[petsc-users] PETSc Windows Installation
Mohammad Ali Yaqteen
mhyaqteen at sju.ac.kr
Tue Nov 1 09:37:14 CDT 2022
The above commands worked but I get an error message when I include petsc.h in Visual Studio. The error message is "Cannot open include file: 'petscconf.h': No such file or directory
Ali
-----Original Message-----
Sent: Tuesday, November 1, 2022 2:40 PM
To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PETSc Windows Installation
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lhwloc: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -levent_core: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -levent_pthreads: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lz: No such file or directory
For some reason cygwin has broken dependencies here. Run cygwin setup and install the following pkgs.
$ cygcheck.exe -f /usr/lib/libhwloc.dll.a /usr/lib/libevent_core.dll.a /usr/lib/libevent_pthreads.dll.a /usr/lib/libz.dll.a
libevent-devel-2.1.12-1
libhwloc-devel-2.6.0-2
zlib-devel-1.2.12-1
BTW: you can attach the file from PETSC_DIR/PETSC_ARCH/lib/petsc/conf/configure.log
Satish
On Tue, 1 Nov 2022, Mohammad Ali Yaqteen wrote:
> I am unable to attach the configure.log file. Hence. I have copied the following text after executing the command (less configure.log) in the cygwin64
> Executing: uname -s
> stdout: CYGWIN_NT-10.0-19044
> Configuring PETSc to compile on your system
> Starting configure run at Tue, 01 Nov 2022 13:06:06 +0900
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> Working directory: /home/SEJONG/petsc-3.18.1
> Machine platform:
> uname_result(system='CYGWIN_NT-10.0-19044', node='DESKTOP-R1C768B', release='3.3.6-341.x86_64', version='2022-09-05 11:15 UTC', machine='x86_64')
> Python version:
> 3.9.10 (main, Jan 20 2022, 21:37:52)
> [GCC 11.2.0]
> Environmental variables
> USERDOMAIN=DESKTOP-R1C768B
> OS=Windows_NT
> COMMONPROGRAMFILES=C:\Program Files\Common Files
> PROCESSOR_LEVEL=6
> PSModulePath=C:\Users\SEJONG\Documents\WindowsPowerShell\Modules;C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
> CommonProgramW6432=C:\Program Files\Common Files
> CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
> LANG=en_US.UTF-8
> TZ=Asia/Seoul
> HOSTNAME=DESKTOP-R1C768B
> PUBLIC=C:\Users\Public
> OLDPWD=/home/SEJONG
> USERNAME=SEJONG
> LOGONSERVER=\\DESKTOP-R1C768B
> PROCESSOR_ARCHITECTURE=AMD64
> LOCALAPPDATA=C:\Users\SEJONG\AppData\Local
> COMPUTERNAME=DESKTOP-R1C768B
> USER=SEJONG
> SYSTEMDRIVE=C:
> USERPROFILE=C:\Users\SEJONG
> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.CPL
> SYSTEMROOT=C:\Windows
> USERDOMAIN_ROAMINGPROFILE=DESKTOP-R1C768B
> OneDriveCommercial=C:\Users\SEJONG\OneDrive - Sejong University
> PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 165 Stepping 5, GenuineIntel
> GNUPLOT_LIB=C:\Program Files\gnuplot\demo;C:\Program Files\gnuplot\demo\games;C:\Program Files\gnuplot\share
> PWD=/home/SEJONG/petsc-3.18.1
> MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
> HOME=/home/SEJONG
> TMP=/tmp
> OneDrive=C:\Users\SEJONG\OneDrive - Sejong University
> ZES_ENABLE_SYSMAN=1
> !C:=C:\cygwin64\bin
> PROCESSOR_REVISION=a505
> PROFILEREAD=true
> PROMPT=$P$G
> NUMBER_OF_PROCESSORS=16
> COMSPEC=C:\Windows\system32\cmd.exe
> APPDATA=C:\Users\SEJONG\AppData\Roaming
> SHELL=/bin/bash
> TERM=xterm-256color
> WINDIR=C:\Windows
> ProgramData=C:\ProgramData
> SHLVL=1
> PRINTER=\\210.107.220.119\HP Color LaserJet Pro MFP M377 PCL 6
> ALLUSERSPROFILE=C:\ProgramData
> TEMP=/tmp
> DriverData=C:\Windows\System32\Drivers\DriverData
> SESSIONNAME=Console
> PATH=/usr/local/bin:/usr/bin:/cygdrive/c/SIMULIA/Commands:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/MATLAB/R2020b/bin:/cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn:/cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn:/cygdrive/c/Program Files/Git/cmd:/cygdrive/c/msys64/mingw64/bin:/cygdrive/c/msys64/usr/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Program Files/dotnet:/:/cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Users/SEJONG/.dotnet/tools:/usr/lib/lapack
> PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
> HOMEDRIVE=C:
> INFOPATH=/usr/local/info:/usr/share/info:/usr/info
> HOMEPATH=\Users\SEJONG
> ORIGINAL_PATH=/cygdrive/c/SIMULIA/Commands:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/MATLAB/R2020b/bin:/cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn:/cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn:/cygdrive/c/Program Files/Git/cmd:/cygdrive/c/msys64/mingw64/bin:/cygdrive/c/msys64/usr/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Program Files/dotnet:/:/cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Users/SEJONG/.dotnet/tools
> EXECIGNORE=*.dll
> _=./configure
> Files in path provided by default path
> /usr/local/bin:
> /usr/bin: addftinfo.exe addr2line.exe apropos ar.exe arch.exe as.exe ash.exe awk b2sum.exe base32.exe base64.exe basename.exe basenc.exe bash.exe bashbug bomtool.exe bunzip2.exe bzcat.exe bzcmp bzdiff bzegrep bzfgrep bzgrep bzip2.exe bzip2recover.exe bzless bzmore c++.exe c++filt.exe c89 c99 ca-legacy cal.exe captoinfo cat.exe catman.exe cc ccmake.exe chattr.exe chcon.exe chgrp.exe chmod.exe chown.exe chroot.exe chrt.exe cksum.exe clear.exe cmake.exe cmp.exe col.exe colcrt.exe colrm.exe column.exe comm.exe cp.exe cpack.exe cpp.exe csplit.exe ctest.exe cut.exe cygarchive-13.dll cygargp-0.dll cygatomic-1.dll cygattr-1.dll cygblkid-1.dll cygbrotlicommon-1.dll cygbrotlidec-1.dll cygbz2-1.dll cygcheck.exe cygcom_err-2.dll cygcrypt-2.dll cygcrypto-1.1.dll cygcurl-4.dll cygdb-5.3.dll cygdb_cxx-5.3.dll cygdb_sql-5.3.dll cygedit-0.dll cygevent-2-1-7.dll cygevent_core-2-1-7.dll cygevent_extra-2-1-7.dll cygevent_openssl-2-1-7.dll cygevent_pthreads-2-1-7.dll cygexpat-1.dll cygfdisk-1.dll cygffi-6.dll cygfido2-1.dll cygformw-10.dll cyggc-1.dll cyggcc_s-seh-1.dll cyggdbm-6.dll cyggdbm_compat-4.dll cyggfortran-5.dll cyggmp-10.dll cyggomp-1.dll cyggsasl-7.dll cyggssapi_krb5-2.dll cygguile-2.2-1.dll cyghistory7.dll cyghwloc-15.dll cygiconv-2.dll cygidn-12.dll cygidn2-0.dll cygintl-8.dll cygisl-23.dll cygjsoncpp-25.dll cygk5crypto-3.dll cygkrb5-3.dll cygkrb5support-0.dll cyglber-2-4-2.dll cyglber-2.dll cygldap-2-4-2.dll cygldap-2.dll cygldap_r-2-4-2.dll cygltdl-7.dll cyglz4-1.dll cyglzma-5.dll cyglzo2-2.dll cygmagic-1.dll cygman-2-11-0.dll cygmandb-2-11-0.dll cygmenuw-10.dll cygmpc-3.dll cygmpfr-6.dll cygmpi-40.dll cygmpi_mpifh-40.dll cygmpi_usempif08-40.dll cygmpi_usempi_ignore_tkr-40.dll cygncursesw-10.dll cygnghttp2-14.dll cygntlm-0.dll cygopen-pal-40.dll cygopen-rte-40.dll cygp11-kit-0.dll cygpanelw-10.dll cygpath.exe cygpcre2-8-0.dll cygperl5_32.dll cygpipeline-1.dll cygpkgconf-4.dll cygpopt-0.dll cygpsl-5.dll cygquadmath-0.dll cygreadline7.dll cygrhash-0.dll cygrunsrv.exe cygsasl2-3.dll cygserver-config cygsigsegv-2.dll cygsmartcols-1.dll cygsqlite3-0.dll cygssh2-1.dll cygssl-1.1.dll cygstart.exe cygstdc++-6.dll cygtasn1-6.dll cygticw-10.dll cygunistring-2.dll cyguuid-1.dll cyguv-1.dll cygwin-console-helper.exe cygwin1.dll cygxml2-2.dll cygxxhash-0.dll cygz.dll cygzstd-1.dll dash.exe date.exe dd.exe df.exe diff.exe diff3.exe dir.exe dircolors.exe dirname.exe dlltool.exe dllwrap.exe dnsdomainname domainname du.exe dumper.exe echo.exe editrights.exe egrep elfedit.exe env.exe eqn.exe eqn2graph ex expand.exe expr.exe f95 factor.exe false.exe fgrep fido2-assert.exe fido2-cred.exe fido2-token.exe file.exe find.exe flock.exe fmt.exe fold.exe g++.exe gawk-5.1.1.exe gawk.exe gcc-ar.exe gcc-nm.exe gcc-ranlib.exe gcc.exe gcov-dump.exe gcov-tool.exe gcov.exe gdiffmk gencat.exe getconf.exe getent.exe getfacl.exe getopt.exe gfortran.exe git-receive-pack.exe git-shell.exe git-upload-archive.exe git-upload-pack.exe git.exe gkill.exe gmondump.exe gprof.exe grap2graph grep.exe grn.exe grodvi.exe groff.exe grolbp.exe grolj4.exe grops.exe grotty.exe groups.exe gunzip gzexe gzip.exe head.exe hexdump.exe hostid.exe hostname.exe hpftodit.exe i686-w64-mingw32-pkg-config id.exe indxbib.exe info.exe infocmp.exe infotocap install-info.exe install.exe ipcmk.exe ipcrm.exe ipcs.exe isosize.exe join.exe kill.exe lastlog.exe ld.bfd.exe ld.exe ldd.exe ldh.exe less.exe lessecho.exe lesskey.exe lexgrog.exe libpython3.9.dll link-cygin.exe lkbib.exe ln.exe locale.exe locate.exe logger.exe login.exe logname.exe look.exe lookbib.exe ls.exe lsattr.exe lto-dump.exe lzcat lzcmp lzdiff lzegrep lzfgrep lzgrep lzless lzma lzmadec.exe lzmainfo.exe lzmore