[petsc-users] Sparse linear system solving
Mon May 30 21:17:45 CDT 2022
On Mon, May 30, 2022 at 10:12 PM Lidia <lidia.varsh at mail.ioffe.ru> wrote:
> Dear colleagues,
> Is here anyone who have solved big sparse linear matrices using PETSC?
There are lots of publications with this kind of data. Here is one recent
one: https://arxiv.org/abs/2204.01722
> We have found NO performance improvement while using more and more mpi
> processes (1-2-3) and open-mp threads (from 1 to 72 threads). Did anyone
> faced to this problem? Does anyone know any possible reasons of such
> behaviour?
Solver behavior is dependent on the input matrix. The only general-purpose
solvers
are direct, but they do not scale linearly and have high memory
requirements.
Thus, in order to make progress you will have to be specific about your
matrices.
> We use AMG preconditioner and GMRES solver from KSP package, as our
> matrix is large (from 100 000 to 1e+6 rows and columns), sparse,
> non-symmetric and includes both positive and negative values. But
> performance problems also exist while using CG solvers with symmetric
> matrices.
There are many PETSc examples, such as example 5 for the Laplacian, that
exhibit
good scaling with both AMG and GMG.
> Could anyone help us to set appropriate options of the preconditioner
> and solver? Now we use default parameters, maybe they are not the best,
> but we do not know a good combination. Or maybe you could suggest any
> other pairs of preconditioner+solver for such tasks?
> I can provide more information: the matrices that we solve, c++ script
> to run solving using petsc and any statistics obtained by our runs.
First, please provide a description of the linear system, and the output of
  -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
for each test case.
     Matt
> Thank you in advance!
> Best regards,
> Lidiia Varshavchik,
> Ioffe Institute, St. Petersburg, Russia
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220530/8c65fe8d/attachment.html>
