[petsc-users] PETSc Windows Installation
Tue Nov 1 00:07:35 CDT 2022
On Tue, Nov 1, 2022 at 12:36 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
wrote:
> I installed the libraries i.e. Cygwin openmpi in its default folder. I
> didn’t change anything. Now there is a folder of C:\cygwin64\lib\openmpi\
> which includes a file name *“cygompi_dbg_msgq.dll”*.
Can you compile any executable with mpicc?
      Matt
> Thanks
> Ali
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Tuesday, November 1, 2022 1:26 PM
> *To:* Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
> *Cc:* petsc-users <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] PETSc Windows Installation
> On Tue, Nov 1, 2022 at 12:16 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
> wrote:
> I am unable to attach the configure.log file. Hence. I have copied the
> following text after executing the command (less configure.log) in the
> cygwin64
> You can see at the end of the file that your "mpicc" does not work. The
> link is broken, possibly because you moved directories after you installed
> it.
>   Thanks,
>     Matt
> Executing: uname -s
> stdout: CYGWIN_NT-10.0-19044
>                          Configuring PETSc to compile on your system
> Starting configure run at Tue, 01 Nov 2022 13:06:06 +0900
> Configure Options: --configModules=PETSc.Configure
> --optionsModule=config.compilerOptions --with-cc=mpicc --with-cxx=mpicxx
> --with-fc=mpif90
> Working directory: /home/SEJONG/petsc-3.18.1
> Machine platform:
> uname_result(system='CYGWIN_NT-10.0-19044', node='DESKTOP-R1C768B',
> release='3.3.6-341.x86_64', version='2022-09-05 11:15 UTC',
> machine='x86_64')
> Python version:
> 3.9.10 (main, Jan 20 2022, 21:37:52)
> [GCC 11.2.0]
>   Environmental variables
> USERDOMAIN=DESKTOP-R1C768B
> OS=Windows_NT
> COMMONPROGRAMFILES=C:\Program Files\Common Files
> PROCESSOR_LEVEL=6
> PSModulePath=C:\Users\SEJONG\Documents\WindowsPowerShell\Modules;C:\Program
> Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
> CommonProgramW6432=C:\Program Files\Common Files
> CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
> LANG=en_US.UTF-8
> TZ=Asia/Seoul
> HOSTNAME=DESKTOP-R1C768B
> PUBLIC=C:\Users\Public
> OLDPWD=/home/SEJONG
> USERNAME=SEJONG
> LOGONSERVER=\\DESKTOP-R1C768B
> PROCESSOR_ARCHITECTURE=AMD64
> LOCALAPPDATA=C:\Users\SEJONG\AppData\Local
> COMPUTERNAME=DESKTOP-R1C768B
> USER=SEJONG
> SYSTEMDRIVE=C:
> USERPROFILE=C:\Users\SEJONG
> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.CPL
> SYSTEMROOT=C:\Windows
> USERDOMAIN_ROAMINGPROFILE=DESKTOP-R1C768B
> OneDriveCommercial=C:\Users\SEJONG\OneDrive - Sejong University
> PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 165 Stepping 5, GenuineIntel
> GNUPLOT_LIB=C:\Program Files\gnuplot\demo;C:\Program
> Files\gnuplot\demo\games;C:\Program Files\gnuplot\share
> PWD=/home/SEJONG/petsc-3.18.1
> MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
> HOME=/home/SEJONG
> TMP=/tmp
> OneDrive=C:\Users\SEJONG\OneDrive - Sejong University
> ZES_ENABLE_SYSMAN=1
> !C:=C:\cygwin64\bin
> PROCESSOR_REVISION=a505
> PROFILEREAD=true
> PROMPT=$P$G
> NUMBER_OF_PROCESSORS=16
> COMSPEC=C:\Windows\system32\cmd.exe
> APPDATA=C:\Users\SEJONG\AppData\Roaming
> SHELL=/bin/bash
> TERM=xterm-256color
> WINDIR=C:\Windows
> ProgramData=C:\ProgramData
> SHLVL=1
> PRINTER=\\210.107.220.119\HP Color LaserJet Pro MFP M377 PCL 6
> ALLUSERSPROFILE=C:\ProgramData
> TEMP=/tmp
> DriverData=C:\Windows\System32\Drivers\DriverData
> SESSIONNAME=Console
> PATH=/usr/local/bin:/usr/bin:/cygdrive/c/SIMULIA/Commands:/cygdrive/c/Program
> Files/Microsoft
> MPI/Bin:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program
> Files/MATLAB/R2020b/bin:/cygdrive/c/Program Files/Microsoft SQL
> Server/130/Tools/Binn:/cygdrive/c/Program Files/Microsoft SQL Server/Client
> SDK/ODBC/170/Tools/Binn:/cygdrive/c/Program
> Files/Git/cmd:/cygdrive/c/msys64/mingw64/bin:/cygdrive/c/msys64/usr/bin:/cygdrive/c/Program
> Files (x86)/Microsoft Visual
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Program
> Files/dotnet:/:/cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft
> VS Code/bin:/cygdrive/c/Program Files (x86)/Microsoft Visual
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64:/cygdrive/c/Users/SEJONG/.dotnet/tools:/usr/lib/lapack
> PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
> HOMEDRIVE=C:
> INFOPATH=/usr/local/info:/usr/share/info:/usr/info
> HOMEPATH=\Users\SEJONG
> ORIGINAL_PATH=/cygdrive/c/SIMULIA/Commands:/cygdrive/c/Program
> Files/Microsoft
> EXECIGNORE=*.dll
> _=./configure
>     Files in path provided by default path
>       /usr/local/bin:
>       /usr/bin: addftinfo.exe addr2line.exe apropos ar.exe arch.exe as.exe
> ash.exe awk b2sum.exe base32.exe base64.exe basename.exe basenc.exe
> bash.exe bashbug bomtool.exe bunzip2.exe bzcat.exe bzcmp bzdiff bzegrep
> bzfgrep bzgrep bzip2.exe bzip2recover.exe bzless bzmore c++.exe c++filt.exe
> c89 c99 ca-legacy cal.exe captoinfo cat.exe catman.exe cc ccmake.exe
> chattr.exe chcon.exe chgrp.exe chmod.exe chown.exe chroot.exe chrt.exe
> cksum.exe clear.exe cmake.exe cmp.exe col.exe colcrt.exe colrm.exe
> column.exe comm.exe cp.exe cpack.exe cpp.exe csplit.exe ctest.exe cut.exe
> cygarchive-13.dll cygargp-0.dll cygatomic-1.dll cygattr-1.dll
> cygblkid-1.dll cygbrotlicommon-1.dll cygbrotlidec-1.dll cygbz2-1.dll
> cygcheck.exe cygcom_err-2.dll cygcrypt-2.dll cygcrypto-1.1.dll
> cygcurl-4.dll cygdb-5.3.dll cygdb_cxx-5.3.dll cygdb_sql-5.3.dll
> cygedit-0.dll cygevent-2-1-7.dll cygevent_core-2-1-7.dll
> cygevent_extra-2-1-7.dll cygevent_openssl-2-1-7.dll
> cygevent_pthreads-2-1-7.dll cygexpat-1.dll cygfdisk-1.dll cygffi-6.dll
> cygfido2-1.dll cygformw-10.dll cyggc-1.dll cyggcc_s-seh-1.dll cyggdbm-6.dll
> cyggdbm_compat-4.dll cyggfortran-5.dll cyggmp-10.dll cyggomp-1.dll
> cyggsasl-7.dll cyggssapi_krb5-2.dll cygguile-2.2-1.dll cyghistory7.dll
> cyghwloc-15.dll cygiconv-2.dll cygidn-12.dll cygidn2-0.dll cygintl-8.dll
> cygisl-23.dll cygjsoncpp-25.dll cygk5crypto-3.dll cygkrb5-3.dll
> cygkrb5support-0.dll cyglber-2-4-2.dll cyglber-2.dll cygldap-2-4-2.dll
> cygldap-2.dll cygldap_r-2-4-2.dll cygltdl-7.dll cyglz4-1.dll cyglzma-5.dll
> cyglzo2-2.dll cygmagic-1.dll cygman-2-11-0.dll cygmandb-2-11-0.dll
> cygmenuw-10.dll cygmpc-3.dll cygmpfr-6.dll cygmpi-40.dll
> cygmpi_mpifh-40.dll cygmpi_usempif08-40.dll cygmpi_usempi_ignore_tkr-40.dll
> cygncursesw-10.dll cygnghttp2-14.dll cygntlm-0.dll cygopen-pal-40.dll
> cygopen-rte-40.dll cygp11-kit-0.dll cygpanelw-10.dll cygpath.exe
> cygpcre2-8-0.dll cygperl5_32.dll cygpipeline-1.dll cygpkgconf-4.dll
> cygpopt-0.dll cygpsl-5.dll cygquadmath-0.dll cygreadline7.dll
> cygrhash-0.dll cygrunsrv.exe cygsasl2-3.dll cygserver-config
> cygsigsegv-2.dll cygsmartcols-1.dll cygsqlite3-0.dll cygssh2-1.dll
> cygssl-1.1.dll cygstart.exe cygstdc++-6.dll cygtasn1-6.dll cygticw-10.dll
> cygunistring-2.dll cyguuid-1.dll cyguv-1.dll cygwin-console-helper.exe
> cygwin1.dll cygxml2-2.dll cygxxhash-0.dll cygz.dll cygzstd-1.dll dash.exe
> date.exe dd.exe df.exe diff.exe diff3.exe dir.exe dircolors.exe dirname.exe
> dlltool.exe dllwrap.exe dnsdomainname domainname du.exe dumper.exe echo.exe
> editrights.exe egrep elfedit.exe env.exe eqn.exe eqn2graph ex expand.exe
> expr.exe f95 factor.exe false.exe fgrep fido2-assert.exe fido2-cred.exe
> fido2-token.exe file.exe find.exe flock.exe fmt.exe fold.exe g++.exe
> gawk-5.1.1.exe gawk.exe gcc-ar.exe gcc-nm.exe gcc-ranlib.exe gcc.exe
> gcov-dump.exe gcov-tool.exe gcov.exe gdiffmk gencat.exe getconf.exe
> getent.exe getfacl.exe getopt.exe gfortran.exe git-receive-pack.exe
> git-shell.exe git-upload-archive.exe git-upload-pack.exe git.exe gkill.exe
> gmondump.exe gprof.exe grap2graph grep.exe grn.exe grodvi.exe groff.exe
> grolbp.exe grolj4.exe grops.exe grotty.exe groups.exe gunzip gzexe gzip.exe
> head.exe hexdump.exe hostid.exe hostname.exe hpftodit.exe
> i686-w64-mingw32-pkg-config id.exe indxbib.exe info.exe infocmp.exe
> infotocap install-info.exe install.exe ipcmk.exe ipcrm.exe ipcs.exe
> isosize.exe join.exe kill.exe lastlog.exe ld.bfd.exe ld.exe ldd.exe ldh.exe
> less.exe lessecho.exe lesskey.exe lexgrog.exe libpython3.9.dll
> link-cygin.exe lkbib.exe ln.exe locale.exe locate.exe logger.exe login.exe
> logname.exe look.exe lookbib.exe ls.exe lsattr.exe lto-dump.exe lzcat lzcmp
> lzdiff lzegrep lzfgrep lzgrep lzless lzma lzmadec.exe lzmainfo.exe lzmore
