[petsc-users] PetscSF Object on Distributed DMPlex for Halo Data Exchange
Tue May 24 20:46:33 CDT 2022
I will also point out that Toby has created a nice example showing how to
create an SF for halo exchange between local vectors.
  https://gitlab.com/petsc/petsc/-/merge_requests/5267
     Matt
On Sun, May 22, 2022 at 9:47 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 22, 2022 at 4:28 PM Mike Michell <mi.mike1021 at gmail.com>
> wrote:
>> Thanks for the reply. The diagram makes sense and is helpful for
>> understanding 1D representation.
>> However, something is still unclear. From your diagram, the number of
>> roots per process seems to vary according to run arguments, such as
>> "-dm_distribute_overlap", because "the number of roots for a DMPlex is the
>> number of mesh points in the local portion of the mesh (cited from your
>> answer to my question (1))" will end up change according to that argument.
>> However, from my mock-up code, number of roots is independent to
>> -dm_distribute_overlap argument. The summation of "number of roots" through
>> processes was always equal to number of physical vertex on my mesh, if I
>> define the section layout on vertex with 1DOF. But in your diagram example,
>> the summation of "nroots" is larger than the actual number of mesh points,
>> which is 13.
> I do not understand your question. Notice the -dm_distribute_overlap does
> _not_ change the owned points for any process. It only puts in new leaves,
> so it also never
> changes the roots for this way of using the SF.
>> Also, it is still unclear how to get the size of "roots" from the
>> PetscSection & PetscSF on distributed DMPlex?
> For an SF mapping ghost dofs in a global vector, the number of roots is
> just the size of the local portion of the vector.
>> In your diagram, how can you tell your code and make it allocate the
>> "nroots=7 for P0, nroots=9 for P1, and nroots=7 for P2" arrays before you
>> call PetscSFBcastBegin/End()? It seems that we need to define arrays having
>> the size of nroots & nleaves before calling PetscSFBcastBegin/End().
> I just want to note that this usage is different from the canonical usage
> in Plex. It is fine to do this, but this will not match what I do in the
> library if you look.
> In Plex, I distinguish two linear spaces:
>   1) Global space: This is the vector space for the solvers. Each point is
> uniquely represented and owned by some process
>   2) Local space: This is the vector space for assembly. Some points are
> represented multiple times.
> I create an SF that maps from the global space (roots) to the local space
> (leaves), and it is called in DMGlobalToLocal() (and associated functions).
> This
> is more natural in FEM. You seem to want an SF that maps between global
> vectors. This will also work. The roots would be the local dofs, and the
> leaves
> would be shared dofs.
>   Does this make sense?
>      Thanks,
>        Matt
>> Thanks,
>> Mike
>> Here's a diagram of a 1D mesh with overlap and 3 partitions, showing what
>>> the petscsf data is for each.  The number of roots is the number of mesh
>>> points in the local representation, and the number of leaves is the number
>>> of mesh points that are duplicates of mesh points on other processes.  With
>>> that in mind, answering your questions
>>> > (1) It seems that the "roots" means the number of vertex not
>>> considering overlap layer, and "leaves" seems the number of distributed
>>> vertex for each processor that includes overlap layer. Can you acknowledge
>>> that this is correct understanding? I have tried to find clearer examples
>>> from PETSc team's articles relevant to Star Forest, but I am still unclear
>>> about the exact relation & graphical notation of roots & leaves in SF if
>>> it's the case of DMPlex solution arrays.
>>> No, the number of roots for a DMPlex is the number of mesh points in the
>>> > (2) If it is so, there is an issue that I cannot define "root data"
>>> and "leave data" generally. I am trying to following
>>> "src/vec/is/sf/tutorials/ex1f.F90", however, in that example, size of roots
>>> and leaves are predefined as 6. How can I generalize that? Because I can
>>> get size of leaves using DAG depth(or height), which is equal to number of
>>> vertices each proc has. But, how can I get the size of my "roots" region
>>> from SF? Any example about that? This question is connected to how can I
>>> define "rootdata" for "PetscSFBcastBegin/End()".
>>> Does the diagram help you generalize?
>>> > (3) More importantly, with the attached PetscSection & SF layout, my
>>> vector is only resolved for the size equal to "number of roots" for each
>>> proc, but not for the overlapping area(i.e., "leaves"). What I wish to do
>>> is to exchange (or reduce) the solution data between each proc, in the
>>> overlapping region. Can I get some advices why my vector does not encompass
>>> the "leaves" regime? Is there any example doing similar things?
