[petsc-users] Convergence issues for SNES NASM
Takahashi, Tadanaga tt73 at njit.edu
Thu May 12 08:01:47 CDT 2022
I ran the code with the additional options but the raw output is about
75,000 lines. I cannot paste it directly in the email. The output is in the
attached file.
On Wed, May 11, 2022 at 11:44 PM Jed Brown <jed at jedbrown.org> wrote:
> Can you add -snes_linesearch_monitor -sub_snes_linesearch_monitor
> -ksp_converged_reason and send the output??
> "Takahashi, Tadanaga" <tt73 at njit.edu> writes:
> > Hello,
> > We are working on a finite difference solver for a 2D nonlinear PDE with
> > Dirichlet Boundary conditions on a rectangular domain. Our goal is to
> solve
> > the problem with parallel nonlinear additive Schwarz (NASM) as the outer
> > solver. Our code is similar to SNES example 5
> > <https://petsc.org/release/src/snes/tutorials/ex5.c.html>. In example 5,
> > the parallel NASM can be executed with a command like `mpiexec -n 4 ./ex5
> > -mms 3 -snes_type nasm -snes_nasm_type restrict -da_overlap 2` which
> gives
> > a convergent result. We assume this is the correct usage. A comment in
> the
> > source code for NASM mentions that NASM should be a preconditioner but
> > there's no documentation on the usage. The Brune paper does not cover
> > parallel NASM either. We observed that increasing the overlap leads to
> > fewer Schwarz iterations. The parallelization works seamlessly for an
> > arbitrary number of subdomains. This is the type of behavior we were
> > expecting from our code.
> > Our method uses box-style stencil width d = ceil(N^(1/3)) on a N by N
> DMDA.
> > The finite difference stencil consists of 4d+1 points spread out in a
> > diamond formation. If a stencil point is out of bounds, then it is
> > projected onto the boundary curve. Since the nodes on the boundary curve
> > would result in an irregular mesh, we chose not treat boundary nodes as
> > unknowns as in Example 5. We use DMDACreate2d to create the DA for the
> > interior points and DMDASNESSetFunctionLocal to associate the residue
> > function to the SNES object.
> > Our code works serially. We have also tested our code
> > with Newton-Krylov-Schwarz (NKS) by running something akin to `mpiexec -n
> > <n> ./solve -snes_type newtonls`. We have tested the NKS for several
> > quantities of subdomains and overlap and the code works as expected. We
> > have some confidence in the correctness of our code. The overlapping NASM
> > was implemented in MATLAB so we know the method converges. However, the
> > parallel NASM will not converge with our PETSc code. We don't understand
> > why NKS works while NASM does not. The F-norm residue monotonically
> > decreases and then stagnates.
> > Here is an example of the output when attempting to run NASM in parallel:
> > takahashi at ubuntu:~/Desktop/MA-DDM/Cpp/Rectangle$ mpiexec -n 4 ./test1
> -t1_N
> > 20 -snes_max_it 50 -snes_monitor -snes_view -da_overlap 3 -snes_type nasm
> >   0 SNES Function norm 7.244681057908e+02
> >   1 SNES Function norm 1.237688062971e+02
> >   2 SNES Function norm 1.068926073552e+02
> >   3 SNES Function norm 1.027563237834e+02
> >   4 SNES Function norm 1.022184806736e+02
> >   5 SNES Function norm 1.020818227640e+02
> >   6 SNES Function norm 1.020325629121e+02
> >   7 SNES Function norm 1.020149036595e+02
> >   8 SNES Function norm 1.020088110545e+02
> >   9 SNES Function norm 1.020067198030e+02
> >  10 SNES Function norm 1.020060034469e+02
> >  11 SNES Function norm 1.020057582380e+02
> >  12 SNES Function norm 1.020056743241e+02
> >  13 SNES Function norm 1.020056456101e+02
> >  14 SNES Function norm 1.020056357849e+02
> >  15 SNES Function norm 1.020056324231e+02
> >  16 SNES Function norm 1.020056312727e+02
> >  17 SNES Function norm 1.020056308791e+02
> >  18 SNES Function norm 1.020056307444e+02
> >  19 SNES Function norm 1.020056306983e+02
> >  20 SNES Function norm 1.020056306826e+02
> >  21 SNES Function norm 1.020056306772e+02
> >  22 SNES Function norm 1.020056306753e+02
> >  23 SNES Function norm 1.020056306747e+02
> >  24 SNES Function norm 1.020056306745e+02
> >  25 SNES Function norm 1.020056306744e+02
> >  26 SNES Function norm 1.020056306744e+02
> >  27 SNES Function norm 1.020056306744e+02
> >  28 SNES Function norm 1.020056306744e+02
> >  29 SNES Function norm 1.020056306744e+02
> >  30 SNES Function norm 1.020056306744e+02
> >  31 SNES Function norm 1.020056306744e+02
> >  32 SNES Function norm 1.020056306744e+02
> >  33 SNES Function norm 1.020056306744e+02
> >  34 SNES Function norm 1.020056306744e+02
> >  35 SNES Function norm 1.020056306744e+02
> >  36 SNES Function norm 1.020056306744e+02
> >  37 SNES Function norm 1.020056306744e+02
> >  38 SNES Function norm 1.020056306744e+02
> >  39 SNES Function norm 1.020056306744e+02
> >  40 SNES Function norm 1.020056306744e+02
> >  41 SNES Function norm 1.020056306744e+02
> >  42 SNES Function norm 1.020056306744e+02
> >  43 SNES Function norm 1.020056306744e+02
> >  44 SNES Function norm 1.020056306744e+02
> >  45 SNES Function norm 1.020056306744e+02
> >  46 SNES Function norm 1.020056306744e+02
> >  47 SNES Function norm 1.020056306744e+02
> >  48 SNES Function norm 1.020056306744e+02
> >  49 SNES Function norm 1.020056306744e+02
> >  50 SNES Function norm 1.020056306744e+02
> > SNES Object: 4 MPI processes
> >   type: nasm
> >     total subdomain blocks = 4
> >     Local solver information for first block on rank 0:
> >     Use -snes_view ::ascii_info_detail to display information for all
> blocks
> >     SNES Object: (sub_) 1 MPI processes
> >       type: newtonls
> >       maximum iterations=50, maximum function evaluations=10000
> >       tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> >       total number of linear solver iterations=22
> >       total number of function evaluations=40
> >       norm schedule ALWAYS
> >       Jacobian is built using a DMDA local Jacobian
> >       SNESLineSearch Object: (sub_) 1 MPI processes
> >         type: bt
> >           interpolation: cubic
> >           alpha=1.000000e-04
> >         maxstep=1.000000e+08, minlambda=1.000000e-12
> >         tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> > lambda=1.000000e-08
> >         maximum iterations=40
> >       KSP Object: (sub_) 1 MPI processes
> >         type: preonly
> >         maximum iterations=10000, initial guess is zero
> >         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >         left preconditioning
> >         using NONE norm type for convergence test
> >       PC Object: (sub_) 1 MPI processes
> >         type: lu
> >           out-of-place factorization
> >           tolerance for zero pivot 2.22045e-14
> >           matrix ordering: nd
> >           factor fill ratio given 5., needed 2.13732
> >             Factored matrix follows:
> >               Mat Object: 1 MPI processes
> >                 type: seqaij
> >                 rows=169, cols=169
> >                 package used to perform factorization: petsc
> >                 total: nonzeros=13339, allocated nonzeros=13339
> >                   using I-node routines: found 104 nodes, limit used is 5
> >         linear system matrix = precond matrix:
> >           type: seqaij
> >           rows=169, cols=169
> >           total: nonzeros=6241, allocated nonzeros=6241
> >           total number of mallocs used during MatSetValues calls=0
> >             not using I-node routines
> >   total number of function evaluations=51
> > problem ex10 on 20 x 20 point 2D grid with d = 3, and eps = 0.082:
> >   error |u-uexact|_inf = 3.996e-01, |u-uexact|_h = 2.837e-01
> > We have been stuck on this for a while now. We do not know how to debug
> > this issue. Please let us know if you have any insights.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220512/fc68d9ae/attachment-0001.html>
        Line search: Using full step: fnorm 2.366767922608e+03 gnorm 7.324644673012e+02
        Line search: Using full step: fnorm 2.366767922608e+03 gnorm 7.368257945624e+02
          Line search: Using full step: fnorm 7.324644673012e+02 gnorm 3.030339094711e+02
        Line search: Using full step: fnorm 7.368257945624e+02 gnorm 3.036925065488e+02
        Line search: Using full step: fnorm 3.030339094711e+02 gnorm 1.710013987307e+02
        Line search: Using full step: fnorm 3.036925065488e+02 gnorm 1.710672486390e+02
        Line search: gnorm after quadratic fit 1.064831535546e+02
        Line search: Quadratically determined step, lambda=4.8598042423461241e-01
        Line search: Quadratically determined step, lambda=4.8598042423461130e-01
        Line search: gnorm after quadratic fit 1.064869986827e+02
        Line search: Quadratically determined step, lambda=4.8628691897289167e-01
        Line search: Quadratically determined step, lambda=4.8628691897289139e-01
        Line search: Using full step: fnorm 1.064831535546e+02 gnorm 2.437895828773e+01
        Line search: Using full step: fnorm 1.064869986827e+02 gnorm 2.437541131039e+01
        Line search: gnorm after quadratic fit 1.904344322941e+01
        Line search: Quadratically determined step, lambda=2.3856317774238858e-01
        Line search: gnorm after quadratic fit 1.904344322942e+01
        Line search: Quadratically determined step, lambda=2.3856317774239236e-01
        Line search: gnorm after quadratic fit 1.904019307986e+01
        Line search: Quadratically determined step, lambda=2.3849940999249908e-01
        Line search: Quadratically determined step, lambda=2.3849940999251007e-01
        Line search: Using full step: fnorm 1.904344322942e+01 gnorm 1.534182314959e+00
        Line search: Using full step: fnorm 1.904344322941e+01 gnorm 1.534182314959e+00
        Line search: Using full step: fnorm 1.904019307986e+01 gnorm 1.533532574103e+00
        Line search: Using full step: fnorm 1.904019307986e+01 gnorm 1.533532574104e+00
          Line search: Using full step: fnorm 1.534182314959e+00 gnorm 4.230505579099e-02
      Line search: Using full step: fnorm 1.534182314959e+00 gnorm 4.230505579101e-02
        Line search: Using full step: fnorm 1.533532574103e+00 gnorm 4.226729088952e-02
        Line search: Using full step: fnorm 1.533532574104e+00 gnorm 4.226729088953e-02
        Line search: Using full step: fnorm 4.230505579101e-02 gnorm 4.234652015899e-05
        Line search: Using full step: fnorm 4.230505579099e-02 gnorm 4.234652021221e-05
        Line search: Using full step: fnorm 4.226729088952e-02 gnorm 4.226810598217e-05
        Line search: Using full step: fnorm 4.226729088953e-02 gnorm 4.226810597805e-05
        Line search: Using full step: fnorm 4.234652021221e-05 gnorm 4.372642285455e-11
        Line search: Using full step: fnorm 4.234652015899e-05 gnorm 4.372470547882e-11
        Line search: Using full step: fnorm 4.226810597805e-05 gnorm 4.356893319390e-11
        Line search: Using full step: fnorm 4.226810598217e-05 gnorm 4.352576718601e-11
          Line search: Using full step: fnorm 4.440079063783e+02 gnorm 1.591389440443e+02
        Line search: Using full step: fnorm 1.591389440443e+02 gnorm 6.251095458324e+01
        Line search: Using full step: fnorm 6.251095458324e+01 gnorm 4.464370931338e+01
        Line search: Using full step: fnorm 4.464370931338e+01 gnorm 2.153664033989e+01
        Line search: Using full step: fnorm 2.153664033989e+01 gnorm 2.367280398205e+00
        Line search: Using full step: fnorm 2.367280398205e+00 gnorm 1.607012542246e-01
        Line search: Using full step: fnorm 2.367280398205e+00 gnorm 1.607012542248e-01
        Line search: Using full step: fnorm 1.607012542246e-01 gnorm 1.008059167344e-03
        Line search: Using full step: fnorm 1.607012542246e-01 gnorm 1.008059167299e-03
        Line search: Using full step: fnorm 1.607012542248e-01 gnorm 1.008059167106e-03
        Line search: Using full step: fnorm 1.607012542246e-01 gnorm 1.008059167242e-03
        Line search: Using full step: fnorm 1.008059167344e-03 gnorm 5.435658530662e-08
        Line search: Using full step: fnorm 1.008059167299e-03 gnorm 5.435653068089e-08
        Line search: Using full step: fnorm 1.008059167106e-03 gnorm 5.435660600498e-08
        Line search: Using full step: fnorm 1.008059167242e-03 gnorm 5.435649103726e-08
        Line search: Using full step: fnorm 2.068615558922e+02 gnorm 1.393723341438e+02
        Line search: Using full step: fnorm 1.393723341438e+02 gnorm 5.409936246836e+01
        Line search: gnorm after quadratic fit 3.800259660005e+01
        Line search: Quadratically determined step, lambda=3.8911460926523889e-01
        Line search: Quadratically determined step, lambda=3.8911460926523883e-01
        Line search: Quadratically determined step, lambda=3.8911460926523928e-01
        Line search: Quadratically determined step, lambda=3.8911460926523894e-01
        Line search: Using full step: fnorm 3.800259660005e+01 gnorm 9.463901192391e+00
        Line search: Using full step: fnorm 9.463901192391e+00 gnorm 4.333340417561e+00
        Line search: Using full step: fnorm 4.333340417561e+00 gnorm 3.981910153224e-01
        Line search: Using full step: fnorm 3.981910153224e-01 gnorm 1.168795270601e-03
        Line search: Using full step: fnorm 3.981910153224e-01 gnorm 1.168795270614e-03
        Line search: Using full step: fnorm 3.981910153224e-01 gnorm 1.168795270615e-03
        Line search: Using full step: fnorm 3.981910153224e-01 gnorm 1.168795270605e-03
        Line search: Using full step: fnorm 1.168795270601e-03 gnorm 5.836712980412e-08
        Line search: Using full step: fnorm 1.168795270614e-03 gnorm 5.836712173140e-08
        Line search: Using full step: fnorm 1.168795270615e-03 gnorm 5.836709729918e-08
        Line search: Using full step: fnorm 1.168795270605e-03 gnorm 5.836712171400e-08
        Line search: gnorm after quadratic fit 5.896621528793e+01
        Line search: Quadratically determined step, lambda=3.3417411759577009e-01
        Line search: Quadratically determined step, lambda=3.3417411759577059e-01
        Line search: Quadratically determined step, lambda=3.3417411759577054e-01
        Line search: Quadratically determined step, lambda=3.3417411759577015e-01
        Line search: gnorm after quadratic fit 4.833412049945e+01
        Line search: Quadratically determined step, lambda=1.8153887761288992e-01
        Line search: Quadratically determined step, lambda=1.8153887761288856e-01
        Line search: Quadratically determined step, lambda=1.8153887761288998e-01
        Line search: Quadratically determined step, lambda=1.8153887761288900e-01
        Line search: gnorm after quadratic fit 4.211065287968e+01
        Line search: Quadratically determined step, lambda=1.2777212868296678e-01
        Line search: Quadratically determined step, lambda=1.2777212868296670e-01
        Line search: Quadratically determined step, lambda=1.2777212868296631e-01
        Line search: Quadratically determined step, lambda=1.2777212868296728e-01
        Line search: gnorm after quadratic fit 3.737772762235e+01
        Line search: Quadratically determined step, lambda=1.1268327473970392e-01
        Line search: Quadratically determined step, lambda=1.1268327473970409e-01
        Line search: Quadratically determined step, lambda=1.1268327473970415e-01
        Line search: Quadratically determined step, lambda=1.1268327473970390e-01
        Line search: gnorm after quadratic fit 3.358979454151e+01
        Line search: Quadratically determined step, lambda=1.0000000000000001e-01
        Line search: gnorm after quadratic fit 2.997444184268e+01
        Line search: gnorm after quadratic fit 2.689133513643e+01
        Line search: Quadratically determined step, lambda=1.0370873563461103e-01
        Line search: Quadratically determined step, lambda=1.0370873563460987e-01
        Line search: Quadratically determined step, lambda=1.0370873563461043e-01
        Line search: gnorm after quadratic fit 2.422821965493e+01
        Line search: gnorm after quadratic fit 2.170508461365e+01
        Line search: gnorm after quadratic fit 1.869338837974e+01
        Line search: Quadratically determined step, lambda=1.4354823991582735e-01
        Line search: Quadratically determined step, lambda=1.4354823991582763e-01
        Line search: Quadratically determined step, lambda=1.4354823991582627e-01
        Line search: Quadratically determined step, lambda=1.4354823991582696e-01
        Line search: gnorm after quadratic fit 1.649244414319e+01
        Line search: Quadratically determined step, lambda=1.1558407038803790e-01
        Line search: gnorm after quadratic fit 1.649244414318e+01
        Line search: Quadratically determined step, lambda=1.1558407038805768e-01
        Line search: Quadratically determined step, lambda=1.1558407038806513e-01
        Line search: Quadratically determined step, lambda=1.1558407038803363e-01
        Line search: gnorm after quadratic fit 1.408701910902e+01
        Line search: Quadratically determined step, lambda=1.4400542250644904e-01
        Line search: Quadratically determined step, lambda=1.4400542250644563e-01
        Line search: Quadratically determined step, lambda=1.4400542250644327e-01
