[petsc-users] Convergence issues for SNES NASM
Takahashi, Tadanaga tt73 at njit.edu
Thu May 12 12:03:31 CDT 2022
Thank you for the feedback. We figured out what was causing the issue. We
were using DMGetBoundingBox
<https://petsc.org/main/docs/manualpages/DM/DMGetBoundingBox/> in order to
get the limits of the global domain, but gmin and gmax contained limits for
the local subdomains when we ran the code with NASM. Hence, our local
coordinates xi and yj were completely wrong. The documentation states
that DMGetBoundingBox gets the global limits. I believe this is a mistake.
This is our new output:
$ mpiexec -n 4 ./test1 -t1_N 20 -snes_max_it 50 -snes_monitor -snes_view
-da_overlap 3 -snes_type nasm -snes_nasm_type restrict
  0 SNES Function norm 7.244681057908e+02
  1 SNES Function norm 4.394913250889e+01
  2 SNES Function norm 1.823326663029e+01
  3 SNES Function norm 7.033938512358e+00
  4 SNES Function norm 2.797351504285e+00
  5 SNES Function norm 1.130613777736e+00
  6 SNES Function norm 4.605418417192e-01
  7 SNES Function norm 1.882307001920e-01
  8 SNES Function norm 7.704148683921e-02
  9 SNES Function norm 3.155090858782e-02
 10 SNES Function norm 1.292418188473e-02
 11 SNES Function norm 5.294645671797e-03
 12 SNES Function norm 2.169143207557e-03
 13 SNES Function norm 8.886826738192e-04
 14 SNES Function norm 3.640894847145e-04
 15 SNES Function norm 1.491663153414e-04
 16 SNES Function norm 6.111303899450e-05
 17 SNES Function norm 2.503785968501e-05
 18 SNES Function norm 1.025795062417e-05
 19 SNES Function norm 4.202657921479e-06
SNES Object: 4 MPI processes
  type: nasm
    total subdomain blocks = 4
    Local solver information for first block on rank 0:
    Use -snes_view ::ascii_info_detail to display information for all blocks
    SNES Object: (sub_) 1 MPI processes
      type: newtonls
      maximum iterations=50, maximum function evaluations=10000
      tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
      total number of linear solver iterations=2
      total number of function evaluations=3
      norm schedule ALWAYS
      Jacobian is built using a DMDA local Jacobian
      SNESLineSearch Object: (sub_) 1 MPI processes
        type: bt
          interpolation: cubic
          alpha=1.000000e-04
        maxstep=1.000000e+08, minlambda=1.000000e-12
        tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
        maximum iterations=40
      KSP Object: (sub_) 1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object: (sub_) 1 MPI processes
        type: lu
          out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: nd
          factor fill ratio given 5., needed 2.13732
            Factored matrix follows:
              Mat Object: 1 MPI processes
                type: seqaij
                rows=169, cols=169
                package used to perform factorization: petsc
                total: nonzeros=13339, allocated nonzeros=13339
                  using I-node routines: found 104 nodes, limit used is 5
        linear system matrix = precond matrix:
          type: seqaij
          rows=169, cols=169
          total: nonzeros=6241, allocated nonzeros=6241
          total number of mallocs used during MatSetValues calls=0
            not using I-node routines
  total number of function evaluations=20
problem ex10 on 20 x 20 point 2D grid with d = 3, and eps = 0.082:
  error |u-uexact|_inf = 2.879e-02, |u-uexact|_h = 1.707e-02
On Thu, May 12, 2022 at 9:37 AM Matthew Knepley <knepley at gmail.com> wrote:
> Your subdomain solves do not appear to be producing descent whatsoever.
> Possible reasons:
>   1) Your subdomain Jacobians are wrong (this is usually the problem)
>   2) You have some global coupling field for which local solves give no
> descent. (For this you want nonlinear elimination I think)
>   Thanks,
>      Matt
> On Thu, May 12, 2022 at 9:02 AM Takahashi, Tadanaga <tt73 at njit.edu> wrote:
>> I ran the code with the additional options but the raw output is about
>> 75,000 lines. I cannot paste it directly in the email. The output is in the
>> attached file.
>> On Wed, May 11, 2022 at 11:44 PM Jed Brown <jed at jedbrown.org> wrote:
>>> Can you add -snes_linesearch_monitor -sub_snes_linesearch_monitor
>>> -ksp_converged_reason and send the output??
>>> "Takahashi, Tadanaga" <tt73 at njit.edu> writes:
>>> > Hello,
>>> > We are working on a finite difference solver for a 2D nonlinear PDE
>>> with
>>> > Dirichlet Boundary conditions on a rectangular domain. Our goal is to
>>> solve
>>> > the problem with parallel nonlinear additive Schwarz (NASM) as the
>>> outer
>>> > solver. Our code is similar to SNES example 5
>>> > <https://petsc.org/release/src/snes/tutorials/ex5.c.html>. In example
>>> 5,
>>> > the parallel NASM can be executed with a command like `mpiexec -n 4
>>> ./ex5
>>> > -mms 3 -snes_type nasm -snes_nasm_type restrict -da_overlap 2` which
>>> gives
>>> > a convergent result. We assume this is the correct usage. A comment in
>>> the
>>> > source code for NASM mentions that NASM should be a preconditioner but
>>> > there's no documentation on the usage. The Brune paper does not cover
>>> > parallel NASM either. We observed that increasing the overlap leads to
>>> > fewer Schwarz iterations. The parallelization works seamlessly for an
>>> > arbitrary number of subdomains. This is the type of behavior we were
>>> > expecting from our code.
