[petsc-users] error with version 3.17.1
Pierre Jolivet pierre at joliv.et
Tue May 3 11:37:15 CDT 2022
Thanks for the reproducer.
My guess is that your AIJ matrix has not a block size of 3.
A simple call such as: call MatConvert(A,MATBAIJ,MAT_INITIAL_MATRIX,C,ierr) is also failing, while it shouldn’t if your AIJ Mat is truly made of 3x3 dense blocks.
How did you determine the block size of your Mat?
Are you allocating 3x3 dense blocks everywhere or are you skipping zero coefficients in your AIJ Mat?
In the meantime, you can bypass the issue by not setting a block size of 3 on your Mat, or by setting different block size for the column and row distributions, see MatSetBlockSizes().
Pierre
> On 3 May 2022, at 5:39 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
> Dear PETSc team:
> A part of our code that has worked for years and previous versions is now failing with the latest version 3.17.1, on the KSP solve with the following error:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Block size 3 is incompatible with the indices: non consecutive indices 153055 153124
> [0]PETSC ERROR: See https://petsc.org/release/faq/ <https://fra01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpetsc.org%2Frelease%2Ffaq%2F&data=05%7C01%7CRandall.Mackie%40CGG.com%7C323fb230ca4f45d45c7408da2d18c44e%7C307ea68275e14701a1146c42f9ff0d24%7C0%7C0%7C637871881639501468%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=3iAxFsi8wDXPcxKRBVFotn7DpoVNc9%2Fq60r%2F57nn7Lw%3D&reserved=0> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.17.1, Apr 28, 2022
> [0]PETSC ERROR: ./test on a linux-gfortran-complex-debug named rmackie-VirtualBox by rmackie Tue May  3 08:12:15 2022
> [0]PETSC ERROR: Configure options --with-clean=1 --with-scalar-type=complex --with-debugging=1 --with-fortran=1 --download-mpich=../external/mpich-4.0.1.tar.gz
> [0]PETSC ERROR: #1 ISSetBlockSize() at /home/rmackie/PETSc/petsc-3.17.1/src/vec/is/is/interface/index.c:1898
> [0]PETSC ERROR: #2 MatIncreaseOverlap() at /home/rmackie/PETSc/petsc-3.17.1/src/mat/interface/matrix.c:7086
> [0]PETSC ERROR: #3 PCSetUp_ASM() at /home/rmackie/PETSc/petsc-3.17.1/src/ksp/pc/impls/asm/asm.c:238
> [0]PETSC ERROR: #4 PCSetUp() at /home/rmackie/PETSc/petsc-3.17.1/src/ksp/pc/interface/precon.c:990
> [0]PETSC ERROR: #5 KSPSetUp() at /home/rmackie/PETSc/petsc-3.17.1/src/ksp/ksp/interface/itfunc.c:407
> [0]PETSC ERROR: #6 KSPSolve_Private() at /home/rmackie/PETSc/petsc-3.17.1/src/ksp/ksp/interface/itfunc.c:843
> [0]PETSC ERROR: #7 KSPSolve() at /home/rmackie/PETSc/petsc-3.17.1/src/ksp/ksp/interface/itfunc.c:1078
> I have a small test program with binary matrix and right hand side that will show the problem and I can send it as a zip file, please advise what email address to use or where to send it.
> Thanks,
> Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220503/85978ada/attachment.html>