>>> Going back to my first response: if you use a section to say how many
>>> pieces of data are associated with each local mesh point, then a PetscSF is
>>> constructed that requires no more manipulation from you.
>>> On Sun, May 22, 2022 at 10:47 AM Mike Michell <mi.mike1021 at gmail.com>
>>> wrote:
>>>> Thank you for the reply.
>>>> The PetscSection and PetscSF objects are defined as in the attached
>>>> mock-up code (Q_PetscSF_1.tar). 1-DOF is defined on vertex as my solution
>>>> is determined on each vertex with 1-DOF from a finite-volume method.
>>>> As follow up questions:
>>>> (2) If it is so, there is an issue that I cannot define "root data" and
>>>> Thanks,
>>>> Mike
>>>>> On Fri, May 20, 2022 at 4:45 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>> > "What I want to do is to exchange data (probably just MPI_Reduce)"
>>>>>> which confuses me, because halo exchange is a point-to-point exchange and
>>>>>> not a reduction.  Can you clarify?
>>>>>> PetscSFReduceBegin/End seems to be the function that do reduction for
>>>>>> PetscSF object. What I intended to mention was either reduction or
>>>>>> exchange, not specifically intended "reduction".
>>>>>> As a follow-up question:
>>>>>> Assuming that the code has its own local solution arrays (not Petsc
>>>>>> type), and if the plex's DAG indices belong to the halo region are the only
>>>>>> information that I want to know (not the detailed section description, such
>>>>>> as degree of freedom on vertex, cells, etc.). I have another PetscSection
>>>>>> for printing out my solution.
>>>>>> Also if I can convert that DAG indices into my local cell/vertex
>>>>>> index, can I just use the PetscSF object created from DMGetPointSF(),
>>>>>> instead of "creating PetscSection + DMGetSectionSF()"? In other words, can
>>>>>> I use the PetscSF object declared from DMGetPointSF() for the halo
>>>>>> communication?
>>>>> No, because that point SF will index information by point number. You
>>>>> would need to build a new SF that indexes your dofs. The steps you would
>>>>> go through are exactly the same as you would if you just told us what
>>>>> the Section is that indexes your data.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Mike
>>>>>> The PetscSF that is created automatically is the "point sf" (
>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMGetPointSF/): it says
>>>>>>> which mesh points (cells, faces, edges and vertices) are duplicates of
>>>>>>> others.
>>>>>>> In a finite volume application we typically want to assign degrees
>>>>>>> of freedom just to cells: some applications may only have one degree of
>>>>>>> freedom, others may have multiple.
>>>>>>> You encode where you want degrees of freedom in a PetscSection and
>>>>>>> set that as the section for the DM in DMSetLocalSection() (
>>>>>>> https://petsc.org/release/docs/manualpages/DM/DMSetLocalSection.html
>>>>>>> (A c example of these steps that sets degrees of freedom for
>>>>>>> *vertices* instead of cells is `src/dm/impls/plex/tutorials/ex7.c`)
>>>>>>> After that you can call DMGetSectionSF() (
>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMGetSectionSF/) to the
>>>>>>> the PetscSF that you want for halo exchange: the one for your solution
>>>>>>> variables.
>>>>>>> After that, the only calls you typically need in a finite volume
>>>>>>> code is PetscSFBcastBegin() to start a halo exchange and PetscSFBcastEnd()
>>>>>>> to complete it.
>>>>>>> You say
>>>>>>> exchange and not a reduction.  Can you clarify?
>>>>>>> On Fri, May 20, 2022 at 8:35 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Dear PETSc developer team,
>>>>>>>> Hi, I am using DMPlex for a finite-volume code and trying to
>>>>>>>> understand the usage of PetscSF. What is a typical procedure for doing halo
>>>>>>>> data exchange at parallel boundary using PetscSF object on DMPlex? Is there
>>>>>>>> any example that I can refer to usage of PetscSF with distributed DMPlex?
>>>>>>>> Assuming to use the attached mock-up code and mesh, if I give
>>>>>>>> "-dm_distribute_overlap 1 -over_dm_view" to run the code, I can see a
>>>>>>>> PetscSF object is already created, although I have not called
>>>>>>>> "PetscSFCreate" in the code. How can I import & use that PetscSF already
>>>>>>>> created by the code to do the halo data exchange?
>>>>>>>> What I want to do is to exchange data (probably just MPI_Reduce) in
>>>>>>>> a parallel boundary region using PetscSF and its functions. I might need to
>>>>>>>> have an overlapping layer or not.
>>>>>>>> Thanks,
>>>>>>>> Mike
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220524/64714188/attachment-0001.html>
