[petsc-users] On PCFIELDSPLIT and its implementation
Edoardo alinovi edoardo.alinovi at gmail.com
Fri Nov 11 13:12:55 CST 2022
Hi guys,
anyone with any suggestion to make this thing work? 🥺🙏
Il Ven 11 Nov 2022, 10:24 Edoardo alinovi <edoardo.alinovi at gmail.com> ha
scritto:
> Hi Barry,
> FYI, in test.F90 I noted that "ui" starts for 1 and not from 0. I fixed it
> but the situation does not change much. I attached the new file in this
> email.
> Thanks for the support, I am really walking in the dark!
> Il giorno gio 10 nov 2022 alle ore 23:28 Edoardo alinovi <
> edoardo.alinovi at gmail.com> ha scritto:
>> Ah I see you have already added the missing interfaces for fortran
>> enthusiasts :) So you likely do not need Matt's hack!
>> [image: image.png]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221111/02a6fe80/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221111/02a6fe80/attachment-0001.png>
