[petsc-users] Redefining MPI functions as macros can break C++ code
Wed Nov 2 22:48:20 CDT 2022
You can define 'PETSC_HAVE_BROKEN_RECURSIVE_MACRO' and then include
petsc.h in your sources to avoid these macros in amrex/application
codes.
PETSc logging is one of the important features - its best to not
disable it (globally for all) due to this issue.
Satish
On Wed, 2 Nov 2022, Erik Schnetter wrote:
> PETSc redefines MPI functions as macros when logging is enabled. This
> breaks some C++ code; see e.g. <
> https://github.com/AMReX-Codes/amrex/pull/3005> for an example. The reason
> is that macros get confused about commas in template arguments.
> It would be convenient if PETSc used a different way to log MPI function
> calls, but I can't think of a good way. Alternatively, logging could be
> disabled by default, or MPI logging could be disabled by default, or there
> could be a simple way to opt out (e.g. use `#define PETSC_LOG_MPI` after
> `#include <petsc.h>` to enable it for a source file).
> -erik