> make-dummy-cert make.exe man-recode.exe man.exe mandb.exe manpath.exe
> mcookie.exe md5sum.exe minidumper.exe mintheme mintty.exe mkdir.exe
> mkfifo.exe mkgroup.exe mknod.exe mkpasswd.exe mkshortcut.exe mktemp.exe
> more.exe mount.exe mpic++ mpicc mpicxx mpiexec mpif77 mpif90 mpifort mpirun
> mv.exe namei.exe neqn nice.exe nl.exe nm.exe nohup.exe nproc.exe nroff
> numfmt.exe objcopy.exe objdump.exe od.exe ompi-clean ompi-server
> ompi_info.exe opal_wrapper.exe openssl.exe orte-clean.exe orte-info.exe
> orte-server.exe ortecc orted.exe orterun.exe p11-kit.exe passwd.exe
> paste.exe pathchk.exe pdfroff peflags.exe peflagsall perl.exe
> perl5.32.1.exe pfbtops.exe pg.exe pic.exe pic2graph pinky.exe pip3 pip3.9
> pkg-config pkgconf.exe pldd.exe post-grohtml.exe pr.exe pre-grohtml.exe
> preconv.exe printenv.exe printf.exe profiler.exe ps.exe ptx.exe pwd.exe
> pydoc3 pydoc3.9 python python3 python3.9.exe pzstd.exe ranlib.exe
> readelf.exe readlink.exe readshortcut.exe realpath.exe rebase-trigger
> rebase.exe rebaseall rebaselst refer.exe regtool.exe rename.exe
> renew-dummy-cert renice.exe reset rev.exe rm.exe rmdir.exe rsync-ssl
> rsync.exe run.exe runcon.exe rvi rview scalar.exe scp.exe script.exe
> scriptreplay.exe sdiff.exe sed.exe seq.exe setfacl.exe setmetamode.exe
> setsid.exe sftp.exe sh.exe sha1sum.exe sha224sum.exe sha256sum.exe
> sha384sum.exe sha512sum.exe shred.exe shuf.exe size.exe sleep.exe slogin
> soelim.exe sort.exe split.exe ssh-add.exe ssh-agent.exe ssh-copy-id
> ssh-host-config ssh-keygen.exe ssh-keyscan.exe ssh-user-config ssh.exe
> ssp.exe stat.exe stdbuf.exe strace.exe strings.exe strip.exe stty.exe
> sum.exe sync.exe tabs.exe tac.exe tail.exe tar.exe taskset.exe tbl.exe
> tee.exe test.exe tfmtodit.exe tic.exe timeout.exe toe.exe touch.exe
> tput.exe tr.exe troff.exe true.exe truncate.exe trust.exe tset.exe
> tsort.exe tty.exe tzselect tzset.exe ul.exe umount.exe uname.exe
> unexpand.exe uniq.exe unlink.exe unlzma unxz unzstd update-ca-trust
> update-crypto-policies updatedb users.exe uuidgen.exe uuidparse.exe
> vdir.exe vi.exe view wc.exe whatis.exe whereis.exe which.exe who.exe
> whoami.exe windmc.exe windres.exe x86_64-pc-cygwin-c++.exe
> x86_64-pc-cygwin-g++.exe x86_64-pc-cygwin-gcc-11.exe
> x86_64-pc-cygwin-gcc-ar.exe x86_64-pc-cygwin-gcc-nm.exe
> x86_64-pc-cygwin-gcc-ranlib.exe x86_64-pc-cygwin-gcc.exe
> x86_64-pc-cygwin-gfortran.exe x86_64-pc-cygwin-pkg-config
> x86_64-w64-mingw32-pkg-config xargs.exe xmlcatalog.exe xmllint.exe xz.exe
> xzcat xzcmp xzdec.exe xzdiff xzegrep xzfgrep xzgrep xzless xzmore yes.exe
> zcat zcmp zdiff zdump.exe zegrep zfgrep zforce zgrep zless zmore znew
> zstd.exe zstdcat zstdgrep zstdless zstdmt [.exe
>       /cygdrive/c/SIMULIA/Commands: abaqus.bat abq2018.bat
> abq_cae_open.bat abq_odb_open.bat
>       /cygdrive/c/Program Files/Microsoft MPI/Bin: mpiexec.exe
> mpitrace.man smpd.exe
> provthrd.dll provtool.exe ProximityCommon.dll ProximityCommonPal.dll
> ProximityRtapiPal.dll ProximityService.dll ProximityServicePal.dll
> ProximityToast ProximityUxHost.exe prproc.exe prvdmofcomp.dll psapi.dll
> pscript.sep PSHED.DLL psisdecd.dll psisrndr.ax PSModuleDis
> coveryProvider.dll psmodulediscoveryprovider.mof PsmServiceExtHost.dll
> psmsrv.dll psr.exe pstask.dll pstorec.dll pt-BR pt-PT ptpprov.dll
> puiapi.dll puiobj.dll PushToInstall.dll pwlauncher.dll pwlauncher.exe
> pwrshplugin.dll pwsso.dll qappsrv.exe qasf.dll qcap.dll qdv.
> dll qdvd.dll qedit.dll qedwipes.dll qmgr.dll qprocess.exe
> QualityUpdateAssistant.dll quartz.dll Query.dll query.exe
> QuickActionsDataModel.dll quickassist.exe QuietHours.dll quser.exe
> qwave.dll qwinsta.exe RacEngn.dll racpldlg.dll radardt.dll radarrs.dll
> RADCUI.dll ra
> s rasadhlp.dll rasapi32.dll rasauto.dll rasautou.exe raschap.dll
> raschapext.dll rasctrnm.h rasctrs.dll rascustom.dll rasdiag.dll rasdial.exe
> rasdlg.dll raserver.exe rasgcw.dll rasman.dll rasmans.dll rasmbmgr.dll
> RasMediaManager.dll RASMM.dll rasmontr.dll rasphone.exe
>  rasplap.dll rasppp.dll rastapi.dll rastls.dll rastlsext.dll RasToast
> rdbui.dll rdpbase.dll rdpcfgex.dll rdpclip.exe rdpcore.dll rdpcorets.dll
> rdpcredentialprovider.dll rdpencom.dll rdpendp.dll rdpinit.exe rdpinput.exe
> rdpnano.dll RdpRelayTransport.dll RdpSa.exe RdpS
> aProxy.exe RdpSaPs.dll RdpSaUacHelper.exe rdpserverbase.dll
> rdpsharercom.dll rdpshell.exe rdpsign.exe rdpudd.dll rdpviewerax.dll
> rdrleakdiag.exe RDSAppXHelper.dll rdsdwmdr.dll rdsxvmaudio.dll
> rdvvmtransport.dll RDXService.dll RDXTaskFactory.dll ReAgent.dll ReAgentc.e
> xe ReAgentTask.dll recdisc.exe recover.exe Recovery recovery.dll
> RecoveryDrive.exe refsutil.exe reg.exe regapi.dll RegCtrl.dll regedt32.exe
> regidle.dll regini.exe Register-CimProvider.exe regsvc.dll regsvr32.exe
> reguwpapi.dll ReInfo.dll rekeywiz.exe relog.exe RelPost
> .exe RemoteAppLifetimeManager.exe RemoteAppLifetimeManagerProxyStub.dll
> remoteaudioendpoint.dll remotepg.dll RemotePosWorker.exe remotesp.tsp
> RemoteWipeCSP.dll RemovableMediaProvisioningPlugin.dll Rem
> oveDeviceContextHandler.dll RemoveDeviceElevated.dll rendezvousSession.tlb
> repair-bde.exe replace.exe ReportingCSP.dll RESAMPLEDMO.DLL ResBParser.dll
> reset.exe reseteng.dll ResetEngine.dll ResetEngine.exe ResetEngOnline.dll
> resmon.exe ResourceMapper.dll ResourcePolic
> yClient.dll ResourcePolicyServer.dll ResPriHMImageList
> ResPriHMImageListLowCost ResPriImageList ResPriImageListLowCost
> RestartManager.mof RestartManagerUninstall.mof
> RestartNowPower_80.png Re
> RestartTonight_80_contrast-white.png restore resutils.dll rgb9rast.dll
> Ribbons.scr riched20.dll riched32.dll rilproxy.dll RjvMDMConfig.dll
> RMActivate.exe RMActivate_isv.exe RMActivate_ssp.exe RMActivate_ssp_isv
> .exe RMapi.dll rmclient.dll RmClient.exe RMSRoamingSecurity.dll
> rmttpmvscmgrsvr.exe rnr20.dll ro-RO RoamingSecurity.dll Robocopy.exe
> rometadata.dll RotMgr.dll ROUTE.EXE RpcEpMap.dll rpchttp.dll RpcNs4.dll
> rpcnsh.dll RpcPing.exe rpcrt4.dll RpcRtRemote.dll rpcss.dll rr
> installer.exe rsaenh.dll rshx32.dll rsop.msc RstMwEventLogMsg.dll
> RstrtMgr.dll rstrui.exe RtCOM64.dll RtDataProc64.dll rtffilt.dll
> RtkApi64U.dll RtkAudUService64.exe RtkCfg64.dll rtm.dll rtmcodecs.dll
> RTMediaFrame.dll rtmmvrortc.dll rtmpal.dll rtmpltfm.dll rtutils.dl
> l RTWorkQ.dll ru-RU RuleBasedDS.dll runas.exe rundll32.exe
> runexehelper.exe RunLegacyCPLElevated.exe runonce.exe RuntimeBroker.exe
> rwinsta.exe samcli.dll samlib.dll samsrv.dll Samsung sas.dll sbe.dll
> sbeio.dll sberes.dll sbservicetrigger.dll sc.exe ScanPlugin.dll sca
> nsetting.dll SCardBi.dll SCardDlg.dll SCardSvr.dll ScavengeSpace.xml
> scavengeui.dll ScDeviceEnum.dll scecli.dll scesrv.dll schannel.dll
> ScheduleTime_80.contrast-white.png ScheduleTime_80.png schtasks.exe sc
> ksp.dll scripto.dll ScriptRunner.exe scrnsave.scr scrobj.dll scrptadm.dll
> scrrun.dll sdbinst.exe sdchange.exe sdclt.exe sdcpl.dll SDDS.dll
> sdengin2.dll SDFHost.dll sdhcinst.dll sdiageng.dll sdiagnhost.exe
> sdiagprv.dll sdiagschd.dll sdohlp.dll sdrsvc.dll sdshext.dll S
> earch.ProtocolHandler.MAPI2.dll SearchFilterHost.exe SearchFolder.dll
> SearchIndexer.exe SearchProtocolHost.exe SebBackgroundManagerPolicy.dll
> SecConfig.efi SecEdit.exe sechost.dll secinit.exe seclogon.dll secpol.msc
> secproc.dll secproc_isv.dll secproc_ssp.dll secproc
> _ssp_isv.dll secur32.dll SecureAssessmentHandlers.dll SecureBootUpdates
> securekernel.exe SecureTimeAggregator.dll security.dll
> SecurityAndMaintenance_Error.png SecurityCenterBroker.dll
> SecurityCenterBrokerPS
> .dll SecurityHealthAgent.dll SecurityHealthHost.exe
> SecurityHealthProxyStub.dll SecurityHealthService.exe SecurityHealthSSO.dll
> SecurityHealthSystray.exe sedplugins.dll SEMgrPS.dll SEMgrSvc.dll
> sendmail.dll Sens.dll SensApi.dll SensorDataService.exe SensorPerformance
> Events.dll SensorsApi.dll SensorsClassExtension.dll SensorsCpl.dll
> SensorService.dll SensorsNativeApi.dll SensorsNativeApi.V2.dll
> SensorsUtilsV2.dll sensrsvc.dll serialui.dll services.exe services.msc
> ServicingUAPI.dll serwvdrv.dll SessEnv.dll sessionmsg.exe setbcdlo
> cale.dll sethc.exe SetNetworkLocation.dll SetNetworkLocationFlyout.dll
> SetProxyCredential.dll setspn.exe SettingMonitor.dll settings.dat
> SettingsEnvironment.Desktop.dll SettingsExtensibilityHandlers.dll
> SettingsHandlers_Accessibility.dll SettingsHandlers_AnalogShell.
