[petsc-users] Different solution while running in parallel
Zhang, Hong
hzhang at mcs.anl.gov
Wed Nov 16 20:07:20 CST 2022
Karhik,
Can you find out the condition number of your matrix?
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov>
Sent: Wednesday, November 16, 2022 6:04 PM
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Different solution while running in parallel
Hello,
I tried to solve a (FE discretized) Poisson equation using PCLU. For some reason I am getting different solutions while running the problem on one and two cores. I have attached the output file (out.txt) from both the runs. I am printing A, b and x from both the runs – while A and b are the same but the solution seems is different.
I am not sure what I doing wrong.
Below is my matrix, vector, and solve setup.
Mat A;
Vec b, x;
ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
ierr = MatSetType(A, MATMPIAIJ); CHKERRQ(ierr);
ierr = MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, N, N); CHKERRQ(ierr);
ierr = MatMPIAIJSetPreallocation(A,d_nz, NULL, o_nz, NULL); CHKERRQ(ierr);
ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE); CHKERRQ(ierr);
ierr = MatCreateVecs(A, &b, &x); CHKERRQ(ierr);
KSP ksp;
PC pc;
KSPCreate(PETSC_COMM_WORLD, &ksp);
KSPSetOperators(ksp, A, A);
ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
ierr = PCSetType(pc,PCLU);CHKERRQ(ierr);
ierr = PCFactorSetMatSolverType(pc,MATSOLVERMUMPS);CHKERRQ(ierr);
KSPSolve(ksp, b, x);
Thank you for your help.
Karhik.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221117/646f8cf7/attachment-0001.html>