make-dummy-cert make.exe man-recode.exe man.exe mandb.exe manpath.exe mcookie.exe md5sum.exe minidumper.exe mintheme mintty.exe mkdir.exe mkfifo.exe mkgroup.exe mknod.exe mkpasswd.exe mkshortcut.exe mktemp.exe more.exe mount.exe mpic++ mpicc mpicxx mpiexec mpif77 mpif90 mpifort mpirun mv.exe namei.exe neqn nice.exe nl.exe nm.exe nohup.exe nproc.exe nroff numfmt.exe objcopy.exe objdump.exe od.exe ompi-clean ompi-server ompi_info.exe opal_wrapper.exe openssl.exe orte-clean.exe orte-info.exe orte-server.exe ortecc orted.exe orterun.exe p11-kit.exe passwd.exe paste.exe pathchk.exe pdfroff peflags.exe peflagsall perl.exe perl5.32.1.exe pfbtops.exe pg.exe pic.exe pic2graph pinky.exe pip3 pip3.9 pkg-config pkgconf.exe pldd.exe post-grohtml.exe pr.exe pre-grohtml.exe preconv.exe printenv.exe printf.exe profiler.exe ps.exe ptx.exe pwd.exe pydoc3 pydoc3.9 python python3 python3.9.exe pzstd.exe ranlib.exe readelf.exe readlink.exe readshortcut.exe realpath.exe rebase-trigger rebase.exe rebaseall rebaselst refer.exe regtool.exe rename.exe renew-dummy-cert renice.exe reset rev.exe rm.exe rmdir.exe rsync-ssl rsync.exe run.exe runcon.exe rvi rview scalar.exe scp.exe script.exe scriptreplay.exe sdiff.exe sed.exe seq.exe setfacl.exe setmetamode.exe setsid.exe sftp.exe sh.exe sha1sum.exe sha224sum.exe sha256sum.exe sha384sum.exe sha512sum.exe shred.exe shuf.exe size.exe sleep.exe slogin soelim.exe sort.exe split.exe ssh-add.exe ssh-agent.exe ssh-copy-id ssh-host-config ssh-keygen.exe ssh-keyscan.exe ssh-user-config ssh.exe ssp.exe stat.exe stdbuf.exe strace.exe strings.exe strip.exe stty.exe sum.exe sync.exe tabs.exe tac.exe tail.exe tar.exe taskset.exe tbl.exe tee.exe test.exe tfmtodit.exe tic.exe timeout.exe toe.exe touch.exe tput.exe tr.exe troff.exe true.exe truncate.exe trust.exe tset.exe tsort.exe tty.exe tzselect tzset.exe ul.exe umount.exe uname.exe unexpand.exe uniq.exe unlink.exe unlzma unxz unzstd update-ca-trust update-crypto-policies updatedb users.exe uuidgen.exe uuidparse.exe vdir.exe vi.exe view wc.exe whatis.exe whereis.exe which.exe who.exe whoami.exe windmc.exe windres.exe x86_64-pc-cygwin-c++.exe x86_64-pc-cygwin-g++.exe x86_64-pc-cygwin-gcc-11.exe x86_64-pc-cygwin-gcc-ar.exe x86_64-pc-cygwin-gcc-nm.exe x86_64-pc-cygwin-gcc-ranlib.exe x86_64-pc-cygwin-gcc.exe x86_64-pc-cygwin-gfortran.exe x86_64-pc-cygwin-pkg-config x86_64-w64-mingw32-pkg-config xargs.exe xmlcatalog.exe xmllint.exe xz.exe xzcat xzcmp xzdec.exe xzdiff xzegrep xzfgrep xzgrep xzless xzmore yes.exe zcat zcmp zdiff zdump.exe zegrep zfgrep zforce zgrep zless zmore znew zstd.exe zstdcat zstdgrep zstdless zstdmt [.exe
> /cygdrive/c/SIMULIA/Commands: abaqus.bat abq2018.bat abq_cae_open.bat abq_odb_open.bat
> /cygdrive/c/Program Files/Microsoft MPI/Bin: mpiexec.exe mpitrace.man smpd.exe
> provthrd.dll provtool.exe ProximityCommon.dll ProximityCommonPal.dll ProximityRtapiPal.dll ProximityService.dll ProximityServicePal.dll ProximityToast ProximityUxHost.exe prproc.exe prvdmofcomp.dll psapi.dll pscript.sep PSHED.DLL psisdecd.dll psisrndr.ax PSModuleDis
> coveryProvider.dll psmodulediscoveryprovider.mof PsmServiceExtHost.dll psmsrv.dll psr.exe pstask.dll pstorec.dll pt-BR pt-PT ptpprov.dll puiapi.dll puiobj.dll PushToInstall.dll pwlauncher.dll pwlauncher.exe pwrshplugin.dll pwsso.dll qappsrv.exe qasf.dll qcap.dll qdv.
> dll qdvd.dll qedit.dll qedwipes.dll qmgr.dll qprocess.exe QualityUpdateAssistant.dll quartz.dll Query.dll query.exe QuickActionsDataModel.dll quickassist.exe QuietHours.dll quser.exe qwave.dll qwinsta.exe RacEngn.dll racpldlg.dll radardt.dll radarrs.dll RADCUI.dll ra
> s rasadhlp.dll rasapi32.dll rasauto.dll rasautou.exe raschap.dll raschapext.dll rasctrnm.h rasctrs.dll rascustom.dll rasdiag.dll rasdial.exe rasdlg.dll raserver.exe rasgcw.dll rasman.dll rasmans.dll rasmbmgr.dll RasMediaManager.dll RASMM.dll rasmontr.dll rasphone.exe
> rasplap.dll rasppp.dll rastapi.dll rastls.dll rastlsext.dll RasToast rdbui.dll rdpbase.dll rdpcfgex.dll rdpclip.exe rdpcore.dll rdpcorets.dll rdpcredentialprovider.dll rdpencom.dll rdpendp.dll rdpinit.exe rdpinput.exe rdpnano.dll RdpRelayTransport.dll RdpSa.exe RdpS
> aProxy.exe RdpSaPs.dll RdpSaUacHelper.exe rdpserverbase.dll rdpsharercom.dll rdpshell.exe rdpsign.exe rdpudd.dll rdpviewerax.dll rdrleakdiag.exe RDSAppXHelper.dll rdsdwmdr.dll rdsxvmaudio.dll rdvvmtransport.dll RDXService.dll RDXTaskFactory.dll ReAgent.dll ReAgentc.e
> xe ReAgentTask.dll recdisc.exe recover.exe Recovery recovery.dll RecoveryDrive.exe refsutil.exe reg.exe regapi.dll RegCtrl.dll regedt32.exe regidle.dll regini.exe Register-CimProvider.exe regsvc.dll regsvr32.exe reguwpapi.dll ReInfo.dll rekeywiz.exe relog.exe RelPost
> .exe RemoteAppLifetimeManager.exe RemoteAppLifetimeManagerProxyStub.dll remoteaudioendpoint.dll remotepg.dll RemotePosWorker.exe remotesp.tsp RemoteSystemToastIcon.contrast-white.png RemoteSystemToastIcon.png RemoteWipeCSP.dll RemovableMediaProvisioningPlugin.dll Rem
> oveDeviceContextHandler.dll RemoveDeviceElevated.dll rendezvousSession.tlb repair-bde.exe replace.exe ReportingCSP.dll RESAMPLEDMO.DLL ResBParser.dll reset.exe reseteng.dll ResetEngine.dll ResetEngine.exe ResetEngOnline.dll resmon.exe ResourceMapper.dll ResourcePolic
> yClient.dll ResourcePolicyServer.dll ResPriHMImageList ResPriHMImageListLowCost ResPriImageList ResPriImageListLowCost RestartManager.mof RestartManagerUninstall.mof RestartNowPower_80.contrast-black.png RestartNowPower_80.contrast-white.png RestartNowPower_80.png Re
> startTonight_80.png RestartTonight_80_contrast-black.png RestartTonight_80_contrast-white.png restore resutils.dll rgb9rast.dll Ribbons.scr riched20.dll riched32.dll rilproxy.dll RjvMDMConfig.dll RMActivate.exe RMActivate_isv.exe RMActivate_ssp.exe RMActivate_ssp_isv
> .exe RMapi.dll rmclient.dll RmClient.exe RMSRoamingSecurity.dll rmttpmvscmgrsvr.exe rnr20.dll ro-RO RoamingSecurity.dll Robocopy.exe rometadata.dll RotMgr.dll ROUTE.EXE RpcEpMap.dll rpchttp.dll RpcNs4.dll rpcnsh.dll RpcPing.exe rpcrt4.dll RpcRtRemote.dll rpcss.dll rr
> installer.exe rsaenh.dll rshx32.dll rsop.msc RstMwEventLogMsg.dll RstrtMgr.dll rstrui.exe RtCOM64.dll RtDataProc64.dll rtffilt.dll RtkApi64U.dll RtkAudUService64.exe RtkCfg64.dll rtm.dll rtmcodecs.dll RTMediaFrame.dll rtmmvrortc.dll rtmpal.dll rtmpltfm.dll rtutils.dl
> l RTWorkQ.dll ru-RU RuleBasedDS.dll runas.exe rundll32.exe runexehelper.exe RunLegacyCPLElevated.exe runonce.exe RuntimeBroker.exe rwinsta.exe samcli.dll samlib.dll samsrv.dll Samsung sas.dll sbe.dll sbeio.dll sberes.dll sbservicetrigger.dll sc.exe ScanPlugin.dll sca
> nsetting.dll SCardBi.dll SCardDlg.dll SCardSvr.dll ScavengeSpace.xml scavengeui.dll ScDeviceEnum.dll scecli.dll scesrv.dll schannel.dll schedcli.dll schedsvc.dll ScheduleTime_80.contrast-black.png ScheduleTime_80.contrast-white.png ScheduleTime_80.png schtasks.exe sc
> ksp.dll scripto.dll ScriptRunner.exe scrnsave.scr scrobj.dll scrptadm.dll scrrun.dll sdbinst.exe sdchange.exe sdclt.exe sdcpl.dll SDDS.dll sdengin2.dll SDFHost.dll sdhcinst.dll sdiageng.dll sdiagnhost.exe sdiagprv.dll sdiagschd.dll sdohlp.dll sdrsvc.dll sdshext.dll S
> earch.ProtocolHandler.MAPI2.dll SearchFilterHost.exe SearchFolder.dll SearchIndexer.exe SearchProtocolHost.exe SebBackgroundManagerPolicy.dll SecConfig.efi SecEdit.exe sechost.dll secinit.exe seclogon.dll secpol.msc secproc.dll secproc_isv.dll secproc_ssp.dll secproc
> _ssp_isv.dll secur32.dll SecureAssessmentHandlers.dll SecureBootUpdates securekernel.exe SecureTimeAggregator.dll security.dll SecurityAndMaintenance.png SecurityAndMaintenance_Alert.png SecurityAndMaintenance_Error.png SecurityCenterBroker.dll SecurityCenterBrokerPS
> .dll SecurityHealthAgent.dll SecurityHealthHost.exe SecurityHealthProxyStub.dll SecurityHealthService.exe SecurityHealthSSO.dll SecurityHealthSystray.exe sedplugins.dll SEMgrPS.dll SEMgrSvc.dll sendmail.dll Sens.dll SensApi.dll SensorDataService.exe SensorPerformance
> Events.dll SensorsApi.dll SensorsClassExtension.dll SensorsCpl.dll SensorService.dll SensorsNativeApi.dll SensorsNativeApi.V2.dll SensorsUtilsV2.dll sensrsvc.dll serialui.dll services.exe services.msc ServicingUAPI.dll serwvdrv.dll SessEnv.dll sessionmsg.exe setbcdlo
> cale.dll sethc.exe SetNetworkLocation.dll SetNetworkLocationFlyout.dll SetProxyCredential.dll setspn.exe SettingMonitor.dll settings.dat SettingsEnvironment.Desktop.dll SettingsExtensibilityHandlers.dll SettingsHandlers_Accessibility.dll SettingsHandlers_AnalogShell.
