[petsc-users] MatCreateSBAIJ
Sam Guo
sam.guo at cd-adapco.com
Tue Mar 22 15:34:49 CDT 2022
Hi Matt,
I refer to the extra memory comparing shell vs PETSc. I am using the
same MUMPS for both shell and PETSc matrix and expect the memory increase
by MUMPS to be the same for both.
Sam
On Tue, Mar 22, 2022 at 1:30 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Mar 22, 2022 at 4:26 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> The matrix only requires 175MB (upper triangular part). Not sure where
>> the other extra memory comes from for np > 1
> This is likely MUMPS. However, we could be sure by using a heap profiler,
> like massif.
> Thanks,
> Matt
>> On Tue, Mar 22, 2022 at 1:21 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Mar 22, 2022 at 4:16 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Here is one memory comparison (memory in MB)
>>>> np=1np=2np=4np=8np=16
>>>> shell 1614 1720 1874 1673 1248
>>>> PETSc(using full matrix) 2108 2260 2364 2215 1734
>>>> PETSc(using symmetric matrix) 1750 2100 2189 2094 1727Those are the
>>>> total water mark memory added.
>>> You should be able to directly read off the memory in the PETSc Mat
>>> structures (it is at the end of the log).
>>> With a tool like massif you could also directly measure the MUMPS memory.
>>> Thanks,
>>> Matt
>>>> On Tue, Mar 22, 2022 at 1:10 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>> Sam,
>>>>> MUMPS is a direct solver, as such, it requires much more memory than
>>>>> the original matrix (stored as a PETSc matrix) to store the factored
>>>>> matrix. The savings you will get by not having a PETSc copy of the matrix
>>>>> and a MUMPS copy of the matrix at the same time is unlikely to be
>>>>> significant. Do you have memory footprint measurements indicating that not
>>>>> having the PETSc copy of the matrix in memory will allow you to run
>>>>> measurably larger simulations?
>>>>> Barry
>>>>> On Mar 22, 2022, at 3:58 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> The reason I want to use shell matrix is to reduce memory footprint.
>>>>> If I create a PETSc matrix and use MUMPS, I understand PETSc will create
>>>>> another copy of the matrix for MUMPS. Is there any way to avoid the extra
>>>>> copy of MUMPS?
>>>>> On Tue, Mar 22, 2022 at 12:53 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>> wrote:
>>>>>> Barry,
>>>>>> Thanks for the illustration. Is there an easy way to mimic the
>>>>>> implementation using shell matrix? I have been studying how the sMvctx is
>>>>>> created and it seems pretty involved.
>>>>>> Thanks,
>>>>>> Sam
>>>>>> On Mon, Mar 21, 2022 at 2:48 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>> On Mar 21, 2022, at 4:36 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>> Barry,
>>>>>>> Thanks. Could you elaborate? I try to implement the matrix-vector
>>>>>>> multiplication for a symmetric matrix using shell matrix.
>>>>>>> Consider with three ranks
>>>>>>> (a) = ( A B D) (x)
>>>>>>> (b) ( B' C E) (y)
>>>>>>> (c) ( D' E' F) (w)
>>>>>>> Only the ones without the ' are stored on the rank. So for
>>>>>>> example B is stored on rank 0.
>>>>>>> Rank 0 computes A x and keeps it in a. Rank 1 computes Cy and
>>>>>>> keeps it in b Rank 2 computes Fw and keeps it in c
>>>>>>> Rank 0 computes B'x and D'x. It puts the nonzero entries of
>>>>>>> these values as well as the values of x into slvec0
>>>>>>> Rank 1 computes E'y and puts the nonzero entries as well as
>>>>>>> the values into slvec0
>>>>>>> Rank 2 puts the values of we needed by the other ranks into
>>>>>>> slvec0
>>>>>>> Rank 0 does B y_h + D z_h where it gets the y_h and z_h
>>>>>>> values from slvec1 and adds it to a
>>>>>>> Rank 1 takes the B'x from slvec1 and adds it to b it then
>>>>>>> takes the E y_h values where the y_h are pulled from slvec1 and adds them b
>>>>>>> Rank 2 takes the B'x and E'y from slvec0 and adds them to c.
>>>>>>> Thanks,
>>>>>>> Sam
>>>>>>> On Mon, Mar 21, 2022 at 12:56 PM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> The "trick" is that though "more" communication is needed to
>>>>>>>> complete the product the communication can still be done in a single
>>>>>>>> VecScatter instead of two separate calls to VecScatter. We simply pack both
>>>>>>>> pieces of information that needs to be sent into a single vector.
>>>>>>>> /* copy x into the vec slvec0 */1111: VecGetArray <https://petsc.org/main/docs/manualpages/Vec/VecGetArray.html#VecGetArray>(a->slvec0,&from);1112: VecGetArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(xx,&x);
>>>>>>>> 1114: PetscArraycpy <https://petsc.org/main/docs/manualpages/Sys/PetscArraycpy.html#PetscArraycpy>(from,x,bs*mbs);1115: VecRestoreArray <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArray.html#VecRestoreArray>(a->slvec0,&from);1116: VecRestoreArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArrayRead.html#VecRestoreArrayRead>(xx,&x);
>>>>>>>> 1118: VecScatterBegin <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterBegin.html#VecScatterBegin>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);1119: VecScatterEnd <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterEnd.html#VecScatterEnd>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);
>>>>>>>> If you create two symmetric matrices, one with SBAIJ and one with
>>>>>>>> BAIJ and compare the time to do the product you will find that the SBAIJ is
>>>>>>>> not significantly slower but does save memory.
