[petsc-users] hypre github location change
Jacob Faibussowitsch
jacob.fai at gmail.com
Mon May 23 20:28:37 CDT 2022
What version of petsc are you using? Current main https://gitlab.com/petsc/petsc/-/blob/main/config/BuildSystem/config/packages/hypre.py downloads from the link you cite (see the self.download member variable).
Best regards,
(Jacob Fai - booss - oh - vitch)
> On May 23, 2022, at 21:24, Pieter VandenBerge <pumpkinpieter at gmail.com> wrote:
> Hi there,
> I was trying to install petsc on my login in the cluster at my school (Portland State University). I noticed that I wasn't able to download hypre, and that when I looked into why it seems to be because the location of hypre changed on github to https://github.com/hypre-space/hypre, whereas the current configuration is looking for it under Lawrence Livermore github.
> I went ahead and installed it without hypre for now, and I might be able to make it work on my own by altering the configuration file for hypre, but thought it should more generally be known about.
> Thanks,
> Pieter Vandenberge
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220523/f8556b09/attachment.html>
