[petsc-users] MatColoring
Mark Adams mfadams at lbl.gov
Tue May 10 11:31:37 CDT 2022
This should do it:
https://petsc.org/release/docs/manualpages/MatOrderings/MatColoringSetType.html#MatColoringSetType
Also, this page has MATCOLORINGMIS, but that is not a type:
typedef const  char*           MatColoringType
<https://petsc.org/release/docs/manualpages/Mat/MatColoringType.html#MatColoringType>;
#define MATCOLORINGJP
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGJP.html#MATCOLORINGJP>
     "jp"
#define MATCOLORINGPOWER
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGPOWER.html#MATCOLORINGPOWER>
  "power"
#define MATCOLORINGNATURAL
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGNATURAL.html#MATCOLORINGNATURAL>
"natural"
#define MATCOLORINGSL
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGSL.html#MATCOLORINGSL>
     "sl"
#define MATCOLORINGLF
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGLF.html#MATCOLORINGLF>
     "lf"
#define MATCOLORINGID
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGID.html#MATCOLORINGID>
     "id"
#define MATCOLORINGGREEDY
<https://petsc.org/release/docs/manualpages/MatOrderings/MATCOLORINGGREEDY.html#MATCOLORINGGREEDY>
 "greedy"
I guess they mean MATCOLORINGGREEDY
but
not sure.
On Tue, May 10, 2022 at 11:40 AM Jorti, Zakariae via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I am solving a non-linear problem and using a finite difference
> approximation with coloring to compute the Jacobian matrix.
> There are several coloring algorithms available in PETSc as indicated here:
> https://petsc.org/release/docs/manualpages/Mat/MatColoring.html
> And I was wondering how to switch from one to another in the Jacobian
> setup routine and also how to check which coloring algorithm I am currently
> using.
> Thank you.
> Zakariae Jorti
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220510/6439fe09/attachment.html>