>>>>>>>> On Mar 21, 2022, at 3:26 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>>> Using following example from the MatCreateSBAIJ documentation
>>>>>>>> 0 1 2 3 4 5 6 7 8 9 10 11
>>>>>>>> row 3 |. . . d d d o o o o o o
>>>>>>>> row 4 |. . . d d d o o o o o o
>>>>>>>> row 5 |. . . d d d o o o o o o
>>>>>>>> On a processor that owns rows 3, 4 and 5, rows 0-2 info are still needed. Is is that the processor that owns rows 0-2 will apply B symmetrical and then send the result
>>>>>>>> to the processor that owns 3-5?
>>>>>>>> On Mon, Mar 21, 2022 at 12:14 PM Mark Adams <mfadams at lbl.gov>
>>>>>>>> wrote:
>>>>>>>>> PETSc stores parallel matrices as two serial matrices. One for the
>>>>>>>>> diagonal (d or A) block and one for the rest (o or B).
>>>>>>>>> I would guess that for symmetric matrices it has a symmetric
>>>>>>>>> matrix for the diagonal and a full AIJ matrix for the (upper) off-diagonal.
>>>>>>>>> So the multtranspose is applying B symmetrically. This lower
>>>>>>>>> off-diagonal and the diagonal block can be done without communication.
>>>>>>>>> Then the off processor values are collected, and the upper
>>>>>>>>> off-diagonal is applied.
>>>>>>>>> On Mon, Mar 21, 2022 at 2:35 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>> wrote:
>>>>>>>>>> I am most interested in how the lower triangular part is
>>>>>>>>>> redistributed. It seems that SBAJI saves memory but requires more
>>>>>>>>>> communication than BAIJ.
>>>>>>>>>> On Mon, Mar 21, 2022 at 11:27 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Mark, thanks for the quick response. I am more interested in
>>>>>>>>>>> parallel implementation of MatMult for SBAIJ. I found following
>>>>>>>>>>> 1094: *PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatMult_MPISBAIJ(Mat <https://petsc.org/main/docs/manualpages/Mat/Mat.html#Mat> A,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> xx,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> yy)*1095: {1096: Mat_MPISBAIJ *a = (Mat_MPISBAIJ*)A->data;1097: PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> ierr;1098: PetscInt <https://petsc.org/main/docs/manualpages/Sys/PetscInt.html#PetscInt> mbs=a->mbs,bs=A->rmap->bs;1099: PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar> *from;1100: const PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar> *x;
>>>>>>>>>>> 1103: /* diagonal part */1104: (*a->A->ops->mult)(a->A,xx,a->slvec1a);1105: VecSet <https://petsc.org/main/docs/manualpages/Vec/VecSet.html#VecSet>(a->slvec1b,0.0);
>>>>>>>>>>> 1107: /* subdiagonal part */1108: (*a->B->ops->multtranspose)(a->B,xx,a->slvec0b);
>>>>>>>>>>> 1110: /* copy x into the vec slvec0 */1111: VecGetArray <https://petsc.org/main/docs/manualpages/Vec/VecGetArray.html#VecGetArray>(a->slvec0,&from);1112: VecGetArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(xx,&x);
>>>>>>>>>>> 1118: VecScatterBegin <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterBegin.html#VecScatterBegin>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);1119: VecScatterEnd <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterEnd.html#VecScatterEnd>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);1120: /* supperdiagonal part */1121: (*a->B->ops->multadd)(a->B,a->slvec1b,a->slvec1a,yy);1122: return(0);1123: }
>>>>>>>>>>> I try to understand the algorithm.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Sam
>>>>>>>>>>> On Mon, Mar 21, 2022 at 11:14 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> This code looks fine to me and the code is
>>>>>>>>>>>> in src/mat/impls/sbaij/seq/sbaij2.c
>>>>>>>>>>>> On Mon, Mar 21, 2022 at 2:02 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Dear PETSc dev team,
>>>>>>>>>>>>> The documentation about MatCreateSBAIJ has following
>>>>>>>>>>>>> "It is recommended that one use the MatCreate
>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatCreate.html#MatCreate>
>>>>>>>>>>>>> (), MatSetType
>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSetType.html#MatSetType>()
>>>>>>>>>>>>> and/or MatSetFromOptions
>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSetFromOptions.html#MatSetFromOptions>(),
>>>>>>>>>>>>> MatXXXXSetPreallocation() paradigm instead of this routine directly.
>>>>>>>>>>>>> [MatXXXXSetPreallocation() is, for example,
>>>>>>>>>>>>> MatSeqAIJSetPreallocation
>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSeqAIJSetPreallocation.html#MatSeqAIJSetPreallocation>
>>>>>>>>>>>>> I currently call MatCreateSBAIJ directly as follows:
>>>>>>>>>>>>> MatCreateSBAIJ (with d_nnz and o_nnz)
>>>>>>>>>>>>> MatSetValues (to add row by row)
>>>>>>>>>>>>> MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>>>>>>>>>>>> MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>>>>>>>>>>>> MatSetOption(A, MAT_SYMMETRIC, PETSC_TRUE);
>>>>>>>>>>>>> Two questions:
>>>>>>>>>>>>> (1) I am wondering whether what I am doing is the
>>>>>>>>>>>>> most efficient.
>>>>>>>>>>>>> (2) I try to find out how the matrix
>>>>>>>>>>>>> vector multiplication is implemented in PETSc for SBAIJ storage.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Sam
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220322/750dcd0c/attachment-0001.html>
