[petsc-users] locate DMSwarm particles with respect to a background DMDA mesh
Matthew Knepley
knepley at gmail.com
Thu Nov 3 20:43:28 CDT 2022
On Thu, Nov 3, 2022 at 8:36 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 27, 2022 at 11:57 AM Semplice Matteo <
> matteo.semplice at uninsubria.it> wrote:
>> Dear Petsc developers,
>> I am trying to use a DMSwarm to locate a cloud of points with respect
>> to a background mesh. In the real application the points will be loaded
>> from disk, but I have created a small demo in which
>> - each processor creates Npart particles, all within the domain
>> covered by the mesh, but not all in the local portion of the mesh
>> - migrate the particles
>> After migration most particles are not any more in the DMSwarm (how many
>> and which ones seems to depend on the number of cpus, but it never happens
>> that all particle survive the migration process).
>> I am clearly missing some step, since I'd expect that a DMDA would be
>> able to locate particles without the need to go through a DMShell as it is
>> done in src/dm/tutorials/swarm_ex3.c.html
>> <https://petsc.org/main/src/dm/tutorials/swarm_ex3.c.html>
>> I attach my demo code.
>> Could someone give me a hint?
> Thanks for sending this. I found the problem. Someone has some overly
> fancy code inside DMDA to figure out the local bounding box from the
> coordinates.
> It is broken for DM_BOUNDARY_GHOSTED, but we never tested with this. I
> will fix it.
Okay, I think this fix is correct
https://gitlab.com/petsc/petsc/-/merge_requests/5802
I incorporated your test as src/dm/impls/da/tests/ex1.c. Can you take a
look and see if this fixes your issue?
Matt
> Thanks,
> Matt
>> Best
>> Matteo
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221103/faabf2a5/attachment-0001.html>