        Line search: Quadratically determined step, lambda=1.4400542250645118e-01
        Line search: gnorm after quadratic fit 1.252374072903e+01
        Line search: Quadratically determined step, lambda=1.1638377830367309e-01
        Line search: Quadratically determined step, lambda=1.1638377830366374e-01
        Line search: Quadratically determined step, lambda=1.1638377830366450e-01
        Line search: Quadratically determined step, lambda=1.1638377830366908e-01
        Line search: gnorm after quadratic fit 1.073719373988e+01
        Line search: Using full step: fnorm 1.073719373988e+01 gnorm 3.796196824527e+00
        Line search: Using full step: fnorm 3.796196824527e+00 gnorm 3.100229870781e-01
        Line search: Using full step: fnorm 3.796196824527e+00 gnorm 3.100229870782e-01
        Line search: Using full step: fnorm 3.100229870781e-01 gnorm 3.833811946146e-03
        Line search: Using full step: fnorm 3.100229870781e-01 gnorm 3.833811945925e-03
        Line search: Using full step: fnorm 3.100229870782e-01 gnorm 3.833811946143e-03
        Line search: Using full step: fnorm 3.100229870781e-01 gnorm 3.833811946166e-03
        Line search: Using full step: fnorm 3.833811946146e-03 gnorm 6.463398868533e-07
        Line search: Using full step: fnorm 3.833811945925e-03 gnorm 6.463398761639e-07
        Line search: Using full step: fnorm 3.833811946143e-03 gnorm 6.463398805254e-07
        Line search: Using full step: fnorm 3.833811946166e-03 gnorm 6.463398843583e-07
        Line search: gnorm after quadratic fit 5.051193144184e+01
        Line search: Quadratically determined step, lambda=2.3451615293273340e-01
        Line search: Quadratically determined step, lambda=2.3451615293273262e-01
        Line search: Quadratically determined step, lambda=2.3451615293273320e-01
        Line search: Quadratically determined step, lambda=2.3451615293273356e-01
        Line search: gnorm after quadratic fit 4.269992085591e+01
        Line search: Quadratically determined step, lambda=1.5271197767584788e-01
        Line search: Quadratically determined step, lambda=1.5271197767584857e-01
        Line search: Quadratically determined step, lambda=1.5271197767584768e-01
        Line search: Quadratically determined step, lambda=1.5271197767584765e-01
        Line search: gnorm after quadratic fit 3.798269131216e+01
        Line search: Quadratically determined step, lambda=1.0906531365480246e-01
        Line search: Quadratically determined step, lambda=1.0906531365480227e-01
        Line search: Quadratically determined step, lambda=1.0906531365480203e-01
        Line search: Quadratically determined step, lambda=1.0906531365480178e-01
        Line search: gnorm after quadratic fit 3.417393882200e+01
        Line search: gnorm after quadratic fit 3.058425475891e+01
        Line search: gnorm after quadratic fit 2.749352490002e+01
        Line search: gnorm after quadratic fit 2.459358093530e+01
        Line search: gnorm after quadratic fit 2.213608601165e+01
        Line search: gnorm after quadratic fit 1.991264702666e+01
        Line search: gnorm after quadratic fit 1.792317241133e+01
        Line search: gnorm after quadratic fit 1.573510323244e+01
        Line search: gnorm after quadratic fit 1.419005399634e+01
        Line search: gnorm after quadratic fit 1.203189063298e+01
        Line search: gnorm after quadratic fit 1.083620093528e+01
        Line search: gnorm after quadratic fit 9.761171525567e+00
        Line search: gnorm after quadratic fit 8.829619997117e+00
        Line search: gnorm after quadratic fit 7.349100833091e+00
        Line search: Using full step: fnorm 7.349100833091e+00 gnorm 3.047940208239e+00
        Line search: Using full step: fnorm 7.349100833091e+00 gnorm 3.047940208238e+00
        Line search: Using full step: fnorm 3.047940208239e+00 gnorm 1.931726734637e-01
        Line search: Using full step: fnorm 3.047940208238e+00 gnorm 1.931726734637e-01
        Line search: Using full step: fnorm 1.931726734637e-01 gnorm 1.178710338200e-03
        Line search: Using full step: fnorm 1.931726734637e-01 gnorm 1.178710338211e-03
        Line search: Using full step: fnorm 1.931726734637e-01 gnorm 1.178710338199e-03
        Line search: Using full step: fnorm 1.931726734637e-01 gnorm 1.178710338187e-03
        Line search: Using full step: fnorm 1.178710338200e-03 gnorm 5.190129168255e-08
        Line search: Using full step: fnorm 1.178710338211e-03 gnorm 5.190120960392e-08
        Line search: Using full step: fnorm 1.178710338199e-03 gnorm 5.190130947964e-08
        Line search: Using full step: fnorm 1.178710338187e-03 gnorm 5.190130139428e-08
        Line search: gnorm after quadratic fit 4.886628019956e+01
        Line search: Quadratically determined step, lambda=2.2353485288897126e-01
        Line search: Quadratically determined step, lambda=2.2353485288897157e-01
        Line search: Quadratically determined step, lambda=2.2353485288897193e-01
        Line search: Quadratically determined step, lambda=2.2353485288897082e-01
        Line search: gnorm after quadratic fit 4.156511898210e+01
        Line search: Quadratically determined step, lambda=1.4738191720329524e-01
        Line search: Quadratically determined step, lambda=1.4738191720329444e-01
        Line search: Quadratically determined step, lambda=1.4738191720329460e-01
        Line search: Quadratically determined step, lambda=1.4738191720329588e-01
        Line search: gnorm after quadratic fit 3.629487597696e+01
        Line search: Quadratically determined step, lambda=1.2653580820893240e-01
        Line search: Quadratically determined step, lambda=1.2653580820893176e-01
        Line search: Quadratically determined step, lambda=1.2653580820893223e-01
        Line search: Quadratically determined step, lambda=1.2653580820893293e-01
        Line search: gnorm after quadratic fit 3.255668624221e+01
        Line search: gnorm after quadratic fit 2.923824703249e+01
        Line search: gnorm after quadratic fit 2.622891008102e+01
        Line search: gnorm after quadratic fit 2.346428241159e+01
        Line search: gnorm after quadratic fit 2.087798992161e+01
        Line search: gnorm after quadratic fit 1.879053026538e+01
        Line search: gnorm after quadratic fit 1.691064054715e+01
        Line search: gnorm after quadratic fit 1.473972706400e+01
        Line search: gnorm after quadratic fit 1.331644381674e+01
        Line search: gnorm after quadratic fit 1.120935946848e+01
        Line search: gnorm after quadratic fit 1.009411971383e+01
        Line search: gnorm after quadratic fit 9.139993160275e+00
        Line search: gnorm after quadratic fit 9.139993160274e+00
        Line search: gnorm after quadratic fit 8.295651769362e+00
        Line search: gnorm after quadratic fit 6.929821666362e+00
        Line search: Using full step: fnorm 6.929821666362e+00 gnorm 3.811156538807e+00
        Line search: Using full step: fnorm 6.929821666362e+00 gnorm 3.811156538808e+00
        Line search: Using full step: fnorm 3.811156538807e+00 gnorm 2.895412800626e-01
        Line search: Using full step: fnorm 3.811156538808e+00 gnorm 2.895412800628e-01
        Line search: Using full step: fnorm 3.811156538808e+00 gnorm 2.895412800627e-01
        Line search: Using full step: fnorm 3.811156538807e+00 gnorm 2.895412800629e-01
        Line search: Using full step: fnorm 2.895412800626e-01 gnorm 2.877381403695e-03
        Line search: Using full step: fnorm 2.895412800628e-01 gnorm 2.877381403684e-03
        Line search: Using full step: fnorm 2.895412800627e-01 gnorm 2.877381403700e-03
        Line search: Using full step: fnorm 2.895412800629e-01 gnorm 2.877381403684e-03
        Line search: Using full step: fnorm 2.877381403695e-03 gnorm 3.430505065554e-07
        Line search: Using full step: fnorm 2.877381403684e-03 gnorm 3.430506224103e-07
        Line search: Using full step: fnorm 2.877381403700e-03 gnorm 3.430505172022e-07
        Line search: Using full step: fnorm 2.877381403684e-03 gnorm 3.430506209398e-07
        Line search: gnorm after quadratic fit 4.849065472094e+01
        Line search: Quadratically determined step, lambda=2.2227399338709344e-01
        Line search: Quadratically determined step, lambda=2.2227399338709419e-01
        Line search: Quadratically determined step, lambda=2.2227399338709405e-01
        Line search: Quadratically determined step, lambda=2.2227399338709330e-01
        Line search: gnorm after quadratic fit 4.129572063278e+01
        Line search: Quadratically determined step, lambda=1.4630139507222042e-01
        Line search: Quadratically determined step, lambda=1.4630139507221984e-01
        Line search: Quadratically determined step, lambda=1.4630139507222006e-01
        Line search: Quadratically determined step, lambda=1.4630139507222079e-01
        Line search: gnorm after quadratic fit 3.609599739550e+01
        Line search: Quadratically determined step, lambda=1.2573103389295170e-01
        Line search: Quadratically determined step, lambda=1.2573103389295126e-01
        Line search: Quadratically determined step, lambda=1.2573103389295212e-01
        Line search: gnorm after quadratic fit 3.237486508254e+01
        Line search: gnorm after quadratic fit 2.907078033076e+01
        Line search: gnorm after quadratic fit 2.606250910062e+01
        Line search: gnorm after quadratic fit 2.329251388799e+01
        Line search: gnorm after quadratic fit 2.095123167273e+01
        Line search: gnorm after quadratic fit 1.885175444728e+01
        Line search: gnorm after quadratic fit 1.696386123167e+01
        Line search: gnorm after quadratic fit 1.479780029534e+01
        Line search: gnorm after quadratic fit 1.322264859603e+01
        Line search: gnorm after quadratic fit 1.112379529750e+01
        Line search: gnorm after quadratic fit 1.001772385067e+01
        Line search: gnorm after quadratic fit 9.086635603164e+00
        Line search: gnorm after quadratic fit 8.253113508182e+00
        Line search: gnorm after quadratic fit 6.978398714791e+00
        Line search: Using full step: fnorm 6.978398714791e+00 gnorm 4.701073111337e+00
        Line search: Using full step: fnorm 6.978398714791e+00 gnorm 4.701073111336e+00
        Line search: Using full step: fnorm 4.701073111337e+00 gnorm 4.125054503988e-01
        Line search: Using full step: fnorm 4.701073111337e+00 gnorm 4.125054503987e-01
        Line search: Using full step: fnorm 4.701073111336e+00 gnorm 4.125054503987e-01
        Line search: Using full step: fnorm 4.701073111337e+00 gnorm 4.125054503989e-01
        Line search: Using full step: fnorm 4.125054503988e-01 gnorm 5.939967797068e-03
        Line search: Using full step: fnorm 4.125054503987e-01 gnorm 5.939967797220e-03
        Line search: Using full step: fnorm 4.125054503987e-01 gnorm 5.939967797213e-03
        Line search: Using full step: fnorm 4.125054503989e-01 gnorm 5.939967797204e-03
        Line search: Using full step: fnorm 5.939967797068e-03 gnorm 1.486255672053e-06
        Line search: Using full step: fnorm 5.939967797220e-03 gnorm 1.486255777495e-06
        Line search: Using full step: fnorm 5.939967797213e-03 gnorm 1.486255775476e-06
        Line search: Using full step: fnorm 5.939967797204e-03 gnorm 1.486255670687e-06
        Line search: Using full step: fnorm 1.486255672053e-06 gnorm 1.166495899486e-12
        Line search: Using full step: fnorm 1.486255777495e-06 gnorm 1.108596666737e-12
        Line search: Using full step: fnorm 1.486255775476e-06 gnorm 1.003003229493e-12
        Line search: Using full step: fnorm 1.486255670687e-06 gnorm 9.972379925769e-13
        Line search: gnorm after quadratic fit 4.838147275872e+01
        Line search: Quadratically determined step, lambda=2.2207338891545284e-01
        Line search: Quadratically determined step, lambda=2.2207338891545234e-01
        Line search: Quadratically determined step, lambda=2.2207338891545256e-01
        Line search: Quadratically determined step, lambda=2.2207338891545136e-01
        Line search: gnorm after quadratic fit 4.121442580568e+01
        Line search: Quadratically determined step, lambda=1.4603704675067056e-01
        Line search: Quadratically determined step, lambda=1.4603704675066992e-01
        Line search: Quadratically determined step, lambda=1.4603704675067067e-01
        Line search: Quadratically determined step, lambda=1.4603704675066970e-01
        Line search: gnorm after quadratic fit 3.604303174308e+01
        Line search: Quadratically determined step, lambda=1.2531846663251531e-01
        Line search: Quadratically determined step, lambda=1.2531846663251558e-01
        Line search: Quadratically determined step, lambda=1.2531846663251572e-01
        Line search: Quadratically determined step, lambda=1.2531846663251631e-01
        Line search: gnorm after quadratic fit 3.232563641995e+01
        Line search: gnorm after quadratic fit 2.902451491358e+01
        Line search: gnorm after quadratic fit 2.601539366454e+01
        Line search: gnorm after quadratic fit 2.322301611665e+01
        Line search: gnorm after quadratic fit 2.089046648609e+01
        Line search: gnorm after quadratic fit 1.879672311405e+01
        Line search: gnorm after quadratic fit 1.691425389869e+01
        Line search: gnorm after quadratic fit 1.475592577765e+01
        Line search: gnorm after quadratic fit 1.318368517224e+01
        Line search: gnorm after quadratic fit 1.109051115021e+01
        Line search: gnorm after quadratic fit 9.987518649316e+00
        Line search: gnorm after quadratic fit 9.065233700103e+00
        Line search: gnorm after quadratic fit 8.235976027732e+00
        Line search: gnorm after quadratic fit 6.990239949430e+00
        Line search: Using full step: fnorm 6.990239949430e+00 gnorm 5.066433100375e+00
        Line search: Using full step: fnorm 6.990239949430e+00 gnorm 5.066433100374e+00
        Line search: Using full step: fnorm 5.066433100375e+00 gnorm 4.665323835740e-01
        Line search: Using full step: fnorm 5.066433100374e+00 gnorm 4.665323835740e-01
        Line search: Using full step: fnorm 5.066433100374e+00 gnorm 4.665323835741e-01
        Line search: Using full step: fnorm 5.066433100374e+00 gnorm 4.665323835739e-01
        Line search: Using full step: fnorm 4.665323835740e-01 gnorm 7.619474682764e-03
        Line search: Using full step: fnorm 4.665323835740e-01 gnorm 7.619474682879e-03
        Line search: Using full step: fnorm 4.665323835741e-01 gnorm 7.619474682768e-03
        Line search: Using full step: fnorm 4.665323835739e-01 gnorm 7.619474682920e-03
        Line search: Using full step: fnorm 7.619474682764e-03 gnorm 2.454074436388e-06
        Line search: Using full step: fnorm 7.619474682879e-03 gnorm 2.454074554498e-06
        Line search: Using full step: fnorm 7.619474682768e-03 gnorm 2.454074425433e-06
        Line search: Using full step: fnorm 7.619474682920e-03 gnorm 2.454074566500e-06
        Line search: Using full step: fnorm 2.454074436388e-06 gnorm 9.474867051356e-13
        Line search: Using full step: fnorm 2.454074554498e-06 gnorm 9.363644684245e-13
        Line search: Using full step: fnorm 2.454074425433e-06 gnorm 9.754856446921e-13
        Line search: Using full step: fnorm 2.454074566500e-06 gnorm 1.010630744432e-12
        Line search: gnorm after quadratic fit 4.834620808075e+01
        Line search: Quadratically determined step, lambda=2.2202847256548619e-01
        Line search: Quadratically determined step, lambda=2.2202847256548550e-01
        Line search: Quadratically determined step, lambda=2.2202847256548586e-01
        Line search: Quadratically determined step, lambda=2.2202847256548650e-01
        Line search: gnorm after quadratic fit 4.118773186956e+01
        Line search: Quadratically determined step, lambda=1.4595922116342475e-01
        Line search: Quadratically determined step, lambda=1.4595922116342439e-01
        Line search: Quadratically determined step, lambda=1.4595922116342333e-01
        Line search: Quadratically determined step, lambda=1.4595922116342477e-01
        Line search: gnorm after quadratic fit 3.602654711105e+01
        Line search: Quadratically determined step, lambda=1.2516120471922076e-01
        Line search: Quadratically determined step, lambda=1.2516120471922093e-01
        Line search: Quadratically determined step, lambda=1.2516120471922143e-01
        Line search: gnorm after quadratic fit 3.231021309634e+01
        Line search: gnorm after quadratic fit 2.900988169561e+01
        Line search: gnorm after quadratic fit 2.600037510624e+01
        Line search: gnorm after quadratic fit 2.319949106997e+01
        Line search: gnorm after quadratic fit 2.086960153433e+01
        Line search: gnorm after quadratic fit 1.877780200491e+01
        Line search: gnorm after quadratic fit 1.689718550586e+01
        Line search: gnorm after quadratic fit 1.474145583527e+01
        Line search: gnorm after quadratic fit 1.317020586350e+01
        Line search: gnorm after quadratic fit 1.107877955050e+01
