[petsc-users] PETSc Windows Installation
    Mohammad Ali Yaqteen
    mhyaqteen at sju.ac.kr
    Mon Nov  7 07:29:16 CST 2022
Do I have to follow all the steps in the first link as it says the following in step 6:
$ pacman -S mingw-w64-ucrt-x86_64-gcc
resolving dependencies...
looking for conflicting packages...
Packages (15) mingw-w64-ucrt-x86_64-binutils-2.39-2
            mingw-w64-ucrt-x86_64-crt-git-10.0.0.r68.g6eb571448-1
            mingw-w64-ucrt-x86_64-gcc-libs-12.2.0-1  mingw-w64-ucrt-x86_64-gmp-6.2.1-3
            mingw-w64-ucrt-x86_64-headers-git-10.0.0.r68.g6eb571448-1
            mingw-w64-ucrt-x86_64-isl-0.25-1  mingw-w64-ucrt-x86_64-libiconv-1.17-1
            mingw-w64-ucrt-x86_64-libwinpthread-git-10.0.0.r68.g6eb571448-1
            mingw-w64-ucrt-x86_64-mpc-1.2.1-1  mingw-w64-ucrt-x86_64-mpfr-4.1.0.p13-1
            mingw-w64-ucrt-x86_64-windows-default-manifest-6.4-4
            mingw-w64-ucrt-x86_64-winpthreads-git-10.0.0.r68.g6eb571448-1
            mingw-w64-ucrt-x86_64-zlib-1.2.12-1  mingw-w64-ucrt-x86_64-zstd-1.5.2-2
            mingw-w64-ucrt-x86_64-gcc-12.2.0-1
Total Installed Size:  397.59 MiB
:: Proceed with installation? [Y/n]
[... downloading and installation continues ...]
Thanks
Ali
Sent: Monday, November 7, 2022 10:06 PM
To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PETSc Windows Installation
Please, keep the list in copy.
You can get MSYS2 from https://www.msys2.org/
Then install the following packages: https://github.com/FreeFem/FreeFem-sources/tree/master/etc/jenkins/deployRelease#windows-system
Also install MS-MPI: https://www.microsoft.com/en-us/download/details.aspx?id=100593
Configure and compile PETSc under a MSYS2 MinGW x64 shell.
Compile your code, and copy the binary.
Notice in my screenshot that there are two shells, the MinGW one for building PETSc.
The Microsoft (native one) for launching the binary.
Pierre
[cid:image001.png at 01D8F2F8.5D863F80]
On 7 Nov 2022, at 1:53 PM, Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
Is there a guide for it? That would be very useful! Because I have been trying a lot of things but every now and then there is a little step that is either outdated or can’t run!
Your help will be highly appreciated
Thanks
Ali
From: Pierre Jolivet <pierre at joliv.et<mailto:pierre at joliv.et>>
Sent: Monday, November 7, 2022 9:50 PM
To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>>
Cc: petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Or you can use MinGW, it’s not tricky, you don’t need to change any PETSc code, and you can ship .exe for either x86_64 (mingw-w64-x86_64-gcc) or ARM (mingw-w64-clang-aarch64-clang, without MPI).
Pierre
On 7 Nov 2022, at 1:38 PM, hamid badi <badi.hamid at gmail.com<mailto:badi.hamid at gmail.com>> wrote:
You can try gcc/clang cross-compilers, it's a little but tricky, i had to change some petsc codes but it works fine.
Le lun. 7 nov. 2022 à 13:30, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> a écrit :
On Mon, Nov 7, 2022 at 7:11 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
Once I finish writing the code, the .exe file will not change. Can I make an .exe file using WSL2 and VScode?
If you build in WSL2, it will link to system libraries. You would probably need to run in WSL2 after that. If you are planning
on running on native Windows, you likely need to build there.
     Matt
Ali
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Monday, November 7, 2022 7:13 PM
On Mon, Nov 7, 2022 at 12:21 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
I have written backend code for a software company. If WSL2 and VSCode(Linux) can be called through a command line and executed at the backend, then it will be great. But if I have to install WSL2 and other required things on every other PC that will run that software, then I think I will be at a disadvantage. What do you suggest?
As long as you do not change the architecture and the compiler libraries are available, you can run the executable.
     Matt
Thank you
Ali
-----Original Message-----
From: Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
Sent: Monday, November 7, 2022 12:00 AM
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Cc: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Likely the compilers are not setup correctly as per instructions.
https://petsc.org/release/install/windows/#installation-with-microsoft-intel-windows-compilers
And if you do not have a specific windows need - and only need IDE - perhaps a WSL2 (aka linux) install with VSCode(linux) might be the way to go.
Satish
On Sun, 6 Nov 2022, Matthew Knepley wrote:
> We need to see configure.log to see what is going on. Can you send it?
>   Thanks,
>      Matt
> On Sun, Nov 6, 2022 at 4:29 AM Mohammad Ali Yaqteen
> wrote:
> > Dear Sir/Madam,
> > I am installing PETSc on windows but it keeps giving me unexpected errors.
> > I want to use it on MS Visual Studio or Codeblocks. When I use the
> > command on your webpage (./configure --with-cc='win32fe cl'
> > --with-fc='win32fe ifort' --with-cxx='win32fe cl' --with-mpi=0
> > --download-fblaslapack), I get the following error message:
> > $ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack
> >                          Configuring PETSc to compile on your system
> > TESTING: checkCCompiler from
> > config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > C compiler you provided with -with-cc=win32fe cl cannot be found or
> > does not work.
> > Cannot compile/link C with
> > /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/win32fe cl.
> > Kindly look into this problem! Your prompt response will highly be
> > appreciated
> > Thank you
> > Ali
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/f055cf9e/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/f055cf9e/attachment-0001.png>
