[petsc-users] PETSc Windows Installation
Mon Nov 7 04:13:00 CST 2022
On Mon, Nov 7, 2022 at 12:21 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
wrote:
> I have written backend code for a software company. If WSL2 and
> VSCode(Linux) can be called through a command line and executed at the
> backend, then it will be great. But if I have to install WSL2 and other
> required things on every other PC that will run that software, then I think
> I will be at a disadvantage. What do you suggest?
As long as you do not change the architecture and the compiler libraries
are available, you can run the executable.
     Matt
> Thank you
> Ali
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Monday, November 7, 2022 12:00 AM
> To: Matthew Knepley <knepley at gmail.com>
> Cc: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] PETSc Windows Installation
> Likely the compilers are not setup correctly as per instructions.
> https://petsc.org/release/install/windows/#installation-with-microsoft-intel-windows-compilers
> And if you do not have a specific windows need - and only need IDE -
> perhaps a WSL2 (aka linux) install with VSCode(linux) might be the way to
> go.
> Satish
> On Sun, 6 Nov 2022, Matthew Knepley wrote:
> > We need to see configure.log to see what is going on. Can you send it?
> >   Thanks,
> >      Matt
> > On Sun, Nov 6, 2022 at 4:29 AM Mohammad Ali Yaqteen
> > wrote:
> > > Dear Sir/Madam,
> > > I am installing PETSc on windows but it keeps giving me unexpected
> errors.
> > > I want to use it on MS Visual Studio or Codeblocks. When I use the
> > > command on your webpage (./configure --with-cc='win32fe cl'
> > > --with-fc='win32fe ifort' --with-cxx='win32fe cl' --with-mpi=0
> > > --download-fblaslapack), I get the following error message:
> > > $ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > > --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack
> > >                          Configuring PETSc to compile on your system
> > > TESTING: checkCCompiler from
> > > config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > C compiler you provided with -with-cc=win32fe cl cannot be found or
> > > does not work.
> > > Cannot compile/link C with
> > > /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/win32fe cl.
> > > Kindly look into this problem! Your prompt response will highly be
> > > appreciated
> > > Thank you
> > > Ali
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/0624e835/attachment.html>