        Line search: gnorm after quadratic fit 9.976870270188e+00
        Line search: gnorm after quadratic fit 9.057717676260e+00
        Line search: gnorm after quadratic fit 9.057717676261e+00
        Line search: gnorm after quadratic fit 8.229992184597e+00
        Line search: gnorm after quadratic fit 6.993972344600e+00
        Line search: Using full step: fnorm 6.993972344600e+00 gnorm 5.200500460154e+00
        Line search: Using full step: fnorm 6.993972344600e+00 gnorm 5.200500460155e+00
        Line search: Using full step: fnorm 6.993972344600e+00 gnorm 5.200500460156e+00
        Line search: Using full step: fnorm 5.200500460155e+00 gnorm 4.868170351610e-01
        Line search: Using full step: fnorm 5.200500460154e+00 gnorm 4.868170351610e-01
        Line search: Using full step: fnorm 5.200500460156e+00 gnorm 4.868170351611e-01
        Line search: Using full step: fnorm 4.868170351610e-01 gnorm 8.300473416952e-03
        Line search: Using full step: fnorm 4.868170351610e-01 gnorm 8.300473417242e-03
        Line search: Using full step: fnorm 4.868170351610e-01 gnorm 8.300473417001e-03
        Line search: Using full step: fnorm 4.868170351611e-01 gnorm 8.300473417216e-03
        Line search: Using full step: fnorm 8.300473417242e-03 gnorm 2.915141326738e-06
        Line search: Using full step: fnorm 8.300473416952e-03 gnorm 2.915141337979e-06
        Line search: Using full step: fnorm 8.300473417216e-03 gnorm 2.915141336751e-06
        Line search: Using full step: fnorm 8.300473417001e-03 gnorm 2.915141336084e-06
        Line search: Using full step: fnorm 2.915141326738e-06 gnorm 9.451456610105e-13
        Line search: Using full step: fnorm 2.915141337979e-06 gnorm 9.562150532625e-13
        Line search: Using full step: fnorm 2.915141336751e-06 gnorm 1.149936274118e-12
        Line search: Using full step: fnorm 2.915141336084e-06 gnorm 1.005610647929e-12
        Line search: gnorm after quadratic fit 4.833437996082e+01
        Line search: Quadratically determined step, lambda=2.2201572160626992e-01
        Line search: Quadratically determined step, lambda=2.2201572160627017e-01
        Line search: Quadratically determined step, lambda=2.2201572160627131e-01
        Line search: Quadratically determined step, lambda=2.2201572160626959e-01
        Line search: gnorm after quadratic fit 4.117873640134e+01
        Line search: Quadratically determined step, lambda=1.4593382049868897e-01
        Line search: Quadratically determined step, lambda=1.4593382049868900e-01
        Line search: Quadratically determined step, lambda=1.4593382049868855e-01
        Line search: Quadratically determined step, lambda=1.4593382049868839e-01
        Line search: gnorm after quadratic fit 3.602109608542e+01
        Line search: Quadratically determined step, lambda=1.2510571913079091e-01
        Line search: Quadratically determined step, lambda=1.2510571913078886e-01
        Line search: Quadratically determined step, lambda=1.2510571913078999e-01
        Line search: gnorm after quadratic fit 3.230510088731e+01
        Line search: gnorm after quadratic fit 2.900501376759e+01
        Line search: gnorm after quadratic fit 2.599536618562e+01
        Line search: gnorm after quadratic fit 2.319149175882e+01
        Line search: gnorm after quadratic fit 2.086248145425e+01
        Line search: gnorm after quadratic fit 1.877134137174e+01
        Line search: gnorm after quadratic fit 1.689135541955e+01
        Line search: gnorm after quadratic fit 1.473650975678e+01
        Line search: gnorm after quadratic fit 1.316559591149e+01
        Line search: gnorm after quadratic fit 1.107474579395e+01
        Line search: gnorm after quadratic fit 9.973208486499e+00
        Line search: gnorm after quadratic fit 9.055139344534e+00
        Line search: gnorm after quadratic fit 8.227944769087e+00
        Line search: gnorm after quadratic fit 6.995228493045e+00
        Line search: Using full step: fnorm 6.995228493045e+00 gnorm 5.247557070544e+00
        Line search: Using full step: fnorm 6.995228493045e+00 gnorm 5.247557070545e+00
        Line search: Using full step: fnorm 6.995228493045e+00 gnorm 5.247557070546e+00
        Line search: Using full step: fnorm 6.995228493045e+00 gnorm 5.247557070549e+00
        Line search: Using full step: fnorm 5.247557070544e+00 gnorm 4.939915297322e-01
        Line search: Using full step: fnorm 5.247557070545e+00 gnorm 4.939915297324e-01
        Line search: Using full step: fnorm 5.247557070546e+00 gnorm 4.939915297324e-01
        Line search: Using full step: fnorm 5.247557070549e+00 gnorm 4.939915297329e-01
        Line search: Using full step: fnorm 4.939915297322e-01 gnorm 8.547804569160e-03
        Line search: Using full step: fnorm 4.939915297324e-01 gnorm 8.547804569122e-03
        Line search: Using full step: fnorm 4.939915297324e-01 gnorm 8.547804569148e-03
        Line search: Using full step: fnorm 4.939915297329e-01 gnorm 8.547804569149e-03
        Line search: Using full step: fnorm 8.547804569160e-03 gnorm 3.092388832677e-06
        Line search: Using full step: fnorm 8.547804569122e-03 gnorm 3.092388954504e-06
        Line search: Using full step: fnorm 8.547804569148e-03 gnorm 3.092388844518e-06
        Line search: Using full step: fnorm 8.547804569149e-03 gnorm 3.092388828405e-06
        Line search: Using full step: fnorm 3.092388832677e-06 gnorm 1.116920140958e-12
        Line search: Using full step: fnorm 3.092388954504e-06 gnorm 1.158324684515e-12
        Line search: Using full step: fnorm 3.092388844518e-06 gnorm 1.154103999264e-12
        Line search: Using full step: fnorm 3.092388828405e-06 gnorm 9.964411900313e-13
        Line search: gnorm after quadratic fit 4.833036038367e+01
        Line search: Quadratically determined step, lambda=2.2201165829644065e-01
        Line search: Quadratically determined step, lambda=2.2201165829644057e-01
        Line search: gnorm after quadratic fit 4.117567446937e+01
        Line search: Quadratically determined step, lambda=1.4592527185938717e-01
        Line search: Quadratically determined step, lambda=1.4592527185938817e-01
        Line search: Quadratically determined step, lambda=1.4592527185938814e-01
        Line search: Quadratically determined step, lambda=1.4592527185938775e-01
        Line search: gnorm after quadratic fit 3.601925279133e+01
        Line search: Quadratically determined step, lambda=1.2508654181788828e-01
        Line search: Quadratically determined step, lambda=1.2508654181788725e-01
        Line search: Quadratically determined step, lambda=1.2508654181788845e-01
        Line search: Quadratically determined step, lambda=1.2508654181788781e-01
        Line search: gnorm after quadratic fit 3.230337073226e+01
        Line search: gnorm after quadratic fit 2.900336416379e+01
        Line search: gnorm after quadratic fit 2.599366735613e+01
        Line search: gnorm after quadratic fit 2.318876112868e+01
        Line search: gnorm after quadratic fit 2.086004827527e+01
        Line search: gnorm after quadratic fit 1.876913307771e+01
        Line search: gnorm after quadratic fit 1.688936239243e+01
        Line search: gnorm after quadratic fit 1.473481863182e+01
        Line search: gnorm after quadratic fit 1.316401939741e+01
        Line search: gnorm after quadratic fit 1.316401939742e+01
        Line search: gnorm after quadratic fit 1.107336388589e+01
        Line search: gnorm after quadratic fit 9.971953947924e+00
        Line search: gnorm after quadratic fit 9.054256825598e+00
        Line search: gnorm after quadratic fit 8.227244639061e+00
        Line search: gnorm after quadratic fit 6.995656311421e+00
        Line search: Using full step: fnorm 6.995656311421e+00 gnorm 5.263801566550e+00
        Line search: Using full step: fnorm 6.995656311421e+00 gnorm 5.263801566549e+00
        Line search: Using full step: fnorm 5.263801566550e+00 gnorm 4.964747029726e-01
        Line search: Using full step: fnorm 5.263801566549e+00 gnorm 4.964747029723e-01
        Line search: Using full step: fnorm 5.263801566550e+00 gnorm 4.964747029727e-01
        Line search: Using full step: fnorm 5.263801566549e+00 gnorm 4.964747029724e-01
        Line search: Using full step: fnorm 4.964747029726e-01 gnorm 8.634190866152e-03
        Line search: Using full step: fnorm 4.964747029723e-01 gnorm 8.634190866021e-03
        Line search: Using full step: fnorm 4.964747029727e-01 gnorm 8.634190866163e-03
        Line search: Using full step: fnorm 4.964747029724e-01 gnorm 8.634190866125e-03
        Line search: Using full step: fnorm 8.634190866021e-03 gnorm 3.155526025939e-06
        Line search: Using full step: fnorm 8.634190866152e-03 gnorm 3.155526138874e-06
        Line search: Using full step: fnorm 8.634190866163e-03 gnorm 3.155526028600e-06
        Line search: Using full step: fnorm 8.634190866125e-03 gnorm 3.155526024493e-06
        Line search: Using full step: fnorm 3.155526025939e-06 gnorm 1.254288877198e-12
        Line search: Using full step: fnorm 3.155526138874e-06 gnorm 1.106442718554e-12
        Line search: Using full step: fnorm 3.155526028600e-06 gnorm 1.467758020724e-12
        Line search: Using full step: fnorm 3.155526024493e-06 gnorm 1.051927357847e-12
        Line search: gnorm after quadratic fit 4.832898823490e+01
        Line search: Quadratically determined step, lambda=2.2201030276178771e-01
        Line search: Quadratically determined step, lambda=2.2201030276178749e-01
        Line search: Quadratically determined step, lambda=2.2201030276178796e-01
        Line search: Quadratically determined step, lambda=2.2201030276178751e-01
        Line search: gnorm after quadratic fit 4.117462864308e+01
        Line search: Quadratically determined step, lambda=1.4592236343740411e-01
        Line search: Quadratically determined step, lambda=1.4592236343740494e-01
        Line search: Quadratically determined step, lambda=1.4592236343740536e-01
        Line search: Quadratically determined step, lambda=1.4592236343740489e-01
        Line search: gnorm after quadratic fit 3.601862462218e+01
        Line search: Quadratically determined step, lambda=1.2507995766039934e-01
        Line search: Quadratically determined step, lambda=1.2507995766040070e-01
        Line search: Quadratically determined step, lambda=1.2507995766039950e-01
        Line search: Quadratically determined step, lambda=1.2507995766039895e-01
        Line search: gnorm after quadratic fit 3.230278095095e+01
        Line search: gnorm after quadratic fit 2.900280159014e+01
        Line search: gnorm after quadratic fit 2.599308782754e+01
        Line search: gnorm after quadratic fit 2.318782757579e+01
        Line search: gnorm after quadratic fit 2.085921611175e+01
        Line search: gnorm after quadratic fit 1.876837777073e+01
        Line search: gnorm after quadratic fit 1.688868068270e+01
        Line search: gnorm after quadratic fit 1.473424015688e+01
        Line search: gnorm after quadratic fit 1.316348008907e+01
        Line search: gnorm after quadratic fit 1.107289086725e+01
        Line search: gnorm after quadratic fit 9.971524519400e+00
        Line search: gnorm after quadratic fit 9.053954839583e+00
        Line search: gnorm after quadratic fit 8.227005143736e+00
        Line search: gnorm after quadratic fit 6.995802481762e+00
        Line search: Using full step: fnorm 6.995802481762e+00 gnorm 5.269376882978e+00
        Line search: Using full step: fnorm 6.995802481762e+00 gnorm 5.269376882979e+00
        Line search: Using full step: fnorm 5.269376882978e+00 gnorm 4.973277167643e-01
        Line search: Using full step: fnorm 5.269376882979e+00 gnorm 4.973277167645e-01
        Line search: Using full step: fnorm 5.269376882979e+00 gnorm 4.973277167646e-01
        Line search: Using full step: fnorm 4.973277167645e-01 gnorm 8.663958689434e-03
        Line search: Using full step: fnorm 4.973277167643e-01 gnorm 8.663958689456e-03
        Line search: Using full step: fnorm 4.973277167646e-01 gnorm 8.663958689441e-03
        Line search: Using full step: fnorm 4.973277167645e-01 gnorm 8.663958689428e-03
        Line search: Using full step: fnorm 8.663958689456e-03 gnorm 3.177429826711e-06
        Line search: Using full step: fnorm 8.663958689434e-03 gnorm 3.177429938007e-06
        Line search: Using full step: fnorm 8.663958689441e-03 gnorm 3.177429938244e-06
        Line search: Using full step: fnorm 8.663958689428e-03 gnorm 3.177429826098e-06
        Line search: Using full step: fnorm 3.177429826711e-06 gnorm 9.463284211891e-13
        Line search: Using full step: fnorm 3.177429938007e-06 gnorm 8.269832139458e-13
        Line search: Using full step: fnorm 3.177429938244e-06 gnorm 8.927195024229e-13
        Line search: Using full step: fnorm 3.177429826098e-06 gnorm 1.161973653290e-12
        Line search: gnorm after quadratic fit 4.832851910567e+01
        Line search: Quadratically determined step, lambda=2.2200984300356646e-01
        Line search: Quadratically determined step, lambda=2.2200984300356605e-01
        Line search: Quadratically determined step, lambda=2.2200984300356666e-01
        Line search: Quadratically determined step, lambda=2.2200984300356502e-01
        Line search: gnorm after quadratic fit 4.117427101286e+01
        Line search: Quadratically determined step, lambda=1.4592137021444229e-01
        Line search: Quadratically determined step, lambda=1.4592137021444096e-01
        Line search: Quadratically determined step, lambda=1.4592137021444224e-01
        Line search: Quadratically determined step, lambda=1.4592137021444271e-01
        Line search: gnorm after quadratic fit 3.601840998022e+01
        Line search: Quadratically determined step, lambda=1.2507770216668498e-01
        Line search: Quadratically determined step, lambda=1.2507770216668360e-01
        Line search: Quadratically determined step, lambda=1.2507770216668432e-01
        Line search: Quadratically determined step, lambda=1.2507770216668518e-01
        Line search: gnorm after quadratic fit 3.230257940617e+01
        Line search: gnorm after quadratic fit 2.900260931349e+01
        Line search: gnorm after quadratic fit 2.599288973654e+01
        Line search: gnorm after quadratic fit 2.318750823590e+01
        Line search: gnorm after quadratic fit 2.085893141889e+01
        Line search: gnorm after quadratic fit 1.876811936486e+01
        Line search: gnorm after quadratic fit 1.688844745230e+01
        Line search: gnorm after quadratic fit 1.473404224243e+01
        Line search: gnorm after quadratic fit 1.316329557028e+01
        Line search: gnorm after quadratic fit 1.107272899579e+01
        Line search: gnorm after quadratic fit 9.971377563985e+00
        Line search: gnorm after quadratic fit 9.053851508344e+00
        Line search: gnorm after quadratic fit 8.226923204477e+00
        Line search: gnorm after quadratic fit 6.995852472138e+00
            Line search: Using full step: fnorm 6.995852472138e+00 gnorm 5.271286574972e+00
    Line search: Using full step: fnorm 6.995852472138e+00 gnorm 5.271286574971e+00
        Line search: Using full step: fnorm 5.271286574971e+00 gnorm 4.976199850840e-01
        Line search: Using full step: fnorm 5.271286574972e+00 gnorm 4.976199850844e-01
        Line search: Using full step: fnorm 5.271286574971e+00 gnorm 4.976199850841e-01
        Line search: Using full step: fnorm 4.976199850840e-01 gnorm 8.674168929552e-03
        Line search: Using full step: fnorm 4.976199850844e-01 gnorm 8.674168929736e-03
        Line search: Using full step: fnorm 4.976199850841e-01 gnorm 8.674168929760e-03
        Line search: Using full step: fnorm 4.976199850840e-01 gnorm 8.674168929544e-03
        Line search: Using full step: fnorm 8.674168929552e-03 gnorm 3.184960277854e-06
        Line search: Using full step: fnorm 8.674168929736e-03 gnorm 3.184960046439e-06
        Line search: Using full step: fnorm 8.674168929760e-03 gnorm 3.184960296072e-06
        Line search: Using full step: fnorm 8.674168929544e-03 gnorm 3.184960269391e-06
        Line search: Using full step: fnorm 3.184960277854e-06 gnorm 1.107419101754e-12
        Line search: Using full step: fnorm 3.184960046439e-06 gnorm 1.119351343697e-12
        Line search: Using full step: fnorm 3.184960296072e-06 gnorm 1.213284109156e-12
        Line search: Using full step: fnorm 3.184960269391e-06 gnorm 1.024080237536e-12
        Line search: gnorm after quadratic fit 4.832835862848e+01
        Line search: Quadratically determined step, lambda=2.2200968616397104e-01
        Line search: Quadratically determined step, lambda=2.2200968616397129e-01
        Line search: Quadratically determined step, lambda=2.2200968616397057e-01
        Line search: Quadratically determined step, lambda=2.2200968616397151e-01
        Line search: gnorm after quadratic fit 4.117414866861e+01
        Line search: Quadratically determined step, lambda=1.4592103059263803e-01
        Line search: Quadratically determined step, lambda=1.4592103059263892e-01
        Line search: Quadratically determined step, lambda=1.4592103059263775e-01
