[petsc-users] On PCFIELDSPLIT and its implementation
Matthew Knepley
knepley at gmail.com
Wed Nov 9 07:12:22 CST 2022
On Wed, Nov 9, 2022 at 8:09 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Sure,
> I'll try on a 3x3 cavity. How can I print the ISs?
ISView() or PetscObjectViewFromOptions()
Matt
> Il Mer 9 Nov 2022, 14:07 Matthew Knepley <knepley at gmail.com> ha scritto:
>> On Wed, Nov 9, 2022 at 7:57 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
>> wrote:
>>> To be clear,
>>> You are suggesting to use ufields(0)=0, ufields(1)=1 and so on?
>> I think you are right. Those should start from 1. However, your ISes do
>> not seem to cover
>> the whole matrix. Can you start with a very small problem so that you can
>> print them to
>> the screen?
>> Thanks,
>> Matt
>>> Il Mer 9 Nov 2022, 13:54 Edoardo alinovi <edoardo.alinovi at gmail.com> ha
>>> scritto:
>>>> Even in the fortran interface?
>>>> Il Mer 9 Nov 2022, 13:52 Matthew Knepley <knepley at gmail.com> ha
>>>> scritto:
>>>>> Fields are numbered from 0.
>>>>> Thanks,
>>>>> Matt
>>>>> On Wed, Nov 9, 2022 at 2:20 AM Edoardo alinovi <
>>>>> edoardo.alinovi at gmail.com> wrote:
>>>>>> Hello guys,
>>>>>> I am getting this error while using fieldsplit:
>>>>>> [3]PETSC ERROR: --------------------- Error Message
>>>>>> *[3]PETSC ERROR: Nonconforming object sizes[3]PETSC ERROR: Local
>>>>>> column sizes 6132 do not add up to total number of columns 9200*
>>>>>> [3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>> shooting.
>>>>>> [3]PETSC ERROR: Petsc Development GIT revision:
>>>>>> v3.18.1-191-g32ed6ae2ff2 GIT Date: 2022-11-08 12:22:17 -0500
>>>>>> [3]PETSC ERROR: flubio_coupled on a gnu named alienware by edo Wed
>>>>>> Nov 9 08:16:29 2022
>>>>>> [3]PETSC ERROR: Configure options PETSC_ARCH=gnu FOPTFLAGS=-O3
>>>>>> COPTFLAGS=-O3 CXXOPTFLAGS=-O3 -with-debugging=no -download-fblaslapack=1
>>>>>> -download-superlu_dist -download-mumps -download-hypre -download-metis
>>>>>> -download-parmetis -download-scalapack -download-ml -download-slepc
>>>>>> -download-hpddm -download-cmake
>>>>>> -with-mpi-dir=/home/edo/software/openmpi-4.1.1/build/
>>>>>> [3]PETSC ERROR: #1 MatCreateSubMatrix_MPIBAIJ_Private() at
>>>>>> /home/edo/software/petsc/src/mat/impls/baij/mpi/mpibaij.c:1987
>>>>>> [3]PETSC ERROR: #2 MatCreateSubMatrix_MPIBAIJ() at
>>>>>> /home/edo/software/petsc/src/mat/impls/baij/mpi/mpibaij.c:1911
>>>>>> [3]PETSC ERROR: #3 MatCreateSubMatrix() at
>>>>>> /home/edo/software/petsc/src/mat/interface/matrix.c:8340
>>>>>> [3]PETSC ERROR: #4 PCSetUp_FieldSplit() at
>>>>>> /home/edo/software/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:657
>>>>>> [3]PETSC ERROR: #5 PCSetUp() at
>>>>>> /home/edo/software/petsc/src/ksp/pc/interface/precon.c:994
>>>>>> [3]PETSC ERROR: #6 KSPSetUp() at
>>>>>> /home/edo/software/petsc/src/ksp/ksp/interface/itfunc.c:406
>>>>>> [3]PETSC ERROR: #7 KSPSolve_Private() at
>>>>>> /home/edo/software/petsc/src/ksp/ksp/interface/itfunc.c:825
>>>>>> [3]PETSC ERROR: #8 KSPSolve() at
>>>>>> /home/edo/software/petsc/src/ksp/ksp/interface/itfunc.c:1071
>>>>>> Do you have any ideas? Probably something missing in my brief
>>>>>> implementation here:
>>>>>> * call PCSetType(mypc, PCFIELDSPLIT, ierr)
>>>>>> call PCFieldSplitSetBlockSize(mypc, 4-bdim, ierr) *
>>>>>> * !2D, 3x3 block if(bdim==1) then
>>>>>> ufields(1) = 0 ufields(2) = 1 pfields(1) =
>>>>>> 2 call PCFieldSplitSetFields(mypc, "u", 2, ufields, ufields,
>>>>>> ierr) call PCFieldSplitSetFields(mypc, "p", 1, pfields,
>>>>>> pfields, ierr) ! 3D 4x4 block else
>>>>>> ufields(1) = 0 ufields(2) = 1 ufields(3) = 2
>>>>>> pfields(1) = 3 call
>>>>>> PCFieldSplitSetFields(mypc, "u", 3, ufields, ufields, ierr)
>>>>>> call PCFieldSplitSetFields(mypc, "p", 1, pfields, pfields, ierr)
>>>>>> endif ! Field split type ADDITIVE, MULTIPLICATIVE
>>>>>> (default), SYMMETRIC_MULTIPLICATIVE, SPECIAL, SCHUR call
>>>>>> PCFieldSplitSetType(mypc, PC_COMPOSITE_SCHUR, ierr)*
>>>>>> Thanks for the help!
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221109/fdf5eda9/attachment-0001.html>
