[petsc-users] Null space and preconditioners
Barry Smith bsmith at petsc.dev
Mon Mar 21 17:07:57 CDT 2022
  I have made a merge request https://gitlab.com/petsc/petsc/-/merge_requests/5002 <https://gitlab.com/petsc/petsc/-/merge_requests/5002> with an attempt to improve the documentation. It turns out that sometimes it works well also with right preconditioning (but generically it should not) so I did not put in error checking to prevent such usage. It turns out a bunch of test examples with null spaces are run with right preconditioning.
  Barry
> On Mar 21, 2022, at 1:51 PM, Marco Cisternino <marco.cisternino at optimad.it> wrote:
> From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
> Sent: lunedì 21 marzo 2022 18:31
> To: Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>>
> Cc: Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>>; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Null space and preconditioners
> On Mon, Mar 21, 2022 at 1:25 PM Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>> wrote:
> Thank you, Matt.
> I already set the null space and test it in the toy code
> If you set this and it is not working, something is wrong. This will remove null space components from each update in the Krylov space.
> This is done in an example where I check convergence to the exact solution: https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex69.c <https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex69.c>
> Do I have to set a special null space when I use GAMG?
> The toy code works for PCNONE and PCILU, giving a zero mean solution the first PC and an almost zero mean solution the second one.
> GAMG floats away, quoting Mark.
> Looking at what I do:
> MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0, nullptr, &nullspace);
> MatSetNullSpace(matrix, nullspace);
> it is more or less what you do at lines 3231-3233 of your reference. Am I wrong?
> What about lines 3220-3223? What is the difference between nullSpace and nullSpacePres?
> I tried your suggestion: the norm and the mean of the solution using -mg_coarse_pc_type svd with PCGAMG is much closer to the one of PCNONE (the norm is the same up to the 6th digit, the mean is about 10e-4 with “svd” PCGAMG and 10e-17 with PCNONE). I’m going to try with the real code and see what happens on larger meshes
> This is not perfect since null space components can be introduced by the rest of the preconditioner, but when I use range-space smoothers and
> local interpolation it tends to be much better for me. Maybe it is just my problems.
> Is there a way to set -mg_coarse_pc_type svd with the API into the code?
> Thanks,
> Marco
>   Thanks,
>      Matt
> Thank you all.
> Marco Cisternino
> Sent: lunedì 21 marzo 2022 18:16
> To: Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>>
> Cc: Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>>; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> On Mon, Mar 21, 2022 at 12:06 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> The solution for Neumann problems can "float away" if the constant is not controlled in some way because floating point errors can introduce it even if your RHS is exactly orthogonal to it.
> You should use a special coarse grid solver for GAMG but it seems to be working for you.
> I have lost track of the simply way to have the KSP solver clean the constant out, which is what you want.
> can someone help Marco?
> I have not had time to look at the code. However, here are two ways we use to fix the pure Neumann solution:
> 1) Attach a null space to the operator using https://petsc.org/main/docs/manualpages/Mat/MatSetNullSpace.html <https://petsc.org/main/docs/manualpages/Mat/MatSetNullSpace.html>
> 2) Use a coarse grid solver that does least-squares
>   Thanks,
>      Matt
> Mark
> On Mon, Mar 21, 2022 at 8:18 AM Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>> wrote:
> Good morning,
> I’m observing an unexpected (to me) behaviour of my code.
> I tried to reduce the problem in a toy code here attached.
> The toy code archive contains a small main, a matrix and a rhs.
> The toy code solves the linear system and check the norms and the mean of the solution.
> The problem into the matrix and the rhs is the finite volume discretization of the pressure equation of an incompressible NS solver.
> It has been cooked as tiny as possible (16 cells!).
> It is important to say that it is an elliptic problem with homogeneous Neumann boundary conditions only, for this reason the toy code sets a null space containing the constant.
> The unexpected (to me) behaviour is evident by launching the code using different preconditioners, using -pc-type <pctype>
> I tested using PCNONE (“none”), PCGAMG (“gamg”) and PCILU (“ilu”). The default solver is KSPFGMRES.
> Using the three PC, I get 3 different solutions. It seems to me that they differ in the mean value, but GAMG is impressive.
> PCNONE gives me the zero mean solution I expected. What about the others?
> Asking for residuals monitor, the ratio ||r||/||b|| shows convergence for PCNONE and PCILU (~10^-16), but it stalls for PCGAMG (~10^-4).
> I cannot see why. Am I doing anything wrong or incorrectly thinking about the expected behaviour?
> Generalizing to larger mesh the behaviour is similar.
> Thank you for any help.
> Marco Cisternino
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220321/bb7c910e/attachment-0001.html>