        Line search: Quadratically determined step, lambda=1.4592103059263878e-01
        Line search: gnorm after quadratic fit 3.601833657131e+01
        Line search: Quadratically determined step, lambda=1.2507693010313473e-01
        Line search: Quadratically determined step, lambda=1.2507693010313392e-01
        Line search: Quadratically determined step, lambda=1.2507693010313536e-01
        Line search: gnorm after quadratic fit 3.230251047427e+01
        Line search: gnorm after quadratic fit 2.900254354800e+01
        Line search: gnorm after quadratic fit 2.599282198005e+01
        Line search: gnorm after quadratic fit 2.318739897868e+01
        Line search: gnorm after quadratic fit 2.085883401152e+01
        Line search: gnorm after quadratic fit 1.876803095079e+01
        Line search: gnorm after quadratic fit 1.688836765163e+01
        Line search: gnorm after quadratic fit 1.473397452487e+01
        Line search: gnorm after quadratic fit 1.316323243560e+01
        Line search: gnorm after quadratic fit 1.107267360623e+01
        Line search: gnorm after quadratic fit 9.971327278322e+00
        Line search: gnorm after quadratic fit 9.053816151534e+00
        Line search: gnorm after quadratic fit 8.226895168456e+00
        Line search: gnorm after quadratic fit 6.995869574435e+00
        Line search: gnorm after quadratic fit 6.995869574436e+00
        Line search: Using full step: fnorm 6.995869574435e+00 gnorm 5.271940245448e+00
        Line search: Using full step: fnorm 6.995869574435e+00 gnorm 5.271940245447e+00
        Line search: Using full step: fnorm 6.995869574436e+00 gnorm 5.271940245447e+00
        Line search: Using full step: fnorm 5.271940245448e+00 gnorm 4.977200363068e-01
        Line search: Using full step: fnorm 5.271940245447e+00 gnorm 4.977200363068e-01
        Line search: Using full step: fnorm 5.271940245447e+00 gnorm 4.977200363069e-01
        Line search: Using full step: fnorm 4.977200363068e-01 gnorm 8.677665442639e-03
        Line search: Using full step: fnorm 4.977200363068e-01 gnorm 8.677665442525e-03
        Line search: Using full step: fnorm 4.977200363069e-01 gnorm 8.677665442755e-03
        Line search: Using full step: fnorm 4.977200363069e-01 gnorm 8.677665442509e-03
        Line search: Using full step: fnorm 8.677665442639e-03 gnorm 3.187541023916e-06
        Line search: Using full step: fnorm 8.677665442525e-03 gnorm 3.187540901092e-06
        Line search: Using full step: fnorm 8.677665442755e-03 gnorm 3.187541253705e-06
        Line search: Using full step: fnorm 8.677665442509e-03 gnorm 3.187541022068e-06
        Line search: Using full step: fnorm 3.187541023916e-06 gnorm 1.265117838248e-12
        Line search: Using full step: fnorm 3.187540901092e-06 gnorm 1.314734637256e-12
        Line search: Using full step: fnorm 3.187541253705e-06 gnorm 1.028877982204e-12
        Line search: Using full step: fnorm 3.187541022068e-06 gnorm 1.234551948975e-12
        Line search: gnorm after quadratic fit 4.832830372338e+01
        Line search: Quadratically determined step, lambda=2.2200963255400011e-01
        Line search: Quadratically determined step, lambda=2.2200963255400094e-01
        Line search: Quadratically determined step, lambda=2.2200963255400044e-01
        Line search: Quadratically determined step, lambda=2.2200963255400161e-01
        Line search: gnorm after quadratic fit 4.117410680924e+01
        Line search: Quadratically determined step, lambda=1.4592091441138491e-01
        Line search: Quadratically determined step, lambda=1.4592091441138377e-01
        Line search: Quadratically determined step, lambda=1.4592091441138466e-01
        Line search: Quadratically determined step, lambda=1.4592091441138474e-01
        Line search: gnorm after quadratic fit 3.601831145716e+01
        Line search: Quadratically determined step, lambda=1.2507666589156130e-01
        Line search: Quadratically determined step, lambda=1.2507666589156277e-01
        Line search: Quadratically determined step, lambda=1.2507666589156224e-01
        Line search: Quadratically determined step, lambda=1.2507666589156205e-01
        Line search: gnorm after quadratic fit 3.230248689149e+01
        Line search: gnorm after quadratic fit 2.900252104810e+01
        Line search: gnorm after quadratic fit 2.599279879872e+01
        Line search: gnorm after quadratic fit 2.318736159556e+01
        Line search: gnorm after quadratic fit 2.085880068242e+01
        Line search: gnorm after quadratic fit 1.876800069877e+01
        Line search: gnorm after quadratic fit 1.688834034675e+01
        Line search: gnorm after quadratic fit 1.473395135434e+01
        Line search: gnorm after quadratic fit 1.316321083311e+01
        Line search: gnorm after quadratic fit 1.107265465340e+01
        Line search: gnorm after quadratic fit 9.971310071896e+00
        Line search: gnorm after quadratic fit 9.053804053530e+00
        Line search: gnorm after quadratic fit 8.226885575529e+00
        Line search: gnorm after quadratic fit 6.995875425974e+00
        Line search: Using full step: fnorm 6.995875425974e+00 gnorm 5.272163938385e+00
        Line search: Using full step: fnorm 5.272163938385e+00 gnorm 4.977542761082e-01
        Line search: Using full step: fnorm 6.995875425974e+00 gnorm 5.272163938384e+00
        Line search: Using full step: fnorm 4.977542761082e-01 gnorm 8.678862178167e-03
        Line search: Using full step: fnorm 5.272163938384e+00 gnorm 4.977542761081e-01
        Line search: Using full step: fnorm 8.678862178167e-03 gnorm 3.188424713670e-06
        Line search: Using full step: fnorm 3.188424713670e-06 gnorm 1.118744170541e-12
        Line search: Using full step: fnorm 4.977542761081e-01 gnorm 8.678862178151e-03
        Line search: Using full step: fnorm 6.995875425974e+00 gnorm 5.272163938383e+00
        Line search: Using full step: fnorm 8.678862178151e-03 gnorm 3.188424679462e-06
        Line search: Using full step: fnorm 5.272163938383e+00 gnorm 4.977542761080e-01
        Line search: Using full step: fnorm 3.188424679462e-06 gnorm 1.286038589946e-12
        Line search: Using full step: fnorm 4.977542761082e-01 gnorm 8.678862178115e-03
        Line search: Using full step: fnorm 4.977542761080e-01 gnorm 8.678862178113e-03
        Line search: Using full step: fnorm 8.678862178115e-03 gnorm 3.188424717345e-06
        Line search: Using full step: fnorm 8.678862178113e-03 gnorm 3.188424680425e-06
        Line search: Using full step: fnorm 3.188424717345e-06 gnorm 1.055049607597e-12
        Line search: Using full step: fnorm 3.188424680425e-06 gnorm 1.150237197570e-12
        Line search: gnorm after quadratic fit 4.832828493718e+01
        Line search: Quadratically determined step, lambda=2.2200961421685994e-01
        Line search: Quadratically determined step, lambda=2.2200961421685822e-01
        Line search: Quadratically determined step, lambda=2.2200961421685750e-01
        Line search: Quadratically determined step, lambda=2.2200961421685864e-01
        Line search: gnorm after quadratic fit 4.117409248662e+01
        Line search: Quadratically determined step, lambda=1.4592087466092307e-01
        Line search: Quadratically determined step, lambda=1.4592087466092382e-01
        Line search: Quadratically determined step, lambda=1.4592087466092435e-01
        Line search: Quadratically determined step, lambda=1.4592087466092346e-01
        Line search: gnorm after quadratic fit 3.601830286436e+01
        Line search: Quadratically determined step, lambda=1.2507657548246989e-01
        Line search: Quadratically determined step, lambda=1.2507657548246978e-01
        Line search: Quadratically determined step, lambda=1.2507657548247064e-01
        Line search: Quadratically determined step, lambda=1.2507657548247050e-01
        Line search: gnorm after quadratic fit 3.230247882262e+01
        Line search: gnorm after quadratic fit 2.900251334969e+01
        Line search: gnorm after quadratic fit 2.599279086713e+01
        Line search: gnorm after quadratic fit 2.318734880438e+01
        Line search: gnorm after quadratic fit 2.085878927833e+01
        Line search: gnorm after quadratic fit 1.876799034754e+01
        Line search: gnorm after quadratic fit 1.688833100393e+01
        Line search: gnorm after quadratic fit 1.473394342615e+01
        Line search: gnorm after quadratic fit 1.316320344144e+01
        Line search: gnorm after quadratic fit 1.107264816830e+01
        Line search: gnorm after quadratic fit 9.971304184367e+00
        Line search: gnorm after quadratic fit 9.053799913971e+00
        Line search: gnorm after quadratic fit 8.226882293144e+00
        Line search: gnorm after quadratic fit 6.995877428148e+00
        Line search: Using full step: fnorm 6.995877428148e+00 gnorm 5.272240482302e+00
        Line search: Using full step: fnorm 6.995877428148e+00 gnorm 5.272240482303e+00
        Line search: Using full step: fnorm 5.272240482302e+00 gnorm 4.977659925280e-01
        Line search: Using full step: fnorm 5.272240482303e+00 gnorm 4.977659925286e-01
        Line search: Using full step: fnorm 5.272240482302e+00 gnorm 4.977659925281e-01
        Line search: Using full step: fnorm 4.977659925280e-01 gnorm 8.679271703488e-03
        Line search: Using full step: fnorm 4.977659925286e-01 gnorm 8.679271703389e-03
        Line search: Using full step: fnorm 4.977659925281e-01 gnorm 8.679271703503e-03
        Line search: Using full step: fnorm 8.679271703488e-03 gnorm 3.188726788899e-06
        Line search: Using full step: fnorm 8.679271703389e-03 gnorm 3.188727014031e-06
        Line search: Using full step: fnorm 8.679271703503e-03 gnorm 3.188726786965e-06
        Line search: Using full step: fnorm 3.188726788899e-06 gnorm 9.994290072819e-13
        Line search: Using full step: fnorm 3.188727014031e-06 gnorm 9.282300833904e-13
        Line search: Using full step: fnorm 4.977659925286e-01 gnorm 8.679271703386e-03
        Line search: Using full step: fnorm 3.188726786965e-06 gnorm 9.658559512996e-13
        Line search: Using full step: fnorm 8.679271703386e-03 gnorm 3.188726990242e-06
        Line search: Using full step: fnorm 3.188726990242e-06 gnorm 1.075961851620e-12
        Line search: gnorm after quadratic fit 4.832827850920e+01
        Line search: Quadratically determined step, lambda=2.2200960794322513e-01
        Line search: Quadratically determined step, lambda=2.2200960794322586e-01
        Line search: Quadratically determined step, lambda=2.2200960794322505e-01
        Line search: Quadratically determined step, lambda=2.2200960794322458e-01
        Line search: gnorm after quadratic fit 4.117408758591e+01
        Line search: Quadratically determined step, lambda=1.4592086105992663e-01
        Line search: Quadratically determined step, lambda=1.4592086105992710e-01
        Line search: Quadratically determined step, lambda=1.4592086105992705e-01
        Line search: Quadratically determined step, lambda=1.4592086105992755e-01
        Line search: gnorm after quadratic fit 3.601829992423e+01
        Line search: Quadratically determined step, lambda=1.2507654454682243e-01
        Line search: Quadratically determined step, lambda=1.2507654454682246e-01
        Line search: Quadratically determined step, lambda=1.2507654454682252e-01
        Line search: Quadratically determined step, lambda=1.2507654454682321e-01
        Line search: gnorm after quadratic fit 3.230247606175e+01
        Line search: gnorm after quadratic fit 2.900251071558e+01
        Line search: gnorm after quadratic fit 2.599278815322e+01
        Line search: gnorm after quadratic fit 2.318734442765e+01
        Line search: gnorm after quadratic fit 2.085878537621e+01
        Line search: gnorm after quadratic fit 1.876798680568e+01
        Line search: gnorm after quadratic fit 1.688832780711e+01
        Line search: gnorm after quadratic fit 1.473394071337e+01
        Line search: gnorm after quadratic fit 1.316320091224e+01
        Line search: gnorm after quadratic fit 1.107264594930e+01
        Line search: gnorm after quadratic fit 9.971302169836e+00
        Line search: gnorm after quadratic fit 9.053798497544e+00
        Line search: gnorm after quadratic fit 8.226881170017e+00
        Line search: gnorm after quadratic fit 8.226881170016e+00
        Line search: gnorm after quadratic fit 6.995878113225e+00
        Line search: Using full step: fnorm 6.995878113225e+00 gnorm 5.272266673611e+00
        Line search: Using full step: fnorm 6.995878113225e+00 gnorm 5.272266673612e+00
        Line search: Using full step: fnorm 5.272266673611e+00 gnorm 4.977700015949e-01
        Line search: Using full step: fnorm 5.272266673612e+00 gnorm 4.977700015949e-01
        Line search: Using full step: fnorm 5.272266673611e+00 gnorm 4.977700015948e-01
        Line search: Using full step: fnorm 4.977700015949e-01 gnorm 8.679411834380e-03
        Line search: Using full step: fnorm 4.977700015949e-01 gnorm 8.679411834510e-03
        Line search: Using full step: fnorm 4.977700015948e-01 gnorm 8.679411834384e-03
        Line search: Using full step: fnorm 4.977700015948e-01 gnorm 8.679411834490e-03
        Line search: Using full step: fnorm 8.679411834380e-03 gnorm 3.188830404071e-06
        Line search: Using full step: fnorm 8.679411834510e-03 gnorm 3.188830549655e-06
        Line search: Using full step: fnorm 8.679411834384e-03 gnorm 3.188830402970e-06
        Line search: Using full step: fnorm 8.679411834490e-03 gnorm 3.188830297368e-06
        Line search: Using full step: fnorm 3.188830404071e-06 gnorm 1.113218384642e-12
        Line search: Using full step: fnorm 3.188830549655e-06 gnorm 1.193135894174e-12
        Line search: Using full step: fnorm 3.188830402970e-06 gnorm 1.381740312219e-12
        Line search: Using full step: fnorm 3.188830297368e-06 gnorm 9.630731360221e-13
        Line search: gnorm after quadratic fit 4.832827630976e+01
        Line search: Quadratically determined step, lambda=2.2200960579667506e-01
        Line search: Quadratically determined step, lambda=2.2200960579667400e-01
        Line search: Quadratically determined step, lambda=2.2200960579667534e-01
        Line search: Quadratically determined step, lambda=2.2200960579667428e-01
        Line search: gnorm after quadratic fit 4.117408590905e+01
        Line search: Quadratically determined step, lambda=1.4592085640613406e-01
        Line search: Quadratically determined step, lambda=1.4592085640613436e-01
        Line search: Quadratically determined step, lambda=1.4592085640613439e-01
        Line search: gnorm after quadratic fit 3.601829891822e+01
        Line search: Quadratically determined step, lambda=1.2507653396155582e-01
        Line search: Quadratically determined step, lambda=1.2507653396155602e-01
        Line search: Quadratically determined step, lambda=1.2507653396155555e-01
        Line search: gnorm after quadratic fit 3.230247511708e+01
        Line search: gnorm after quadratic fit 2.900250981427e+01
        Line search: gnorm after quadratic fit 2.599278722461e+01
        Line search: gnorm after quadratic fit 2.318734293008e+01
        Line search: gnorm after quadratic fit 2.085878404103e+01
        Line search: gnorm after quadratic fit 1.876798559376e+01
        Line search: gnorm after quadratic fit 1.688832671326e+01
        Line search: gnorm after quadratic fit 1.473393978515e+01
        Line search: gnorm after quadratic fit 1.316320004683e+01
        Line search: gnorm after quadratic fit 1.107264519003e+01
        Line search: gnorm after quadratic fit 9.971301480526e+00
        Line search: gnorm after quadratic fit 9.053798012887e+00
        Line search: gnorm after quadratic fit 8.226880785718e+00
        Line search: gnorm after quadratic fit 6.995878347636e+00
        Line search: Using full step: fnorm 6.995878347636e+00 gnorm 5.272275635500e+00
        Line search: Using full step: fnorm 6.995878347636e+00 gnorm 5.272275635499e+00
        Line search: Using full step: fnorm 5.272275635500e+00 gnorm 4.977713733802e-01
        Line search: Using full step: fnorm 5.272275635500e+00 gnorm 4.977713733805e-01
        Line search: Using full step: fnorm 5.272275635499e+00 gnorm 4.977713733800e-01
        Line search: Using full step: fnorm 5.272275635500e+00 gnorm 4.977713733800e-01
        Line search: Using full step: fnorm 4.977713733802e-01 gnorm 8.679459783722e-03
        Line search: Using full step: fnorm 4.977713733805e-01 gnorm 8.679459783607e-03
        Line search: Using full step: fnorm 4.977713733800e-01 gnorm 8.679459783589e-03
        Line search: Using full step: fnorm 4.977713733800e-01 gnorm 8.679459783569e-03
        Line search: Using full step: fnorm 8.679459783607e-03 gnorm 3.188866091111e-06
        Line search: Using full step: fnorm 8.679459783722e-03 gnorm 3.188865975930e-06
        Line search: Using full step: fnorm 8.679459783589e-03 gnorm 3.188865985170e-06
        Line search: Using full step: fnorm 8.679459783569e-03 gnorm 3.188865956015e-06
