[petsc-users] Memory leak when combining PETSc-based vectors and boost::odeint
Roland Richter
roland.richter at ntnu.no
Thu Mar 31 08:46:56 CDT 2022
The backtrace is
#0 0x00007fffeec4ba97in VecGetSize_Seq() from
/opt/petsc/lib/libpetsc.so.3.016
#1 0x00007fffeec78f5ain VecGetSize() from /opt/petsc/lib/libpetsc.so.3.016
#2 0x0000000000410b73in
test_ts_arma_with_pure_petsc_preconfigured_clean(unsigned long, unsigned
long, arma::Col<std::complex<doubl
e> > const&, arma::Col<std::complex<double> >&, double, double, double)
[clone .constprop.0]()
#3 0x0000000000414384in test_RK4_solvers_clean(unsigned long, unsigned
long, unsigned long, bool) [clone .constprop.0]()
#4 0x0000000000405c6cin main()
Roland Richter
Am 31.03.22 um 15:35 schrieb Matthew Knepley:
> On Thu, Mar 31, 2022 at 9:01 AM Roland Richter
> <roland.richter at ntnu.no> wrote:
> Hei,
> Thanks for the idea! I added a simple std::cout for both
> constructor and destructor, and found out that my destructor is
> called multiple times, while the constructor is called only once.
> This could explain the error (double free), but I do not know why
> segfault is thrown even though I explicitly check if the vector
> has been used. Are there explanations for that?
> Run with -start_in_debugger and get the stack trace when it faults.
> Right now, I have no idea where it is faulting.
> Thanks,
> Matt
> Regards,
> Roland Richter
> Am 31.03.22 um 12:14 schrieb Matthew Knepley:
>> On Thu, Mar 31, 2022 at 5:58 AM Roland Richter
>> Hei,
>> For a project I wanted to combine boost::odeint for
>> timestepping and PETSc-based vectors and matrices for
>> calculating the right hand side. As comparison for both
>> timing and correctness I set up an armadillo-based right hand
>> side (with the main-function being in *main.cpp*, and the
>> test code in *test_timestepping_clean.cpp*)
>> In theory, the code works fine, but I have some issues with
>> cleaning up afterwards in my struct /Petsc_RHS_state_clean/.
>> My initial intention was to set up all involved matrices and
>> vectors within the constructor, and free the memory in the
>> destructor. To avoid freeing vectors I have not used I
>> initially set them to /PETSC_NULL/, and check if this value
>> has been changed before calling /VecDestroy()./
>> You do not need to check. Destroy() functions already check for NULL.
>> However, when doing that I get the following error:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>> Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or
>> -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>> Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes,
>> recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: --------------------- Error Message
>> If I comment out that code in ~Petsc_RHS_state_clean(), the
>> program runs, but will use ~17 GByte of RAM during runtime.
>> As the memory is not used immediately in full, but rather
>> increases during running, I assume a memory leak somewhere.
>> Where does it come from, and how can I avoid it?
>> It must be that your constructor is called multiple times without
>> calling your destructor. I cannot understand this code in order
>> to see where that happens, but you should just be able to run in
>> the debugger and put a break point at the creation and
>> destruction calls.
>> Thanks,
>> Matt
>> Thanks!
>> Regards,
>> Roland Richter
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220331/5ddf22ce/attachment.html>
