[petsc-users] Solver/Preconditioner suggestions
Alfredo J Duarte Gomez aduarteg at utexas.edu
Thu May 19 13:08:43 CDT 2022
Hello,
Yes, the boundary layer is important to the problem and is resolved by the
mesh, although it is a very small part of the mesh.
-Alfredo
On Thu, May 19, 2022 at 1:03 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 19, 2022 at 8:00 AM Alfredo J Duarte Gomez <
> aduarteg at utexas.edu> wrote:
>> Hello Matthew,
>> Thank you for your suggestion on the Laplace solver.
>> About the other systems I would say B and C are mostly dominated by
>> advection, except for diffusive layers at the boundaries.
>> A is a bit more difficult to judge, although it can be expected to have a
>> very large advective component, it also has a large reactive component, and
>> the diffusion dominated layers at the boundaries.
> Is your mesh resolving the boundary layers?
>   Thanks,
>      Matt
>> Thank you,
>> -Alfredo
>> On Thu, May 19, 2022 at 12:31 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, May 19, 2022 at 7:27 AM Alfredo J Duarte Gomez <
>>>> Good afternoon PETSC users,
>>>> I am looking for some suggestions on preconditioners/solvers.
>>>> Currently, I have a custom preconditioner that solves 4 independent
>>>> systems, let's call them A,B,C, and D.
>>>> A is an advective, diffusive, reactive system, although due to some
>>>> coefficient it is the system with the highest condition number and
>>>> therefore the most difficult to solve.
>>>> B and C, are more "standard" advective, diffusion, reactive systems.
>>>> The condition number is not as high as A.
>>>> D is simply the laplacian used to solve an elliptic Poisson equation.
>>>> For more context, A,B, and C need to be recomputed about once every
>>>> time step, while D is a one time cost.
>>>> The problem is 2-D, sizes are on the order of 1-10 million grid points,
>>>> and I am using a structured grid. These usually run on somewhere between
>>>> 100-400 processors.
>>>> Currently  I am solving A,B, and C with the HYPRE Euclid algorithm
>>>> ILU(1), and D is solved with the direct solver MUMPS.
>>>> While these were very useful to get the code working, I am now trying
>>>> to get better parallel scaling/efficiencies and performance. HYPRE euclid
>>>> does not seem to scale super well beyond like 60 procs, and MUMPS has very
>>>> large memory requirements.
>>>> Does anyone have suggestions on more scalable ILU algorithms for A,B,
>>>> and C, or any other good alternatives?
>>> Are these advectively dominated?
>>>> From what I have read, multigrid methods are probably the best
>>>> alternative for D, but I have very little experience with these and they
>>>> seem to require a lot of parameters. Does anyone have pointers on a good
>>>> setup for a multigrid preconditioner?
>>> This is the easy one. If you are using DMDA, just turn on -pc_type mg
>>> and give a number of levels and it should be fine. If not, then use GAMG
>>> and it
>>> should be fine, You could also use Hypre Boomeramg for this since it is
>>> optimized for the 2D Laplacian.
>>>   Thanks,
>>>     Matt
>>>> Thank you and have a good day,
>>>> -Alfredo
>>>> Alfredo Duarte
>>>> Graduate Research Assistant
>>>> The University of Texas at Austin
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Alfredo Duarte
> experiments lead.
> -- Norbert Wiener
Alfredo Duarte
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220519/75b99f96/attachment.html>