> dll SettingsHandlers_AppControl.dll SettingsHandlers_AppExecutionAlias.dll
> SettingsHandlers_AssignedAccess.dll SettingsHandlers_Authentication.dll
> SettingsHandlers_BackgroundApps.dll SettingsHandlers_BatteryUsage.dll
> SettingsHandlers_BrowserDeclutter.dll SettingsHand
> lers_CapabilityAccess.dll SettingsHandlers_Clipboard.dll
> SettingsHandlers_ClosedCaptioning.dll
> SettingsHandlers_ContentDeliveryManager.dll SettingsHandlers_Cortana.dll
> SettingsHandlers_Devices.dll SettingsHandlers_Display.dll
> SettingsHandlers_Flights.dll SettingsHand
> lers_Fonts.dll SettingsHandlers_ForceSync.dll SettingsHandlers_Gaming.dll
> SettingsHandlers_Geolocation.dll SettingsHandlers_Gpu.dll
> SettingsHandlers_HoloLens_Environment.dll SettingsHandlers_IME.dll
> SettingsHandlers_InkingTypingPrivacy.dll SettingsHandlers_InputPerso
> nalization.dll SettingsHandlers_Language.dll
> SettingsHandlers_ManagePhone.dll SettingsHandlers_Maps.dll
> SettingsHandlers_Mouse.dll SettingsHandlers_Notifications.dll
> SettingsHandlers_nt.dll SettingsHandlers_OneCore_BatterySaver.dll
> SettingsHandlers_OneCore_PowerAndSl
> eep.dll SettingsHandlers_OneDriveBackup.dll
> SettingsHandlers_OptionalFeatures.dll SettingsHandlers_PCDisplay.dll
> SettingsHandlers_Pen.dll SettingsHandlers_QuickActions.dll
> SettingsHandlers_Region.dll SettingsHandlers_SharedExperiences_Rome.dll
> SettingsHandlers_SIUF.d
> ll SettingsHandlers_SpeechPrivacy.dll SettingsHandlers_Startup.dll
> SettingsHandlers_StorageSense.dll SettingsHandlers_Troubleshoot.dll
> SettingsHandlers_User.dll SettingsHandlers_UserAccount.dll
> SettingsHandlers_UserExperience.dll SettingsHandlers_WorkAccess.dll Setti
> ngSync.dll SettingSyncCore.dll SettingSyncDownloadHelper.dll
> SettingSyncHost.exe setup setupapi.dll setupcl.dll setupcl.exe setupcln.dll
> setupetw.dll setupugc.exe setx.exe sfc.dll sfc.exe sfc_os.dll Sgrm
> SgrmBroker.exe SgrmEnclave.dll SgrmEnclave_secure.dll SgrmLpac.
> exe shacct.dll shacctprofile.dll SharedPCCSP.dll SharedRealitySvc.dll
> ShareHost.dll sharemediacpl.dll SHCore.dll shdocvw.dll shell32.dll
> ShellAppRuntime.exe ShellCommonCommonProxyStub.dll ShellExperiences
> shellstyle.dll shfolder.dll shgina.dll ShiftJIS.uce shimeng.dl
> l shimgvw.dll shlwapi.dll shpafact.dll shrpubw.exe shsetup.dll shsvcs.dll
> shunimpl.dll shutdown.exe shutdownext.dll shutdownux.dll shwebsvc.dll si-lk
> signdrv.dll sigverif.exe SIHClient.exe sihost.exe SimAuth.dll SimCfg.dll
> simpdata.tlb sk-SK skci.dll sl-SI slc.dll sl
> cext.dll SleepStudy SlideToShutDown.exe slmgr slmgr.vbs slui.exe slwga.dll
> SmallRoom.bin SmartCardBackgroundPolicy.dll SmartcardCredentialProvider.dll
> SmartCardSimulator.dll smartscreen.exe smartscreenps.dll SMBHelperClass.dll
> smbwmiv2.dll SMI SmiEngine.dll smphost.d
> ll SmsRouterSvc.dll smss.exe SndVol.exe SndVolSSO.dll SnippingTool.exe
> Snooze_80.contrast-white.png Snooze_80.png socialapis.dll softkbd.dll
> softpub.dll sort.exe SortServer2003Compat.dll SortWindows61.dll SortWind
> ows62.dll SortWindows64.dll SortWindows6Compat.dll SpaceAgent.exe
> spacebridge.dll SpaceControl.dll spaceman.exe SpatialAudioLicenseSrv.exe
> SpatializerApo.dll SpatialStore.dll spbcd.dll
> Spectrum.ex
> e SpectrumSyncClient.dll Speech SpeechPal.dll Speech_OneCore spfileq.dll
> spinf.dll spmpm.dll spnet.dll spool spoolss.dll spoolsv.exe spopk.dll spp
> spp.dll sppc.dll sppcext.dll sppcomapi.dll sppcommdlg.dll SppExtComObj.Exe
> sppinst.dll sppnp.dll sppobjs.dll sppsvc.exe
> sppui sppwinob.dll sppwmi.dll spwinsat.dll spwizeng.dll spwizimg.dll
> spwizres.dll spwmp.dll SqlServerSpatial130.dll SqlServerSpatial150.dll
> sqlsrv32.dll sqlsrv32.rll sqmapi.dll sr-Latn-RS srchadmin.dll srclient.dll
> srcore.dll srdelayed.exe SrEvents.dll SRH.dll srhelp
> er.dll srm.dll srmclient.dll srmlib.dll srms-apr-v.dat srms-apr.dat
> srms.dat srmscan.dll srmshell.dll srmstormod.dll srmtrace.dll srm_ps.dll
> srpapi.dll SrpUxNativeSnapIn.dll srrstr.dll SrTasks.exe sru srumapi.dll
> srumsvc.dll srvcli.dll srvsvc.dll srwmi.dll sscore.dll
>  sscoreext.dll ssdm.dll ssdpapi.dll ssdpsrv.dll sspicli.dll sspisrv.dll
> SSShim.dll ssText3d.scr sstpsvc.dll StartTileData.dll Startupscan.dll
> StateRepository.Core.dll stclient.dll stdole2.tlb stdole32.tlb sti.dll
> sti_ci.dll stobject.dll StorageContextHandler.dll Stor
> ageUsage.dll storagewmi.dll storagewmi_passthru.dll stordiag.exe
> storewuauth.dll Storprop.dll StorSvc.dll streamci.dll
> StringFeedbackEngine.dll StructuredQuery.dll SubRange.uce subst.exe sud.dll
> sv-SE SvBannerBackground.png svchost.exe svf.dll svsvc.dll SwitcherDataM
> odel.dll swprv.dll sxproxy.dll sxs.dll sxshared.dll sxssrv.dll
> sxsstore.dll sxstrace.exe SyncAppvPublishingServer.exe
> SyncAppvPublishingServer.vbs SyncCenter.dll SyncController.dll SyncHost.exe
> SyncHostps.dll SyncInfrastructure.dll SyncInfrastructureps.dll SyncProxy.
> dll Syncreg.dll SyncRes.dll SyncSettings.dll syncutil.dll sysclass.dll
> sysdm.cpl SysFxUI.dll sysmain.dll sysmon.ocx sysntfy.dll Sysprep
> sysprint.sep sysprtj.sep SysResetErr.exe syssetup.dll systemcpl.dll
> SystemEventsBrokerClient.dll SystemEventsBrokerServer.dll syste
> minfo.exe SystemPropertiesAdvanced.exe SystemPropertiesComputerName.exe
> SystemPropertiesDataExecutionPrevention.exe SystemPropertiesHardware.exe
> SystemPropertiesPerformance.exe SystemPropertiesProtection.exe
> SystemPropertiesRemote.exe systemreset.exe SystemResetPlatf
> orm SystemSettings.DataModel.dll
> SystemSettings.DeviceEncryptionHandlers.dll SystemSettings.Handlers.dll
> SystemSettings.SettingsExtensibility.dll
> SystemSettings.UserAccountsHandlers.dll SystemSettingsAdminFlows.exe
> SystemSettingsBroker.exe SystemSettingsRemoveDevice.
> exe SystemSettingsThresholdAdminFlowUI.dll SystemSupportInfo.dll
> SystemUWPLauncher.exe systray.exe t2embed.dll ta-in ta-lk Tabbtn.dll
> TabbtnEx.dll tabcal.exe TabletPC.cpl TabSvc.dll takeown.exe tapi3.dll
> tapi32.dll tapilua.dll TapiMigPlugin.dll tapiperf.dll tapisrv.d
> ll TapiSysprep.dll tapiui.dll TapiUnattend.exe tar.exe TaskApis.dll
> taskbarcpl.dll taskcomp.dll TaskFlowDataEngine.dll taskhostw.exe
> taskkill.exe tasklist.exe Taskmgr.exe Tasks taskschd.dll taskschd.msc
> TaskSchdPS.dll tbauth.dll tbs.dll tcblaunch.exe tcbloader.dll tc
> msetup.exe tcpbidi.xml tcpipcfg.dll tcpmib.dll tcpmon.dll tcpmon.ini
> tcpmonui.dll TCPSVCS.EXE tdc.ocx tdh.dll TDLMigration.dll
> TEEManagement64.dll telephon.cpl TelephonyInteractiveUser.dll
> TelephonyInteractiveUserRes.dll tellib.dll
> TempSignedLicenseExchangeTask.dll T
> enantRestrictionsPlugin.dll termmgr.dll termsrv.dll tetheringclient.dll
> tetheringconfigsp.dll TetheringIeProvider.dll TetheringMgr.dll
> tetheringservice.dll TetheringStation.dll TextInputFramework.dll
> TextInputMethodFormatter.dll TextShaping.dll th-TH themecpl.dll The
> mes.SsfDownload.ScheduledTask.dll themeservice.dll themeui.dll
> ThirdPartyNoticesBySHS.txt threadpoolwinrt.dll thumbcache.dll
> ThumbnailExtractionHost.exe ti-et tier2punctuations.dll
> TieringEngineProxy.dll TieringEngineService.exe TileDataRepository.dll
> TimeBrokerClien
> t.dll TimeBrokerServer.dll timedate.cpl TimeDateMUICallback.dll
> timeout.exe timesync.dll TimeSyncTask.dll TKCtrl2k64.sys TKFsAv64.sys
> TKFsFt64.sys TKFWFV.inf TKFWFV64.cat TKFWFV64.sys tkfwvt64.sys
> TKIdsVt64.sys TKPcFtCb64.sys TKPcFtCb64.sys_ TKPcFtHk64.sys TKRgAc2k64
> .sys TKRgFtXp64.sys TKTool2k.sys TKTool2k64.sys tlscsp.dll
> tokenbinding.dll TokenBroker.dll TokenBrokerCookies.exe TokenBrokerUI.dll
> tpm.msc TpmCertResources.dll tpmcompc.dll TpmCoreProvisioning.dll
> TpmInit.exe TpmTasks.dll TpmTool.exe tpmvsc.dll tpmvscmgr.exe tpmvsc
> mgrsvr.exe tquery.dll tr-TR tracerpt.exe TRACERT.EXE traffic.dll
> TransformPPSToWlan.xslt TransformPPSToWlanCredentials.xslt
> TransliterationRanker.dll TransportDSA.dll tree.com trie.dll trkwks.dll
> TrustedSignalCredProv.dll tsbyuv.dll tscfgwmi.dll tscon.exe tsdiscon.ex
> e TSErrRedir.dll tsf3gip.dll tsgqec.dll tskill.exe tsmf.dll TSpkg.dll
> tspubwmi.dll TSSessionUX.dll tssrvlic.dll TSTheme.exe
> TsUsbGDCoInstaller.dll TsUsbRedirectionGroupPolicyExtension.dll
> TSWbPrxy.exe TSWorkspace.dll TsWpfWrp.exe ttdinject.exe ttdloader.dll
> ttdplm.dl
> l ttdrecord.dll ttdrecordcpu.dll TtlsAuth.dll TtlsCfg.dll TtlsExt.dll
> tttracer.exe tvratings.dll twext.dll twinapi.appcore.dll twinapi.dll
> twinui.appcore.dll twinui.dll twinui.pcshell.dll txflog.dll txfw32.dll
> typeperf.exe tzautoupdate.dll tzres.dll tzsync.exe tzsync
> res.dll tzutil.exe ubpm.dll ucmhc.dll ucrtbase.dll ucrtbased.dll
> ucrtbase_clr0400.dll ucrtbase_enclave.dll ucsvc.exe udhisapi.dll uDWM.dll
> UefiCsp.dll UevAgentPolicyGenerator.exe UevAppMonitor.exe
> UevAppMonitor.exe.config UevCustomActionTypes.tlb UevTemplateBaselineG
> enerator.exe UevTemplateConfigItemGenerator.exe uexfat.dll ufat.dll
> UiaManager.dll UIAnimation.dll UIAutomationCore.dll uicom.dll
> UIManagerBrokerps.dll UIMgrBroker.exe uireng.dll UIRibbon.dll
> UIRibbonRes.dll uk-UA ulib.dll umb.dll umdmxfrm.dll umpdc.dll umpnpmgr.dll
> umpo-overrides.dll umpo.dll umpoext.dll umpowmi.dll umrdp.dll unattend.dll
> unenrollhook.dll unimdm.tsp unimdmat.dll uniplat.dll Unistore.dll
> unlodctr.exe UNP unregmp2.exe untfs.dll UpdateAgent.dll updatecsp.dll
> UpdateDeploymentProvider.dll UpdateHeartbeat.dll updatep
> olicy.dll upfc.exe UpgradeResultsUI.exe upnp.dll upnpcont.exe upnphost.dll
> UPPrinterInstaller.exe UPPrinterInstallsCSP.dll upshared.dll uReFS.dll
> uReFSv1.dll ureg.dll url.dll urlmon.dll UsbCApi.dll usbceip.dll usbmon.dll
> usbperf.dll UsbPmApi.dll UsbSettingsHandlers.d
> ll UsbTask.dll usbui.dll user32.dll UserAccountBroker.exe
> UserAccountControlSettings.dll UserAccountControlSettings.exe
> useractivitybroker.dll usercpl.dll UserDataAccessRes.dll
> UserDataAccountApis.dll UserDataLanguageUtil.dll
> UserDataPlatformHelperUtil.dll UserDataSe
> rvice.dll UserDataTimeUtil.dll UserDataTypeHelperUtil.dll
> UserDeviceRegistration.dll UserDeviceRegistration.Ngc.dll userenv.dll
> userinit.exe userinitext.dll UserLanguageProfileCallback.dll usermgr.dll
> usermgrcli.dll UserMgrProxy.dll usk.rs usoapi.dll UsoClient.exe us
> ocoreps.dll usocoreworker.exe usosvc.dll usp10.dll ustprov.dll
> UtcDecoderHost.exe UtcManaged.dll utcutil.dll utildll.dll Utilman.exe
> uudf.dll UvcModel.dll uwfcfgmgmt.dll uwfcsp.dll uwfservicingapi.dll
> UXInit.dll uxlib.dll uxlibres.dll uxtheme.dll vac.dll VAN.dll Vaul
> t.dll VaultCDS.dll vaultcli.dll VaultCmd.exe VaultRoaming.dll vaultsvc.dll
> VBICodec.ax vbisurf.ax vbsapi.dll vbscript.dll vbssysprep.dll
> vcamp120.dll vcamp140.dll vcamp140d.dll VCardParser.dll vccorlib110.dll
> vccorlib120.dll vccorlib140.dll vccorlib140d.dll vcomp100.
