[petsc-users] MatCreateSBAIJ
Barry Smith bsmith at petsc.dev
Mon Mar 21 14:56:03 CDT 2022
  The "trick" is that though "more" communication is needed to complete the product the communication can still be done in a single VecScatter instead of two separate calls to VecScatter. We simply pack both pieces of information that needs to be sent into a single vector.
 /* copy x into the vec slvec0 */
1111:  <>  VecGetArray <https://petsc.org/main/docs/manualpages/Vec/VecGetArray.html#VecGetArray>(a->slvec0,&from);
1112:  <>  VecGetArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(xx,&x);
1114:  <>  PetscArraycpy <https://petsc.org/main/docs/manualpages/Sys/PetscArraycpy.html#PetscArraycpy>(from,x,bs*mbs);
1115:  <>  VecRestoreArray <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArray.html#VecRestoreArray>(a->slvec0,&from);
1116:  <>  VecRestoreArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArrayRead.html#VecRestoreArrayRead>(xx,&x);
1118:  <>  VecScatterBegin <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterBegin.html#VecScatterBegin>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);
1119:  <>  VecScatterEnd <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterEnd.html#VecScatterEnd>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);
If you create two symmetric matrices, one with SBAIJ and one with BAIJ and compare the time to do the product you will find that the SBAIJ is not significantly slower but does save memory.
> On Mar 21, 2022, at 3:26 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Using following example from the  MatCreateSBAIJ documentation
>           0 1 2 3 4 5 6 7 8 9 10 11
>    row 3  |. . . d d d o o o o  o  o
>    row 4  |. . . d d d o o o o  o  o
>    row 5  |. . . d d d o o o o  o  o
> On a processor that owns rows 3, 4 and 5, rows 0-2 info are still needed. Is is that the processor that owns rows 0-2 will apply B symmetrical and then send the result
> to the processor that owns 3-5?
> On Mon, Mar 21, 2022 at 12:14 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> PETSc stores parallel matrices as two serial matrices. One for the diagonal (d or A) block and one for the rest (o or B).
> I would guess that for symmetric matrices it has a symmetric matrix for the diagonal and a full AIJ matrix for the (upper) off-diagonal.
> So the multtranspose is applying B symmetrically. This lower off-diagonal and the diagonal block can be done without communication.
> Then the off processor values are collected, and the upper off-diagonal is applied.
> On Mon, Mar 21, 2022 at 2:35 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> I am most interested in how the lower triangular part is redistributed. It seems that SBAJI saves memory but requires more communication than BAIJ.
> On Mon, Mar 21, 2022 at 11:27 AM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> Mark, thanks for the quick response. I am more interested in parallel implementation of MatMult for SBAIJ. I found following
> 1094:  <> <>PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatMult_MPISBAIJ(Mat <https://petsc.org/main/docs/manualpages/Mat/Mat.html#Mat> A,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> xx,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> yy)
> 1095:  <>{
> 1096:  <>  Mat_MPISBAIJ      *a = (Mat_MPISBAIJ*)A->data;
> 1097:  <>  PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>    ierr;
> 1098:  <>  PetscInt <https://petsc.org/main/docs/manualpages/Sys/PetscInt.html#PetscInt>          mbs=a->mbs,bs=A->rmap->bs;
> 1099:  <>  PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar>       *from;
> 1100:  <>  const PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar> *x;
> 1103:  <>  /* diagonal part */
> 1104:  <>  (*a->A->ops->mult)(a->A,xx,a->slvec1a);
> 1105:  <>  VecSet <https://petsc.org/main/docs/manualpages/Vec/VecSet.html#VecSet>(a->slvec1b,0.0);
> 1107:  <>  /* subdiagonal part */
> 1108:  <>  (*a->B->ops->multtranspose)(a->B,xx,a->slvec0b);
> 1110:  <>  /* copy x into the vec slvec0 */
> 1120:  <>  /* supperdiagonal part */
> 1121:  <>  (*a->B->ops->multadd)(a->B,a->slvec1b,a->slvec1a,yy);
> 1122:  <>  return(0);
> 1123:  <>}
>   I try to understand the algorithm.
> Thanks,
> Sam
> On Mon, Mar 21, 2022 at 11:14 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> This code looks fine to me and the code is in src/mat/impls/sbaij/seq/sbaij2.c
> On Mon, Mar 21, 2022 at 2:02 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> Dear PETSc dev team,
>    The documentation about MatCreateSBAIJ has following
> "It is recommended that one use the MatCreate <https://petsc.org/main/docs/manualpages/Mat/MatCreate.html#MatCreate>(), MatSetType <https://petsc.org/main/docs/manualpages/Mat/MatSetType.html#MatSetType>() and/or MatSetFromOptions <https://petsc.org/main/docs/manualpages/Mat/MatSetFromOptions.html#MatSetFromOptions>(), MatXXXXSetPreallocation() paradigm instead of this routine directly. [MatXXXXSetPreallocation() is, for example, MatSeqAIJSetPreallocation <https://petsc.org/main/docs/manualpages/Mat/MatSeqAIJSetPreallocation.html#MatSeqAIJSetPreallocation>]"
>    I currently call MatCreateSBAIJ directly as follows:
> MatCreateSBAIJ (with d_nnz and o_nnz)
> MatSetValues (to add row by row)
> MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
> MatSetOption(A, MAT_SYMMETRIC, PETSC_TRUE);
>    Two questions:
>    (1) I am wondering whether what I am doing is the most efficient.
>    (2) I try to find out how the matrix vector multiplication is implemented in PETSc for SBAIJ storage.
> Thanks,
> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220321/92f1fec1/attachment.html>