> dll SettingsHandlers_AppControl.dll SettingsHandlers_AppExecutionAlias.dll SettingsHandlers_AssignedAccess.dll SettingsHandlers_Authentication.dll SettingsHandlers_BackgroundApps.dll SettingsHandlers_BatteryUsage.dll SettingsHandlers_BrowserDeclutter.dll SettingsHand
> lers_CapabilityAccess.dll SettingsHandlers_Clipboard.dll SettingsHandlers_ClosedCaptioning.dll SettingsHandlers_ContentDeliveryManager.dll SettingsHandlers_Cortana.dll SettingsHandlers_Devices.dll SettingsHandlers_Display.dll SettingsHandlers_Flights.dll SettingsHand
> lers_Fonts.dll SettingsHandlers_ForceSync.dll SettingsHandlers_Gaming.dll SettingsHandlers_Geolocation.dll SettingsHandlers_Gpu.dll SettingsHandlers_HoloLens_Environment.dll SettingsHandlers_IME.dll SettingsHandlers_InkingTypingPrivacy.dll SettingsHandlers_InputPerso
> nalization.dll SettingsHandlers_Language.dll SettingsHandlers_ManagePhone.dll SettingsHandlers_Maps.dll SettingsHandlers_Mouse.dll SettingsHandlers_Notifications.dll SettingsHandlers_nt.dll SettingsHandlers_OneCore_BatterySaver.dll SettingsHandlers_OneCore_PowerAndSl
> eep.dll SettingsHandlers_OneDriveBackup.dll SettingsHandlers_OptionalFeatures.dll SettingsHandlers_PCDisplay.dll SettingsHandlers_Pen.dll SettingsHandlers_QuickActions.dll SettingsHandlers_Region.dll SettingsHandlers_SharedExperiences_Rome.dll SettingsHandlers_SIUF.d
> ll SettingsHandlers_SpeechPrivacy.dll SettingsHandlers_Startup.dll SettingsHandlers_StorageSense.dll SettingsHandlers_Troubleshoot.dll SettingsHandlers_User.dll SettingsHandlers_UserAccount.dll SettingsHandlers_UserExperience.dll SettingsHandlers_WorkAccess.dll Setti
> ngSync.dll SettingSyncCore.dll SettingSyncDownloadHelper.dll SettingSyncHost.exe setup setupapi.dll setupcl.dll setupcl.exe setupcln.dll setupetw.dll setupugc.exe setx.exe sfc.dll sfc.exe sfc_os.dll Sgrm SgrmBroker.exe SgrmEnclave.dll SgrmEnclave_secure.dll SgrmLpac.
> exe shacct.dll shacctprofile.dll SharedPCCSP.dll SharedRealitySvc.dll ShareHost.dll sharemediacpl.dll SHCore.dll shdocvw.dll shell32.dll ShellAppRuntime.exe ShellCommonCommonProxyStub.dll ShellExperiences shellstyle.dll shfolder.dll shgina.dll ShiftJIS.uce shimeng.dl
> l shimgvw.dll shlwapi.dll shpafact.dll shrpubw.exe shsetup.dll shsvcs.dll shunimpl.dll shutdown.exe shutdownext.dll shutdownux.dll shwebsvc.dll si-lk signdrv.dll sigverif.exe SIHClient.exe sihost.exe SimAuth.dll SimCfg.dll simpdata.tlb sk-SK skci.dll sl-SI slc.dll sl
> cext.dll SleepStudy SlideToShutDown.exe slmgr slmgr.vbs slui.exe slwga.dll SmallRoom.bin SmartCardBackgroundPolicy.dll SmartcardCredentialProvider.dll SmartCardSimulator.dll smartscreen.exe smartscreenps.dll SMBHelperClass.dll smbwmiv2.dll SMI SmiEngine.dll smphost.d
> ll SmsRouterSvc.dll smss.exe SndVol.exe SndVolSSO.dll SnippingTool.exe snmpapi.dll snmptrap.exe Snooze_80.contrast-black.png Snooze_80.contrast-white.png Snooze_80.png socialapis.dll softkbd.dll softpub.dll sort.exe SortServer2003Compat.dll SortWindows61.dll SortWind
> ows62.dll SortWindows64.dll SortWindows6Compat.dll SpaceAgent.exe spacebridge.dll SpaceControl.dll spaceman.exe SpatialAudioLicenseSrv.exe SpatializerApo.dll SpatialStore.dll spbcd.dll SpeakersSystemToastIcon.contrast-white.png SpeakersSystemToastIcon.png Spectrum.ex
> e SpectrumSyncClient.dll Speech SpeechPal.dll Speech_OneCore spfileq.dll spinf.dll spmpm.dll spnet.dll spool spoolss.dll spoolsv.exe spopk.dll spp spp.dll sppc.dll sppcext.dll sppcomapi.dll sppcommdlg.dll SppExtComObj.Exe sppinst.dll sppnp.dll sppobjs.dll sppsvc.exe
> sppui sppwinob.dll sppwmi.dll spwinsat.dll spwizeng.dll spwizimg.dll spwizres.dll spwmp.dll SqlServerSpatial130.dll SqlServerSpatial150.dll sqlsrv32.dll sqlsrv32.rll sqmapi.dll sr-Latn-RS srchadmin.dll srclient.dll srcore.dll srdelayed.exe SrEvents.dll SRH.dll srhelp
> er.dll srm.dll srmclient.dll srmlib.dll srms-apr-v.dat srms-apr.dat srms.dat srmscan.dll srmshell.dll srmstormod.dll srmtrace.dll srm_ps.dll srpapi.dll SrpUxNativeSnapIn.dll srrstr.dll SrTasks.exe sru srumapi.dll srumsvc.dll srvcli.dll srvsvc.dll srwmi.dll sscore.dll
> sscoreext.dll ssdm.dll ssdpapi.dll ssdpsrv.dll sspicli.dll sspisrv.dll SSShim.dll ssText3d.scr sstpsvc.dll StartTileData.dll Startupscan.dll StateRepository.Core.dll stclient.dll stdole2.tlb stdole32.tlb sti.dll sti_ci.dll stobject.dll StorageContextHandler.dll Stor
> ageUsage.dll storagewmi.dll storagewmi_passthru.dll stordiag.exe storewuauth.dll Storprop.dll StorSvc.dll streamci.dll StringFeedbackEngine.dll StructuredQuery.dll SubRange.uce subst.exe sud.dll sv-SE SvBannerBackground.png svchost.exe svf.dll svsvc.dll SwitcherDataM
> odel.dll swprv.dll sxproxy.dll sxs.dll sxshared.dll sxssrv.dll sxsstore.dll sxstrace.exe SyncAppvPublishingServer.exe SyncAppvPublishingServer.vbs SyncCenter.dll SyncController.dll SyncHost.exe SyncHostps.dll SyncInfrastructure.dll SyncInfrastructureps.dll SyncProxy.
> dll Syncreg.dll SyncRes.dll SyncSettings.dll syncutil.dll sysclass.dll sysdm.cpl SysFxUI.dll sysmain.dll sysmon.ocx sysntfy.dll Sysprep sysprint.sep sysprtj.sep SysResetErr.exe syssetup.dll systemcpl.dll SystemEventsBrokerClient.dll SystemEventsBrokerServer.dll syste
> minfo.exe SystemPropertiesAdvanced.exe SystemPropertiesComputerName.exe SystemPropertiesDataExecutionPrevention.exe SystemPropertiesHardware.exe SystemPropertiesPerformance.exe SystemPropertiesProtection.exe SystemPropertiesRemote.exe systemreset.exe SystemResetPlatf
> orm SystemSettings.DataModel.dll SystemSettings.DeviceEncryptionHandlers.dll SystemSettings.Handlers.dll SystemSettings.SettingsExtensibility.dll SystemSettings.UserAccountsHandlers.dll SystemSettingsAdminFlows.exe SystemSettingsBroker.exe SystemSettingsRemoveDevice.
> exe SystemSettingsThresholdAdminFlowUI.dll SystemSupportInfo.dll SystemUWPLauncher.exe systray.exe t2embed.dll ta-in ta-lk Tabbtn.dll TabbtnEx.dll tabcal.exe TabletPC.cpl TabSvc.dll takeown.exe tapi3.dll tapi32.dll tapilua.dll TapiMigPlugin.dll tapiperf.dll tapisrv.d
> ll TapiSysprep.dll tapiui.dll TapiUnattend.exe tar.exe TaskApis.dll taskbarcpl.dll taskcomp.dll TaskFlowDataEngine.dll taskhostw.exe taskkill.exe tasklist.exe Taskmgr.exe Tasks taskschd.dll taskschd.msc TaskSchdPS.dll tbauth.dll tbs.dll tcblaunch.exe tcbloader.dll tc
> msetup.exe tcpbidi.xml tcpipcfg.dll tcpmib.dll tcpmon.dll tcpmon.ini tcpmonui.dll TCPSVCS.EXE tdc.ocx tdh.dll TDLMigration.dll TEEManagement64.dll telephon.cpl TelephonyInteractiveUser.dll TelephonyInteractiveUserRes.dll tellib.dll TempSignedLicenseExchangeTask.dll T
> enantRestrictionsPlugin.dll termmgr.dll termsrv.dll tetheringclient.dll tetheringconfigsp.dll TetheringIeProvider.dll TetheringMgr.dll tetheringservice.dll TetheringStation.dll TextInputFramework.dll TextInputMethodFormatter.dll TextShaping.dll th-TH themecpl.dll The
> mes.SsfDownload.ScheduledTask.dll themeservice.dll themeui.dll ThirdPartyNoticesBySHS.txt threadpoolwinrt.dll thumbcache.dll ThumbnailExtractionHost.exe ti-et tier2punctuations.dll TieringEngineProxy.dll TieringEngineService.exe TileDataRepository.dll TimeBrokerClien
> t.dll TimeBrokerServer.dll timedate.cpl TimeDateMUICallback.dll timeout.exe timesync.dll TimeSyncTask.dll TKCtrl2k64.sys TKFsAv64.sys TKFsFt64.sys TKFWFV.inf TKFWFV64.cat TKFWFV64.sys tkfwvt64.sys TKIdsVt64.sys TKPcFtCb64.sys TKPcFtCb64.sys_ TKPcFtHk64.sys TKRgAc2k64
> .sys TKRgFtXp64.sys TKTool2k.sys TKTool2k64.sys tlscsp.dll tokenbinding.dll TokenBroker.dll TokenBrokerCookies.exe TokenBrokerUI.dll tpm.msc TpmCertResources.dll tpmcompc.dll TpmCoreProvisioning.dll TpmInit.exe TpmTasks.dll TpmTool.exe tpmvsc.dll tpmvscmgr.exe tpmvsc
> mgrsvr.exe tquery.dll tr-TR tracerpt.exe TRACERT.EXE traffic.dll TransformPPSToWlan.xslt TransformPPSToWlanCredentials.xslt TransliterationRanker.dll TransportDSA.dll tree.com trie.dll trkwks.dll TrustedSignalCredProv.dll tsbyuv.dll tscfgwmi.dll tscon.exe tsdiscon.ex
> e TSErrRedir.dll tsf3gip.dll tsgqec.dll tskill.exe tsmf.dll TSpkg.dll tspubwmi.dll TSSessionUX.dll tssrvlic.dll TSTheme.exe TsUsbGDCoInstaller.dll TsUsbRedirectionGroupPolicyExtension.dll TSWbPrxy.exe TSWorkspace.dll TsWpfWrp.exe ttdinject.exe ttdloader.dll ttdplm.dl
> l ttdrecord.dll ttdrecordcpu.dll TtlsAuth.dll TtlsCfg.dll TtlsExt.dll tttracer.exe tvratings.dll twext.dll twinapi.appcore.dll twinapi.dll twinui.appcore.dll twinui.dll twinui.pcshell.dll txflog.dll txfw32.dll typeperf.exe tzautoupdate.dll tzres.dll tzsync.exe tzsync
> res.dll tzutil.exe ubpm.dll ucmhc.dll ucrtbase.dll ucrtbased.dll ucrtbase_clr0400.dll ucrtbase_enclave.dll ucsvc.exe udhisapi.dll uDWM.dll UefiCsp.dll UevAgentPolicyGenerator.exe UevAppMonitor.exe UevAppMonitor.exe.config UevCustomActionTypes.tlb UevTemplateBaselineG
> enerator.exe UevTemplateConfigItemGenerator.exe uexfat.dll ufat.dll UiaManager.dll UIAnimation.dll UIAutomationCore.dll uicom.dll UIManagerBrokerps.dll UIMgrBroker.exe uireng.dll UIRibbon.dll UIRibbonRes.dll uk-UA ulib.dll umb.dll umdmxfrm.dll umpdc.dll umpnpmgr.dll
> umpo-overrides.dll umpo.dll umpoext.dll umpowmi.dll umrdp.dll unattend.dll unenrollhook.dll unimdm.tsp unimdmat.dll uniplat.dll Unistore.dll unlodctr.exe UNP unregmp2.exe untfs.dll UpdateAgent.dll updatecsp.dll UpdateDeploymentProvider.dll UpdateHeartbeat.dll updatep
> olicy.dll upfc.exe UpgradeResultsUI.exe upnp.dll upnpcont.exe upnphost.dll UPPrinterInstaller.exe UPPrinterInstallsCSP.dll upshared.dll uReFS.dll uReFSv1.dll ureg.dll url.dll urlmon.dll UsbCApi.dll usbceip.dll usbmon.dll usbperf.dll UsbPmApi.dll UsbSettingsHandlers.d
> ll UsbTask.dll usbui.dll user32.dll UserAccountBroker.exe UserAccountControlSettings.dll UserAccountControlSettings.exe useractivitybroker.dll usercpl.dll UserDataAccessRes.dll UserDataAccountApis.dll UserDataLanguageUtil.dll UserDataPlatformHelperUtil.dll UserDataSe
> rvice.dll UserDataTimeUtil.dll UserDataTypeHelperUtil.dll UserDeviceRegistration.dll UserDeviceRegistration.Ngc.dll userenv.dll userinit.exe userinitext.dll UserLanguageProfileCallback.dll usermgr.dll usermgrcli.dll UserMgrProxy.dll usk.rs usoapi.dll UsoClient.exe us
> ocoreps.dll usocoreworker.exe usosvc.dll usp10.dll ustprov.dll UtcDecoderHost.exe UtcManaged.dll utcutil.dll utildll.dll Utilman.exe uudf.dll UvcModel.dll uwfcfgmgmt.dll uwfcsp.dll uwfservicingapi.dll UXInit.dll uxlib.dll uxlibres.dll uxtheme.dll vac.dll VAN.dll Vaul
> t.dll VaultCDS.dll vaultcli.dll VaultCmd.exe VaultRoaming.dll vaultsvc.dll VBICodec.ax vbisurf.ax vbsapi.dll vbscript.dll vbssysprep.dll vcamp120.dll vcamp140.dll vcamp140d.dll VCardParser.dll vccorlib110.dll vccorlib120.dll vccorlib140.dll vccorlib140d.dll vcomp100.