        Line search: Using full step: fnorm 3.188865975930e-06 gnorm 1.110726041543e-12
        Line search: Using full step: fnorm 3.188866091111e-06 gnorm 1.093395320892e-12
        Line search: Using full step: fnorm 3.188865985170e-06 gnorm 1.070900135705e-12
        Line search: Using full step: fnorm 3.188865956015e-06 gnorm 1.182828525900e-12
        Line search: gnorm after quadratic fit 4.832827555718e+01
        Line search: Quadratically determined step, lambda=2.2200960506220271e-01
        Line search: Quadratically determined step, lambda=2.2200960506220294e-01
        Line search: Quadratically determined step, lambda=2.2200960506220352e-01
        Line search: Quadratically determined step, lambda=2.2200960506220277e-01
        Line search: gnorm after quadratic fit 4.117408533528e+01
        Line search: Quadratically determined step, lambda=1.4592085481375763e-01
        Line search: Quadratically determined step, lambda=1.4592085481375783e-01
        Line search: Quadratically determined step, lambda=1.4592085481375824e-01
        Line search: Quadratically determined step, lambda=1.4592085481375727e-01
        Line search: gnorm after quadratic fit 3.601829857399e+01
        Line search: Quadratically determined step, lambda=1.2507653033960256e-01
        Line search: Quadratically determined step, lambda=1.2507653033960139e-01
        Line search: Quadratically determined step, lambda=1.2507653033960253e-01
        Line search: Quadratically determined step, lambda=1.2507653033960356e-01
        Line search: gnorm after quadratic fit 3.230247479384e+01
        Line search: gnorm after quadratic fit 2.900250950587e+01
        Line search: gnorm after quadratic fit 2.599278690687e+01
        Line search: gnorm after quadratic fit 2.318734241765e+01
        Line search: gnorm after quadratic fit 2.085878358418e+01
        Line search: gnorm after quadratic fit 1.876798517908e+01
        Line search: gnorm after quadratic fit 1.688832633898e+01
        Line search: gnorm after quadratic fit 1.473393946754e+01
        Line search: gnorm after quadratic fit 1.316319975071e+01
        Line search: gnorm after quadratic fit 1.107264493023e+01
        Line search: gnorm after quadratic fit 9.971301244666e+00
        Line search: gnorm after quadratic fit 9.053797847052e+00
        Line search: gnorm after quadratic fit 8.226880654223e+00
        Line search: gnorm after quadratic fit 6.995878427845e+00
        Line search: Using full step: fnorm 6.995878427845e+00 gnorm 5.272278701982e+00
        Line search: gnorm after quadratic fit 6.995878427844e+00
        Line search: Using full step: fnorm 5.272278701982e+00 gnorm 4.977718427631e-01
        Line search: Using full step: fnorm 5.272278701982e+00 gnorm 4.977718427633e-01
        Line search: Using full step: fnorm 6.995878427844e+00 gnorm 5.272278701982e+00
        Line search: Using full step: fnorm 4.977718427631e-01 gnorm 8.679476190618e-03
        Line search: Using full step: fnorm 4.977718427633e-01 gnorm 8.679476190755e-03
        Line search: Using full step: fnorm 8.679476190618e-03 gnorm 3.188877939196e-06
        Line search: Using full step: fnorm 4.977718427631e-01 gnorm 8.679476190507e-03
        Line search: Using full step: fnorm 8.679476190755e-03 gnorm 3.188877936875e-06
        Line search: Using full step: fnorm 3.188877939196e-06 gnorm 1.097409539338e-12
        Line search: Using full step: fnorm 4.977718427631e-01 gnorm 8.679476190475e-03
        Line search: Using full step: fnorm 8.679476190507e-03 gnorm 3.188877951083e-06
        Line search: Using full step: fnorm 3.188877936875e-06 gnorm 1.054800126589e-12
        Line search: Using full step: fnorm 3.188877951083e-06 gnorm 1.158829754197e-12
        Line search: Using full step: fnorm 8.679476190475e-03 gnorm 3.188877938713e-06
        Line search: Using full step: fnorm 3.188877938713e-06 gnorm 1.227184346060e-12
 19 SNES Function norm 1.020056306983e+02
        Line search: gnorm after quadratic fit 4.832827529967e+01
        Line search: Quadratically determined step, lambda=2.2200960481088952e-01
        Line search: Quadratically determined step, lambda=2.2200960481089002e-01
        Line search: gnorm after quadratic fit 4.117408513895e+01
        Line search: Quadratically determined step, lambda=1.4592085426889648e-01
        Line search: Quadratically determined step, lambda=1.4592085426889642e-01
        Line search: Quadratically determined step, lambda=1.4592085426889678e-01
        Line search: gnorm after quadratic fit 3.601829845621e+01
        Line search: Quadratically determined step, lambda=1.2507652910028233e-01
        Line search: Quadratically determined step, lambda=1.2507652910028280e-01
        Line search: Quadratically determined step, lambda=1.4592085426889739e-01
        Line search: gnorm after quadratic fit 3.230247468324e+01
        Line search: Quadratically determined step, lambda=1.2507652910028194e-01
        Line search: Quadratically determined step, lambda=1.2507652910028258e-01
        Line search: gnorm after quadratic fit 2.900250940035e+01
        Line search: gnorm after quadratic fit 2.599278679815e+01
        Line search: gnorm after quadratic fit 2.318734224232e+01
        Line search: gnorm after quadratic fit 2.085878342785e+01
        Line search: gnorm after quadratic fit 1.876798503719e+01
        Line search: gnorm after quadratic fit 1.688832621091e+01
        Line search: gnorm after quadratic fit 1.473393935886e+01
        Line search: gnorm after quadratic fit 1.316319964939e+01
        Line search: gnorm after quadratic fit 1.107264484133e+01
        Line search: gnorm after quadratic fit 9.971301163962e+00
        Line search: gnorm after quadratic fit 9.053797790309e+00
        Line search: gnorm after quadratic fit 8.226880609229e+00
        Line search: gnorm after quadratic fit 6.995878455289e+00
        Line search: Using full step: fnorm 6.995878455289e+00 gnorm 5.272279751237e+00
        Line search: Using full step: fnorm 5.272279751237e+00 gnorm 4.977720033716e-01
        Line search: Using full step: fnorm 5.272279751237e+00 gnorm 4.977720033718e-01
        Line search: Using full step: fnorm 4.977720033716e-01 gnorm 8.679481804351e-03
        Line search: Using full step: fnorm 4.977720033718e-01 gnorm 8.679481804479e-03
        Line search: Using full step: fnorm 8.679481804351e-03 gnorm 3.188882021255e-06
        Line search: Using full step: fnorm 8.679481804479e-03 gnorm 3.188882019351e-06
        Line search: Using full step: fnorm 5.272279751237e+00 gnorm 4.977720033715e-01
        Line search: Using full step: fnorm 3.188882021255e-06 gnorm 9.749912104957e-13
        Line search: Using full step: fnorm 3.188882019351e-06 gnorm 1.118893472013e-12
        Line search: Using full step: fnorm 4.977720033715e-01 gnorm 8.679481804239e-03
        Line search: Using full step: fnorm 8.679481804239e-03 gnorm 3.188882021445e-06
        Line search: Using full step: fnorm 3.188882021445e-06 gnorm 1.177327797150e-12
        Line search: Using full step: fnorm 4.977720033718e-01 gnorm 8.679481804440e-03
        Line search: Using full step: fnorm 8.679481804440e-03 gnorm 3.188882027659e-06
        Line search: Using full step: fnorm 3.188882027659e-06 gnorm 1.118986643133e-12
 20 SNES Function norm 1.020056306826e+02
        Line search: gnorm after quadratic fit 4.832827521156e+01
        Line search: Quadratically determined step, lambda=2.2200960472489900e-01
        Line search: Quadratically determined step, lambda=2.2200960472489945e-01
        Line search: Quadratically determined step, lambda=2.2200960472489942e-01
        Line search: Quadratically determined step, lambda=2.2200960472489872e-01
        Line search: gnorm after quadratic fit 4.117408507178e+01
        Line search: Quadratically determined step, lambda=1.4592085408246327e-01
        Line search: Quadratically determined step, lambda=1.4592085408246272e-01
        Line search: Quadratically determined step, lambda=1.4592085408246239e-01
        Line search: Quadratically determined step, lambda=1.4592085408246341e-01
        Line search: gnorm after quadratic fit 3.601829841591e+01
        Line search: Quadratically determined step, lambda=1.2507652867622648e-01
        Line search: Quadratically determined step, lambda=1.2507652867622626e-01
        Line search: Quadratically determined step, lambda=1.2507652867622723e-01
        Line search: Quadratically determined step, lambda=1.2507652867622598e-01
        Line search: gnorm after quadratic fit 3.230247464539e+01
        Line search: gnorm after quadratic fit 2.900250936424e+01
        Line search: gnorm after quadratic fit 2.599278676095e+01
        Line search: gnorm after quadratic fit 2.318734218232e+01
        Line search: gnorm after quadratic fit 2.085878337437e+01
        Line search: gnorm after quadratic fit 1.876798498864e+01
        Line search: gnorm after quadratic fit 1.688832616709e+01
        Line search: gnorm after quadratic fit 1.473393932167e+01
        Line search: gnorm after quadratic fit 1.316319961472e+01
        Line search: gnorm after quadratic fit 1.107264481092e+01
        Line search: gnorm after quadratic fit 1.107264481091e+01
        Line search: gnorm after quadratic fit 9.971301136347e+00
        Line search: gnorm after quadratic fit 9.053797770893e+00
        Line search: gnorm after quadratic fit 8.226880593834e+00
        Line search: gnorm after quadratic fit 6.995878464680e+00
        Line search: Using full step: fnorm 6.995878464680e+00 gnorm 5.272280110258e+00
        Line search: Using full step: fnorm 5.272280110258e+00 gnorm 4.977720583264e-01
        Line search: Using full step: fnorm 5.272280110258e+00 gnorm 4.977720583265e-01
        Line search: Using full step: fnorm 5.272280110258e+00 gnorm 4.977720583268e-01
        Line search: Using full step: fnorm 5.272280110258e+00 gnorm 4.977720583266e-01
        Line search: Using full step: fnorm 4.977720583264e-01 gnorm 8.679483724927e-03
        Line search: Using full step: fnorm 4.977720583265e-01 gnorm 8.679483724911e-03
        Line search: Using full step: fnorm 4.977720583268e-01 gnorm 8.679483725154e-03
        Line search: Using full step: fnorm 4.977720583266e-01 gnorm 8.679483724907e-03
        Line search: Using full step: fnorm 8.679483724927e-03 gnorm 3.188883648710e-06
        Line search: Using full step: fnorm 8.679483724911e-03 gnorm 3.188883521668e-06
        Line search: Using full step: fnorm 8.679483725154e-03 gnorm 3.188883528412e-06
        Line search: Using full step: fnorm 8.679483724907e-03 gnorm 3.188883646614e-06
        Line search: Using full step: fnorm 3.188883648710e-06 gnorm 1.136497020689e-12
        Line search: Using full step: fnorm 3.188883521668e-06 gnorm 1.105469910677e-12
        Line search: Using full step: fnorm 3.188883528412e-06 gnorm 9.183316572053e-13
        Line search: Using full step: fnorm 3.188883646614e-06 gnorm 1.077095213730e-12
 21 SNES Function norm 1.020056306772e+02
        Line search: gnorm after quadratic fit 4.832827518141e+01
        Line search: Quadratically determined step, lambda=2.2200960469547532e-01
        Line search: Quadratically determined step, lambda=2.2200960469547551e-01
        Line search: Quadratically determined step, lambda=2.2200960469547676e-01
        Line search: Quadratically determined step, lambda=2.2200960469547534e-01
        Line search: gnorm after quadratic fit 4.117408504879e+01
        Line search: Quadratically determined step, lambda=1.4592085401866978e-01
        Line search: Quadratically determined step, lambda=1.4592085401867055e-01
        Line search: Quadratically determined step, lambda=1.4592085401867064e-01
        Line search: Quadratically determined step, lambda=1.4592085401867111e-01
        Line search: gnorm after quadratic fit 3.601829840212e+01
        Line search: Quadratically determined step, lambda=1.2507652853112647e-01
        Line search: Quadratically determined step, lambda=1.2507652853112664e-01
        Line search: Quadratically determined step, lambda=1.2507652853112694e-01
        Line search: Quadratically determined step, lambda=1.2507652853112772e-01
        Line search: gnorm after quadratic fit 3.230247463244e+01
        Line search: gnorm after quadratic fit 2.900250935189e+01
        Line search: gnorm after quadratic fit 2.599278674822e+01
        Line search: gnorm after quadratic fit 2.318734216180e+01
        Line search: gnorm after quadratic fit 2.085878335606e+01
        Line search: gnorm after quadratic fit 1.876798497203e+01
        Line search: gnorm after quadratic fit 1.688832615210e+01
        Line search: gnorm after quadratic fit 1.473393930895e+01
        Line search: gnorm after quadratic fit 1.316319960286e+01
        Line search: gnorm after quadratic fit 1.107264480051e+01
        Line search: gnorm after quadratic fit 9.971301126899e+00
        Line search: gnorm after quadratic fit 9.971301126898e+00
        Line search: gnorm after quadratic fit 9.053797764250e+00
        Line search: gnorm after quadratic fit 9.053797764249e+00
        Line search: gnorm after quadratic fit 8.226880588566e+00
        Line search: gnorm after quadratic fit 6.995878467893e+00
        Line search: Using full step: fnorm 6.995878467893e+00 gnorm 5.272280233103e+00
        Line search: Using full step: fnorm 6.995878467893e+00 gnorm 5.272280233104e+00
        Line search: Using full step: fnorm 5.272280233103e+00 gnorm 4.977720771303e-01
        Line search: Using full step: fnorm 5.272280233104e+00 gnorm 4.977720771305e-01
        Line search: Using full step: fnorm 5.272280233103e+00 gnorm 4.977720771304e-01
        Line search: Using full step: fnorm 5.272280233103e+00 gnorm 4.977720771302e-01
        Line search: Using full step: fnorm 4.977720771303e-01 gnorm 8.679484382280e-03
        Line search: Using full step: fnorm 4.977720771305e-01 gnorm 8.679484382273e-03
        Line search: Using full step: fnorm 4.977720771304e-01 gnorm 8.679484382276e-03
        Line search: Using full step: fnorm 4.977720771302e-01 gnorm 8.679484382248e-03
        Line search: Using full step: fnorm 8.679484382280e-03 gnorm 3.188884140450e-06
        Line search: Using full step: fnorm 8.679484382273e-03 gnorm 3.188884366514e-06
        Line search: Using full step: fnorm 8.679484382276e-03 gnorm 3.188884259091e-06
        Line search: Using full step: fnorm 8.679484382248e-03 gnorm 3.188884387373e-06
        Line search: Using full step: fnorm 3.188884140450e-06 gnorm 1.139508012229e-12
        Line search: Using full step: fnorm 3.188884366514e-06 gnorm 9.749688842638e-13
        Line search: Using full step: fnorm 3.188884259091e-06 gnorm 1.097515360832e-12
        Line search: Using full step: fnorm 3.188884387373e-06 gnorm 1.085131098271e-12
 22 SNES Function norm 1.020056306753e+02
        Line search: gnorm after quadratic fit 4.832827517109e+01
        Line search: Quadratically determined step, lambda=2.2200960468540748e-01
        Line search: Quadratically determined step, lambda=2.2200960468540770e-01
        Line search: Quadratically determined step, lambda=2.2200960468540795e-01
        Line search: Quadratically determined step, lambda=2.2200960468540881e-01
        Line search: gnorm after quadratic fit 4.117408504092e+01
        Line search: Quadratically determined step, lambda=1.4592085399684199e-01
        Line search: Quadratically determined step, lambda=1.4592085399684288e-01
        Line search: Quadratically determined step, lambda=1.4592085399684221e-01
        Line search: Quadratically determined step, lambda=1.4592085399684218e-01
        Line search: gnorm after quadratic fit 3.601829839740e+01
        Line search: Quadratically determined step, lambda=1.2507652848147843e-01
        Line search: Quadratically determined step, lambda=1.2507652848147813e-01
        Line search: Quadratically determined step, lambda=1.2507652848147965e-01
        Line search: Quadratically determined step, lambda=1.2507652848147932e-01
        Line search: gnorm after quadratic fit 3.230247462801e+01
        Line search: Quadratically determined step, lambda=1.0000000000000001e-01
        Line search: gnorm after quadratic fit 2.900250934766e+01
        Line search: gnorm after quadratic fit 2.599278674387e+01
        Line search: gnorm after quadratic fit 2.318734215477e+01
        Line search: gnorm after quadratic fit 2.085878334980e+01
        Line search: gnorm after quadratic fit 1.876798496635e+01
        Line search: gnorm after quadratic fit 1.688832614697e+01
        Line search: gnorm after quadratic fit 1.473393930460e+01
        Line search: gnorm after quadratic fit 1.316319959880e+01
        Line search: gnorm after quadratic fit 1.107264479695e+01
        Line search: gnorm after quadratic fit 9.971301123666e+00
        Line search: gnorm after quadratic fit 9.971301123665e+00
        Line search: gnorm after quadratic fit 9.053797761976e+00
        Line search: gnorm after quadratic fit 8.226880586764e+00
        Line search: gnorm after quadratic fit 6.995878468993e+00
