[petsc-users] Reading Vectors from a PETSc Vec
Mohammad Ali Yaqteen
mhyaqteen at sju.ac.kr
Mon Nov 14 18:39:04 CST 2022
I am using the following procedure to read from Vec, but it keeps giving me the same values! I was told that using VecGetValues gives wrog output. If not this, then what function should be used to read the contents of a vector?
for (int i = 0; i < nconv; i++)
PetscCall(EPSGetEigenpair(eps,i,&kr,&ki,xr,xi));
PetscCall(EPSComputeError(eps,i,EPS_ERROR_RELATIVE,&error1));
#if defined(PETSC_USE_COMPLEX)
re = PetscRealPart(kr);
im = PetscImaginaryPart(kr);
#else
re = kr;
im = ki;
#endif
if (im!=0.0) PetscCall(PetscPrintf(PETSC_COMM_WORLD," %9f%+9fi %12g\n",(double)re,(double)im,(double)error1));
else PetscCall(PetscPrintf(PETSC_COMM_WORLD," %12f %12g\n",(double)re,(double)error1));
eval(i) = re;
VecGetValues(xr, tdof, ei, eveci);
for (int j = 0; j < tdof; j++)
evec(j, i) = eveci[j];
PetscCall(PetscPrintf(PETSC_COMM_WORLD,"\n"));
Thank you
Ali
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221115/29dd7bc1/attachment.html>