> dll vcomp110.dll vcomp120.dll vcomp140.dll vcomp140d.dll vcruntime140.dll vcruntime140d.dll vcruntime140_1.dll vcruntime140_1d.dll vcruntime140_clr0400.dll vds.exe vdsbas.dll vdsdyn.dll vdsldr.exe vdsutil.dll vdsvd.dll vds_ps.dll verclsid.exe verifier.dll verifier.ex
> e verifiergui.exe version.dll vertdll.dll vfbasics.dll vfcompat.dll vfcuzz.dll vfluapriv.dll vfnet.dll vfntlmless.dll vfnws.dll vfprint.dll vfprintpthelper.dll vfrdvcompat.dll vfuprov.dll vfwwdm32.dll VhfUm.dll vid.dll vidcap.ax VideoHandlers.dll VIDRESZR.DLL virtdis
> k.dll VirtualMonitorManager.dll VmApplicationHealthMonitorProxy.dll vmbuspipe.dll vmdevicehost.dll vmictimeprovider.dll vmrdvcore.dll VocabRoamingHandler.dll VoiceActivationManager.dll VoipRT.dll vpnike.dll vpnikeapi.dll VpnSohDesktop.dll VPNv2CSP.dll vrfcore.dll Vsc
> MgrPS.dll vscover160.dll VSD3DWARPDebug.dll VsGraphicsCapture.dll VsGraphicsDesktopEngine.exe VsGraphicsExperiment.dll VsGraphicsHelper.dll VsGraphicsProxyStub.dll VsGraphicsRemoteEngine.exe vsjitdebugger.exe VSPerf160.dll vssadmin.exe vssapi.dll vsstrace.dll VSSVC.e
> xe vss_ps.dll vulkan-1-999-0-0-0.dll vulkan-1.dll vulkaninfo-1-999-0-0-0.exe vulkaninfo.exe w32time.dll w32tm.exe w32topl.dll WaaSAssessment.dll WaaSMedicAgent.exe WaaSMedicCapsule.dll WaaSMedicPS.dll WaaSMedicSvc.dll WABSyncProvider.dll waitfor.exe WalletBackgroundS
> erviceProxy.dll WalletProxy.dll WalletService.dll WallpaperHost.exe wavemsp.dll wbadmin.exe wbem wbemcomn.dll wbengine.exe wbiosrvc.dll wci.dll wcimage.dll wcmapi.dll wcmcsp.dll wcmsvc.dll WCN WcnApi.dll wcncsvc.dll WcnEapAuthProxy.dll WcnEapPeerProxy.dll WcnNetsh.dl
> l wcnwiz.dll wc_storage.dll wdc.dll WDI wdi.dll wdigest.dll wdmaud.drv wdscore.dll WdsUnattendTemplate.xml WEB.rs webauthn.dll WebcamUi.dll webcheck.dll WebClnt.dll webio.dll webplatstorageserver.dll WebRuntimeManager.dll webservices.dll Websocket.dll wecapi.dll wecs
> vc.dll wecutil.exe wephostsvc.dll wer.dll werconcpl.dll wercplsupport.dll werdiagcontroller.dll WerEnc.dll weretw.dll WerFault.exe WerFaultSecure.exe wermgr.exe wersvc.dll werui.dll wevtapi.dll wevtfwd.dll wevtsvc.dll wevtutil.exe wextract.exe WF.msc wfapigp.dll wfdp
> rov.dll WFDSConMgr.dll WFDSConMgrSvc.dll WfHC.dll WFS.exe WFSR.dll whealogr.dll where.exe whhelper.dll whoami.exe wiaacmgr.exe wiaaut.dll wiadefui.dll wiadss.dll WiaExtensionHost64.dll wiarpc.dll wiascanprofiles.dll wiaservc.dll wiashext.dll wiatrace.dll wiawow64.exe
> WiFiCloudStore.dll WiFiConfigSP.dll wifidatacapabilityhandler.dll WiFiDisplay.dll wifinetworkmanager.dll wifitask.exe WimBootCompress.ini wimgapi.dll wimserv.exe win32appinventorycsp.dll Win32AppSettingsProvider.dll Win32CompatibilityAppraiserCSP.dll win32k.sys win3
> 2kbase.sys win32kfull.sys win32kns.sys win32spl.dll win32u.dll Win32_DeviceGuard.dll winbio.dll WinBioDatabase WinBioDataModel.dll WinBioDataModelOOBE.exe winbioext.dll WinBioPlugIns winbrand.dll wincorlib.dll wincredprovider.dll wincredui.dll WindowManagement.dll Wi
> ndowManagementAPI.dll Windows.AccountsControl.dll Windows.AI.MachineLearning.dll Windows.AI.MachineLearning.Preview.dll Windows.ApplicationModel.Background.SystemEventsBroker.dll Windows.ApplicationModel.Background.TimeBroker.dll Windows.ApplicationModel.Conversation
> alAgent.dll windows.applicationmodel.conversationalagent.internal.proxystub.dll windows.applicationmodel.conversationalagent.proxystub.dll Windows.ApplicationModel.Core.dll windows.applicationmodel.datatransfer.dll Windows.ApplicationModel.dll Windows.ApplicationMode
> l.LockScreen.dll Windows.ApplicationModel.Store.dll Windows.ApplicationModel.Store.Preview.DOSettings.dll Windows.ApplicationModel.Store.TestingFramework.dll Windows.ApplicationModel.Wallet.dll Windows.CloudStore.dll Windows.CloudStore.Schema.DesktopShell.dll Windows
> .CloudStore.Schema.Shell.dll Windows.Cortana.Desktop.dll Windows.Cortana.OneCore.dll Windows.Cortana.ProxyStub.dll Windows.Data.Activities.dll Windows.Data.Pdf.dll Windows.Devices.AllJoyn.dll Windows.Devices.Background.dll Windows.Devices.Background.ps.dll Windows.De
> vices.Bluetooth.dll Windows.Devices.Custom.dll Windows.Devices.Custom.ps.dll Windows.Devices.Enumeration.dll Windows.Devices.Haptics.dll Windows.Devices.HumanInterfaceDevice.dll Windows.Devices.Lights.dll Windows.Devices.LowLevel.dll Windows.Devices.Midi.dll Windows.
> Devices.Perception.dll Windows.Devices.Picker.dll Windows.Devices.PointOfService.dll Windows.Devices.Portable.dll Windows.Devices.Printers.dll Windows.Devices.Printers.Extensions.dll Windows.Devices.Radios.dll Windows.Devices.Scanners.dll Windows.Devices.Sensors.dll
> Windows.Devices.SerialCommunication.dll Windows.Devices.SmartCards.dll Windows.Devices.SmartCards.Phone.dll Windows.Devices.Usb.dll Windows.Devices.WiFi.dll Windows.Devices.WiFiDirect.dll Windows.Energy.dll Windows.FileExplorer.Common.dll Windows.Gaming.Input.dll Win
> dows.Gaming.Preview.dll Windows.Gaming.UI.GameBar.dll Windows.Gaming.XboxLive.Storage.dll Windows.Globalization.dll Windows.Globalization.Fontgroups.dll Windows.Globalization.PhoneNumberFormatting.dll Windows.Graphics.Display.BrightnessOverride.dll Windows.Graphics.D
> isplay.DisplayEnhancementOverride.dll Windows.Graphics.dll Windows.Graphics.Printing.3D.dll Windows.Graphics.Printing.dll Windows.Graphics.Printing.Workflow.dll Windows.Graphics.Printing.Workflow.Native.dll Windows.Help.Runtime.dll windows.immersiveshell.serviceprovi
> der.dll Windows.Internal.AdaptiveCards.XamlCardRenderer.dll Windows.Internal.Bluetooth.dll Windows.Internal.CapturePicker.Desktop.dll Windows.Internal.CapturePicker.dll Windows.Internal.Devices.Sensors.dll Windows.Internal.Feedback.Analog.dll Windows.Internal.Feedbac
> k.Analog.ProxyStub.dll Windows.Internal.Graphics.Display.DisplayColorManagement.dll Windows.Internal.Graphics.Display.DisplayEnhancementManagement.dll Windows.Internal.Management.dll Windows.Internal.Management.SecureAssessment.dll Windows.Internal.PlatformExtension.