        Line search: Using full step: fnorm 6.995878468993e+00 gnorm 5.272280275139e+00
        Line search: Using full step: fnorm 6.995878468993e+00 gnorm 5.272280275140e+00
        Line search: Using full step: fnorm 5.272280275139e+00 gnorm 4.977720835648e-01
        Line search: Using full step: fnorm 5.272280275140e+00 gnorm 4.977720835646e-01
        Line search: Using full step: fnorm 5.272280275140e+00 gnorm 4.977720835648e-01
        Line search: Using full step: fnorm 4.977720835648e-01 gnorm 8.679484607319e-03
        Line search: Using full step: fnorm 4.977720835646e-01 gnorm 8.679484607225e-03
        Line search: Using full step: fnorm 4.977720835648e-01 gnorm 8.679484607215e-03
        Line search: Using full step: fnorm 5.272280275139e+00 gnorm 4.977720835649e-01
        Line search: Using full step: fnorm 8.679484607319e-03 gnorm 3.188884219030e-06
        Line search: Using full step: fnorm 8.679484607225e-03 gnorm 3.188884360507e-06
        Line search: Using full step: fnorm 8.679484607215e-03 gnorm 3.188884222691e-06
        Line search: Using full step: fnorm 3.188884219030e-06 gnorm 1.093327184170e-12
        Line search: Using full step: fnorm 4.977720835649e-01 gnorm 8.679484607214e-03
        Line search: Using full step: fnorm 3.188884360507e-06 gnorm 1.024164823888e-12
        Line search: Using full step: fnorm 3.188884222691e-06 gnorm 1.185699041916e-12
        Line search: Using full step: fnorm 8.679484607214e-03 gnorm 3.188884218962e-06
        Line search: Using full step: fnorm 3.188884218962e-06 gnorm 1.148385566901e-12
 23 SNES Function norm 1.020056306747e+02
        Line search: gnorm after quadratic fit 4.832827516756e+01
        Line search: Quadratically determined step, lambda=2.2200960468196251e-01
        Line search: Quadratically determined step, lambda=2.2200960468196260e-01
        Line search: Quadratically determined step, lambda=2.2200960468196221e-01
        Line search: Quadratically determined step, lambda=2.2200960468196276e-01
        Line search: gnorm after quadratic fit 4.117408503823e+01
        Line search: Quadratically determined step, lambda=1.4592085398937416e-01
        Line search: Quadratically determined step, lambda=1.4592085398937443e-01
        Line search: Quadratically determined step, lambda=1.4592085398937479e-01
        Line search: Quadratically determined step, lambda=1.4592085398937393e-01
        Line search: gnorm after quadratic fit 3.601829839578e+01
        Line search: Quadratically determined step, lambda=1.2507652846449116e-01
        Line search: Quadratically determined step, lambda=1.2507652846449069e-01
        Line search: Quadratically determined step, lambda=1.2507652846449149e-01
        Line search: Quadratically determined step, lambda=1.2507652846449049e-01
        Line search: gnorm after quadratic fit 3.230247462649e+01
        Line search: gnorm after quadratic fit 2.900250934621e+01
        Line search: gnorm after quadratic fit 2.599278674238e+01
        Line search: gnorm after quadratic fit 2.318734215237e+01
        Line search: gnorm after quadratic fit 2.085878334766e+01
        Line search: gnorm after quadratic fit 1.876798496440e+01
        Line search: gnorm after quadratic fit 1.688832614521e+01
        Line search: gnorm after quadratic fit 1.473393930311e+01
        Line search: gnorm after quadratic fit 1.316319959741e+01
        Line search: gnorm after quadratic fit 1.107264479573e+01
        Line search: gnorm after quadratic fit 9.971301122559e+00
        Line search: gnorm after quadratic fit 9.053797761199e+00
        Line search: gnorm after quadratic fit 9.053797761198e+00
        Line search: gnorm after quadratic fit 8.226880586147e+00
        Line search: gnorm after quadratic fit 6.995878469369e+00
        Line search: Using full step: fnorm 6.995878469369e+00 gnorm 5.272280289524e+00
        Line search: Using full step: fnorm 5.272280289524e+00 gnorm 4.977720857667e-01
        Line search: Using full step: fnorm 4.977720857667e-01 gnorm 8.679484684267e-03
        Line search: Using full step: fnorm 4.977720857667e-01 gnorm 8.679484684266e-03
        Line search: Using full step: fnorm 4.977720857667e-01 gnorm 8.679484684145e-03
        Line search: Using full step: fnorm 4.977720857667e-01 gnorm 8.679484684148e-03
        Line search: Using full step: fnorm 8.679484684267e-03 gnorm 3.188884230032e-06
        Line search: Using full step: fnorm 8.679484684266e-03 gnorm 3.188884478684e-06
        Line search: Using full step: fnorm 8.679484684145e-03 gnorm 3.188884374833e-06
        Line search: Using full step: fnorm 8.679484684148e-03 gnorm 3.188884373244e-06
        Line search: Using full step: fnorm 3.188884230032e-06 gnorm 1.267011225998e-12
        Line search: Using full step: fnorm 3.188884478684e-06 gnorm 1.114503519977e-12
        Line search: Using full step: fnorm 3.188884374833e-06 gnorm 1.050489646649e-12
        Line search: Using full step: fnorm 3.188884373244e-06 gnorm 1.042181154901e-12
 24 SNES Function norm 1.020056306745e+02
        Line search: gnorm after quadratic fit 4.832827516635e+01
        Line search: Quadratically determined step, lambda=2.2200960468078432e-01
        Line search: Quadratically determined step, lambda=2.2200960468078410e-01
        Line search: Quadratically determined step, lambda=2.2200960468078454e-01
        Line search: Quadratically determined step, lambda=2.2200960468078373e-01
        Line search: gnorm after quadratic fit 4.117408503731e+01
        Line search: Quadratically determined step, lambda=1.4592085398681848e-01
        Line search: Quadratically determined step, lambda=1.4592085398681900e-01
    Line search: Quadratically determined step, lambda=1.4592085398681842e-01
        Line search: Quadratically determined step, lambda=1.4592085398681834e-01
        Line search: gnorm after quadratic fit 3.601829839523e+01
        Line search: Quadratically determined step, lambda=1.2507652845867751e-01
        Line search: Quadratically determined step, lambda=1.2507652845867870e-01
        Line search: Quadratically determined step, lambda=1.2507652845867862e-01
        Line search: Quadratically determined step, lambda=1.2507652845867884e-01
        Line search: gnorm after quadratic fit 3.230247462598e+01
        Line search: gnorm after quadratic fit 2.900250934572e+01
        Line search: gnorm after quadratic fit 2.599278674187e+01
        Line search: gnorm after quadratic fit 2.318734215155e+01
        Line search: gnorm after quadratic fit 2.085878334692e+01
        Line search: gnorm after quadratic fit 2.085878334693e+01
        Line search: gnorm after quadratic fit 1.876798496374e+01
        Line search: gnorm after quadratic fit 1.688832614461e+01
        Line search: gnorm after quadratic fit 1.473393930260e+01
        Line search: gnorm after quadratic fit 1.316319959694e+01
        Line search: gnorm after quadratic fit 1.107264479531e+01
        Line search: gnorm after quadratic fit 9.971301122181e+00
        Line search: gnorm after quadratic fit 9.053797760933e+00
        Line search: gnorm after quadratic fit 8.226880585936e+00
        Line search: gnorm after quadratic fit 6.995878469497e+00
        Line search: Using full step: fnorm 6.995878469497e+00 gnorm 5.272280294443e+00
        Line search: Using full step: fnorm 5.272280294443e+00 gnorm 4.977720865195e-01
        Line search: Using full step: fnorm 5.272280294443e+00 gnorm 4.977720865197e-01
        Line search: Using full step: fnorm 5.272280294443e+00 gnorm 4.977720865194e-01
        Line search: Using full step: fnorm 5.272280294443e+00 gnorm 4.977720865196e-01
        Line search: Using full step: fnorm 4.977720865195e-01 gnorm 8.679484710459e-03
        Line search: Using full step: fnorm 4.977720865197e-01 gnorm 8.679484710686e-03
        Line search: Using full step: fnorm 4.977720865194e-01 gnorm 8.679484710425e-03
        Line search: Using full step: fnorm 4.977720865196e-01 gnorm 8.679484710323e-03
        Line search: Using full step: fnorm 8.679484710459e-03 gnorm 3.188884306284e-06
        Line search: Using full step: fnorm 8.679484710686e-03 gnorm 3.188884302433e-06
        Line search: Using full step: fnorm 8.679484710425e-03 gnorm 3.188884312227e-06
        Line search: Using full step: fnorm 8.679484710323e-03 gnorm 3.188884309895e-06
        Line search: Using full step: fnorm 3.188884306284e-06 gnorm 1.193975548164e-12
        Line search: Using full step: fnorm 3.188884302433e-06 gnorm 1.415378968891e-12
        Line search: Using full step: fnorm 3.188884312227e-06 gnorm 1.244666413159e-12
        Line search: Using full step: fnorm 3.188884309895e-06 gnorm 1.332296272996e-12
 25 SNES Function norm 1.020056306744e+02
        Line search: gnorm after quadratic fit 4.832827516594e+01
        Line search: Quadratically determined step, lambda=2.2200960468038117e-01
      Line search: Quadratically determined step, lambda=2.2200960468038125e-01
        Line search: Quadratically determined step, lambda=2.2200960468038197e-01
        Line search: Quadratically determined step, lambda=2.2200960468038181e-01
        Line search: gnorm after quadratic fit 4.117408503700e+01
        Line search: Quadratically determined step, lambda=1.4592085398594351e-01
        Line search: Quadratically determined step, lambda=1.4592085398594404e-01
        Line search: Quadratically determined step, lambda=1.4592085398594420e-01
        Line search: Quadratically determined step, lambda=1.4592085398594357e-01
        Line search: gnorm after quadratic fit 3.601829839504e+01
        Line search: Quadratically determined step, lambda=1.2507652845668907e-01
        Line search: Quadratically determined step, lambda=1.2507652845669001e-01
        Line search: Quadratically determined step, lambda=1.2507652845668812e-01
        Line search: Quadratically determined step, lambda=1.2507652845668857e-01
        Line search: gnorm after quadratic fit 3.230247462580e+01
        Line search: gnorm after quadratic fit 2.900250934555e+01
        Line search: gnorm after quadratic fit 2.599278674169e+01
        Line search: gnorm after quadratic fit 2.318734215127e+01
        Line search: gnorm after quadratic fit 2.318734215126e+01
        Line search: gnorm after quadratic fit 2.085878334667e+01
        Line search: gnorm after quadratic fit 1.876798496351e+01
        Line search: gnorm after quadratic fit 1.688832614441e+01
        Line search: gnorm after quadratic fit 1.473393930242e+01
        Line search: gnorm after quadratic fit 1.316319959678e+01
        Line search: gnorm after quadratic fit 1.107264479517e+01
        Line search: gnorm after quadratic fit 9.971301122051e+00
        Line search: gnorm after quadratic fit 9.053797760842e+00
        Line search: gnorm after quadratic fit 9.053797760841e+00
        Line search: gnorm after quadratic fit 8.226880585864e+00
        Line search: gnorm after quadratic fit 8.226880585863e+00
        Line search: gnorm after quadratic fit 6.995878469542e+00
        Line search: gnorm after quadratic fit 6.995878469541e+00
        Line search: Using full step: fnorm 6.995878469542e+00 gnorm 5.272280296129e+00
        Line search: Using full step: fnorm 6.995878469541e+00 gnorm 5.272280296129e+00
        Line search: Using full step: fnorm 6.995878469541e+00 gnorm 5.272280296128e+00
        Line search: Using full step: fnorm 5.272280296129e+00 gnorm 4.977720867777e-01
        Line search: Using full step: fnorm 5.272280296129e+00 gnorm 4.977720867772e-01
        Line search: Using full step: fnorm 5.272280296128e+00 gnorm 4.977720867773e-01
        Line search: Using full step: fnorm 4.977720867777e-01 gnorm 8.679484719684e-03
        Line search: Using full step: fnorm 4.977720867777e-01 gnorm 8.679484719430e-03
        Line search: Using full step: fnorm 4.977720867772e-01 gnorm 8.679484719803e-03
        Line search: Using full step: fnorm 4.977720867773e-01 gnorm 8.679484719791e-03
        Line search: Using full step: fnorm 8.679484719684e-03 gnorm 3.188884185305e-06
        Line search: Using full step: fnorm 8.679484719430e-03 gnorm 3.188884297937e-06
        Line search: Using full step: fnorm 8.679484719803e-03 gnorm 3.188884195770e-06
        Line search: Using full step: fnorm 8.679484719791e-03 gnorm 3.188884192446e-06
        Line search: Using full step: fnorm 3.188884185305e-06 gnorm 1.325924665877e-12
        Line search: Using full step: fnorm 3.188884297937e-06 gnorm 1.041648871691e-12
        Line search: Using full step: fnorm 3.188884195770e-06 gnorm 1.187227631816e-12
        Line search: Using full step: fnorm 3.188884192446e-06 gnorm 1.287319276045e-12
 26 SNES Function norm 1.020056306744e+02
        Line search: gnorm after quadratic fit 4.832827516580e+01
        Line search: Quadratically determined step, lambda=2.2200960468024339e-01
        Line search: Quadratically determined step, lambda=2.2200960468024344e-01
        Line search: Quadratically determined step, lambda=2.2200960468024236e-01
        Line search: gnorm after quadratic fit 4.117408503689e+01
        Line search: Quadratically determined step, lambda=1.4592085398564555e-01
        Line search: Quadratically determined step, lambda=1.4592085398564564e-01
        Line search: Quadratically determined step, lambda=1.4592085398564547e-01
        Line search: Quadratically determined step, lambda=1.4592085398564503e-01
        Line search: gnorm after quadratic fit 3.601829839498e+01
        Line search: Quadratically determined step, lambda=1.2507652845600861e-01
        Line search: Quadratically determined step, lambda=1.2507652845600820e-01
        Line search: Quadratically determined step, lambda=1.2507652845600975e-01
        Line search: Quadratically determined step, lambda=1.2507652845600933e-01
        Line search: gnorm after quadratic fit 3.230247462574e+01
        Line search: gnorm after quadratic fit 2.900250934549e+01
        Line search: gnorm after quadratic fit 2.599278674163e+01
        Line search: gnorm after quadratic fit 2.318734215117e+01
        Line search: gnorm after quadratic fit 2.085878334659e+01
        Line search: gnorm after quadratic fit 1.876798496343e+01
        Line search: gnorm after quadratic fit 1.688832614434e+01
        Line search: gnorm after quadratic fit 1.473393930236e+01
        Line search: gnorm after quadratic fit 1.316319959672e+01
        Line search: gnorm after quadratic fit 1.107264479512e+01
        Line search: gnorm after quadratic fit 9.971301122007e+00
        Line search: gnorm after quadratic fit 9.053797760810e+00
        Line search: gnorm after quadratic fit 8.226880585839e+00
        Line search: gnorm after quadratic fit 6.995878469557e+00
        Line search: Using full step: fnorm 6.995878469557e+00 gnorm 5.272280296704e+00
        Line search: Using full step: fnorm 6.995878469557e+00 gnorm 5.272280296705e+00
        Line search: Using full step: fnorm 5.272280296704e+00 gnorm 4.977720868656e-01
        Line search: Using full step: fnorm 5.272280296705e+00 gnorm 4.977720868657e-01
        Line search: Using full step: fnorm 5.272280296705e+00 gnorm 4.977720868658e-01
        Line search: Using full step: fnorm 5.272280296705e+00 gnorm 4.977720868661e-01
        Line search: Using full step: fnorm 4.977720868656e-01 gnorm 8.679484722829e-03
        Line search: Using full step: fnorm 4.977720868657e-01 gnorm 8.679484722812e-03
        Line search: Using full step: fnorm 4.977720868658e-01 gnorm 8.679484722840e-03
        Line search: Using full step: fnorm 4.977720868661e-01 gnorm 8.679484722723e-03
        Line search: Using full step: fnorm 8.679484722829e-03 gnorm 3.188884364524e-06
        Line search: Using full step: fnorm 8.679484722812e-03 gnorm 3.188884366224e-06
        Line search: Using full step: fnorm 8.679484722840e-03 gnorm 3.188884375985e-06
        Line search: Using full step: fnorm 8.679484722723e-03 gnorm 3.188884265122e-06
        Line search: Using full step: fnorm 3.188884364524e-06 gnorm 9.942455994581e-13
        Line search: Using full step: fnorm 3.188884366224e-06 gnorm 1.108631689515e-12
        Line search: Using full step: fnorm 3.188884375985e-06 gnorm 1.151899806314e-12
        Line search: Using full step: fnorm 3.188884265122e-06 gnorm 1.185037869177e-12
 27 SNES Function norm 1.020056306744e+02
        Line search: gnorm after quadratic fit 4.832827516575e+01
        Line search: Quadratically determined step, lambda=2.2200960468019579e-01
        Line search: Quadratically determined step, lambda=2.2200960468019632e-01
        Line search: Quadratically determined step, lambda=2.2200960468019643e-01
        Line search: Quadratically determined step, lambda=2.2200960468019604e-01
        Line search: gnorm after quadratic fit 4.117408503685e+01
        Line search: Quadratically determined step, lambda=1.4592085398554283e-01
        Line search: Quadratically determined step, lambda=1.4592085398554214e-01
        Line search: Quadratically determined step, lambda=1.4592085398554278e-01
        Line search: gnorm after quadratic fit 3.601829839496e+01
