[petsc-users] Local columns of A10 do not equal local rows of A00
Matthew Knepley
knepley at gmail.com
Mon Nov 7 14:32:54 CST 2022
On Mon, Nov 7, 2022 at 2:09 PM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> The libMesh/MOOSE specific code that identifies dof indices for
> ISCreateGeneral is in DMooseGetEmbedding_Private. I can share that function
> (it's quite long) or more details if that could be helpful.
Sorry, I should have written more. The puzzling thing for me is that
somehow it looks like the row and column index sets are not the same. I did
not think
PCFIELDSPLIT could do that. The PCFieldSplitSetIS() interface does not
allow it. I was wondering how you were setting the ISes.
Matt
> On Mon, Nov 7, 2022 at 10:55 AM Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> I'm not sure exactly what you mean, but I'll try to give more details. We
>> have our own DM class (DM_Moose) and we set our own field and domain
>> decomposition routines:
>> dm->ops->createfielddecomposition = DMCreateFieldDecomposition_Moose;
>> dm->ops->createdomaindecomposition = DMCreateDomainDecomposition_Moose;
>> The field and domain decomposition routines are as follows (can see also
>> at
>> https://github.com/idaholab/moose/blob/next/framework/src/utils/PetscDMMoose.C
>> static PetscErrorCode
>> DMCreateFieldDecomposition_Moose(
>> DM dm, PetscInt * len, char *** namelist, IS ** islist, DM ** dmlist)
>> PetscErrorCode ierr;
>> DM_Moose * dmm = (DM_Moose *)(dm->data);
>> PetscFunctionBegin;
>> /* Only called after DMSetUp(). */
>> if (!dmm->_splitlocs)
>> PetscFunctionReturn(0);
>> *len = dmm->_splitlocs->size();
>> if (namelist)
>> ierr = PetscMalloc(*len * sizeof(char *), namelist);
>> CHKERRQ(ierr);
>> if (islist)
>> ierr = PetscMalloc(*len * sizeof(IS), islist);
>> CHKERRQ(ierr);
>> if (dmlist)
>> ierr = PetscMalloc(*len * sizeof(DM), dmlist);
>> CHKERRQ(ierr);
>> for (const auto & dit : *(dmm->_splitlocs))
>> unsigned int d = dit.second;
>> std::string dname = dit.first;
>> DM_Moose::SplitInfo & dinfo = (*dmm->_splits)[dname];
>> if (!dinfo._dm)
>> ierr = DMCreateMoose(((PetscObject)dm)->comm, *dmm->_nl,
>> &dinfo._dm);
>> CHKERRQ(ierr);
>> ierr = PetscObjectSetOptionsPrefix((PetscObject)dinfo._dm,
>> ((PetscObject)dm)->prefix);
>> CHKERRQ(ierr);
>> std::string suffix = std::string("fieldsplit_") + dname + "_";
>> ierr = PetscObjectAppendOptionsPrefix((PetscObject)dinfo._dm,
>> suffix.c_str());
>> CHKERRQ(ierr);
>> ierr = DMSetFromOptions(dinfo._dm);
>> CHKERRQ(ierr);
>> ierr = DMSetUp(dinfo._dm);
>> CHKERRQ(ierr);
>> if (namelist)
>> ierr = PetscStrallocpy(dname.c_str(), (*namelist) + d);
>> CHKERRQ(ierr);
>> if (islist)
>> if (!dinfo._rembedding)
>> IS dembedding, lembedding;
>> ierr = DMMooseGetEmbedding_Private(dinfo._dm, &dembedding);
>> CHKERRQ(ierr);
>> if (dmm->_embedding)
>> // Create a relative embedding into the parent's index space.