> dll vcomp110.dll vcomp120.dll vcomp140.dll vcomp140d.dll vcruntime140.dll
> vcruntime140d.dll vcruntime140_1.dll vcruntime140_1d.dll
> vcruntime140_clr0400.dll vds.exe vdsbas.dll vdsdyn.dll vdsldr.exe
> vdsutil.dll vdsvd.dll vds_ps.dll verclsid.exe verifier.dll verifier.ex
> e verifiergui.exe version.dll vertdll.dll vfbasics.dll vfcompat.dll
> vfcuzz.dll vfluapriv.dll vfnet.dll vfntlmless.dll vfnws.dll vfprint.dll
> vfprintpthelper.dll vfrdvcompat.dll vfuprov.dll vfwwdm32.dll VhfUm.dll
> vid.dll vidcap.ax VideoHandlers.dll VIDRESZR.DLL virtdis
> k.dll VirtualMonitorManager.dll VmApplicationHealthMonitorProxy.dll
> vmbuspipe.dll vmdevicehost.dll vmictimeprovider.dll vmrdvcore.dll
> VocabRoamingHandler.dll VoiceActivationManager.dll VoipRT.dll vpnike.dll
> vpnikeapi.dll VpnSohDesktop.dll VPNv2CSP.dll vrfcore.dll Vsc
> MgrPS.dll vscover160.dll VSD3DWARPDebug.dll VsGraphicsCapture.dll
> VsGraphicsDesktopEngine.exe VsGraphicsExperiment.dll VsGraphicsHelper.dll
> VsGraphicsProxyStub.dll VsGraphicsRemoteEngine.exe vsjitdebugger.exe
> VSPerf160.dll vssadmin.exe vssapi.dll vsstrace.dll VSSVC.e
> xe vss_ps.dll vulkan-1-999-0-0-0.dll vulkan-1.dll
> vulkaninfo-1-999-0-0-0.exe vulkaninfo.exe w32time.dll w32tm.exe w32topl.dll
> WaaSAssessment.dll WaaSMedicAgent.exe WaaSMedicCapsule.dll WaaSMedicPS.dll
> WaaSMedicSvc.dll WABSyncProvider.dll waitfor.exe WalletBackgroundS
> erviceProxy.dll WalletProxy.dll WalletService.dll WallpaperHost.exe
> wavemsp.dll wbadmin.exe wbem wbemcomn.dll wbengine.exe wbiosrvc.dll wci.dll
> wcimage.dll wcmapi.dll wcmcsp.dll wcmsvc.dll WCN WcnApi.dll wcncsvc.dll
> WcnEapAuthProxy.dll WcnEapPeerProxy.dll WcnNetsh.dl
> l wcnwiz.dll wc_storage.dll wdc.dll WDI wdi.dll wdigest.dll wdmaud.drv
> wdscore.dll WdsUnattendTemplate.xml WEB.rs webauthn.dll WebcamUi.dll
> webcheck.dll WebClnt.dll webio.dll webplatstorageserver.dll
> WebRuntimeManager.dll webservices.dll Websocket.dll wecapi.dll wecs
> vc.dll wecutil.exe wephostsvc.dll wer.dll werconcpl.dll wercplsupport.dll
> werdiagcontroller.dll WerEnc.dll weretw.dll WerFault.exe WerFaultSecure.exe
> wermgr.exe wersvc.dll werui.dll wevtapi.dll wevtfwd.dll wevtsvc.dll
> wevtutil.exe wextract.exe WF.msc wfapigp.dll wfdp
> rov.dll WFDSConMgr.dll WFDSConMgrSvc.dll WfHC.dll WFS.exe WFSR.dll
> whealogr.dll where.exe whhelper.dll whoami.exe wiaacmgr.exe wiaaut.dll
> wiadefui.dll wiadss.dll WiaExtensionHost64.dll wiarpc.dll
> wiascanprofiles.dll wiaservc.dll wiashext.dll wiatrace.dll wiawow64.exe
>  WiFiCloudStore.dll WiFiConfigSP.dll wifidatacapabilityhandler.dll
> WiFiDisplay.dll wifinetworkmanager.dll wifitask.exe WimBootCompress.ini
> wimgapi.dll wimserv.exe win32appinventorycsp.dll
> Win32AppSettingsProvider.dll Win32CompatibilityAppraiserCSP.dll win32k.sys
> win3
> 2kbase.sys win32kfull.sys win32kns.sys win32spl.dll win32u.dll
> Win32_DeviceGuard.dll winbio.dll WinBioDatabase WinBioDataModel.dll
> WinBioDataModelOOBE.exe winbioext.dll WinBioPlugIns winbrand.dll
> wincorlib.dll wincredprovider.dll wincredui.dll WindowManagement.dll Wi
> ndowManagementAPI.dll Windows.AccountsControl.dll
> Windows.AI.MachineLearning.dll Windows.AI.MachineLearning.Preview.dll
> Windows.ApplicationModel.Background.SystemEventsBroker.dll
> Windows.ApplicationModel.Background.TimeBroker.dll
> Windows.ApplicationModel.Conversation
> alAgent.dll
> windows.applicationmodel.conversationalagent.internal.proxystub.dll
> windows.applicationmodel.conversationalagent.proxystub.dll
> Windows.ApplicationModel.Core.dll windows.applicationmodel.datatransfer.dll
> Windows.ApplicationModel.dll Windows.ApplicationMode
> l.LockScreen.dll Windows.ApplicationModel.Store.dll
> Windows.ApplicationModel.Store.Preview.DOSettings.dll
> Windows.ApplicationModel.Store.TestingFramework.dll
> Windows.ApplicationModel.Wallet.dll Windows.CloudStore.dll
> Windows.CloudStore.Schema.DesktopShell.dll Windows
> .CloudStore.Schema.Shell.dll Windows.Cortana.Desktop.dll
> Windows.Cortana.OneCore.dll Windows.Cortana.ProxyStub.dll
> Windows.Data.Activities.dll Windows.Data.Pdf.dll
> Windows.Devices.AllJoyn.dll Windows.Devices.Background.dll
> Windows.Devices.Background.ps.dll Windows.De
> vices.Bluetooth.dll Windows.Devices.Custom.dll
> Windows.Devices.Custom.ps.dll Windows.Devices.Enumeration.dll
> Windows.Devices.Haptics.dll Windows.Devices.HumanInterfaceDevice.dll
> Windows.Devices.Lights.dll Windows.Devices.LowLevel.dll
> Windows.Devices.Midi.dll Windows.
> Devices.Perception.dll Windows.Devices.Picker.dll
> Windows.Devices.PointOfService.dll Windows.Devices.Portable.dll
> Windows.Devices.Printers.dll Windows.Devices.Printers.Extensions.dll
> Windows.Devices.Radios.dll Windows.Devices.Scanners.dll
> Windows.Devices.Sensors.dll
> Windows.Devices.SerialCommunication.dll Windows.Devices.SmartCards.dll
> Windows.Devices.SmartCards.Phone.dll Windows.Devices.Usb.dll
> Windows.Devices.WiFi.dll Windows.Devices.WiFiDirect.dll Windows.Energy.dll
> Windows.FileExplorer.Common.dll Windows.Gaming.Input.dll Win
> dows.Gaming.Preview.dll Windows.Gaming.UI.GameBar.dll
> Windows.Gaming.XboxLive.Storage.dll Windows.Globalization.dll
> Windows.Globalization.Fontgroups.dll
> Windows.Globalization.PhoneNumberFormatting.dll
> Windows.Graphics.Display.BrightnessOverride.dll Windows.Graphics.D
> isplay.DisplayEnhancementOverride.dll Windows.Graphics.dll
> Windows.Graphics.Printing.3D.dll Windows.Graphics.Printing.dll
> Windows.Graphics.Printing.Workflow.dll
> Windows.Graphics.Printing.Workflow.Native.dll Windows.Help.Runtime.dll
> windows.immersiveshell.serviceprovi
> der.dll Windows.Internal.AdaptiveCards.XamlCardRenderer.dll
> Windows.Internal.Bluetooth.dll Windows.Internal.CapturePicker.Desktop.dll
> Windows.Internal.CapturePicker.dll Windows.Internal.Devices.Sensors.dll
> Windows.Internal.Feedback.Analog.dll Windows.Internal.Feedbac
> k.Analog.ProxyStub.dll
> Windows.Internal.Graphics.Display.DisplayColorManagement.dll
> Windows.Internal.Graphics.Display.DisplayEnhancementManagement.dll
> Windows.Internal.Management.dll
> Windows.Internal.Management.SecureAssessment.dll
> Windows.Internal.PlatformExtension.