> DevicePickerExperience.dll Windows.Internal.PlatformExtension.MiracastBannerExperience.dll Windows.Internal.PredictionUnit.dll Windows.Internal.Security.Attestation.DeviceAttestation.dll Windows.Internal.SecurityMitigationsBroker.dll Windows.Internal.Shell.Broker.dll
> windows.internal.shellcommon.AccountsControlExperience.dll windows.internal.shellcommon.AppResolverModal.dll Windows.Internal.ShellCommon.Broker.dll windows.internal.shellcommon.FilePickerExperienceMEM.dll Windows.Internal.ShellCommon.PrintExperience.dll windows.int
> ernal.shellcommon.shareexperience.dll windows.internal.shellcommon.TokenBrokerModal.dll Windows.Internal.Signals.dll Windows.Internal.System.UserProfile.dll Windows.Internal.Taskbar.dll Windows.Internal.UI.BioEnrollment.ProxyStub.dll Windows.Internal.UI.Logon.ProxySt
> ub.dll Windows.Internal.UI.Shell.WindowTabManager.dll Windows.Management.EnrollmentStatusTracking.ConfigProvider.dll Windows.Management.InprocObjects.dll Windows.Management.ModernDeployment.ConfigProviders.dll Windows.Management.Provisioning.ProxyStub.dll Windows.Man
> agement.SecureAssessment.CfgProvider.dll Windows.Management.SecureAssessment.Diagnostics.dll Windows.Management.Service.dll Windows.Management.Workplace.dll Windows.Management.Workplace.WorkplaceSettings.dll Windows.Media.Audio.dll Windows.Media.BackgroundMediaPlayba
> ck.dll Windows.Media.BackgroundPlayback.exe Windows.Media.Devices.dll Windows.Media.dll Windows.Media.Editing.dll Windows.Media.FaceAnalysis.dll Windows.Media.Import.dll Windows.Media.MediaControl.dll Windows.Media.MixedRealityCapture.dll Windows.Media.Ocr.dll Window
> s.Media.Playback.BackgroundMediaPlayer.dll Windows.Media.Playback.MediaPlayer.dll Windows.Media.Playback.ProxyStub.dll Windows.Media.Protection.PlayReady.dll Windows.Media.Renewal.dll Windows.Media.Speech.dll Windows.Media.Speech.UXRes.dll Windows.Media.Streaming.dll
> Windows.Media.Streaming.ps.dll Windows.Mirage.dll Windows.Mirage.Internal.Capture.Pipeline.ProxyStub.dll Windows.Mirage.Internal.dll Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll Windows.Networking.BackgroundTransfer.ContentPrefetchTask.dll Windo
> ws.Networking.BackgroundTransfer.dll Windows.Networking.Connectivity.dll Windows.Networking.dll Windows.Networking.HostName.dll Windows.Networking.NetworkOperators.ESim.dll Windows.Networking.NetworkOperators.HotspotAuthentication.dll Windows.Networking.Proximity.dll
> Windows.Networking.ServiceDiscovery.Dnssd.dll Windows.Networking.Sockets.PushEnabledApplication.dll Windows.Networking.UX.EapRequestHandler.dll Windows.Networking.Vpn.dll Windows.Networking.XboxLive.ProxyStub.dll Windows.Payments.dll Windows.Perception.Stub.dll Wind
> ows.Security.Authentication.Identity.Provider.dll Windows.Security.Authentication.OnlineId.dll Windows.Security.Authentication.Web.Core.dll Windows.Security.Credentials.UI.CredentialPicker.dll Windows.Security.Credentials.UI.UserConsentVerifier.dll Windows.Security.I
> ntegrity.dll Windows.Services.TargetedContent.dll Windows.SharedPC.AccountManager.dll Windows.SharedPC.CredentialProvider.dll Windows.Shell.BlueLightReduction.dll Windows.Shell.ServiceHostBuilder.dll Windows.Shell.StartLayoutPopulationEvents.dll Windows.StateReposito
> ry.dll Windows.StateRepositoryBroker.dll Windows.StateRepositoryClient.dll Windows.StateRepositoryCore.dll Windows.StateRepositoryPS.dll Windows.StateRepositoryUpgrade.dll Windows.Storage.ApplicationData.dll Windows.Storage.Compression.dll windows.storage.dll Windows
> .Storage.OneCore.dll Windows.Storage.Search.dll Windows.System.Diagnostics.dll Windows.System.Diagnostics.Telemetry.PlatformTelemetryClient.dll Windows.System.Diagnostics.TraceReporting.PlatformDiagnosticActions.dll Windows.System.Launcher.dll Windows.System.Profile.
> HardwareId.dll Windows.System.Profile.PlatformDiagnosticsAndUsageDataSettings.dll Windows.System.Profile.RetailInfo.dll Windows.System.Profile.SystemId.dll Windows.System.Profile.SystemManufacturers.dll Windows.System.RemoteDesktop.dll Windows.System.SystemManagement
> .dll Windows.System.UserDeviceAssociation.dll Windows.System.UserProfile.DiagnosticsSettings.dll Windows.UI.Accessibility.dll Windows.UI.AppDefaults.dll Windows.UI.BioFeedback.dll Windows.UI.BlockedShutdown.dll Windows.UI.Core.TextInput.dll Windows.UI.Cred.dll Window
> s.UI.CredDialogController.dll Windows.UI.dll Windows.UI.FileExplorer.dll Windows.UI.Immersive.dll Windows.UI.Input.Inking.Analysis.dll Windows.UI.Input.Inking.dll Windows.UI.Internal.Input.ExpressiveInput.dll Windows.UI.Internal.Input.ExpressiveInput.Resource.dll Win
> dows.UI.Logon.dll Windows.UI.NetworkUXController.dll Windows.UI.PicturePassword.dll Windows.UI.Search.dll Windows.UI.Shell.dll Windows.UI.Shell.Internal.AdaptiveCards.dll Windows.UI.Storage.dll Windows.UI.Xaml.Controls.dll Windows.UI.Xaml.dll Windows.UI.Xaml.InkContr
> ols.dll Windows.UI.Xaml.Maps.dll Windows.UI.Xaml.Phone.dll Windows.UI.Xaml.Resources.19h1.dll Windows.UI.Xaml.Resources.Common.dll Windows.UI.Xaml.Resources.rs1.dll Windows.UI.Xaml.Resources.rs2.dll Windows.UI.Xaml.Resources.rs3.dll Windows.UI.Xaml.Resources.rs4.dll
> Windows.UI.Xaml.Resources.rs5.dll Windows.UI.Xaml.Resources.th.dll Windows.UI.Xaml.Resources.win81.dll Windows.UI.Xaml.Resources.win8rtm.dll Windows.UI.XamlHost.dll Windows.WARP.JITService.dll Windows.WARP.JITService.exe Windows.Web.Diagnostics.dll Windows.Web.dll Wi
> ndows.Web.Http.dll WindowsActionDialog.exe WindowsCodecs.dll WindowsCodecsExt.dll WindowsCodecsRaw.dll WindowsCodecsRaw.txt WindowsDefaultHeatProcessor.dll windowsdefenderapplicationguardcsp.dll WindowsInternal.ComposableShell.ComposerFramework.dll WindowsInternal.Co
> mposableShell.DesktopHosting.dll WindowsInternal.Shell.CompUiActivation.dll WindowsIoTCsp.dll windowslivelogin.dll WindowsManagementServiceWinRt.ProxyStub.dll windowsperformancerecordercontrol.dll WindowsPowerShell WindowsSecurityIcon.png windowsudk.shellcommon.dll W
> indowsUpdateElevatedInstaller.exe winethc.dll winevt WinFax.dll winhttp.dll winhttpcom.dll WinHvEmulation.dll WinHvPlatform.dll wininet.dll wininetlui.dll wininit.exe wininitext.dll winipcfile.dll winipcsecproc.dll winipsec.dll winjson.dll Winlangdb.dll winload.efi w
> inload.exe winlogon.exe winlogonext.dll winmde.dll WinMetadata winml.dll winmm.dll winmmbase.dll winmsipc.dll WinMsoIrmProtector.dll winnlsres.dll winnsi.dll WinOpcIrmProtector.dll WinREAgent.dll winresume.efi winresume.exe winrm winrm.cmd winrm.vbs winrnr.dll winrs.
> exe winrscmd.dll winrshost.exe winrsmgr.dll winrssrv.dll WinRTNetMUAHostServer.exe WinRtTracing.dll WinSAT.exe WinSATAPI.dll WinSCard.dll WinSetupUI.dll winshfhc.dll winsku.dll winsockhc.dll winspool.drv winsqlite3.dll WINSRPC.DLL winsrv.dll winsrvext.dll winsta.dll
> WinSync.dll WinSyncMetastore.dll WinSyncProviders.dll wintrust.dll WinTypes.dll winusb.dll winver.exe WiredNetworkCSP.dll wisp.dll witnesswmiv2provider.dll wkscli.dll wkspbroker.exe wkspbrokerAx.dll wksprt.exe wksprtPS.dll wkssvc.dll wlanapi.dll wlancfg.dll WLanConn.
> dll wlandlg.dll wlanext.exe wlangpui.dll WLanHC.dll wlanhlp.dll WlanMediaManager.dll WlanMM.dll wlanmsm.dll wlanpref.dll WlanRadioManager.dll wlansec.dll wlansvc.dll wlansvcpal.dll wlanui.dll wlanutil.dll Wldap32.dll wldp.dll wlgpclnt.dll wlidcli.dll wlidcredprov.dll
> wlidfdp.dll wlidnsp.dll wlidprov.dll wlidres.dll wlidsvc.dll wlrmdr.exe WMADMOD.DLL WMADMOE.DLL WMALFXGFXDSP.dll WMASF.DLL wmcodecdspps.dll wmdmlog.dll wmdmps.dll wmdrmsdk.dll wmerror.dll wmi.dll wmiclnt.dll wmicmiplugin.dll wmidcom.dll wmidx.dll WmiMgmt.msc wmiprop
> .dll wmitomi.dll WMNetMgr.dll wmp.dll WMPDMC.exe WmpDui.dll wmpdxm.dll wmpeffects.dll WMPhoto.dll wmploc.DLL wmpps.dll wmpshell.dll wmsgapi.dll WMSPDMOD.DLL WMSPDMOE.DLL WMVCORE.DLL WMVDECOD.DLL wmvdspa.dll WMVENCOD.DLL WMVSDECD.DLL WMVSENCD.DLL WMVXENCD.DLL WofTasks
> .dll WofUtil.dll WordBreakers.dll WorkFolders.exe WorkfoldersControl.dll WorkFoldersGPExt.dll WorkFoldersRes.dll WorkFoldersShell.dll workfolderssvc.dll wosc.dll wow64.dll wow64cpu.dll wow64win.dll wowreg32.exe WpAXHolder.dll wpbcreds.dll Wpc.dll WpcApi.dll wpcatltoa
> st.png WpcDesktopMonSvc.dll WpcMon.exe wpcmon.png WpcProxyStubs.dll WpcRefreshTask.dll WpcTok.exe WpcWebFilter.dll wpdbusenum.dll WpdMtp.dll WpdMtpUS.dll wpdshext.dll WPDShextAutoplay.exe WPDShServiceObj.dll WPDSp.dll wpd_ci.dll wpnapps.dll wpnclient.dll wpncore.dll
> wpninprc.dll wpnpinst.exe wpnprv.dll wpnservice.dll wpnsruprov.dll WpnUserService.dll WpPortingLibrary.dll WppRecorderUM.dll wpr.config.xml wpr.exe WPTaskScheduler.dll wpx.dll write.exe ws2help.dll ws2_32.dll wscadminui.exe wscapi.dll wscinterop.dll wscisvif.dll WSCl
> ient.dll WSCollect.exe wscproxystub.dll wscript.exe wscsvc.dll wscui.cpl WSDApi.dll wsdchngr.dll WSDPrintProxy.DLL WsdProviderUtil.dll WSDScanProxy.dll wsecedit.dll wsepno.dll wshbth.dll wshcon.dll wshelper.dll wshext.dll wshhyperv.dll wship6.dll wshom.ocx wshqos.dll
> wshrm.dll WSHTCPIP.DLL wshunix.dll wsl.exe wslapi.dll WsmAgent.dll wsmanconfig_schema.xml WSManHTTPConfig.exe WSManMigrationPlugin.dll WsmAuto.dll wsmplpxy.dll wsmprovhost.exe WsmPty.xsl WsmRes.dll WsmSvc.dll WsmTxt.xsl WsmWmiPl.dll wsnmp32.dll wsock32.dll wsplib.dl
> l wsp_fs.dll wsp_health.dll wsp_sr.dll wsqmcons.exe WSReset.exe WSTPager.ax wtsapi32.dll wuapi.dll wuapihost.exe wuauclt.exe wuaueng.dll wuceffects.dll WUDFCoinstaller.dll WUDFCompanionHost.exe WUDFHost.exe WUDFPlatform.dll WudfSMCClassExt.dll WUDFx.dll WUDFx02000.dl
> l wudriver.dll wups.dll wups2.dll wusa.exe wuuhext.dll wuuhosdeployment.dll wvc.dll WwaApi.dll WwaExt.dll WWAHost.exe WWanAPI.dll wwancfg.dll wwanconn.dll WWanHC.dll wwanmm.dll Wwanpref.dll wwanprotdim.dll WwanRadioManager.dll wwansvc.dll wwapi.dll XamlTileRender.dll XAudio2_8.dll XAudio2_9.dll XblAuthManager.dll XblAuthManagerProxy.dll XblAuthTokenBrokerExt.dll XblGameSave.dll XblGameSaveExt.dll XblGameSaveProxy.dll XblGameSaveTask.exe XboxGipRadioManager.dll xboxgipsvc.dll xboxgipsynthetic.dll XboxNetApiSvc.dll xcopy.exe XInput1_4.dll XInput9_1_0.dll XInputUap.dll xmlfilter.dll xmllite.dll xmlprovi.dll xolehlp.dll XpsDocumentTargetPrint.dll XpsGdiConverter.dll XpsPrint.dll xpspushlayer.dll XpsRasterService.dll xpsservices.dll XpsToPclmConverter.dll XpsToPwgrConverter.dll xwizard.dtd xwizard.exe xwizards.dll xwreg.dll xwtpdui.dll xwtpw32.dll X_80.contrast-black.png X_80.contrast-white.png X_80.png ze_loader.dll ze_tracing_layer.dll ze_validation_layer.dll zh-CN zh-TW zipcontainer.dll zipfldr.dll ztrace_maps.dll
> /cygdrive/c/Windows: addins AhnInst.log appcompat Application Data apppatch AppReadiness assembly bcastdvr bfsvc.exe BitLockerDiscoveryVolumeContents Boot bootstat.dat Branding CbsTemp Containers CSC Cursors debug diagnostics DiagTrack DigitalLocker Downloaded
> Program Files DtcInstall.log ELAMBKUP en-US explorer.exe Fonts GameBarPresenceWriter gethelp_audiotroubleshooter_latestpackage.zip Globalization Help HelpPane.exe hh.exe hipiw.dll IdentityCRL ImageSAFERSvc.exe IME IMGSF50Svc.exe ImmersiveControlPanel INF InputMethod
> Installer ko-KR L2Schemas LanguageOverlayCache LiveKernelReports Logs lsasetup.log Media mib.bin Microsoft.NET Migration ModemLogs notepad.exe OCR Offline Web Pages Panther Performance PFRO.log PLA PolicyDefinitions Prefetch PrintDialog Professional.xml Provisioning
> regedit.exe Registration RemotePackages rescache Resources RtlExUpd.dll SchCache schemas security ServiceProfiles ServiceState servicing Setup setupact.log setuperr.log ShellComponents ShellExperiences SHELLNEW SKB SoftwareDistribution Speech Speech_OneCore splwow64.
