[petsc-users] On the usage of MatSetValuesBlocked
Matthew Knepley
knepley at gmail.com
Fri Nov 4 05:51:42 CDT 2022
On Fri, Nov 4, 2022 at 4:32 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> It is working like a charm now!
> Is it mandatory to use VecSetValuesBlocked to assemble the rhs? Does the
> Vec need to be of any other type than VECMPI?
SetValuesBlocked() is never required. You can always use the normal
versions, but you would have to supply all the indices, not just the block
indices.
Matt
> I am assembling it like this:
> brhs(1:3-bdim) = this%Ueqn%bC(iElement,1:3-bdim)
> brhs(4-bdim) = this%Peqn%bC(iElement,1)
> call VecSetValuesBlocked(this%rhs, 1,
> mesh%cellGlobalAddr(iElement)-1, brhs, INSERT_VALUES, ierr)
> But I am getting into troubles:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: *PetscSegBufferAlloc_Private*
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.18.0, Sep 30, 2022
> [0]PETSC ERROR: flubio_coupled on a gnu named alienware by edo Fri Nov 4
> 09:31:03 2022
> [0]PETSC ERROR: Configure options PETSC_ARCH=gnu FOPTFLAGS=-O3
> COPTFLAGS=-O3 CXXOPTFLAGS=-O3 -with-debugging=no -download-fblaslapack=1
> -download-superlu_dist -download-mumps -download-hypre -download-metis
> -download-parmetis -download-scalapack -download-ml -download-slepc
> -download-hpddm -download-cmake
> -with-mpi-dir=/home/edo/software/openmpi-4.1.1/build/
> [0]PETSC ERROR: #1 PetscMallocAlign() at
> /home/edo/software/petsc-3.18.0/src/sys/memory/mal.c:55
> [0]PETSC ERROR: #2 PetscSegBufferAlloc_Private() at
> /home/edo/software/petsc-3.18.0/src/sys/utils/segbuffer.c:31
> [0]PETSC ERROR: #3 PetscSegBufferGet() at
> /home/edo/software/petsc-3.18.0/src/sys/utils/segbuffer.c:94
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: General MPI error
> [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.18.0, Sep 30, 2022
> [1]PETSC ERROR: flubio_coupled on a gnu named alienware by edo Fri Nov 4
> 09:31:03 2022
> [1]PETSC ERROR: Configure options PETSC_ARCH=gnu FOPTFLAGS=-O3
> [1]PETSC ERROR: #1 VecAssemblySend_MPI_Private() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/impls/mpi/pbvec.c:133
> [1]PETSC ERROR: #2 PetscCommBuildTwoSidedFReq_Reference() at
> /home/edo/software/petsc-3.18.0/src/sys/utils/mpits.c:314
> [1]PETSC ERROR: #3 PetscCommBuildTwoSidedFReq() at
> /home/edo/software/petsc-3.18.0/src/sys/utils/mpits.c:526
> [1]PETSC ERROR: [0]PETSC ERROR: #4 VecAssemblyRecv_MPI_Private() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/impls/mpi/pbvec.c:164
> [0]PETSC ERROR: #5 PetscCommBuildTwoSidedFReq_Reference() at
> /home/edo/software/petsc-3.18.0/src/sys/utils/mpits.c:320
> [0]PETSC ERROR: #6 PetscCommBuildTwoSidedFReq() at
> [0]PETSC ERROR: #7 VecAssemblyBegin_MPI_BTS() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/impls/mpi/pbvec.c:238
> #4 VecAssemblyBegin_MPI_BTS() at
> [1]PETSC ERROR: #5 VecAssemblyBegin() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/interface/vector.c:124
> [1]PETSC ERROR: #6 VecAssemblyEnd_MPI_BTS() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/impls/mpi/pbvec.c:337
> [1]PETSC ERROR: #7 VecAssemblyEnd() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/interface/vector.c:158
> [1]PETSC ERROR: #8 VecView() at
> /home/edo/software/petsc-3.18.0/src/vec/vec/interface/vector.c:719
> [0]PETSC ERROR: #8 VecAssemblyBegin() at
> Vec Object: 2 MPI processes
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221104/82ec93ab/attachment.html>
