[petsc-users] [EXTERNAL] Re: Kokkos backend for Mat and Vec diverging when running on CUDA device.
Fackler, Philip
facklerpw at ornl.gov
Tue Nov 15 10:24:28 CST 2022
Yes, most (but not all) of our system test cases fail with the kokkos/cuda or cuda backends. All of them pass with the CPU-only kokkos backend.
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Monday, November 14, 2022 19:34
To: Fackler, Philip <facklerpw at ornl.gov>
Cc: xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Blondel, Sophie <sblondel at utk.edu>; Zhang, Junchao <jczhang at mcs.anl.gov>; Roth, Philip <rothpc at ornl.gov>
Subject: [EXTERNAL] Re: [petsc-users] Kokkos backend for Mat and Vec diverging when running on CUDA device.
Hi, Philip,
Sorry to hear that. It seems you could run the same code on CPUs but not no GPUs (with either petsc/Kokkos backend or petsc/cuda backend, is it right?
--Junchao Zhang
On Mon, Nov 14, 2022 at 12:13 PM Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
This is an issue I've brought up before (and discussed in-person with Richard). I wanted to bring it up again because I'm hitting the limits of what I know to do, and I need help figuring this out.
The problem can be reproduced using Xolotl's "develop" branch built against a petsc build with kokkos and kokkos-kernels enabled. Then, either add the relevant kokkos options to the "petscArgs=" line in the system test parameter file(s), or just replace the system test parameter files with the ones from the "feature-petsc-kokkos" branch. See here the files that begin with "params_system_".
Note that those files use the "kokkos" options, but the problem is similar using the corresponding cuda/cusparse options. I've already tried building kokkos-kernels with no TPLs and got slightly different results, but the same problem.
Any help would be appreciated.
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221115/cc152852/attachment.html>