> DevicePickerExperience.dll
> Windows.Internal.PlatformExtension.MiracastBannerExperience.dll
> Windows.Internal.PredictionUnit.dll
> Windows.Internal.Security.Attestation.DeviceAttestation.dll
> Windows.Internal.SecurityMitigationsBroker.dll
> Windows.Internal.Shell.Broker.dll
>  windows.internal.shellcommon.AccountsControlExperience.dll
> windows.internal.shellcommon.AppResolverModal.dll
> Windows.Internal.ShellCommon.Broker.dll
> windows.internal.shellcommon.FilePickerExperienceMEM.dll
> Windows.Internal.ShellCommon.PrintExperience.dll windows.int
> ernal.shellcommon.shareexperience.dll
> windows.internal.shellcommon.TokenBrokerModal.dll
> Windows.Internal.Signals.dll Windows.Internal.System.UserProfile.dll
> Windows.Internal.Taskbar.dll
> Windows.Internal.UI.BioEnrollment.ProxyStub.dll
> Windows.Internal.UI.Logon.ProxySt
> ub.dll Windows.Internal.UI.Shell.WindowTabManager.dll
> Windows.Management.EnrollmentStatusTracking.ConfigProvider.dll
> Windows.Management.InprocObjects.dll
> Windows.Management.ModernDeployment.ConfigProviders.dll
> Windows.Management.Provisioning.ProxyStub.dll Windows.Man
> agement.SecureAssessment.CfgProvider.dll
> Windows.Management.SecureAssessment.Diagnostics.dll
> Windows.Management.Service.dll Windows.Management.Workplace.dll
> Windows.Management.Workplace.WorkplaceSettings.dll Windows.Media.Audio.dll
> Windows.Media.BackgroundMediaPlayba
> ck.dll Windows.Media.BackgroundPlayback.exe Windows.Media.Devices.dll
> Windows.Media.dll Windows.Media.Editing.dll Windows.Media.FaceAnalysis.dll
> Windows.Media.Import.dll Windows.Media.MediaControl.dll
> Windows.Media.MixedRealityCapture.dll Windows.Media.Ocr.dll Window
> s.Media.Playback.BackgroundMediaPlayer.dll
> Windows.Media.Playback.MediaPlayer.dll Windows.Media.Playback.ProxyStub.dll
> Windows.Media.Protection.PlayReady.dll Windows.Media.Renewal.dll
> Windows.Media.Speech.dll Windows.Media.Speech.UXRes.dll
> Windows.Media.Streaming.dll
>  Windows.Media.Streaming.ps.dll Windows.Mirage.dll
> Windows.Mirage.Internal.Capture.Pipeline.ProxyStub.dll
> Windows.Mirage.Internal.dll
> Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll
> Windows.Networking.BackgroundTransfer.ContentPrefetchTask.dll Windo
> ws.Networking.BackgroundTransfer.dll Windows.Networking.Connectivity.dll
> Windows.Networking.dll Windows.Networking.HostName.dll
> Windows.Networking.NetworkOperators.ESim.dll
> Windows.Networking.NetworkOperators.HotspotAuthentication.dll
> Windows.Networking.Proximity.dll
>  Windows.Networking.ServiceDiscovery.Dnssd.dll
> Windows.Networking.Sockets.PushEnabledApplication.dll
> Windows.Networking.UX.EapRequestHandler.dll Windows.Networking.Vpn.dll
> Windows.Networking.XboxLive.ProxyStub.dll Windows.Payments.dll
> Windows.Perception.Stub.dll Wind
> ows.Security.Authentication.Identity.Provider.dll
> Windows.Security.Authentication.OnlineId.dll
> Windows.Security.Authentication.Web.Core.dll
> Windows.Security.Credentials.UI.CredentialPicker.dll
> Windows.Security.Credentials.UI.UserConsentVerifier.dll Windows.Security.I
> ntegrity.dll Windows.Services.TargetedContent.dll
> Windows.SharedPC.AccountManager.dll Windows.SharedPC.CredentialProvider.dll
> Windows.Shell.BlueLightReduction.dll Windows.Shell.ServiceHostBuilder.dll
> Windows.Shell.StartLayoutPopulationEvents.dll Windows.StateReposito
> ry.dll Windows.StateRepositoryBroker.dll Windows.StateRepositoryClient.dll
> Windows.StateRepositoryCore.dll Windows.StateRepositoryPS.dll
> Windows.StateRepositoryUpgrade.dll Windows.Storage.ApplicationData.dll
> Windows.Storage.Compression.dll windows.storage.dll Windows
> .Storage.OneCore.dll Windows.Storage.Search.dll
> Windows.System.Diagnostics.dll
> Windows.System.Diagnostics.Telemetry.PlatformTelemetryClient.dll
> Windows.System.Diagnostics.TraceReporting.PlatformDiagnosticActions.dll
> Windows.System.Launcher.dll Windows.System.Profile.
> HardwareId.dll
> Windows.System.Profile.PlatformDiagnosticsAndUsageDataSettings.dll
> Windows.System.Profile.RetailInfo.dll Windows.System.Profile.SystemId.dll
> Windows.System.Profile.SystemManufacturers.dll
> Windows.System.RemoteDesktop.dll Windows.System.SystemManagement
> .dll Windows.System.UserDeviceAssociation.dll
> Windows.System.UserProfile.DiagnosticsSettings.dll
> Windows.UI.Accessibility.dll Windows.UI.AppDefaults.dll
> Windows.UI.BioFeedback.dll Windows.UI.BlockedShutdown.dll
> Windows.UI.Core.TextInput.dll Windows.UI.Cred.dll Window
> s.UI.CredDialogController.dll Windows.UI.dll Windows.UI.FileExplorer.dll
> Windows.UI.Immersive.dll Windows.UI.Input.Inking.Analysis.dll
> Windows.UI.Input.Inking.dll Windows.UI.Internal.Input.ExpressiveInput.dll
> Windows.UI.Internal.Input.ExpressiveInput.Resource.dll Win
> dows.UI.Logon.dll Windows.UI.NetworkUXController.dll
> Windows.UI.PicturePassword.dll Windows.UI.Search.dll Windows.UI.Shell.dll
> Windows.UI.Shell.Internal.AdaptiveCards.dll Windows.UI.Storage.dll
> Windows.UI.Xaml.Controls.dll Windows.UI.Xaml.dll Windows.UI.Xaml.InkContr
> ols.dll Windows.UI.Xaml.Maps.dll Windows.UI.Xaml.Phone.dll
> Windows.UI.Xaml.Resources.19h1.dll Windows.UI.Xaml.Resources.Common.dll
> Windows.UI.Xaml.Resources.rs1.dll Windows.UI.Xaml.Resources.rs2.dll
> Windows.UI.Xaml.Resources.rs3.dll Windows.UI.Xaml.Resources.rs4.dll
> Windows.UI.Xaml.Resources.rs5.dll Windows.UI.Xaml.Resources.th.dll
> Windows.UI.Xaml.Resources.win81.dll Windows.UI.Xaml.Resources.win8rtm.dll
> Windows.UI.XamlHost.dll Windows.WARP.JITService.dll
> Windows.WARP.JITService.exe Windows.Web.Diagnostics.dll Windows.Web.dll Wi
> ndows.Web.Http.dll WindowsActionDialog.exe WindowsCodecs.dll
> WindowsCodecsExt.dll WindowsCodecsRaw.dll WindowsCodecsRaw.txt
> WindowsDefaultHeatProcessor.dll windowsdefenderapplicationguardcsp.dll
> WindowsInternal.ComposableShell.ComposerFramework.dll WindowsInternal.Co
> mposableShell.DesktopHosting.dll
> WindowsInternal.Shell.CompUiActivation.dll WindowsIoTCsp.dll
> windowslivelogin.dll WindowsManagementServiceWinRt.ProxyStub.dll
> windowsperformancerecordercontrol.dll WindowsPowerShell
> WindowsSecurityIcon.png windowsudk.shellcommon.dll W
> indowsUpdateElevatedInstaller.exe winethc.dll winevt WinFax.dll
> winhttp.dll winhttpcom.dll WinHvEmulation.dll WinHvPlatform.dll wininet.dll
> wininetlui.dll wininit.exe wininitext.dll winipcfile.dll winipcsecproc.dll
> winipsec.dll winjson.dll Winlangdb.dll winload.efi w
> inload.exe winlogon.exe winlogonext.dll winmde.dll WinMetadata winml.dll
> winmm.dll winmmbase.dll winmsipc.dll WinMsoIrmProtector.dll winnlsres.dll
> winnsi.dll WinOpcIrmProtector.dll WinREAgent.dll winresume.efi
> winresume.exe winrm winrm.cmd winrm.vbs winrnr.dll winrs.
> exe winrscmd.dll winrshost.exe winrsmgr.dll winrssrv.dll
> WinRTNetMUAHostServer.exe WinRtTracing.dll WinSAT.exe WinSATAPI.dll
> WinSCard.dll WinSetupUI.dll winshfhc.dll winsku.dll winsockhc.dll
> winspool.drv winsqlite3.dll WINSRPC.DLL winsrv.dll winsrvext.dll winsta.dll
> WinSync.dll WinSyncMetastore.dll WinSyncProviders.dll wintrust.dll
> WinTypes.dll winusb.dll winver.exe WiredNetworkCSP.dll wisp.dll
> witnesswmiv2provider.dll wkscli.dll wkspbroker.exe wkspbrokerAx.dll
> wksprt.exe wksprtPS.dll wkssvc.dll wlanapi.dll wlancfg.dll WLanConn.
> dll wlandlg.dll wlanext.exe wlangpui.dll WLanHC.dll wlanhlp.dll
> WlanMediaManager.dll WlanMM.dll wlanmsm.dll wlanpref.dll
> WlanRadioManager.dll wlansec.dll wlansvc.dll wlansvcpal.dll wlanui.dll
> wlanutil.dll Wldap32.dll wldp.dll wlgpclnt.dll wlidcli.dll wlidcredprov.dll
>  wlidfdp.dll wlidnsp.dll wlidprov.dll wlidres.dll wlidsvc.dll wlrmdr.exe
> WMADMOD.DLL WMADMOE.DLL WMALFXGFXDSP.dll WMASF.DLL wmcodecdspps.dll
> wmdmlog.dll wmdmps.dll wmdrmsdk.dll wmerror.dll wmi.dll wmiclnt.dll
> wmicmiplugin.dll wmidcom.dll wmidx.dll WmiMgmt.msc wmiprop
> .dll wmitomi.dll WMNetMgr.dll wmp.dll WMPDMC.exe WmpDui.dll wmpdxm.dll
> wmpeffects.dll WMPhoto.dll wmploc.DLL wmpps.dll wmpshell.dll wmsgapi.dll
> WMSPDMOD.DLL WMSPDMOE.DLL WMVCORE.DLL WMVDECOD.DLL wmvdspa.dll WMVENCOD.DLL
> WMVSDECD.DLL WMVSENCD.DLL WMVXENCD.DLL WofTasks
> .dll WofUtil.dll WordBreakers.dll WorkFolders.exe WorkfoldersControl.dll
> WorkFoldersGPExt.dll WorkFoldersRes.dll WorkFoldersShell.dll
> workfolderssvc.dll wosc.dll wow64.dll wow64cpu.dll wow64win.dll
> wowreg32.exe WpAXHolder.dll wpbcreds.dll Wpc.dll WpcApi.dll wpcatltoa
> st.png WpcDesktopMonSvc.dll WpcMon.exe wpcmon.png WpcProxyStubs.dll
> WpcRefreshTask.dll WpcTok.exe WpcWebFilter.dll wpdbusenum.dll WpdMtp.dll
> WpdMtpUS.dll wpdshext.dll WPDShextAutoplay.exe WPDShServiceObj.dll
> WPDSp.dll wpd_ci.dll wpnapps.dll wpnclient.dll wpncore.dll
> wpninprc.dll wpnpinst.exe wpnprv.dll wpnservice.dll wpnsruprov.dll
> WpnUserService.dll WpPortingLibrary.dll WppRecorderUM.dll wpr.config.xml
> wpr.exe WPTaskScheduler.dll wpx.dll write.exe ws2help.dll ws2_32.dll
> wscadminui.exe wscapi.dll wscinterop.dll wscisvif.dll WSCl
> ient.dll WSCollect.exe wscproxystub.dll wscript.exe wscsvc.dll wscui.cpl
> WSDApi.dll wsdchngr.dll WSDPrintProxy.DLL WsdProviderUtil.dll
> WSDScanProxy.dll wsecedit.dll wsepno.dll wshbth.dll wshcon.dll wshelper.dll
> wshext.dll wshhyperv.dll wship6.dll wshom.ocx wshqos.dll
>  wshrm.dll WSHTCPIP.DLL wshunix.dll wsl.exe wslapi.dll WsmAgent.dll
> wsmanconfig_schema.xml WSManHTTPConfig.exe WSManMigrationPlugin.dll
> WsmAuto.dll wsmplpxy.dll wsmprovhost.exe WsmPty.xsl WsmRes.dll WsmSvc.dll
> WsmTxt.xsl WsmWmiPl.dll wsnmp32.dll wsock32.dll wsplib.dl
> l wsp_fs.dll wsp_health.dll wsp_sr.dll wsqmcons.exe WSReset.exe
> WSTPager.ax wtsapi32.dll wuapi.dll wuapihost.exe wuauclt.exe wuaueng.dll
> wuceffects.dll WUDFCoinstaller.dll WUDFCompanionHost.exe WUDFHost.exe
> WUDFPlatform.dll WudfSMCClassExt.dll WUDFx.dll WUDFx02000.dl
> l wudriver.dll wups.dll wups2.dll wusa.exe wuuhext.dll
> wuuhosdeployment.dll wvc.dll WwaApi.dll WwaExt.dll WWAHost.exe WWanAPI.dll
> wwancfg.dll wwanconn.dll WWanHC.dll wwanmm.dll Wwanpref.dll wwanprotdim.dll
> WwanRadioManager.dll wwansvc.dll wwapi.dll XamlTileRender.dll XAudio2_8.dll
> XAudio2_9.dll XblAuthManager.dll XblAuthManagerProxy.dll
> XblAuthTokenBrokerExt.dll XblGameSave.dll XblGameSaveExt.dll
> XblGameSaveProxy.dll XblGameSaveTask.exe XboxGipRadioManager.dll
> xboxgipsvc.dll xboxgipsynthetic.dll XboxNetApiSvc.dll xcopy.exe
> XInput1_4.dll XInput9_1_0.dll XInputUap.dll xmlfilter.dll xmllite.dll
> xmlprovi.dll xolehlp.dll XpsDocumentTargetPrint.dll XpsGdiConverter.dll
> XpsPrint.dll xpspushlayer.dll XpsRasterService.dll xpsservices.dll
> XpsToPclmConverter.dll XpsToPwgrConverter.dll xwizard.dtd xwizard.exe
> X_80.contrast-white.png X_80.png ze_loader.dll ze_tracing_layer.dll
> ze_validation_layer.dll zh-CN zh-TW zipcontainer.dll zipfldr.dll
> ztrace_maps.dll
> /cygdrive/c/Windows: addins AhnInst.log appcompat Application Data
> apppatch AppReadiness assembly bcastdvr bfsvc.exe
> BitLockerDiscoveryVolumeContents Boot bootstat.dat Branding CbsTemp
> Containers CSC Cursors debug diagnostics DiagTrack DigitalLocker Downloaded
> Program Files DtcInstall.log ELAMBKUP en-US explorer.exe Fonts
> GameBarPresenceWriter gethelp_audiotroubleshooter_latestpackage.zip
> Globalization Help HelpPane.exe hh.exe hipiw.dll IdentityCRL
> ImageSAFERSvc.exe IME IMGSF50Svc.exe ImmersiveControlPanel INF InputMethod
> Installer ko-KR L2Schemas LanguageOverlayCache LiveKernelReports Logs
> lsasetup.log Media mib.bin Microsoft.NET Migration ModemLogs notepad.exe
> OCR Offline Web Pages Panther Performance PFRO.log PLA PolicyDefinitions
> Prefetch PrintDialog Professional.xml Provisioning
> regedit.exe Registration RemotePackages rescache Resources RtlExUpd.dll
> SchCache schemas security ServiceProfiles ServiceState servicing Setup
> setupact.log setuperr.log ShellComponents ShellExperiences SHELLNEW SKB
> SoftwareDistribution Speech Speech_OneCore splwow64.
