[petsc-users] different periodicity per dof in DMDA?
Mon May 2 11:28:54 CDT 2022
On Mon, May 2, 2022 at 12:23 PM Matteo Semplice <
matteo.semplice at uninsubria.it> wrote:
> Thanks!
> On 02/05/2022 18:07, Matthew Knepley wrote:
> On Mon, May 2, 2022 at 11:25 AM Matteo Semplice <
>> Hi.
>> I am facing a PDE with 2 dofs per node in which one dof has periodic
>> b.c. in the x direction and the other one periodic b.c. in the y
>> direction. Is there a (possibly quick-and-dirty) solution to represent
>> this in a DM (not necessarily a DMDA)?
> I am trying to understand what this means.
> It comes from a toy model for more complicated quantum field theory model
> that's hard for me to understand.
> Usually we think of periodicity as arising from the domain, not the field.
> I think it would be easiest to:
>   a) Use two different DMDA for the fields that "match up" where needed
> This is kind of what I was thinking at. So I would create two DMDA, then a
> DMComposite with the two and finally create Vecs and Matrices from the
> DMComposite?
> Yes. The drawback here is that DMDA will not help you make the proper
Jacobian. I'm not sure how important this is to you.
> If so, then how do I assemble matrices for linear systems? If I extract
> submatrices, I could use MatSetValuesStencil on diagonal blocks, but how
> about the off-diagonal ones? These latter would have rows/cols indexed by
> different DMDAs.
> Yes, you would need to manage it. Here is an example doing this:
https://petsc.org/main/src/snes/tutorials/ex28.c.html
I have never loved it, but sometimes it makes the most sense.
As a third option, you could manually construct the local to global map.
Periodicity is encoded here. However, this is pretty
intrusive.
     Matt
> Matteo
> or
>   b) Use a DMStag since it sounds like these should live on horizontal and
> vertical edges
>   Thanks,
>      Matt
>> I understand the request it's strange, but I should add that we are
>> experimenting numerically with this toy model, so in fact the b.c. may
>> change in the future... just to stress once more that I am not after a
>> perfect solution, but anything that would at least allow parallel runs
>> with few processors would do for now.
>> Thanks in advance
>>      Matteo
> experiments lead.
> -- Norbert Wiener
> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7Cba6f4499929f45d75a5f08da2c55e259%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637871044633599928%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=DRvIjjr1cjHWdoSpQJr9UkIWVxlopKbKt%2BW5sQBvQE4%3D&reserved=0>
> Prof. Matteo Semplice
> Università degli Studi dell’Insubria
> Dipartimento di Scienza e Alta Tecnologia – DiSAT
> Professore Associato
> Via Valleggio, 11 – 22100 Como (CO) – Italia
> tel.: +39 031 2386316
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220502/ae32c2b7/attachment-0001.html>