> exe System system.ini System32 SystemApps SystemResources SystemTemp SysWOW64 TAPI Tasks Temp TempInst tracing twain_32 twain_32.dll Vss WaaS Web win.ini WindowsShell.Manifest WindowsUpdate.log winhlp32.exe WinSxS WMSysPr9.prx write.exe
> /cygdrive/c/Windows/System32/Wbem: aeinv.mof AgentWmi.mof AgentWmiUninstall.mof appbackgroundtask.dll appbackgroundtask.mof appbackgroundtask_uninstall.mof AuditRsop.mof authfwcfg.mof AutoRecover bcd.mof BthMtpEnum.mof cimdmtf.mof cimwin32.dll cimwin32.mof CIWm
> i.mof classlog.mof cli.mof cliegaliases.mof ddp.mof dimsjob.mof dimsroam.mof DMWmiBridgeProv.dll DMWmiBridgeProv.mof DMWmiBridgeProv1.dll DMWmiBridgeProv1.mof DMWmiBridgeProv1_Uninstall.mof DMWmiBridgeProv_Uninstall.mof dnsclientcim.dll dnsclientcim.mof dnsclientpspr
> ovider.dll dnsclientpsprovider.mof dnsclientpsprovider_Uninstall.mof drvinst.mof DscCore.mof DscCoreConfProv.mof dscproxy.mof Dscpspluginwkr.dll DscTimer.mof dsprov.dll dsprov.mof eaimeapi.mof EmbeddedLockdownWmi.dll embeddedlockdownwmi.mof embeddedlockdownwmi_Uninst
> all.mof en en-US esscli.dll EventTracingManagement.dll EventTracingManagement.mof fastprox.dll fdPHost.mof fdrespub.mof fdSSDP.mof fdWNet.mof fdWSD.mof filetrace.mof firewallapi.mof FolderRedirectionWMIProvider.mof FunDisc.mof fwcfg.mof hbaapi.mof hnetcfg.mof IMAPIv2
> -Base.mof IMAPIv2-FileSystemSupport.mof IMAPIv2-LegacyShim.mof interop.mof IpmiDTrc.mof ipmiprr.dll ipmiprv.dll ipmiprv.mof IpmiPTrc.mof ipsecsvc.mof iscsidsc.mof iscsihba.mof iscsiprf.mof iscsirem.mof iscsiwmiv2.mof iscsiwmiv2_uninstall.mof kerberos.mof ko ko-KR Krn
> lProv.dll krnlprov.mof L2SecHC.mof lltdio.mof lltdsvc.mof Logs lsasrv.mof mblctr.mof MDMAppProv.dll MDMAppProv.mof MDMAppProv_Uninstall.mof MDMSettingsProv.dll MDMSettingsProv.mof MDMSettingsProv_Uninstall.mof Microsoft-Windows-OfflineFiles.mof Microsoft-Windows-Remo
> te-FileSystem.mof Microsoft.AppV.AppVClientWmi.dll Microsoft.AppV.AppVClientWmi.mof Microsoft.Uev.AgentWmi.dll Microsoft.Uev.ManagedAgentWmi.mof Microsoft.Uev.ManagedAgentWmiUninstall.mof mispace.mof mispace_uninstall.mof mmc.mof MMFUtil.dll MOF mofcomp.exe mofd.dll
> mofinstall.dll mountmgr.mof mpeval.mof mpsdrv.mof mpssvc.mof msdtcwmi.dll MsDtcWmi.mof msfeeds.mof msfeedsbs.mof msi.mof msiprov.dll msiscsi.mof MsNetImPlatform.mof mstsc.mof mstscax.mof msv1_0.mof mswmdm.mof NCProv.dll ncprov.mof ncsi.mof ndisimplatcim.dll ndistrace
> .mof NetAdapterCim.dll NetAdapterCim.mof NetAdapterCimTrace.mof NetAdapterCimTraceUninstall.mof NetAdapterCim_uninstall.mof netdacim.dll netdacim.mof netdacim_uninstall.mof NetEventPacketCapture.dll NetEventPacketCapture.mof NetEventPacketCapture_uninstall.mof netncc
> im.dll netnccim.mof netnccim_uninstall.mof NetPeerDistCim.dll NetPeerDistCim.mof NetPeerDistCim_uninstall.mof netprofm.mof NetSwitchTeam.mof netswitchteamcim.dll NetTCPIP.dll NetTCPIP.mof NetTCPIP_Uninstall.mof netttcim.dll netttcim.mof netttcim_uninstall.mof network
> itemfactory.mof newdev.mof nlasvc.mof nlmcim.dll nlmcim.mof nlmcim_uninstall.mof nlsvc.mof npivwmi.mof nshipsec.mof ntevt.dll ntevt.mof ntfs.mof OfflineFilesConfigurationWmiProvider.mof OfflineFilesConfigurationWmiProvider_Uninstall.mof OfflineFilesWmiProvider.mof Of
> flineFilesWmiProvider_Uninstall.mof p2p-mesh.mof p2p-pnrp.mof pcsvDevice.mof pcsvDevice_Uninstall.mof Performance PNPXAssoc.mof PolicMan.dll PolicMan.mof polproc.mof polprocl.mof polprou.mof polstore.mof portabledeviceapi.mof portabledeviceclassextension.mof portable
> deviceconnectapi.mof portabledevicetypes.mof portabledevicewiacompat.mof powermeterprovider.mof PowerPolicyProvider.mof ppcRsopCompSchema.mof ppcRsopUserSchema.mof PrintFilterPipelineSvc.mof PrintManagementProvider.dll PrintManagementProvider.mof PrintManagementProvider_Uninstall.mof profileassociationprovider.mof PS_MMAgent.mof qmgr.mof qoswmi.dll qoswmi.mof qoswmitrc.mof qoswmitrc_uninstall.mof qoswmi_uninstall.mof RacWmiProv.dll RacWmiProv.mof rawxml.xsl rdpendp.mof rdpinit.mof rdpshell.mof refs.mof refsv1.mof regevent.mof Remove.Microsoft.AppV.AppvClientWmi.mof repdrvfs.dll Repository rsop.mof rspndr.mof samsrv.mof scersop.mof schannel.mof schedprov.dll SchedProv.mof scm.mof scrcons.exe scrcons.mof sdbus.mof secrcw32.mof SensorsClassExtension.mof ServDeps.dll ServiceModel.mof ServiceModel.mof.uninstall ServiceModel35.mof ServiceModel35.mof.uninstall services.mof setupapi.mof SmbWitnessWmiv2Provider.mof smbwmiv2.mof SMTPCons.dll smtpcons.mof sppwmi.mof sr.mof sstpsvc.mof stdprov.dll storagewmi.mof storagewmi_passthru.mof storagewmi_passthru_uninstall.mof storagewmi_uninstall.mof stortrace.mof subscrpt.mof system.mof tcpip.mof texttable.xsl textvaluelist.xsl tmf tsallow.mof tscfgwmi.mof tsmf.mof tspkg.mof umb.mof umbus.mof umpass.mof umpnpmgr.mof unsecapp.exe UserProfileConfigurationWmiProvider.mof UserProfileWmiProvider.mof UserStateWMIProvider.mof vds.mof vdswmi.dll viewprov.dll vpnclientpsprovider.dll vpnclientpsprovider.mof vpnclientpsprovider_Uninstall.mof vss.mof vsswmi.dll wbemcntl.dll wbemcons.dll WBEMCons.mof wbemcore.dll wbemdisp.dll wbemdisp.tlb wbemess.dll wbemprox.dll wbemsvc.dll wbemtest.exe wcncsvc.mof WdacEtwProv.mof WdacWmiProv.dll WdacWmiProv.mof WdacWmiProv_Uninstall.mof Wdf01000.mof Wdf01000Uninstall.mof wdigest.mof WFAPIGP.mof wfascim.dll wfascim.mof wfascim_uninstall.mof WFP.MOF wfs.mof whqlprov.mof Win32_DeviceGuard.mof Win32_EncryptableVolume.dll win32_encryptablevolume.mof Win32_EncryptableVolumeUninstall.mof win32_printer.mof Win32_Tpm.dll Win32_Tpm.mof wininit.mof winipsec.mof winlogon.mof WinMgmt.exe WinMgmtR.dll Winsat.mof WinsatUninstall.mof wlan.mof WLanHC.mof wmi.mof WMIADAP.exe WmiApRes.dll WmiApRpl.dll WmiApSrv.exe WMIC.exe WMICOOKR.dll WmiDcPrv.dll wmipcima.dll wmipcima.mof wmipdfs.dll wmipdfs.mof wmipdskq.dll wmipdskq.mof WmiPerfClass.dll WmiPerfClass.mof WmiPerfInst.dll WmiPerfInst.mof WMIPICMP.dll wmipicmp.mof WMIPIPRT.dll wmipiprt.mof WMIPJOBJ.dll wmipjobj.mof wmiprov.dll WmiPrvSD.dll WmiPrvSE.exe WMIPSESS.dll wmipsess.mof WMIsvc.dll wmitimep.dll wmitimep.mof wmiutils.dll WMI_Tracing.mof wmp.mof wmpnetwk.mof wpdbusenum.mof wpdcomp.mof wpdfs.mof wpdmtp.mof wpdshext.mof WPDShServiceObj.mof wpdsp.mof wpd_ci.mof wscenter.mof WsmAgent.mof WsmAgentUninstall.mof WsmAuto.mof wsp_fs.mof wsp_fs_uninstall.mof wsp_health.mof wsp_health_uninstall.mof wsp_sr.mof wsp_sr_uninstall.mof WUDFx.mof Wudfx02000.mof Wudfx02000Uninstall.mof WUDFxUninstall.mof xml xsl-mappings.xml xwizards.mof
> /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0: Certificate.format.ps1xml Diagnostics.Format.ps1xml DotNetTypes.format.ps1xml en en-US Event.Format.ps1xml Examples FileSystem.format.ps1xml getevent.types.ps1xml Help.format.ps1xml HelpV3.format.ps1xml ko ko-KR Modules powershell.exe powershell.exe.config PowerShellCore.format.ps1xml PowerShellTrace.format.ps1xml powershell_ise.exe powershell_ise.exe.config PSEvents.dll pspluginwkr.dll pwrshmsg.dll pwrshsip.dll Registry.format.ps1xml Schemas SessionConfig types.ps1xml typesv3.ps1xml WSMan.Format.ps1xml