> exe System system.ini System32 SystemApps SystemResources SystemTemp
> SysWOW64 TAPI Tasks Temp TempInst tracing twain_32 twain_32.dll Vss WaaS
> Web win.ini WindowsShell.Manifest WindowsUpdate.log winhlp32.exe WinSxS
> WMSysPr9.prx write.exe
>       /cygdrive/c/Windows/System32/Wbem: aeinv.mof AgentWmi.mof
> AgentWmiUninstall.mof appbackgroundtask.dll appbackgroundtask.mof
> appbackgroundtask_uninstall.mof AuditRsop.mof authfwcfg.mof AutoRecover
> bcd.mof BthMtpEnum.mof cimdmtf.mof cimwin32.dll cimwin32.mof CIWm
> i.mof classlog.mof cli.mof cliegaliases.mof ddp.mof dimsjob.mof
> dimsroam.mof DMWmiBridgeProv.dll DMWmiBridgeProv.mof DMWmiBridgeProv1.dll
> DMWmiBridgeProv1.mof DMWmiBridgeProv1_Uninstall.mof
> DMWmiBridgeProv_Uninstall.mof dnsclientcim.dll dnsclientcim.mof
> dnsclientpspr
> ovider.dll dnsclientpsprovider.mof dnsclientpsprovider_Uninstall.mof
> drvinst.mof DscCore.mof DscCoreConfProv.mof dscproxy.mof Dscpspluginwkr.dll
> DscTimer.mof dsprov.dll dsprov.mof eaimeapi.mof EmbeddedLockdownWmi.dll
> embeddedlockdownwmi.mof embeddedlockdownwmi_Uninst
> all.mof en en-US esscli.dll EventTracingManagement.dll
> EventTracingManagement.mof fastprox.dll fdPHost.mof fdrespub.mof fdSSDP.mof
> fdWNet.mof fdWSD.mof filetrace.mof firewallapi.mof
> FolderRedirectionWMIProvider.mof FunDisc.mof fwcfg.mof hbaapi.mof
> hnetcfg.mof IMAPIv2
> -Base.mof IMAPIv2-FileSystemSupport.mof IMAPIv2-LegacyShim.mof interop.mof
> IpmiDTrc.mof ipmiprr.dll ipmiprv.dll ipmiprv.mof IpmiPTrc.mof ipsecsvc.mof
> iscsidsc.mof iscsihba.mof iscsiprf.mof iscsirem.mof iscsiwmiv2.mof
> iscsiwmiv2_uninstall.mof kerberos.mof ko ko-KR Krn
> lProv.dll krnlprov.mof L2SecHC.mof lltdio.mof lltdsvc.mof Logs lsasrv.mof
> mblctr.mof MDMAppProv.dll MDMAppProv.mof MDMAppProv_Uninstall.mof
> MDMSettingsProv.dll MDMSettingsProv.mof MDMSettingsProv_Uninstall.mof
> Microsoft-Windows-OfflineFiles.mof Microsoft-Windows-Remo
> te-FileSystem.mof Microsoft.AppV.AppVClientWmi.dll
> Microsoft.AppV.AppVClientWmi.mof Microsoft.Uev.AgentWmi.dll
> Microsoft.Uev.ManagedAgentWmi.mof
> Microsoft.Uev.ManagedAgentWmiUninstall.mof mispace.mof
> mispace_uninstall.mof mmc.mof MMFUtil.dll MOF mofcomp.exe mofd.dll
> mofinstall.dll mountmgr.mof mpeval.mof mpsdrv.mof mpssvc.mof msdtcwmi.dll
> MsDtcWmi.mof msfeeds.mof msfeedsbs.mof msi.mof msiprov.dll msiscsi.mof
> MsNetImPlatform.mof mstsc.mof mstscax.mof msv1_0.mof mswmdm.mof NCProv.dll
> ncprov.mof ncsi.mof ndisimplatcim.dll ndistrace
> .mof NetAdapterCim.dll NetAdapterCim.mof NetAdapterCimTrace.mof
> NetAdapterCimTraceUninstall.mof NetAdapterCim_uninstall.mof netdacim.dll
> netdacim.mof netdacim_uninstall.mof NetEventPacketCapture.dll
> NetEventPacketCapture.mof NetEventPacketCapture_uninstall.mof netncc
> im.dll netnccim.mof netnccim_uninstall.mof NetPeerDistCim.dll
> NetPeerDistCim.mof NetPeerDistCim_uninstall.mof netprofm.mof
> NetSwitchTeam.mof netswitchteamcim.dll NetTCPIP.dll NetTCPIP.mof
> NetTCPIP_Uninstall.mof netttcim.dll netttcim.mof netttcim_uninstall.mof
> network
> itemfactory.mof newdev.mof nlasvc.mof nlmcim.dll nlmcim.mof
> nlmcim_uninstall.mof nlsvc.mof npivwmi.mof nshipsec.mof ntevt.dll ntevt.mof
> ntfs.mof OfflineFilesConfigurationWmiProvider.mof
> OfflineFilesConfigurationWmiProvider_Uninstall.mof
> OfflineFilesWmiProvider.mof Of
> flineFilesWmiProvider_Uninstall.mof p2p-mesh.mof p2p-pnrp.mof
> pcsvDevice.mof pcsvDevice_Uninstall.mof Performance PNPXAssoc.mof
> PolicMan.dll PolicMan.mof polproc.mof polprocl.mof polprou.mof polstore.mof
> portabledeviceapi.mof portabledeviceclassextension.mof portable
> deviceconnectapi.mof portabledevicetypes.mof portabledevicewiacompat.mof
> powermeterprovider.mof PowerPolicyProvider.mof ppcRsopCompSchema.mof
> ppcRsopUserSchema.mof PrintFilterPipelineSvc.mof
> PrintManagementProvider.dll PrintManagementProvider.mof
> PrintManagementProvider_Uninstall.mof profileassociationprovider.mof
> PS_MMAgent.mof qmgr.mof qoswmi.dll qoswmi.mof qoswmitrc.mof
> qoswmitrc_uninstall.mof qoswmi_uninstall.mof RacWmiProv.dll RacWmiProv.mof
> rawxml.xsl rdpendp.mof rdpinit.mof rdpshell.mof refs.mof refsv1.mof
> regevent.mof Remove.Microsoft.AppV.AppvClientWmi.mof repdrvfs.dll
> Repository rsop.mof rspndr.mof samsrv.mof scersop.mof schannel.mof
> schedprov.dll SchedProv.mof scm.mof scrcons.exe scrcons.mof sdbus.mof
> secrcw32.mof SensorsClassExtension.mof ServDeps.dll ServiceModel.mof
> ServiceModel.mof.uninstall ServiceModel35.mof ServiceModel35.mof.uninstall
> services.mof setupapi.mof SmbWitnessWmiv2Provider.mof smbwmiv2.mof
> SMTPCons.dll smtpcons.mof sppwmi.mof sr.mof sstpsvc.mof stdprov.dll
> storagewmi.mof storagewmi_passthru.mof storagewmi_passthru_uninstall.mof
> storagewmi_uninstall.mof stortrace.mof subscrpt.mof system.mof tcpip.mof
> texttable.xsl textvaluelist.xsl tmf tsallow.mof tscfgwmi.mof tsmf.mof
> tspkg.mof umb.mof umbus.mof umpass.mof umpnpmgr.mof unsecapp.exe
> UserProfileConfigurationWmiProvider.mof UserProfileWmiProvider.mof
> UserStateWMIProvider.mof vds.mof vdswmi.dll viewprov.dll
> vpnclientpsprovider.dll vpnclientpsprovider.mof
> vpnclientpsprovider_Uninstall.mof vss.mof vsswmi.dll wbemcntl.dll
> wbemcons.dll WBEMCons.mof wbemcore.dll wbemdisp.dll wbemdisp.tlb
> wbemess.dll wbemprox.dll wbemsvc.dll wbemtest.exe wcncsvc.mof
> WdacEtwProv.mof WdacWmiProv.dll WdacWmiProv.mof WdacWmiProv_Uninstall.mof
> Wdf01000.mof Wdf01000Uninstall.mof wdigest.mof WFAPIGP.mof wfascim.dll
> wfascim.mof wfascim_uninstall.mof WFP.MOF wfs.mof whqlprov.mof
> Win32_DeviceGuard.mof Win32_EncryptableVolume.dll
> win32_encryptablevolume.mof Win32_EncryptableVolumeUninstall.mof
> win32_printer.mof Win32_Tpm.dll Win32_Tpm.mof wininit.mof winipsec.mof
> winlogon.mof WinMgmt.exe WinMgmtR.dll Winsat.mof WinsatUninstall.mof
> wlan.mof WLanHC.mof wmi.mof WMIADAP.exe WmiApRes.dll WmiApRpl.dll
> WmiApSrv.exe WMIC.exe WMICOOKR.dll WmiDcPrv.dll wmipcima.dll wmipcima.mof
> wmipdfs.dll wmipdfs.mof wmipdskq.dll wmipdskq.mof WmiPerfClass.dll
> WmiPerfClass.mof WmiPerfInst.dll WmiPerfInst.mof WMIPICMP.dll wmipicmp.mof
> WMIPIPRT.dll wmipiprt.mof WMIPJOBJ.dll wmipjobj.mof wmiprov.dll
> WmiPrvSD.dll WmiPrvSE.exe WMIPSESS.dll wmipsess.mof WMIsvc.dll wmitimep.dll
> wmitimep.mof wmiutils.dll WMI_Tracing.mof wmp.mof wmpnetwk.mof
> wpdbusenum.mof wpdcomp.mof wpdfs.mof wpdmtp.mof wpdshext.mof
> WPDShServiceObj.mof wpdsp.mof wpd_ci.mof wscenter.mof WsmAgent.mof
> WsmAgentUninstall.mof WsmAuto.mof wsp_fs.mof wsp_fs_uninstall.mof
> wsp_health.mof wsp_health_uninstall.mof wsp_sr.mof wsp_sr_uninstall.mof
> WUDFx.mof Wudfx02000.mof Wudfx02000Uninstall.mof WUDFxUninstall.mof xml
> xsl-mappings.xml xwizards.mof
> Certificate.format.ps1xml Diagnostics.Format.ps1xml
> DotNetTypes.format.ps1xml en en-US Event.Format.ps1xml Examples
> FileSystem.format.ps1xml getevent.types.ps1xml Help.format.ps1xml
> HelpV3.format.ps1xml ko ko-KR Modules powershell.exe powershell.exe.config
> PowerShellCore.format.ps1xml PowerShellTrace.format.ps1xml
> powershell_ise.exe powershell_ise.exe.config PSEvents.dll pspluginwkr.dll
