unable to locate PETSc BAMG dynamic library
 You cannot move the dynamic libraries!
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.18.1-291-g89fba64eb45
 GIT Date: 2022-11-15 14:31:39 +0000
[0]PETSC ERROR: Unknown Name on a arch-main-debug named ws6 by z2yang Thu
Nov 17 21:59:09 2022
[0]PETSC ERROR: Configure options PETSC_ARCH=arch-main-debug
--download-bamg --download-bison --download-chaco --download-ctetgen
--download-egads --download-eigen --download-exodusii --download-fftw
--download-hpddm --download-ks --download-libceed --download-metis
--download-ml --download-mmg --download-mumps --download-netcdf
--download-opencascade --download-p4est --download-parmetis
--download-parmmg --download-pnetcdf --download-pragmatic
--download-ptscotch --download-scalapack --download-slepc
--download-slepc-configure-arguments=--with-slepc4py=1
--download-suitesparse --download-superlu_dist --download-tetgen
--download-triangle --download-cmake --download-hdf5 --download-mpich
--download-mpi4py --download-slepc --download-zlib --download-libpng
--download-muparser --with-petsc4py=1 --with-shared-libraries --with-x=1
--with-x-include="[/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libx11-1.7.0-5c4ah77x6u7zfm6msg6hbkt23vmwjgkz/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/xproto-7.0.31-z33ate5bew7b7xrpj3pv6nb3towcfimo/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/kbproto-1.0.7-ea2l5e2kp43i2b423eotqxseywjvqis6/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxcb-1.14-e2ea2x3zga5xipq5wvcgsw25ilq5yo63/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxau-1.0.8-gmwxeffxcbkmxvwawtndhutiwficmxwv/include,/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libxdmcp-1.1.2-bsggzn5pf6pu5guwbooi3riu5uhaqgee/include]"
--with-x-lib="-L/home/z2yang/opt/spack/opt/spack/linux-ubuntu22.04-cascadelake/gcc-11.2.0/libx11-1.7.0-5c4ah77x6u7zfm6msg6hbkt23vmwjgkz/lib
-lX11" --force
[0]PETSC ERROR: #1 PetscInitialize_DynamicLibraries() at
/home/z2yang/repos/petsc/src/sys/dll/reg.c:135
[0]PETSC ERROR: #2 PetscInitialize_Common() at
/home/z2yang/repos/petsc/src/sys/objects/pinit.c:1025
[0]PETSC ERROR: #3 PetscInitialize() at
/home/z2yang/repos/petsc/src/sys/objects/pinit.c:1267
Traceback (most recent call last):
  File
"/home/z2yang/repos/petsc/arch-main-debug/externalpackages/git.slepc/./configure",
line 11, in <module>
    exec(open(os.path.join(os.path.dirname(__file__), 'config',
'configure.py')).read())
  File "<string>", line 215, in <module>
  File
"/home/z2yang/repos/petsc/arch-main-debug/externalpackages/git.slepc/config/packages/slepc4py.py",
line 53, in Process
    from petsc4py import PETSc
  File "/home/z2yang/repos/petsc/arch-main-debug/lib/petsc4py/PETSc.py",
line 4, in <module>
    PETSc._initialize()
  File "PETSc/PETSc.pyx", line 509, in petsc4py.PETSc._initialize
  File "PETSc/PETSc.pyx", line 402, in petsc4py.PETSc.initialize
petsc4py.PETSc.Error: error code 65
**************************ERROR*************************************
Error building SLEPc.
gmake[2]: ***
[/home/z2yang/repos/petsc/arch-main-debug/lib/petsc/conf/petscrules:29:
slepcbuild] Error 1
  Error during compile, check arch-main-debug/lib/petsc/conf/make.log
  Send it and arch-main-debug/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
Finishing make run at Thu, 17 Nov 2022 21:59:09 +0800
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221117/e096d22d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221117/e096d22d/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221117/e096d22d/attachment-0003.obj>