> /cygdrive/c/Windows/System32/OpenSSH: scp.exe sftp.exe ssh-add.exe ssh-agent.exe ssh-keygen.exe ssh-keyscan.exe ssh.exe
> /cygdrive/c/Program Files/MATLAB/R2020b/bin: crash_analyzer.cfg icutzdata lcdata.xml lcdata.xsd lcdata_utf8.xml m3iregistry matlab.exe mex.bat mexext.bat util win32 win64
> /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn: Resources SqlLocalDB.exe
> /cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn: batchparser.dll bcp.exe Resources SQLCMD.EXE xmlrw.dll
> /cygdrive/c/Program Files/Git/cmd: git-gui.exe git-lfs.exe git.exe gitk.exe start-ssh-agent.cmd start-ssh-pageant.cmd
> Warning accessing /cygdrive/c/msys64/mingw64/bin gives errors: [Errno 2] No such file or directory: '/cygdrive/c/msys64/mingw64/bin'
> Warning accessing /cygdrive/c/msys64/usr/bin gives errors: [Errno 2] No such file or directory: '/cygdrive/c/msys64/usr/bin'
> /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64: 1033 asan_blacklist.txt atlprov.dll bscmake.exe c1.dll c1xx.dll c2.dll cfgpersist.dll cl.exe cl.exe.config clang_rt.asan_dbg_dynamic-x86_64.dll clang_rt.asan_dynamic-x86_64.dll ConcurrencyCheck.dll CppBuildInsights.dll CppBuildInsightsEtw.xml CppCoreCheck.dll cvtres.exe d3dcompiler_47.dll dpcmi.dll dumpbin.exe editbin.exe EnumIndex.dll EspXEngine.dll HResultCheck.dll KernelTraceControl.dll lib.exe link.exe link.exe.config llvm-symbolizer.exe LocalESPC.dll Microsoft.Diagnostics.Tracing.EventSource.dll Microsoft.VisualStudio.RemoteControl.dll Microsoft.VisualStudio.Telemetry.dll Microsoft.VisualStudio.Utilities.Internal.dll ml64.exe msobj140.dll mspdb140.dll mspdbcmf.exe mspdbcore.dll mspdbsrv.exe mspdbst.dll mspft140.dll msvcdis140.dll msvcp140.dll msvcp140_1.dll msvcp140_2.dll msvcp140_atomic_wait.dll msvcp140_codecvt_ids.dll Newtonsoft.Json.dll nmake.exe onecore perf_msvcbuildinsights.dll pgocvt.exe pgodb140.dll pgodriver.sys pgomgr.exe pgort140.dll pgosweep.exe System.Runtime.CompilerServices.Unsafe.dll tbbmalloc.dll undname.exe VariantClear.dll vcmeta.dll vcperf.exe vcruntime140.dll vcruntime140_1.dll vctip.exe xdcmake.exe xdcmake.exe.config
> /cygdrive/c/Program Files/dotnet: dotnet.exe host LICENSE.txt packs sdk shared templates ThirdPartyNotices.txt
> /: bin Cygwin-Terminal.ico Cygwin.bat Cygwin.ico dev etc home lib mpich-4.0.2 mpich-4.0.2.tar.gz sbin tmp usr var proc cygdrive
> /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps: Backup GameBarElevatedFT_Alias.exe Microsoft.DesktopAppInstaller_8wekyb3d8bbwe Microsoft.MicrosoftEdge_8wekyb3d8bbwe Microsoft.SkypeApp_kzf8qxf38zg5c Microsoft.XboxGamingOverlay_8wekyb3d8bbwe MicrosoftEdge.exe python.exe python3.exe Skype.exe winget.exe
> /cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin: code code.cmd
> Warning accessing /cygdrive/c/Users/SEJONG/.dotnet/tools gives errors: [Errno 2] No such file or directory: '/cygdrive/c/Users/SEJONG/.dotnet/tools'
> /usr/lib/lapack: cygblas-0.dll cyglapack-0.dll
> TESTING: configureExternalPackagesDir from config.framework(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py:1045)
> Set alternative directory external packages are built in
> serialEvaluation: initial cxxDialectRanges ('c++11', 'c++17')
> serialEvaluation: new cxxDialectRanges ('c++11', 'c++17')
> child config.utilities.macosFirewall took 0.000005 seconds
> TESTING: configureDebuggers from config.utilities.debuggers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/utilities/debuggers.py:20)
> Find a default debugger and determine its arguments
> Checking for program /usr/local/bin/gdb...not found
> Checking for program /usr/bin/gdb...not found
> Checking for program /cygdrive/c/SIMULIA/Commands/gdb...not found
> Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/gdb...not found
> Checking for program /cygdrive/c/Windows/system32/gdb...not found
> Checking for program /cygdrive/c/Windows/gdb...not found
> Checking for program /cygdrive/c/Windows/System32/Wbem/gdb...not found
> Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/gdb...not found
> Checking for program /cygdrive/c/Windows/System32/OpenSSH/gdb...not found
> Checking for program /cygdrive/c/Program Files/MATLAB/R2020b/bin/gdb...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/gdb...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn/gdb...not found
> Checking for program /cygdrive/c/Program Files/Git/cmd/gdb...not found
> Checking for program /cygdrive/c/msys64/mingw64/bin/gdb...not found
> Checking for program /cygdrive/c/msys64/usr/bin/gdb...not found
> Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/gdb...not found
> Checking for program /cygdrive/c/Program Files/dotnet/gdb...not found
> Checking for program /gdb...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/gdb...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin/gdb...not found
> Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/gdb...not found
> Checking for program /usr/lib/lapack/gdb...not found
> Checking for program /usr/local/bin/dbx...not found
> Checking for program /usr/bin/dbx...not found
> Checking for program /cygdrive/c/SIMULIA/Commands/dbx...not found
> Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/dbx...not found
> Checking for program /cygdrive/c/Windows/system32/dbx...not found
> Checking for program /cygdrive/c/Windows/dbx...not found
> Checking for program /cygdrive/c/Windows/System32/Wbem/dbx...not found
> Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/dbx...not found
> Checking for program /cygdrive/c/Windows/System32/OpenSSH/dbx...not found
> Checking for program /cygdrive/c/Program Files/MATLAB/R2020b/bin/dbx...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/dbx...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn/dbx...not found
> Checking for program /cygdrive/c/Program Files/Git/cmd/dbx...not found
> Checking for program /cygdrive/c/msys64/mingw64/bin/dbx...not found
> Checking for program /cygdrive/c/msys64/usr/bin/dbx...not found
> Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/dbx...not found
> Checking for program /cygdrive/c/Program Files/dotnet/dbx...not found
> Checking for program /dbx...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/dbx...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin/dbx...not found
> Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/dbx...not found
> Checking for program /usr/lib/lapack/dbx...not found
> Defined make macro "DSYMUTIL" to "true"
> child config.utilities.debuggers took 0.014310 seconds
> TESTING: configureDirectories from PETSc.options.petscdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/petscdir.py:22)
> Checks PETSC_DIR and sets if not set
> PETSC_VERSION_RELEASE of 1 indicates the code is from a release branch or a branch created from a release branch.