> pwrshmsg.dll pwrshsip.dll Registry.format.ps1xml Schemas SessionConfig
> types.ps1xml typesv3.ps1xml WSMan.Format.ps1xml
>       /cygdrive/c/Windows/System32/OpenSSH: scp.exe sftp.exe ssh-add.exe
> ssh-agent.exe ssh-keygen.exe ssh-keyscan.exe ssh.exe
>       /cygdrive/c/Program Files/MATLAB/R2020b/bin: crash_analyzer.cfg
> icutzdata lcdata.xml lcdata.xsd lcdata_utf8.xml m3iregistry matlab.exe
> mex.bat mexext.bat util win32 win64
>       /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn:
> Resources SqlLocalDB.exe
> SDK/ODBC/170/Tools/Binn: batchparser.dll bcp.exe Resources SQLCMD.EXE
> xmlrw.dll
>       /cygdrive/c/Program Files/Git/cmd: git-gui.exe git-lfs.exe git.exe
> gitk.exe start-ssh-agent.cmd start-ssh-pageant.cmd
>       Warning accessing /cygdrive/c/msys64/mingw64/bin gives errors:
> [Errno 2] No such file or directory: '/cygdrive/c/msys64/mingw64/bin'
>       Warning accessing /cygdrive/c/msys64/usr/bin gives errors: [Errno 2]
> No such file or directory: '/cygdrive/c/msys64/usr/bin'
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64: 1033
> asan_blacklist.txt atlprov.dll bscmake.exe c1.dll c1xx.dll c2.dll
> cfgpersist.dll cl.exe cl.exe.config clang_rt.asan_dbg_dynamic-x86_64.dll
> clang_rt.asan_dynamic-x86_64.dll ConcurrencyCheck.dll CppBuildInsights.dll
> CppBuildInsightsEtw.xml CppCoreCheck.dll cvtres.exe d3dcompiler_47.dll
> dpcmi.dll dumpbin.exe editbin.exe EnumIndex.dll EspXEngine.dll
> HResultCheck.dll KernelTraceControl.dll lib.exe link.exe link.exe.config
> llvm-symbolizer.exe LocalESPC.dll
> Microsoft.Diagnostics.Tracing.EventSource.dll
> Microsoft.VisualStudio.RemoteControl.dll
> Microsoft.VisualStudio.Telemetry.dll
> Microsoft.VisualStudio.Utilities.Internal.dll ml64.exe msobj140.dll
> mspdb140.dll mspdbcmf.exe mspdbcore.dll mspdbsrv.exe mspdbst.dll
> mspft140.dll msvcdis140.dll msvcp140.dll msvcp140_1.dll msvcp140_2.dll
> msvcp140_atomic_wait.dll msvcp140_codecvt_ids.dll Newtonsoft.Json.dll
> nmake.exe onecore perf_msvcbuildinsights.dll pgocvt.exe pgodb140.dll
> pgodriver.sys pgomgr.exe pgort140.dll pgosweep.exe
> System.Runtime.CompilerServices.Unsafe.dll tbbmalloc.dll undname.exe
> VariantClear.dll vcmeta.dll vcperf.exe vcruntime140.dll vcruntime140_1.dll
> vctip.exe xdcmake.exe xdcmake.exe.config
>       /cygdrive/c/Program Files/dotnet: dotnet.exe host LICENSE.txt packs
> sdk shared templates ThirdPartyNotices.txt
>       /: bin Cygwin-Terminal.ico Cygwin.bat Cygwin.ico dev etc home lib
> mpich-4.0.2 mpich-4.0.2.tar.gz sbin tmp usr var proc cygdrive
>       /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps: Backup
> GameBarElevatedFT_Alias.exe Microsoft.DesktopAppInstaller_8wekyb3d8bbwe
> Microsoft.MicrosoftEdge_8wekyb3d8bbwe Microsoft.SkypeApp_kzf8qxf38zg5c
> Microsoft.XboxGamingOverlay_8wekyb3d8bbwe MicrosoftEdge.exe python.exe
> python3.exe Skype.exe winget.exe
>       /cygdrive/c/Users/SEJONG/AppData/Local/Programs/Microsoft VS
> Code/bin: code code.cmd
>       Warning accessing /cygdrive/c/Users/SEJONG/.dotnet/tools gives
> errors: [Errno 2] No such file or directory:
> '/cygdrive/c/Users/SEJONG/.dotnet/tools'
>       /usr/lib/lapack: cygblas-0.dll cyglapack-0.dll
> TESTING: configureExternalPackagesDir from
> config.framework(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py:1045)
>   Set alternative directory external packages are built in
>     serialEvaluation: initial cxxDialectRanges ('c++11', 'c++17')
>     serialEvaluation: new cxxDialectRanges ('c++11', 'c++17')
>     child config.utilities.macosFirewall took 0.000005 seconds
> TESTING: configureDebuggers from
> config.utilities.debuggers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/utilities/debuggers.py:20)
>   Find a default debugger and determine its arguments
>     Checking for program /usr/local/bin/gdb...not found
>     Checking for program /usr/bin/gdb...not found
>     Checking for program /cygdrive/c/SIMULIA/Commands/gdb...not found
>     Checking for program /cygdrive/c/Program Files/Microsoft
> MPI/Bin/gdb...not found
>     Checking for program /cygdrive/c/Windows/system32/gdb...not found
>     Checking for program /cygdrive/c/Windows/gdb...not found
>     Checking for program /cygdrive/c/Windows/System32/Wbem/gdb...not found
> /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/gdb...not found
>     Checking for program /cygdrive/c/Windows/System32/OpenSSH/gdb...not
> found
> Files/MATLAB/R2020b/bin/gdb...not found
>     Checking for program /cygdrive/c/Program Files/Microsoft SQL
> Server/130/Tools/Binn/gdb...not found
> Server/Client SDK/ODBC/170/Tools/Binn/gdb...not found
>     Checking for program /cygdrive/c/Program Files/Git/cmd/gdb...not found
>     Checking for program /cygdrive/c/msys64/mingw64/bin/gdb...not found
>     Checking for program /cygdrive/c/msys64/usr/bin/gdb...not found
>     Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/gdb...not
> found
>     Checking for program /cygdrive/c/Program Files/dotnet/gdb...not found
>     Checking for program /gdb...not found
> /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/gdb...not found
> Code/bin/gdb...not found
> found
>     Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/gdb...not
> found
>     Checking for program /usr/lib/lapack/gdb...not found
>     Checking for program /usr/local/bin/dbx...not found
>     Checking for program /usr/bin/dbx...not found
>     Checking for program /cygdrive/c/SIMULIA/Commands/dbx...not found
> MPI/Bin/dbx...not found
>     Checking for program /cygdrive/c/Windows/system32/dbx...not found
>     Checking for program /cygdrive/c/Windows/dbx...not found
>     Checking for program /cygdrive/c/Windows/System32/Wbem/dbx...not found
> /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/dbx...not found
>     Checking for program /cygdrive/c/Windows/System32/OpenSSH/dbx...not
> found
> Files/MATLAB/R2020b/bin/dbx...not found
> Server/130/Tools/Binn/dbx...not found
> Server/Client SDK/ODBC/170/Tools/Binn/dbx...not found
>     Checking for program /cygdrive/c/Program Files/Git/cmd/dbx...not found
>     Checking for program /cygdrive/c/msys64/mingw64/bin/dbx...not found
>     Checking for program /cygdrive/c/msys64/usr/bin/dbx...not found
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/dbx...not
> found
>     Checking for program /cygdrive/c/Program Files/dotnet/dbx...not found
>     Checking for program /dbx...not found
> /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/dbx...not found
> Code/bin/dbx...not found
> found
>     Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/dbx...not
> found
>     Checking for program /usr/lib/lapack/dbx...not found
>             Defined make macro "DSYMUTIL" to "true"
>     child config.utilities.debuggers took 0.014310 seconds
> TESTING: configureDirectories from
> PETSc.options.petscdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/petscdir.py:22)
>   Checks PETSC_DIR and sets if not set
>           PETSC_VERSION_RELEASE of 1 indicates the code is from a release
> branch or a branch created from a release branch.