>> ierr = ISEmbed(dembedding, dmm->_embedding, PETSC_TRUE,
>> &lembedding);
>> CHKERRQ(ierr);
>> const PetscInt * lindices;
>> PetscInt len, dlen, llen, *rindices, off, i;
>> ierr = ISGetLocalSize(dembedding, &dlen);
>> CHKERRQ(ierr);
>> ierr = ISGetLocalSize(lembedding, &llen);
>> CHKERRQ(ierr);
>> if (llen != dlen)
>> SETERRQ1(((PetscObject)dm)->comm, PETSC_ERR_PLIB, "Failed to
>> embed split %D", d);
>> ierr = ISDestroy(&dembedding);
>> CHKERRQ(ierr);
>> // Convert local embedding to global (but still relative)
>> embedding
>> ierr = PetscMalloc(llen * sizeof(PetscInt), &rindices);
>> CHKERRQ(ierr);
>> ierr = ISGetIndices(lembedding, &lindices);
>> CHKERRQ(ierr);
>> ierr = PetscMemcpy(rindices, lindices, llen * sizeof(PetscInt));
>> CHKERRQ(ierr);
>> ierr = ISDestroy(&lembedding);
>> CHKERRQ(ierr);
>> // We could get the index offset from a corresponding global
>> vector, but subDMs don't yet
>> // have global vectors
>> ierr = ISGetLocalSize(dmm->_embedding, &len);
>> CHKERRQ(ierr);
>> ierr = MPI_Scan(&len,
>> &off,
>> 1,
>> #ifdef PETSC_USE_64BIT_INDICES
>> MPI_LONG_LONG_INT,
>> #else
>> MPI_INT,
>> #endif
>> MPI_SUM,
>> ((PetscObject)dm)->comm);
>> CHKERRQ(ierr);
>> off -= len;
>> for (i = 0; i < llen; ++i)
>> rindices[i] += off;
>> ierr = ISCreateGeneral(
>> ((PetscObject)dm)->comm, llen, rindices, PETSC_OWN_POINTER,
>> &(dinfo._rembedding));
>> CHKERRQ(ierr);
>> else
>> dinfo._rembedding = dembedding;
>> ierr = PetscObjectReference((PetscObject)(dinfo._rembedding));
>> CHKERRQ(ierr);
>> (*islist)[d] = dinfo._rembedding;
>> if (dmlist)
>> ierr = PetscObjectReference((PetscObject)dinfo._dm);
>> CHKERRQ(ierr);
>> (*dmlist)[d] = dinfo._dm;
>> DMCreateDomainDecomposition_Moose(
>> DM dm, PetscInt * len, char *** namelist, IS ** innerislist, IS **
>> outerislist, DM ** dmlist)
>> PetscFunctionBegin;
>> /* Use DMCreateFieldDecomposition_Moose() to obtain everything but
>> outerislist, which is currently
>> * PETSC_NULL. */
>> if (outerislist)
>> *outerislist = PETSC_NULL; /* FIX: allow mesh-based overlap. */
>> ierr = DMCreateFieldDecomposition_Moose(dm, len, namelist, innerislist,
>> dmlist);
>> CHKERRQ(ierr);
>> On Thu, Nov 3, 2022 at 5:19 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Nov 3, 2022 at 7:52 PM Alexander Lindsay <
>>>> I have errors on quite a few (but not all) processes of the like
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Nonconforming object sizes
>>>> [1]PETSC ERROR: Local columns of A10 4137 do not equal local rows of
>>>> A00 4129
>>>> when performing field splits. We (MOOSE) have some code for identifying
>>>> the index sets for each split. However, the code was written by some
>>>> authors who are no longer with us. Normally I would chase this down in a
>>>> debugger, but this error only seems to crop up for pretty complex and large
>>>> meshes. If anyone has an idea for what we might be doing wrong, that might
>>>> help me chase this down faster. I guess intuitively I'm pretty perplexed
>>>> that we could get ourselves into this pickle as it almost appears that we
>>>> have two different local dof index counts for a given block (0 in this
>>>> case). More background, if helpful, can be found in
>>>> https://github.com/idaholab/moose/issues/22359 as well as
>>>> https://github.com/idaholab/moose/discussions/22468.
>>> How are you specifying the blocks? I would not have thought this was
>>> possible.
>>> Thanks,
>>> Matt
>>>> I should note that we are currently running with 3.16.6 as our PETSc
>>>> submodule hash (we are talking about updating to 3.18 soon).
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/1285266d/attachment.html>
