[petsc-users] A compilation error about VecGetValues
Barry Smith bsmith at petsc.dev
Sun May 22 11:44:13 CDT 2022
   This should work for at least the last three versions of PETSc. Please upgrade to the latest PETSc version and let us know if you continue to get this error message.
    Yes, for some PETSc versions between 3.8 and 3.14 it may generate this error message with some Fortran compilers.
   Barry
> On May 21, 2022, at 9:23 AM, wang yuqi <yu1299885905 at outlook.com> wrote:
> 从 Windows 版邮件 <https://go.microsoft.com/fwlink/?LinkId=550986>发送
> Hi, Dear developer:
> I had compilation problems when using VecGetValues. My procedure is as follows:
> program main
> #include <petsc/finclude/petscvec.h>
> use petscvec
>       Vec     x
>       PetscInt N,i,ione
>       PetscErrorCode ierr
>       PetscMPIInt rank
>       PetscScalar  one
>       call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>       if (ierr .ne. 0) then
>         print*,'PetscInitialize failed'
>         stop
>       endif
>       one   = 1.0
>       call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>       N = rank + 1
>       call VecCreateMPI(PETSC_COMM_WORLD,N,PETSC_DECIDE,x,ierr)
>       call VecGetSize(x,N,ierr)
>       call VecSet(x,one,ierr)
>       ione = 1
>       do 100 i=0,N-rank-1
>          call VecSetValues(x,ione,i,one,ADD_VALUES,ierr)
>  100  continue
> call VecAssemblyBegin(x,ierr)
>       call VecAssemblyEnd(x,ierr)
>       if (rank .eq. 0) then
>         ione = 0
>         call VecGetValues(x,ione,i,one,ierr)
>       endif
>       call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>       call VecDestroy(x,ierr)
>       call PetscFinalize(ierr)
> end PROGRAM main
> The compilation error is as follows:
> mpif90  -I/root/soft/petsc/3.8.0/include  -o ex2f.o ex2f.F90
> ex2f.F90(62): error #8284: If the actual argument is scalar, the dummy argument shall be scalar unless the actual argument is of type character or is an element of an array that is not assumed shape, pointer, or polymorphic.   [C]
> ex2f.F90(62): error #8284: If the actual argument is scalar, the dummy argument shall be scalar unless the actual argument is of type character or is an element of an array that is not assumed shape, pointer, or polymorphic.   [D]
> compilation aborted for ex2f.F90 (code 1)
> And this error only appears when the Petsc version is higher than 3.8.
> I look forward to hearing from you.
> Thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220522/1421d823/attachment.html>