> Version Information:
> #define PETSC_VERSION_RELEASE 1
> #define PETSC_VERSION_MAJOR 3
> #define PETSC_VERSION_MINOR 18
> #define PETSC_VERSION_SUBMINOR 1
> #define PETSC_VERSION_DATE "Oct 26, 2022"
> #define PETSC_VERSION_GIT "v3.18.1"
> #define PETSC_VERSION_DATE_GIT "2022-10-26 07:57:29 -0500"
> #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_ PETSC_VERSION_EQ
> #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
> child PETSc.options.petscdir took 0.015510 seconds
> TESTING: getDatafilespath from PETSc.options.dataFilesPath(/home/SEJONG/petsc-3.18.1/config/PETSc/options/dataFilesPath.py:29)
> Checks what DATAFILESPATH should be
> child PETSc.options.dataFilesPath took 0.002462 seconds
> TESTING: configureGit from config.sourceControl(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/sourceControl.py:24)
> Find the Git executable
> Checking for program /usr/local/bin/git...not found
> Checking for program /usr/bin/git...found
> Defined make macro "GIT" to "git"
> Executing: git --version
> stdout: git version 2.38.1
> TESTING: configureMercurial from config.sourceControl(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/sourceControl.py:35)
> Find the Mercurial executable
> Checking for program /usr/local/bin/hg...not found
> Checking for program /usr/bin/hg...not found
> Checking for program /cygdrive/c/SIMULIA/Commands/hg...not found
> Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/hg...not found
> Checking for program /cygdrive/c/Windows/system32/hg...not found
> Checking for program /cygdrive/c/Windows/hg...not found
> Checking for program /cygdrive/c/Windows/System32/Wbem/hg...not found
> Checking for program /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/hg...not found
> Checking for program /cygdrive/c/Windows/System32/OpenSSH/hg...not found
> Checking for program /cygdrive/c/Program Files/MATLAB/R2020b/bin/hg...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/hg...not found
> Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/170/Tools/Binn/hg...not found
> Checking for program /cygdrive/c/Program Files/Git/cmd/hg...not found
> Checking for program /cygdrive/c/msys64/mingw64/bin/hg...not found
> Checking for program /cygdrive/c/msys64/usr/bin/hg...not found
> Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/hg...not found
> Checking for program /cygdrive/c/Program Files/dotnet/hg...not found
> Checking for program /hg...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/hg...not found
> Checking for program /cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS Code/bin/hg...not found
> Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/hg...not found
> Checking for program /usr/lib/lapack/hg...not found
> Checking for program /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/hg...not found
> child config.sourceControl took 0.121914 seconds
> TESTING: configureInstallationMethod from PETSc.options.petscclone(/home/SEJONG/petsc-3.18.1/config/PETSc/options/petscclone.py:20)
> Determine if PETSc was obtained via git or a tarball
> This is a tarball installation
> child PETSc.options.petscclone took 0.003125 seconds
> TESTING: setNativeArchitecture from PETSc.options.arch(/home/SEJONG/petsc-3.18.1/config/PETSc/options/arch.py:29)
> Forms the arch as GNU's configure would form it
> TESTING: configureArchitecture from PETSc.options.arch(/home/SEJONG/petsc-3.18.1/config/PETSc/options/arch.py:42)
> Checks if PETSC_ARCH is set and sets it if not set
> No previous hashfile found
> Setting hashfile: arch-mswin-c-debug/lib/petsc/conf/configure-hash
> Deleting configure hash file: arch-mswin-c-debug/lib/petsc/conf/configure-hash
> Unable to delete configure hash file: arch-mswin-c-debug/lib/petsc/conf/configure-hash
> child PETSc.options.arch took 0.149094 seconds
> TESTING: setInstallDir from PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:31)
> Set installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
> Defined make macro "PREFIXDIR" to "/home/SEJONG/petsc-3.18.1/arch-mswin-c-debug"
> TESTING: saveReconfigure from PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:76)
> Save the configure options in a script in PETSC_ARCH/lib/petsc/conf so the same configure may be easily re-run
> TESTING: cleanConfDir from PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:68)
> Remove all the files from configuration directory for this PETSC_ARCH, from --with-clean option
> TESTING: configureInstallDir from PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:52)
> Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
> Changed persistence directory to /home/SEJONG/petsc-3.18.1/arch-mswin-c-debug/lib/petsc/conf
> TESTING: restoreReconfigure from PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:90)
> If --with-clean was requested but restoring the reconfigure file was requested then restore it
> child PETSc.options.installDir took 0.006476 seconds
> TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/externalpackagesdir.py:15)
> Set location where external packages will be downloaded to
> TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/externalpackagesdir.py:23)
> Remove all downloaded external packages, from --with-clean
> child PETSc.options.externalpackagesdir took 0.000990 seconds
> TESTING: configureCLanguage from PETSc.options.languages(/home/SEJONG/petsc-3.18.1/config/PETSc/options/languages.py:28)
> Choose whether to compile the PETSc library using a C or C++ compiler
> C language is C
> Defined "CLANGUAGE_C" to "1"
> Defined make macro "CLANGUAGE" to "C"
> child PETSc.options.languages took 0.003172 seconds
> TESTING: resetEnvCompilers from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2652)
> Remove compilers from the shell environment so they do not interfer with testing
> TESTING: checkEnvCompilers from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2669)
> Set configure compilers from the environment, from -with-environment-variables
> TESTING: checkMPICompilerOverride from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2622)
> Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
> This usually prevents mpi compilers from being used - so issue a warning
> TESTING: requireMpiLdPath from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2643)
> OpenMPI wrappers require LD_LIBRARY_PATH set
> TESTING: checkInitialFlags from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:723)
> Initialize the compiler and linker flags
> Initialized CFLAGS to
> Initialized LDFLAGS to
> Initialized CUDAFLAGS to
> Initialized HIPFLAGS to
> Initialized SYCLFLAGS to
> Initialized CXXFLAGS to
> Initialized CXX_CXXFLAGS to
> Initialized FFLAGS to
> Initialized CPPFLAGS to
> Initialized FPPFLAGS to
> Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
> Initialized CXXPPFLAGS to
> Initialized HIPPPFLAGS to
> Initialized SYCLPPFLAGS to
> Initialized CC_LINKER_FLAGS to []
> Initialized CXX_LINKER_FLAGS to []
> Initialized FC_LINKER_FLAGS to []
> Initialized CUDAC_LINKER_FLAGS to []
> Initialized HIPC_LINKER_FLAGS to []
> Initialized SYCLC_LINKER_FLAGS to []
> TESTING: checkCCompiler from config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:1341)
> Locate a functional C compiler
> Checking for program /usr/local/bin/mpicc...not found
> Checking for program /usr/bin/mpicc...found
> Defined make macro "CC" to "mpicc"
> Executing: mpicc -c -o /tmp/petsc-uqt11yqc/config.setCompilers/conftest.o -I/tmp/petsc-uqt11yqc/config.setCompilers /tmp/petsc-uqt11yqc/config.setCompilers/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Executing: mpicc -o /tmp/petsc-uqt11yqc/config.setCompilers/conftest.exe /tmp/petsc-uqt11yqc/config.setCompilers/conftest.o
> Possible ERROR while running linker: exit code 1
> stderr:
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lhwloc: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -levent_core: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -levent_pthreads: No such file or directory
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lz: No such file or directory
> collect2: error: ld returned 1 exit status
> Linker output before filtering:
> Linker output after filtering:
> collect2: error: ld returned 1 exit status:
> Error testing C compiler: Cannot compile/link C with mpicc.
> MPI compiler wrapper mpicc failed to compile
> Executing: mpicc -show
> stdout: gcc -L/usr/lib -lmpi -lopen-rte -lopen-pal -lhwloc -levent_core -levent_pthreads -lz
> MPI compiler wrapper mpicc is likely incorrect.
> Use --with-mpi-dir to indicate an alternate MPI.
> Deleting "CC"
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> C compiler you provided with -with-cc=mpicc cannot be found or does not work.
> File "/home/SEJONG/petsc-3.18.1/config/configure.py", line 461, in petsc_configure
> framework.configure(out = sys.stdout)
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py", line 1412, in configure
> self.processChildren()
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py", line 1400, in processChildren
> self.serialEvaluation(self.childGraph)
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py", line 1375, in serialEvaluation
> child.configure()
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py", line 2712, in configure
> self.executeTest(self.checkCCompiler)
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/base.py", line 138, in executeTest
> ret = test(*args,**kargs)
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py", line 1346, in checkCCompiler
> for compiler in self.generateCCompilerGuesses():
> File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py", line 1274, in generateCCompilerGuesses
> raise RuntimeError('C compiler you provided with -with-cc='+self.argDB['with-cc']+' cannot be found or does not work.'+'\n'+self.mesg)
> Finishing configure run at Tue, 01 Nov 2022 13:06:09 +0900
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Tuesday, November 1, 2022 11:36 AM
> To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Subject: RE: [petsc-users] PETSc Windows Installation
> you'll have to send configure.log for this failure
> Satish
> On Tue, 1 Nov 2022, Mohammad Ali Yaqteen wrote:
> > I have checked the required Cygwin openmpi libraries and they are all installed. When I run ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90, it returns:
> > $ ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> > Configuring PETSc to compile on your system
> > TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*******************************************************************************
> > --------- C compiler you provided with -with-cc=mpicc cannot be found
> > or does not work.
> > As for the case of WSL2, I will try to install that on my PC.
> > Meanwhile, could you please look into this issue
> > Thank you
> > Ali
> > Sent: Monday, October 31, 2022 10:56 PM
> > To: Satish Balay via petsc-users <petsc-users at mcs.anl.gov>
> > Cc: Matthew Knepley <knepley at gmail.com>; Mohammad Ali Yaqteen
> > Subject: Re: [petsc-users] PETSc Windows Installation
> > BTW: If you have WSL2 on windows - it might be easier to build/use PETSc.
> > Satish
> > On Mon, 31 Oct 2022, Satish Balay via petsc-users wrote:
> > > Make sure you have cygwin openmpi installed [and cywin blas/lapack]
> > > $ cygcheck -cd |grep openmpi
> > > libopenmpi-devel 4.1.2-1
> > > libopenmpi40 4.1.2-1
> > > libopenmpifh40 4.1.2-1
> > > libopenmpiusef08_40 4.1.2-1
> > > libopenmpiusetkr40 4.1.2-1
> > > openmpi 4.1.2-1
> > > $ cygcheck -cd |grep lapack
> > > liblapack-devel 3.10.1-1
> > > liblapack0 3.10.1-1
> > > > ./configure --with-cc=gcc --with-cxx=0 --with-fc=0
> > > > --download-f2cblaslapack
> > > Should be:
> > > > > $ ./configure --download-scalapack --download-mumps
> > > i.e [default] --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 [an
> > > default cygwin blas/lapack]
> > > Satish
> > > On Mon, 31 Oct 2022, Matthew Knepley wrote:
> > > > On Mon, Oct 31, 2022 at 1:56 AM Mohammad Ali Yaqteen
> > > > wrote:
> > > > > Dear Satish
> > > > > When I configure PETSc with (./configure --with-cc=gcc
> > > > > --with-cxx=0
> > > > > --with-fc=0 --download-f2cblaslapack) it runs as I shared
> > > > > initially which you said is not an issue anymore. But when I add
> > > > > (--download-scalapack
> > > > > --download-mumps) or configure with these later, it gives the
> > > > > following
> > > > > error:
> > > > > system
> > > > > TESTING: FortranMPICheck from
> > > > > config.packages.MPI(config/BuildSystem/config/packages/MPI.py:614)*******************************************************************************
> > > > > details):
> > > > > ------------- Fortran error! mpi_init() could not be located!
> > > > > What could be the problem here?
> > > > Without configure.log we cannot tell what went wrong. However,
> > > > from the error message, I would guess that your MPI was not built
> > > > with Fortran bindings. You need these for those packages.
> > > > Thanks,
> > > > Matt
> > > > > Your help is highly appreciated.
> > > > > Thank you
> > > > > Ali
> > > > > Sent: Saturday, October 29, 2022 2:11 PM
> > > > > Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov
> > > > > On Sat, 29 Oct 2022, Mohammad Ali Yaqteen wrote:
> > > > > > I haven’t accessed PETSC or given any command of my own. I was
> > > > > > just
> > > > > installing by following the instructions. I don’t know why it is
> > > > > attaching the debugger. Although it says “Possible error running
> > > > > C/C++
> > > > > src/snes/tutorials/ex19 with 1 MPI process” which I think is
> > > > > indicating of missing of MPI!
> > > > > The diff is not smart enough to detect the extra message from
> > > > > cygwin/OpenMPI - hence it assumes there is a potential problem -
> > > > > and prints the above message.
> > > > > But you can assume its installed properly - and use it.
> > > > > Satish
> > > > > > From: Matthew Knepley <knepley at gmail.com>
> > > > > > Sent: Friday, October 28, 2022 10:31 PM
> > > > > > Cc: petsc-users at mcs.anl.gov
> > > > > > On Fri, Oct 28, 2022 at 9:11 AM Mohammad Ali Yaqteen <
> > > > > mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
> > > > > > Dear Sir,
> > > > > > During the Installation of PETSc in windows, I installed
> > > > > > Cygwin and the
> > > > > required libraries as mentioned on your website:
> > > > > > [cid:image001.png at 01D8EB93.7C17E410]
> > > > > > However, when I install PETSc using the configure commands
> > > > > > present on
> > > > > the petsc website:
> > > > > --download-f2cblaslapack --download-mpich
> > > > > > it gives me the following error:
> > > > > > [cid:image002.png at 01D8EB93.7C17E410]
> > > > > > I already installed OpenMPI using Cygwin installer but it
> > > > > > still asks me
> > > > > to. When I configure without “—download-mpich” and run “make check”
> > > > > command, it gives me the following errors:
> > > > > > [cid:image003.png at 01D8EB93.7C17E410]
> > > > > > Could you kindly look into this and help me with this? Your
> > > > > > prompt
> > > > > response will highly be appreciated.
> > > > > > The runs look fine.
> > > > > > The test should not try to attach the debugger. Do you have
> > > > > > that in the
> > > > > PETSC_OPTIONS env variable?
> > > > > > Thanks,
> > > > > > Matt
> > > > > > Thank you!
> > > > > > Mohammad Ali
> > > > > > Researcher, Sejong University
> > > > > > What most experimenters take for granted before they begin
> > > > > > their
> > > > > experiments is infinitely more interesting than any results to
> > > > > which their experiments lead.
> > > > > > -- Norbert Wiener
> > > > > > https://www.cse.buffalo.edu/~knepley/<
> > > > > http://www.cse.buffalo.edu/~knepley/>