        Line search: Quadratically determined step, lambda=1.2507652845577485e-01
        Line search: Quadratically determined step, lambda=1.2507652845577591e-01
        Line search: Quadratically determined step, lambda=1.2507652845577641e-01
        Line search: Quadratically determined step, lambda=1.2507652845577621e-01
        Line search: gnorm after quadratic fit 3.230247462572e+01
        Line search: gnorm after quadratic fit 2.900250934547e+01
        Line search: gnorm after quadratic fit 2.599278674161e+01
        Line search: gnorm after quadratic fit 2.318734215114e+01
        Line search: gnorm after quadratic fit 2.085878334656e+01
        Line search: gnorm after quadratic fit 1.876798496340e+01
        Line search: gnorm after quadratic fit 1.688832614431e+01
        Line search: gnorm after quadratic fit 1.473393930234e+01
        Line search: gnorm after quadratic fit 1.316319959670e+01
        Line search: gnorm after quadratic fit 1.107264479510e+01
        Line search: gnorm after quadratic fit 9.971301121992e+00
        Line search: gnorm after quadratic fit 9.053797760800e+00
        Line search: gnorm after quadratic fit 9.053797760799e+00
        Line search: gnorm after quadratic fit 8.226880585830e+00
        Line search: gnorm after quadratic fit 6.995878469562e+00
        Line search: Using full step: fnorm 6.995878469562e+00 gnorm 5.272280296903e+00
        Line search: Using full step: fnorm 6.995878469562e+00 gnorm 5.272280296902e+00
        Line search: Using full step: fnorm 6.995878469562e+00 gnorm 5.272280296901e+00
        Line search: Using full step: fnorm 5.272280296903e+00 gnorm 4.977720868958e-01
        Line search: Using full step: fnorm 5.272280296902e+00 gnorm 4.977720868959e-01
        Line search: Using full step: fnorm 5.272280296902e+00 gnorm 4.977720868960e-01
        Line search: Using full step: fnorm 5.272280296901e+00 gnorm 4.977720868959e-01
        Line search: Using full step: fnorm 4.977720868958e-01 gnorm 8.679484723649e-03
        Line search: Using full step: fnorm 4.977720868960e-01 gnorm 8.679484723635e-03
        Line search: Using full step: fnorm 4.977720868959e-01 gnorm 8.679484723636e-03
        Line search: Using full step: fnorm 8.679484723649e-03 gnorm 3.188884476249e-06
        Line search: Using full step: fnorm 4.977720868959e-01 gnorm 8.679484723634e-03
        Line search: Using full step: fnorm 8.679484723635e-03 gnorm 3.188884487112e-06
        Line search: Using full step: fnorm 3.188884476249e-06 gnorm 1.015090019563e-12
        Line search: Using full step: fnorm 8.679484723636e-03 gnorm 3.188884480508e-06
        Line search: Using full step: fnorm 3.188884487112e-06 gnorm 1.006813583605e-12
        Line search: Using full step: fnorm 8.679484723634e-03 gnorm 3.188884485399e-06
        Line search: Using full step: fnorm 3.188884480508e-06 gnorm 1.124708288428e-12
        Line search: Using full step: fnorm 3.188884485399e-06 gnorm 1.017053128759e-12
 28 SNES Function norm 1.020056306744e+02
        Line search: gnorm after quadratic fit 4.832827516573e+01
        Line search: Quadratically determined step, lambda=2.2200960468017888e-01
        Line search: Quadratically determined step, lambda=2.2200960468017938e-01
        Line search: Quadratically determined step, lambda=2.2200960468017927e-01
        Line search: Quadratically determined step, lambda=2.2200960468017894e-01
        Line search: gnorm after quadratic fit 4.117408503684e+01
        Line search: Quadratically determined step, lambda=1.4592085398550789e-01
        Line search: Quadratically determined step, lambda=1.4592085398550833e-01
        Line search: Quadratically determined step, lambda=1.4592085398550825e-01
        Line search: Quadratically determined step, lambda=1.4592085398550717e-01
            Line search: gnorm after quadratic fit 3.601829839495e+01
        Line search: Quadratically determined step, lambda=1.2507652845569578e-01
        Line search: Quadratically determined step, lambda=1.2507652845569625e-01
        Line search: Quadratically determined step, lambda=1.2507652845569606e-01
        Line search: Quadratically determined step, lambda=1.2507652845569575e-01
        Line search: gnorm after quadratic fit 3.230247462571e+01
        Line search: gnorm after quadratic fit 2.318734215112e+01
        Line search: gnorm after quadratic fit 2.085878334655e+01
        Line search: gnorm after quadratic fit 1.876798496339e+01
        Line search: gnorm after quadratic fit 1.688832614430e+01
        Line search: gnorm after quadratic fit 1.316319959669e+01
        Line search: gnorm after quadratic fit 9.971301121987e+00
        Line search: gnorm after quadratic fit 9.053797760796e+00
        Line search: gnorm after quadratic fit 8.226880585827e+00
        Line search: gnorm after quadratic fit 8.226880585828e+00
        Line search: gnorm after quadratic fit 6.995878469564e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296970e+00
        Line search: Using full step: fnorm 5.272280296970e+00 gnorm 4.977720869065e-01
        Line search: Using full step: fnorm 5.272280296970e+00 gnorm 4.977720869063e-01
        Line search: Using full step: fnorm 4.977720869065e-01 gnorm 8.679484724049e-03
        Line search: Using full step: fnorm 4.977720869063e-01 gnorm 8.679484724057e-03
        Line search: Using full step: fnorm 5.272280296970e+00 gnorm 4.977720869064e-01
        Line search: Using full step: fnorm 8.679484724049e-03 gnorm 3.188884387631e-06
        Line search: Using full step: fnorm 8.679484724057e-03 gnorm 3.188884490220e-06
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296969e+00
        Line search: Using full step: fnorm 4.977720869064e-01 gnorm 8.679484724168e-03
        Line search: Using full step: fnorm 3.188884387631e-06 gnorm 1.011705276682e-12
        Line search: Using full step: fnorm 3.188884490220e-06 gnorm 1.075925650836e-12
        Line search: Using full step: fnorm 5.272280296969e+00 gnorm 4.977720869062e-01
        Line search: Using full step: fnorm 8.679484724168e-03 gnorm 3.188884391122e-06
        Line search: Using full step: fnorm 4.977720869062e-01 gnorm 8.679484724057e-03
        Line search: Using full step: fnorm 3.188884391122e-06 gnorm 1.218742722311e-12
        Line search: Using full step: fnorm 8.679484724057e-03 gnorm 3.188884508673e-06
        Line search: Using full step: fnorm 3.188884508673e-06 gnorm 9.396637003174e-13
 29 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017292e-01
        Line search: Quadratically determined step, lambda=2.2200960468017283e-01
        Line search: Quadratically determined step, lambda=2.2200960468017339e-01
        Line search: Quadratically determined step, lambda=2.2200960468017403e-01
        Line search: Quadratically determined step, lambda=1.4592085398549656e-01
        Line search: Quadratically determined step, lambda=1.4592085398549590e-01
        Line search: Quadratically determined step, lambda=1.4592085398549634e-01
        Line search: Quadratically determined step, lambda=1.4592085398549598e-01
        Line search: Quadratically determined step, lambda=1.2507652845566977e-01
        Line search: Quadratically determined step, lambda=1.2507652845566869e-01
        Line search: Quadratically determined step, lambda=1.2507652845566875e-01
        Line search: Quadratically determined step, lambda=1.2507652845566877e-01
        Line search: gnorm after quadratic fit 2.900250934546e+01
        Line search: gnorm after quadratic fit 2.599278674160e+01
        Line search: gnorm after quadratic fit 1.473393930233e+01
        Line search: gnorm after quadratic fit 1.107264479509e+01
        Line search: gnorm after quadratic fit 9.971301121985e+00
        Line search: gnorm after quadratic fit 9.053797760795e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296992e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296993e+00
        Line search: Using full step: fnorm 5.272280296992e+00 gnorm 4.977720869098e-01
        Line search: Using full step: fnorm 5.272280296993e+00 gnorm 4.977720869102e-01
        Line search: Using full step: fnorm 5.272280296992e+00 gnorm 4.977720869101e-01
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296994e+00
        Line search: Using full step: fnorm 4.977720869098e-01 gnorm 8.679484724109e-03
        Line search: Using full step: fnorm 4.977720869102e-01 gnorm 8.679484724127e-03
        Line search: Using full step: fnorm 4.977720869101e-01 gnorm 8.679484724332e-03
        Line search: Using full step: fnorm 5.272280296994e+00 gnorm 4.977720869099e-01
        Line search: Using full step: fnorm 8.679484724109e-03 gnorm 3.188884366954e-06
        Line search: Using full step: fnorm 8.679484724332e-03 gnorm 3.188884481493e-06
        Line search: Using full step: fnorm 8.679484724127e-03 gnorm 3.188884140213e-06
        Line search: Using full step: fnorm 4.977720869099e-01 gnorm 8.679484724103e-03
        Line search: Using full step: fnorm 3.188884366954e-06 gnorm 1.081069327575e-12
        Line search: Using full step: fnorm 3.188884140213e-06 gnorm 1.140126765994e-12
        Line search: Using full step: fnorm 3.188884481493e-06 gnorm 1.098104504104e-12
        Line search: Using full step: fnorm 8.679484724103e-03 gnorm 3.188884614242e-06
        Line search: Using full step: fnorm 3.188884614242e-06 gnorm 9.611554868156e-13
 30 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017247e-01
        Line search: Quadratically determined step, lambda=2.2200960468017197e-01
        Line search: Quadratically determined step, lambda=2.2200960468017300e-01
        Line search: Quadratically determined step, lambda=2.2200960468017267e-01
        Line search: gnorm after quadratic fit 4.117408503683e+01
        Line search: Quadratically determined step, lambda=1.4592085398549140e-01
        Line search: Quadratically determined step, lambda=1.4592085398549115e-01
        Line search: Quadratically determined step, lambda=1.4592085398549104e-01
        Line search: Quadratically determined step, lambda=1.2507652845565936e-01
        Line search: Quadratically determined step, lambda=1.2507652845565825e-01
        Line search: Quadratically determined step, lambda=1.2507652845565906e-01
        Line search: Quadratically determined step, lambda=1.2507652845565939e-01
        Line search: gnorm after quadratic fit 2.085878334654e+01
        Line search: gnorm after quadratic fit 9.971301121984e+00
            Line search: gnorm after quadratic fit 8.226880585826e+00
        Line search: gnorm after quadratic fit 6.995878469565e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280296999e+00
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280296999e+00
        Line search: Using full step: fnorm 5.272280296999e+00 gnorm 4.977720869105e-01
        Line search: Using full step: fnorm 5.272280296999e+00 gnorm 4.977720869107e-01
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280296998e+00
        Line search: Using full step: fnorm 4.977720869105e-01 gnorm 8.679484724219e-03
        Line search: Using full step: fnorm 4.977720869105e-01 gnorm 8.679484724324e-03
        Line search: Using full step: fnorm 4.977720869107e-01 gnorm 8.679484724192e-03
        Line search: Using full step: fnorm 5.272280296998e+00 gnorm 4.977720869106e-01
        Line search: Using full step: fnorm 8.679484724219e-03 gnorm 3.188884468866e-06
        Line search: Using full step: fnorm 8.679484724324e-03 gnorm 3.188884583014e-06
        Line search: Using full step: fnorm 8.679484724192e-03 gnorm 3.188884469700e-06
        Line search: Using full step: fnorm 4.977720869106e-01 gnorm 8.679484724245e-03
        Line search: Using full step: fnorm 3.188884468866e-06 gnorm 1.204416932363e-12
        Line search: Using full step: fnorm 3.188884583014e-06 gnorm 1.166994961184e-12
        Line search: Using full step: fnorm 3.188884469700e-06 gnorm 1.062333793343e-12
        Line search: Using full step: fnorm 8.679484724245e-03 gnorm 3.188884465264e-06
        Line search: Using full step: fnorm 3.188884465264e-06 gnorm 1.294230480350e-12
 31 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017092e-01
        Line search: Quadratically determined step, lambda=2.2200960468017156e-01
        Line search: Quadratically determined step, lambda=2.2200960468017134e-01
        Line search: Quadratically determined step, lambda=2.2200960468017139e-01
        Line search: Quadratically determined step, lambda=1.4592085398549032e-01
        Line search: Quadratically determined step, lambda=1.4592085398549090e-01
        Line search: Quadratically determined step, lambda=1.4592085398549079e-01
        Line search: Quadratically determined step, lambda=1.4592085398549109e-01
        Line search: gnorm after quadratic fit 3.601829839494e+01
        Line search: Quadratically determined step, lambda=1.2507652845565576e-01
        Line search: Quadratically determined step, lambda=1.2507652845565570e-01
        Line search: Quadratically determined step, lambda=1.2507652845565634e-01
        Line search: Quadratically determined step, lambda=1.2507652845565650e-01
        Line search: gnorm after quadratic fit 9.053797760794e+00
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280297002e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280297002e+00
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280297001e+00
        Line search: Using full step: fnorm 5.272280297002e+00 gnorm 4.977720869109e-01
        Line search: Using full step: fnorm 5.272280297002e+00 gnorm 4.977720869113e-01
        Line search: Using full step: fnorm 5.272280297002e+00 gnorm 4.977720869114e-01
        Line search: Using full step: fnorm 5.272280297001e+00 gnorm 4.977720869109e-01
        Line search: Using full step: fnorm 4.977720869109e-01 gnorm 8.679484724167e-03
        Line search: Using full step: fnorm 4.977720869113e-01 gnorm 8.679484724425e-03
        Line search: Using full step: fnorm 4.977720869114e-01 gnorm 8.679484724422e-03
        Line search: Using full step: fnorm 4.977720869109e-01 gnorm 8.679484724429e-03
        Line search: Using full step: fnorm 8.679484724167e-03 gnorm 3.188884272156e-06
        Line search: Using full step: fnorm 8.679484724425e-03 gnorm 3.188884063436e-06
        Line search: Using full step: fnorm 8.679484724422e-03 gnorm 3.188884054884e-06
        Line search: Using full step: fnorm 8.679484724429e-03 gnorm 3.188884272302e-06
        Line search: Using full step: fnorm 3.188884272156e-06 gnorm 1.063520435978e-12
        Line search: Using full step: fnorm 3.188884063436e-06 gnorm 1.279189487429e-12
        Line search: Using full step: fnorm 3.188884054884e-06 gnorm 1.155874150726e-12
        Line search: Using full step: fnorm 3.188884272302e-06 gnorm 1.219191504218e-12
 32 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017078e-01
        Line search: Quadratically determined step, lambda=2.2200960468017067e-01
        Line search: Quadratically determined step, lambda=2.2200960468017086e-01
        Line search: Quadratically determined step, lambda=2.2200960468017131e-01
        Line search: Quadratically determined step, lambda=1.4592085398549004e-01
        Line search: Quadratically determined step, lambda=1.4592085398549021e-01
        Line search: Quadratically determined step, lambda=1.4592085398549023e-01
        Line search: Quadratically determined step, lambda=1.2507652845565548e-01
        Line search: Quadratically determined step, lambda=1.2507652845565556e-01
        Line search: Quadratically determined step, lambda=1.2507652845565542e-01
        Line search: Quadratically determined step, lambda=1.2507652845565623e-01
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280297004e+00
        Line search: Using full step: fnorm 5.272280297004e+00 gnorm 4.977720869116e-01
        Line search: Using full step: fnorm 5.272280297004e+00 gnorm 4.977720869112e-01
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280297005e+00
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724414e-03
        Line search: Using full step: fnorm 4.977720869112e-01 gnorm 8.679484724309e-03
        Line search: Using full step: fnorm 5.272280297005e+00 gnorm 4.977720869117e-01
        Line search: Using full step: fnorm 4.977720869112e-01 gnorm 8.679484724169e-03
        Line search: Using full step: fnorm 8.679484724414e-03 gnorm 3.188884190373e-06
        Line search: Using full step: fnorm 8.679484724309e-03 gnorm 3.188884308390e-06
        Line search: Using full step: fnorm 4.977720869117e-01 gnorm 8.679484724411e-03
        Line search: Using full step: fnorm 8.679484724169e-03 gnorm 3.188884194371e-06
        Line search: Using full step: fnorm 3.188884308390e-06 gnorm 1.247866045127e-12
        Line search: Using full step: fnorm 3.188884190373e-06 gnorm 1.228645313556e-12
        Line search: Using full step: fnorm 3.188884194371e-06 gnorm 1.472066558456e-12
        Line search: Using full step: fnorm 8.679484724411e-03 gnorm 3.188884229520e-06