>>> > Our method uses box-style stencil width d = ceil(N^(1/3)) on a N by N
>>> DMDA.
>>> > The finite difference stencil consists of 4d+1 points spread out in a
>>> > diamond formation. If a stencil point is out of bounds, then it is
>>> > projected onto the boundary curve. Since the nodes on the boundary
>>> curve
>>> > would result in an irregular mesh, we chose not treat boundary nodes as
>>> > unknowns as in Example 5. We use DMDACreate2d to create the DA for the
>>> > interior points and DMDASNESSetFunctionLocal to associate the residue
>>> > function to the SNES object.
>>> > Our code works serially. We have also tested our code
>>> > with Newton-Krylov-Schwarz (NKS) by running something akin to `mpiexec
>>> -n
>>> > <n> ./solve -snes_type newtonls`. We have tested the NKS for several
>>> > quantities of subdomains and overlap and the code works as expected. We
>>> > have some confidence in the correctness of our code. The overlapping
>>> NASM
>>> > was implemented in MATLAB so we know the method converges. However, the
>>> > parallel NASM will not converge with our PETSc code. We don't
>>> understand
>>> > why NKS works while NASM does not. The F-norm residue monotonically
>>> > decreases and then stagnates.
>>> > Here is an example of the output when attempting to run NASM in
>>> parallel:
>>> > takahashi at ubuntu:~/Desktop/MA-DDM/Cpp/Rectangle$ mpiexec -n 4 ./test1
>>> -t1_N
>>> > 20 -snes_max_it 50 -snes_monitor -snes_view -da_overlap 3 -snes_type
>>> nasm
>>> >   1 SNES Function norm 1.237688062971e+02
>>> >   2 SNES Function norm 1.068926073552e+02
>>> >   3 SNES Function norm 1.027563237834e+02
>>> >   4 SNES Function norm 1.022184806736e+02
>>> >   5 SNES Function norm 1.020818227640e+02
>>> >   6 SNES Function norm 1.020325629121e+02
>>> >   7 SNES Function norm 1.020149036595e+02
>>> >   8 SNES Function norm 1.020088110545e+02
>>> >   9 SNES Function norm 1.020067198030e+02
>>> >  10 SNES Function norm 1.020060034469e+02
>>> >  11 SNES Function norm 1.020057582380e+02
>>> >  12 SNES Function norm 1.020056743241e+02
>>> >  13 SNES Function norm 1.020056456101e+02
>>> >  14 SNES Function norm 1.020056357849e+02
>>> >  15 SNES Function norm 1.020056324231e+02
>>> >  16 SNES Function norm 1.020056312727e+02
>>> >  17 SNES Function norm 1.020056308791e+02
>>> >  18 SNES Function norm 1.020056307444e+02
>>> >  19 SNES Function norm 1.020056306983e+02
>>> >  20 SNES Function norm 1.020056306826e+02
>>> >  21 SNES Function norm 1.020056306772e+02
>>> >  22 SNES Function norm 1.020056306753e+02
>>> >  23 SNES Function norm 1.020056306747e+02
>>> >  24 SNES Function norm 1.020056306745e+02
>>> >  25 SNES Function norm 1.020056306744e+02
>>> >  26 SNES Function norm 1.020056306744e+02
>>> >  27 SNES Function norm 1.020056306744e+02
>>> >  28 SNES Function norm 1.020056306744e+02
>>> >  29 SNES Function norm 1.020056306744e+02
>>> >  30 SNES Function norm 1.020056306744e+02
>>> >  31 SNES Function norm 1.020056306744e+02
>>> >  32 SNES Function norm 1.020056306744e+02
>>> >  33 SNES Function norm 1.020056306744e+02
>>> >  34 SNES Function norm 1.020056306744e+02
>>> >  35 SNES Function norm 1.020056306744e+02
>>> >  36 SNES Function norm 1.020056306744e+02
>>> >  37 SNES Function norm 1.020056306744e+02
>>> >  38 SNES Function norm 1.020056306744e+02
>>> >  39 SNES Function norm 1.020056306744e+02
>>> >  40 SNES Function norm 1.020056306744e+02
>>> >  41 SNES Function norm 1.020056306744e+02
>>> >  42 SNES Function norm 1.020056306744e+02
>>> >  43 SNES Function norm 1.020056306744e+02
>>> >  44 SNES Function norm 1.020056306744e+02
>>> >  45 SNES Function norm 1.020056306744e+02
>>> >  46 SNES Function norm 1.020056306744e+02
>>> >  47 SNES Function norm 1.020056306744e+02
>>> >  48 SNES Function norm 1.020056306744e+02
>>> >  49 SNES Function norm 1.020056306744e+02
>>> >  50 SNES Function norm 1.020056306744e+02
>>> >   type: nasm
>>> blocks
>>> >       type: newtonls
>>> >       total number of linear solver iterations=22
>>> >       total number of function evaluations=40
>>> >         type: bt
>>> >           alpha=1.000000e-04
>>> > lambda=1.000000e-08
>>> >         type: preonly
>>> >         type: lu
>>> >           matrix ordering: nd
>>> >                 type: seqaij
>>> >                 rows=169, cols=169
>>> is 5
>>> >           type: seqaij
>>> >           rows=169, cols=169
>>> >   total number of function evaluations=51
>>> >   error |u-uexact|_inf = 3.996e-01, |u-uexact|_h = 2.837e-01
>>> > We have been stuck on this for a while now. We do not know how to debug
>>> > this issue. Please let us know if you have any insights.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220512/23503124/attachment.html>