>           Version Information:
>           #define PETSC_VERSION_RELEASE    1
>           #define PETSC_VERSION_MAJOR      3
>           #define PETSC_VERSION_MINOR      18
>           #define PETSC_VERSION_SUBMINOR   1
>           #define PETSC_VERSION_DATE       "Oct 26, 2022"
>           #define PETSC_VERSION_GIT        "v3.18.1"
>           #define PETSC_VERSION_DATE_GIT   "2022-10-26 07:57:29 -0500"
>           #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
>           #define PETSC_VERSION_ PETSC_VERSION_EQ
>           #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
>           #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
>           #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
>           #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
>     child PETSc.options.petscdir took 0.015510 seconds
> TESTING: getDatafilespath from
> PETSc.options.dataFilesPath(/home/SEJONG/petsc-3.18.1/config/PETSc/options/dataFilesPath.py:29)
>   Checks what DATAFILESPATH should be
>     child PETSc.options.dataFilesPath took 0.002462 seconds
> TESTING: configureGit from
> config.sourceControl(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/sourceControl.py:24)
>   Find the Git executable
>     Checking for program /usr/local/bin/git...not found
>     Checking for program /usr/bin/git...found
>               Defined make macro "GIT" to "git"
> Executing: git --version
> stdout: git version 2.38.1
> TESTING: configureMercurial from
> config.sourceControl(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/sourceControl.py:35)
>   Find the Mercurial executable
>     Checking for program /usr/local/bin/hg...not found
>     Checking for program /usr/bin/hg...not found
>     Checking for program /cygdrive/c/SIMULIA/Commands/hg...not found
> MPI/Bin/hg...not found
>     Checking for program /cygdrive/c/Windows/system32/hg...not found
>     Checking for program /cygdrive/c/Windows/hg...not found
>     Checking for program /cygdrive/c/Windows/System32/Wbem/hg...not found
> /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0/hg...not found
>     Checking for program /cygdrive/c/Windows/System32/OpenSSH/hg...not
> found
> Files/MATLAB/R2020b/bin/hg...not found
> Server/130/Tools/Binn/hg...not found
> Server/Client SDK/ODBC/170/Tools/Binn/hg...not found
>     Checking for program /cygdrive/c/Program Files/Git/cmd/hg...not found
>     Checking for program /cygdrive/c/msys64/mingw64/bin/hg...not found
>     Checking for program /cygdrive/c/msys64/usr/bin/hg...not found
> Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/hg...not
> found
>     Checking for program /cygdrive/c/Program Files/dotnet/hg...not found
>     Checking for program /hg...not found
> /cygdrive/c/Users/SEJONG/AppData/Local/Microsoft/WindowsApps/hg...not found
> Code/bin/hg...not found
> found
>     Checking for program /cygdrive/c/Users/SEJONG/.dotnet/tools/hg...not
> found
>     Checking for program /usr/lib/lapack/hg...not found
> /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/hg...not found
>     child config.sourceControl took 0.121914 seconds
> TESTING: configureInstallationMethod from
> PETSc.options.petscclone(/home/SEJONG/petsc-3.18.1/config/PETSc/options/petscclone.py:20)
>   Determine if PETSc was obtained via git or a tarball
>           This is a tarball installation
>     child PETSc.options.petscclone took 0.003125 seconds
> TESTING: setNativeArchitecture from
> PETSc.options.arch(/home/SEJONG/petsc-3.18.1/config/PETSc/options/arch.py:29)
>   Forms the arch as GNU's configure would form it
> TESTING: configureArchitecture from
> PETSc.options.arch(/home/SEJONG/petsc-3.18.1/config/PETSc/options/arch.py:42)
>   Checks if PETSC_ARCH is set and sets it if not set
>         No previous hashfile found
>           Setting hashfile:
> arch-mswin-c-debug/lib/petsc/conf/configure-hash
>           Deleting configure hash file:
>           Unable to delete configure hash file:
>     child PETSc.options.arch took 0.149094 seconds
> TESTING: setInstallDir from
> PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:31)
>   Set installDir to either prefix or if that is not set to
> PETSC_DIR/PETSC_ARCH
>             Defined make macro "PREFIXDIR" to
> "/home/SEJONG/petsc-3.18.1/arch-mswin-c-debug"
> TESTING: saveReconfigure from
> PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:76)
>   Save the configure options in a script in PETSC_ARCH/lib/petsc/conf so
> the same configure may be easily re-run
> TESTING: cleanConfDir from
> PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:68)
>   Remove all the files from configuration directory for this PETSC_ARCH,
> from --with-clean option
> TESTING: configureInstallDir from
> PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:52)
>   Makes  installDir subdirectories if it does not exist for both prefix
> install location and PETSc work install location
>           Changed persistence directory to
> /home/SEJONG/petsc-3.18.1/arch-mswin-c-debug/lib/petsc/conf
> TESTING: restoreReconfigure from
> PETSc.options.installDir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/installDir.py:90)
>   If --with-clean was requested but restoring the reconfigure file was
> requested then restore it
>     child PETSc.options.installDir took 0.006476 seconds
> TESTING: setExternalPackagesDir from
> PETSc.options.externalpackagesdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/externalpackagesdir.py:15)
>   Set location where external packages will be downloaded to
> TESTING: cleanExternalpackagesDir from
> PETSc.options.externalpackagesdir(/home/SEJONG/petsc-3.18.1/config/PETSc/options/externalpackagesdir.py:23)
>   Remove all downloaded external packages, from --with-clean
>     child PETSc.options.externalpackagesdir took 0.000990 seconds
> TESTING: configureCLanguage from
> PETSc.options.languages(/home/SEJONG/petsc-3.18.1/config/PETSc/options/languages.py:28)
>   Choose whether to compile the PETSc library using a C or C++ compiler
>           C language is C
>             Defined "CLANGUAGE_C" to "1"
>             Defined make macro "CLANGUAGE" to "C"
>     child PETSc.options.languages took 0.003172 seconds
> TESTING: resetEnvCompilers from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2652)
>   Remove compilers from the shell environment so they do not interfer with
> testing
> TESTING: checkEnvCompilers from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2669)
>   Set configure compilers from the environment, from
> -with-environment-variables
> TESTING: checkMPICompilerOverride from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2622)
>   Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
>     This usually prevents mpi compilers from being used - so issue a
> warning
> TESTING: requireMpiLdPath from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:2643)
>   OpenMPI wrappers require LD_LIBRARY_PATH set
> TESTING: checkInitialFlags from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:723)
>   Initialize the compiler and linker flags
>           Initialized CFLAGS to
>           Initialized LDFLAGS to
>           Initialized CUDAFLAGS to
>           Initialized HIPFLAGS to
>           Initialized SYCLFLAGS to
>           Initialized CXXFLAGS to
>           Initialized CXX_CXXFLAGS to
>           Initialized FFLAGS to
>           Initialized CPPFLAGS to
>           Initialized FPPFLAGS to
>           Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
>           Initialized CXXPPFLAGS to
>           Initialized HIPPPFLAGS to
>           Initialized SYCLPPFLAGS to
>           Initialized CC_LINKER_FLAGS to []
>           Initialized CXX_LINKER_FLAGS to []
>           Initialized FC_LINKER_FLAGS to []
>           Initialized CUDAC_LINKER_FLAGS to []
>           Initialized HIPC_LINKER_FLAGS to []
>           Initialized SYCLC_LINKER_FLAGS to []
> TESTING: checkCCompiler from
> config.setCompilers(/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py:1341)
>   Locate a functional C compiler
>     Checking for program /usr/local/bin/mpicc...not found
>     Checking for program /usr/bin/mpicc...found
>               Defined make macro "CC" to "mpicc"
> Executing: mpicc -c -o /tmp/petsc-uqt11yqc/config.setCompilers/conftest.o
> -I/tmp/petsc-uqt11yqc/config.setCompilers
>  /tmp/petsc-uqt11yqc/config.setCompilers/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
>   return 0;
> Successful compile:
> Source:
> int main() {
>   return 0;
> Executing: mpicc  -o /tmp/petsc-uqt11yqc/config.setCompilers/conftest.exe
> Possible ERROR while running linker: exit code 1
> stderr:
> /usr/lib/gcc/x86_64-pc-cygwin/11/../../../../x86_64-pc-cygwin/bin/ld:
> cannot find -lhwloc: No such file or directory
> cannot find -levent_core: No such file or directory
> cannot find -levent_pthreads: No such file or directory
> cannot find -lz: No such file or directory
> collect2: error: ld returned 1 exit status
> Linker output before filtering:
> Linker output after filtering:
> collect2: error: ld returned 1 exit status:
>           Error testing C compiler: Cannot compile/link C with mpicc.
>              MPI compiler wrapper mpicc failed to compile
> Executing: mpicc -show
> stdout: gcc -L/usr/lib -lmpi -lopen-rte -lopen-pal -lhwloc -levent_core
> -levent_pthreads -lz
>              MPI compiler wrapper mpicc is likely incorrect.
>   Use --with-mpi-dir to indicate an alternate MPI.
>             Deleting "CC"
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> C compiler you provided with -with-cc=mpicc cannot be found or does not
> work.
>   File "/home/SEJONG/petsc-3.18.1/config/configure.py", line 461, in
> petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/framework.py",
> line 1412, in configure
>     self.processChildren()
> line 1400, in processChildren
>     self.serialEvaluation(self.childGraph)
> line 1375, in serialEvaluation
>     child.configure()
>   File
> "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/setCompilers.py", line
> 2712, in configure
>     self.executeTest(self.checkCCompiler)
>   File "/home/SEJONG/petsc-3.18.1/config/BuildSystem/config/base.py", line
> 138, in executeTest
>     ret = test(*args,**kargs)
>   File
> 1346, in checkCCompiler
>     for compiler in self.generateCCompilerGuesses():
>   File
> 1274, in generateCCompilerGuesses
>     raise RuntimeError('C compiler you provided with
> -with-cc='+self.argDB['with-cc']+' cannot be found or does not
> work.'+'\n'+self.mesg)
> Finishing configure run at Tue, 01 Nov 2022 13:06:09 +0900
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Tuesday, November 1, 2022 11:36 AM
> To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Subject: RE: [petsc-users] PETSc Windows Installation
> you'll have to send configure.log for this failure
> Satish
> On Tue, 1 Nov 2022, Mohammad Ali Yaqteen wrote:
> > I have checked the required Cygwin openmpi libraries and they are all
> installed. When I run ./configure --with-cc=mpicc --with-cxx=mpicxx
> --with-fc=mpif90, it returns:
> > $ ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> >                          Configuring PETSc to compile on your system
> config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*******************************************************************************
> for details):
> > --------- C compiler you provided with -with-cc=mpicc cannot be found
> > or does not work.
> > As for the case of WSL2, I will try to install that on my PC.
> > Meanwhile, could you please look into this issue
> > Thank you
> > Ali
> > Sent: Monday, October 31, 2022 10:56 PM
> > To: Satish Balay via petsc-users <petsc-users at mcs.anl.gov>
> > Cc: Matthew Knepley <knepley at gmail.com>; Mohammad Ali Yaqteen
> > Subject: Re: [petsc-users] PETSc Windows Installation
> > BTW: If you have WSL2 on windows - it might be easier to build/use PETSc.
> > Satish
> > On Mon, 31 Oct 2022, Satish Balay via petsc-users wrote:
> > > Make sure you have cygwin openmpi installed [and cywin blas/lapack]
> > > $ cygcheck -cd |grep openmpi
> > > libopenmpi-devel              4.1.2-1
> > > libopenmpi40                  4.1.2-1
> > > libopenmpifh40                4.1.2-1
> > > libopenmpiusef08_40           4.1.2-1
> > > libopenmpiusetkr40            4.1.2-1
> > > openmpi                       4.1.2-1
> > > $ cygcheck -cd |grep lapack
> > > liblapack-devel               3.10.1-1
> > > liblapack0                    3.10.1-1
> > > > ./configure --with-cc=gcc --with-cxx=0 --with-fc=0
> > > > --download-f2cblaslapack
> > > Should be:
> > > > > $ ./configure --download-scalapack --download-mumps
> > > i.e [default] --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 [an
> > > default cygwin blas/lapack]
> > > Satish
> > > On Mon, 31 Oct 2022, Matthew Knepley wrote:
> > > > On Mon, Oct 31, 2022 at 1:56 AM Mohammad Ali Yaqteen
> > > > wrote:
> > > > > Dear Satish
> > > > > When I configure PETSc with (./configure --with-cc=gcc
> > > > > --with-cxx=0
> > > > > --with-fc=0 --download-f2cblaslapack) it runs as I shared
> > > > > initially which you said is not an issue anymore. But when I add
> > > > > (--download-scalapack
> > > > > --download-mumps) or configure with these later, it gives the
> > > > > following
> > > > > error:
> > > > > system
> > > > > TESTING: FortranMPICheck from
> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:614)*******************************************************************************
> configure.log for
> > > > > details):
> > > > > ------------- Fortran error! mpi_init() could not be located!
> > > > > What could be the problem here?
> > > > Without configure.log we cannot tell what went wrong. However,
> > > > from the error message, I would guess that your MPI was not built
> > > > with Fortran bindings. You need these for those packages.
> > > >   Thanks,
> > > >      Matt
> > > > > Your help is highly appreciated.
> > > > > Thank you
> > > > > Ali
> > > > > Sent: Saturday, October 29, 2022 2:11 PM
> > > > > Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov
> > > > > On Sat, 29 Oct 2022, Mohammad Ali Yaqteen wrote:
> > > > > > I haven’t accessed PETSC or given any command of my own. I was
> > > > > > just
> > > > > installing by following the instructions. I don’t know why it is
> > > > > attaching the debugger. Although it says “Possible error running
> > > > > C/C++
> > > > > src/snes/tutorials/ex19 with 1 MPI process” which I think is
> > > > > indicating of missing of MPI!
> > > > > The diff is not smart enough to detect the extra message from
> > > > > cygwin/OpenMPI - hence it assumes there is a potential problem -
> > > > > and prints the above message.
> > > > > But you can assume its installed properly - and use it.
> > > > > Satish
> > > > > > From: Matthew Knepley <knepley at gmail.com>
> > > > > > Sent: Friday, October 28, 2022 10:31 PM
> > > > > > Cc: petsc-users at mcs.anl.gov
> > > > > > On Fri, Oct 28, 2022 at 9:11 AM Mohammad Ali Yaqteen <
> > > > > mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
> > > > > > Dear Sir,
> > > > > > During the Installation of PETSc in windows, I installed
> > > > > > Cygwin and the
> > > > > required libraries as mentioned on your website:
> > > > > > [cid:image001.png at 01D8EB93.7C17E410]
> > > > > > However, when I install PETSc using the configure commands
> > > > > > present on
> > > > > the petsc website:
> > > > > --download-f2cblaslapack --download-mpich
> > > > > > it gives me the following error:
> > > > > > [cid:image002.png at 01D8EB93.7C17E410]
> > > > > > I already installed OpenMPI using Cygwin installer but it
> > > > > > still asks me
> > > > > to. When I configure without “—download-mpich” and run “make check”
> > > > > command, it gives me the following errors:
> > > > > > [cid:image003.png at 01D8EB93.7C17E410]
> > > > > > Could you kindly look into this and help me with this? Your
> > > > > > prompt
> > > > > response will highly be appreciated.
> > > > > > The runs look fine.
> > > > > > The test should not try to attach the debugger. Do you have
> > > > > > that in the
> > > > > PETSC_OPTIONS env variable?
> > > > > >   Thanks,
> > > > > >      Matt
> > > > > > Thank you!
> > > > > > Mohammad Ali
> > > > > > Researcher, Sejong University
> > > > > > What most experimenters take for granted before they begin
> > > > > > their
> > > > > experiments is infinitely more interesting than any results to
> > > > > which their experiments lead.
> > > > > > -- Norbert Wiener
> > > > > > https://www.cse.buffalo.edu/~knepley/<
> > > > > http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221101/0ef5af10/attachment-0001.html>