        Line search: Using full step: fnorm 3.188884229520e-06 gnorm 1.216794771148e-12
 33 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017220e-01
        Line search: Quadratically determined step, lambda=2.2200960468017195e-01
        Line search: Quadratically determined step, lambda=2.2200960468017170e-01
        Line search: Quadratically determined step, lambda=2.2200960468017211e-01
        Line search: Quadratically determined step, lambda=1.4592085398548887e-01
        Line search: Quadratically determined step, lambda=1.4592085398548968e-01
        Line search: Quadratically determined step, lambda=1.4592085398548868e-01
        Line search: Quadratically determined step, lambda=1.4592085398548890e-01
        Line search: Quadratically determined step, lambda=1.2507652845565406e-01
        Line search: Quadratically determined step, lambda=1.2507652845565534e-01
        Line search: Quadratically determined step, lambda=1.2507652845565473e-01
        Line search: Quadratically determined step, lambda=1.2507652845565448e-01
        Line search: Using full step: fnorm 5.272280297004e+00 gnorm 4.977720869114e-01
        Line search: Using full step: fnorm 5.272280297005e+00 gnorm 4.977720869116e-01
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724296e-03
        Line search: Using full step: fnorm 5.272280297004e+00 gnorm 4.977720869117e-01
        Line search: Using full step: fnorm 4.977720869114e-01 gnorm 8.679484724304e-03
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724322e-03
        Line search: Using full step: fnorm 8.679484724296e-03 gnorm 3.188884108496e-06
        Line search: Using full step: fnorm 8.679484724304e-03 gnorm 3.188884326655e-06
        Line search: Using full step: fnorm 4.977720869117e-01 gnorm 8.679484724315e-03
        Line search: Using full step: fnorm 8.679484724322e-03 gnorm 3.188884335183e-06
        Line search: Using full step: fnorm 3.188884108496e-06 gnorm 1.269563130991e-12
        Line search: Using full step: fnorm 3.188884326655e-06 gnorm 1.384732858637e-12
        Line search: Using full step: fnorm 8.679484724315e-03 gnorm 3.188884334185e-06
        Line search: Using full step: fnorm 3.188884335183e-06 gnorm 1.131705806116e-12
        Line search: Using full step: fnorm 3.188884334185e-06 gnorm 1.166660051381e-12
 34 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017172e-01
        Line search: Quadratically determined step, lambda=2.2200960468017239e-01
        Line search: Quadratically determined step, lambda=2.2200960468017272e-01
        Line search: Quadratically determined step, lambda=1.4592085398548860e-01
        Line search: Quadratically determined step, lambda=1.4592085398548854e-01
        Line search: Quadratically determined step, lambda=1.4592085398548876e-01
        Line search: Quadratically determined step, lambda=1.2507652845565426e-01
        Line search: Quadratically determined step, lambda=1.2507652845565506e-01
        Line search: Quadratically determined step, lambda=1.2507652845565478e-01
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724437e-03
        Line search: Using full step: fnorm 4.977720869117e-01 gnorm 8.679484724329e-03
        Line search: Using full step: fnorm 4.977720869112e-01 gnorm 8.679484724326e-03
        Line search: Using full step: fnorm 5.272280297004e+00 gnorm 4.977720869115e-01
        Line search: Using full step: fnorm 8.679484724437e-03 gnorm 3.188884219161e-06
        Line search: Using full step: fnorm 8.679484724329e-03 gnorm 3.188884339566e-06
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724330e-03
        Line search: Using full step: fnorm 8.679484724326e-03 gnorm 3.188884098513e-06
        Line search: Using full step: fnorm 3.188884219161e-06 gnorm 1.238443985503e-12
        Line search: Using full step: fnorm 3.188884339566e-06 gnorm 1.270488082810e-12
        Line search: Using full step: fnorm 3.188884098513e-06 gnorm 1.401136100534e-12
        Line search: Using full step: fnorm 8.679484724330e-03 gnorm 3.188884087471e-06
        Line search: Using full step: fnorm 3.188884087471e-06 gnorm 1.201771434924e-12
 35 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017122e-01
        Line search: Quadratically determined step, lambda=2.2200960468017245e-01
      Line search: Quadratically determined step, lambda=2.2200960468017236e-01
        Line search: Quadratically determined step, lambda=1.4592085398548912e-01
        Line search: Quadratically determined step, lambda=1.4592085398548871e-01
        Line search: Quadratically determined step, lambda=1.4592085398548879e-01
        Line search: Quadratically determined step, lambda=1.4592085398548801e-01
        Line search: Quadratically determined step, lambda=1.2507652845565442e-01
        Line search: Quadratically determined step, lambda=1.2507652845565417e-01
        Line search: Quadratically determined step, lambda=1.2507652845565470e-01
        Line search: Quadratically determined step, lambda=1.2507652845565348e-01
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724350e-03
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724440e-03
        Line search: Using full step: fnorm 8.679484724350e-03 gnorm 3.188884099350e-06
        Line search: Using full step: fnorm 8.679484724440e-03 gnorm 3.188884217874e-06
        Line search: Using full step: fnorm 6.995878469564e+00 gnorm 5.272280297003e+00
        Line search: Using full step: fnorm 3.188884099350e-06 gnorm 1.273610826522e-12
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724440e-03
        Line search: Using full step: fnorm 3.188884217874e-06 gnorm 1.206943870198e-12
        Line search: Using full step: fnorm 5.272280297003e+00 gnorm 4.977720869114e-01
        Line search: Using full step: fnorm 8.679484724440e-03 gnorm 3.188884218766e-06
        Line search: Using full step: fnorm 4.977720869114e-01 gnorm 8.679484724326e-03
        Line search: Using full step: fnorm 3.188884218766e-06 gnorm 1.435480418399e-12
        Line search: Using full step: fnorm 8.679484724326e-03 gnorm 3.188884098224e-06
        Line search: Using full step: fnorm 3.188884098224e-06 gnorm 1.090002762591e-12
 36 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017128e-01
        Line search: Quadratically determined step, lambda=2.2200960468017192e-01
        Line search: Quadratically determined step, lambda=1.4592085398548940e-01
        Line search: Quadratically determined step, lambda=1.4592085398548824e-01
        Line search: Quadratically determined step, lambda=1.4592085398548924e-01
        Line search: Quadratically determined step, lambda=1.4592085398548851e-01
        Line search: Quadratically determined step, lambda=1.2507652845565412e-01
        Line search: Quadratically determined step, lambda=1.2507652845565440e-01
        Line search: Quadratically determined step, lambda=1.2507652845565459e-01
        Line search: Quadratically determined step, lambda=1.2507652845565512e-01
        Line search: Using full step: fnorm 6.995878469565e+00 gnorm 5.272280297003e+00
        Line search: Using full step: fnorm 5.272280297005e+00 gnorm 4.977720869115e-01
        Line search: Using full step: fnorm 4.977720869114e-01 gnorm 8.679484724432e-03
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724311e-03
        Line search: Using full step: fnorm 4.977720869116e-01 gnorm 8.679484724438e-03
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724442e-03
        Line search: Using full step: fnorm 8.679484724311e-03 gnorm 3.188884098538e-06
        Line search: Using full step: fnorm 8.679484724432e-03 gnorm 3.188884220070e-06
        Line search: Using full step: fnorm 8.679484724438e-03 gnorm 3.188884097464e-06
        Line search: Using full step: fnorm 8.679484724442e-03 gnorm 3.188884218614e-06
        Line search: Using full step: fnorm 3.188884098538e-06 gnorm 1.240359149945e-12
        Line search: Using full step: fnorm 3.188884220070e-06 gnorm 1.255043917216e-12
        Line search: Using full step: fnorm 3.188884097464e-06 gnorm 1.110796462156e-12
        Line search: Using full step: fnorm 3.188884218614e-06 gnorm 1.383304064781e-12
 37 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017183e-01
        Line search: Quadratically determined step, lambda=1.4592085398548840e-01
        Line search: Quadratically determined step, lambda=1.4592085398548882e-01
        Line search: Quadratically determined step, lambda=1.2507652845565392e-01
        Line search: Using full step: fnorm 5.272280297003e+00 gnorm 4.977720869115e-01
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724437e-03
        Line search: Using full step: fnorm 4.977720869114e-01 gnorm 8.679484724311e-03
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724456e-03
        Line search: Using full step: fnorm 8.679484724437e-03 gnorm 3.188884217511e-06
        Line search: Using full step: fnorm 8.679484724311e-03 gnorm 3.188884098591e-06
        Line search: Using full step: fnorm 8.679484724438e-03 gnorm 3.188884097392e-06
        Line search: Using full step: fnorm 8.679484724456e-03 gnorm 3.188884218797e-06
        Line search: Using full step: fnorm 3.188884217511e-06 gnorm 1.268226786200e-12
        Line search: Using full step: fnorm 3.188884098591e-06 gnorm 1.253055271389e-12
        Line search: Using full step: fnorm 3.188884097392e-06 gnorm 1.115079465187e-12
        Line search: Using full step: fnorm 3.188884218797e-06 gnorm 1.420277433111e-12
 38 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017164e-01
        Line search: Quadratically determined step, lambda=2.2200960468017178e-01
        Line search: Quadratically determined step, lambda=2.2200960468017120e-01
        Line search: Quadratically determined step, lambda=1.4592085398548899e-01
        Line search: Quadratically determined step, lambda=1.4592085398548929e-01
        Line search: Quadratically determined step, lambda=1.2507652845565423e-01
        Line search: Quadratically determined step, lambda=1.2507652845565415e-01
        Line search: Using full step: fnorm 5.272280297003e+00 gnorm 4.977720869113e-01
        Line search: Using full step: fnorm 4.977720869113e-01 gnorm 8.679484724436e-03
        Line search: Using full step: fnorm 8.679484724311e-03 gnorm 3.188884098554e-06
        Line search: Using full step: fnorm 8.679484724436e-03 gnorm 3.188884217757e-06
        Line search: Using full step: fnorm 3.188884098554e-06 gnorm 1.252075052491e-12
        Line search: Using full step: fnorm 3.188884217757e-06 gnorm 1.289827237421e-12
        Line search: Using full step: fnorm 8.679484724438e-03 gnorm 3.188884097138e-06
        Line search: Using full step: fnorm 8.679484724442e-03 gnorm 3.188884218809e-06
        Line search: Using full step: fnorm 3.188884097138e-06 gnorm 1.115369901153e-12
        Line search: Using full step: fnorm 3.188884218809e-06 gnorm 1.375476144695e-12
 39 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017114e-01
        Line search: Quadratically determined step, lambda=2.2200960468017159e-01
        Line search: Quadratically determined step, lambda=1.4592085398548943e-01
        Line search: Quadratically determined step, lambda=1.4592085398548901e-01
        Line search: Quadratically determined step, lambda=1.4592085398548996e-01
        Line search: Quadratically determined step, lambda=1.2507652845565381e-01
        Line search: Quadratically determined step, lambda=1.2507652845565387e-01
        Line search: Quadratically determined step, lambda=1.2507652845565481e-01
        Line search: Using full step: fnorm 8.679484724311e-03 gnorm 3.188884098470e-06
        Line search: Using full step: fnorm 8.679484724436e-03 gnorm 3.188884217747e-06
        Line search: Using full step: fnorm 8.679484724438e-03 gnorm 3.188884097116e-06
        Line search: Using full step: fnorm 3.188884217747e-06 gnorm 1.258821430469e-12
        Line search: Using full step: fnorm 3.188884098470e-06 gnorm 1.242709087863e-12
        Line search: Using full step: fnorm 3.188884097116e-06 gnorm 1.115278549854e-12
        Line search: Using full step: fnorm 3.188884218797e-06 gnorm 1.420284150295e-12
 40 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017111e-01
        Line search: Quadratically determined step, lambda=2.2200960468017125e-01
        Line search: Quadratically determined step, lambda=1.4592085398548976e-01
        Line search: Quadratically determined step, lambda=1.4592085398548910e-01
        Line search: Quadratically determined step, lambda=1.2507652845565376e-01
        Line search: Quadratically determined step, lambda=1.2507652845565390e-01
        Line search: Using full step: fnorm 4.977720869113e-01 gnorm 8.679484724310e-03
        Line search: Using full step: fnorm 8.679484724310e-03 gnorm 3.188884094770e-06
        Line search: Using full step: fnorm 8.679484724436e-03 gnorm 3.188884217574e-06
        Line search: Using full step: fnorm 8.679484724456e-03 gnorm 3.188884218792e-06
        Line search: Using full step: fnorm 3.188884094770e-06 gnorm 1.244255786179e-12
        Line search: Using full step: fnorm 3.188884217574e-06 gnorm 1.241013276105e-12
        Line search: Using full step: fnorm 3.188884218792e-06 gnorm 1.419691596810e-12
 41 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=2.2200960468017181e-01
        Line search: Quadratically determined step, lambda=2.2200960468017145e-01
        Line search: Quadratically determined step, lambda=1.4592085398548907e-01
        Line search: Quadratically determined step, lambda=1.2507652845565378e-01
        Line search: Quadratically determined step, lambda=1.2507652845565398e-01
        Line search: Quadratically determined step, lambda=1.2507652845565370e-01
        Line search: Using full step: fnorm 3.188884094770e-06 gnorm 1.241955401726e-12
        Line search: Using full step: fnorm 3.188884097116e-06 gnorm 1.115294552897e-12
 42 SNES Function norm 1.020056306744e+02
        Line search: Quadratically determined step, lambda=1.4592085398548843e-01
        Line search: Using full step: fnorm 4.977720869115e-01 gnorm 8.679484724436e-03
        Line search: Using full step: fnorm 8.679484724436e-03 gnorm 3.188884217741e-06
        Line search: Using full step: fnorm 3.188884217741e-06 gnorm 1.251783426833e-12
 43 SNES Function norm 1.020056306744e+02
        Line search: Using full step: fnorm 4.977720869113e-01 gnorm 8.679484724309e-03
        Line search: Using full step: fnorm 8.679484724309e-03 gnorm 3.188884094767e-06
        Line search: Using full step: fnorm 3.188884094767e-06 gnorm 1.243433253077e-12
        Line search: Using full step: fnorm 8.679484724456e-03 gnorm 3.188884219331e-06
        Line search: Using full step: fnorm 3.188884219331e-06 gnorm 1.425470073162e-12
 44 SNES Function norm 1.020056306744e+02
 45 SNES Function norm 1.020056306744e+02
 46 SNES Function norm 1.020056306744e+02
 47 SNES Function norm 1.020056306744e+02
 48 SNES Function norm 1.020056306744e+02
 49 SNES Function norm 1.020056306744e+02
 50 SNES Function norm 1.020056306744e+02
SNES Object: 4 MPI processes
  type: nasm
    total subdomain blocks = 4
    Local solver information for first block on rank 0:
    Use -snes_view ::ascii_info_detail to display information for all blocks
    SNES Object: (sub_) 1 MPI processes
      type: newtonls
      maximum iterations=50, maximum function evaluations=10000
      tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
      total number of linear solver iterations=22
      total number of function evaluations=40
      norm schedule ALWAYS
      Jacobian is built using a DMDA local Jacobian
      SNESLineSearch Object: (sub_) 1 MPI processes
        type: bt
          interpolation: cubic
          alpha=1.000000e-04
        maxstep=1.000000e+08, minlambda=1.000000e-12
        tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
        maximum iterations=40
      KSP Object: (sub_) 1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object: (sub_) 1 MPI processes
        type: lu
          out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: nd
          factor fill ratio given 5., needed 2.13732
            Factored matrix follows:
              Mat Object: 1 MPI processes
                type: seqaij
                rows=169, cols=169
                package used to perform factorization: petsc
                total: nonzeros=13339, allocated nonzeros=13339
                  using I-node routines: found 104 nodes, limit used is 5
        linear system matrix = precond matrix:
          type: seqaij
          rows=169, cols=169
          total: nonzeros=6241, allocated nonzeros=6241
          total number of mallocs used during MatSetValues calls=0
            not using I-node routines
  total number of function evaluations=51
problem ex10 on 20 x 20 point 2D grid with d = 3, and eps = 0.082:
  error |u-uexact|_inf = 3.996e-01, |u-uexact|_h = 2.837e-01
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 2 unused database options. They are:
Option left: name:-ksp_converged_reason (no value)
Option left: name:-snes_linesearch_monitor (no value)
