[petsc-users] strumpack in ilu mode
    Randall Mackie
    rlmackie862 at gmail.com
    Mon May 23 12:59:41 CDT 2022
Dear PETSc team:
I am trying to use Strumpack in ILU mode, which is suppose to activate it’s low rank approximation as described on the man page:
https://petsc.org/release/docs/manualpages/Mat/MATSOLVERSSTRUMPACK.html <https://petsc.org/release/docs/manualpages/Mat/MATSOLVERSSTRUMPACK.html>
and in this exchange a few years ago:
https://lists.mcs.anl.gov/pipermail/petsc-users/2017-October/033560.html <https://lists.mcs.anl.gov/pipermail/petsc-users/2017-October/033560.html>
However, regardless of whether I specify ILU or LU, the behavior is the same, and the solution is in 1 step, meaning (to me) it’s doing the LU direct solve.
Furthermore, when I set verbose mode, it doesn’t seem to be activating low rank mode (that is, there are HSS or BLR frontal matrices created).
I’m running this example:
https://petsc.org/release/src/ksp/ksp/tutorials/ex2.c.html <https://petsc.org/release/src/ksp/ksp/tutorials/ex2.c.html>
using options:
mpiexec -n 4 ./ex2 -pc_type ilu -pc_factor_mat_solver_package strumpack
I’m likely doing something wrong, but I can’t figure out what, and would appreciate advice on how to use the strumpack ILU mode.
Thanks, Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220523/ce89d7e6/attachment.html>
