[petsc-users] MatCreateSBAIJ
Mark Adams
mfadams at lbl.gov
Mon Mar 21 14:13:54 CDT 2022
PETSc stores parallel matrices as two serial matrices. One for the diagonal
(d or A) block and one for the rest (o or B).
I would guess that for symmetric matrices it has a symmetric matrix for the
diagonal and a full AIJ matrix for the (upper) off-diagonal.
So the multtranspose is applying B symmetrically. This lower off-diagonal
and the diagonal block can be done without communication.
Then the off processor values are collected, and the upper off-diagonal is
applied.
On Mon, Mar 21, 2022 at 2:35 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> I am most interested in how the lower triangular part is redistributed. It
> seems that SBAJI saves memory but requires more communication than BAIJ.
> On Mon, Mar 21, 2022 at 11:27 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Mark, thanks for the quick response. I am more interested in parallel
>> implementation of MatMult for SBAIJ. I found following
>> 1094: *PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatMult_MPISBAIJ(Mat <https://petsc.org/main/docs/manualpages/Mat/Mat.html#Mat> A,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> xx,Vec <https://petsc.org/main/docs/manualpages/Vec/Vec.html#Vec> yy)*1095: {1096: Mat_MPISBAIJ *a = (Mat_MPISBAIJ*)A->data;1097: PetscErrorCode <https://petsc.org/main/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> ierr;1098: PetscInt <https://petsc.org/main/docs/manualpages/Sys/PetscInt.html#PetscInt> mbs=a->mbs,bs=A->rmap->bs;1099: PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar> *from;1100: const PetscScalar <https://petsc.org/main/docs/manualpages/Sys/PetscScalar.html#PetscScalar> *x;
>> 1103: /* diagonal part */1104: (*a->A->ops->mult)(a->A,xx,a->slvec1a);1105: VecSet <https://petsc.org/main/docs/manualpages/Vec/VecSet.html#VecSet>(a->slvec1b,0.0);
>> 1107: /* subdiagonal part */1108: (*a->B->ops->multtranspose)(a->B,xx,a->slvec0b);
>> 1110: /* copy x into the vec slvec0 */1111: VecGetArray <https://petsc.org/main/docs/manualpages/Vec/VecGetArray.html#VecGetArray>(a->slvec0,&from);1112: VecGetArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(xx,&x);
>> 1114: PetscArraycpy <https://petsc.org/main/docs/manualpages/Sys/PetscArraycpy.html#PetscArraycpy>(from,x,bs*mbs);1115: VecRestoreArray <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArray.html#VecRestoreArray>(a->slvec0,&from);1116: VecRestoreArrayRead <https://petsc.org/main/docs/manualpages/Vec/VecRestoreArrayRead.html#VecRestoreArrayRead>(xx,&x);
>> 1118: VecScatterBegin <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterBegin.html#VecScatterBegin>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);1119: VecScatterEnd <https://petsc.org/main/docs/manualpages/PetscSF/VecScatterEnd.html#VecScatterEnd>(a->sMvctx,a->slvec0,a->slvec1,ADD_VALUES <https://petsc.org/main/docs/manualpages/Sys/ADD_VALUES.html#ADD_VALUES>,SCATTER_FORWARD <https://petsc.org/main/docs/manualpages/Vec/SCATTER_FORWARD.html#SCATTER_FORWARD>);1120: /* supperdiagonal part */1121: (*a->B->ops->multadd)(a->B,a->slvec1b,a->slvec1a,yy);1122: return(0);1123: }
>> I try to understand the algorithm.
>> Thanks,
>> Sam
>> On Mon, Mar 21, 2022 at 11:14 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> This code looks fine to me and the code is
>>> in src/mat/impls/sbaij/seq/sbaij2.c
>>> On Mon, Mar 21, 2022 at 2:02 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Dear PETSc dev team,
>>>> The documentation about MatCreateSBAIJ has following
>>>> "It is recommended that one use the MatCreate
>>>> <https://petsc.org/main/docs/manualpages/Mat/MatCreate.html#MatCreate>
>>>> (), MatSetType
>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSetType.html#MatSetType>()
>>>> and/or MatSetFromOptions
>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSetFromOptions.html#MatSetFromOptions>(),
>>>> MatXXXXSetPreallocation() paradigm instead of this routine directly.
>>>> [MatXXXXSetPreallocation() is, for example, MatSeqAIJSetPreallocation
>>>> <https://petsc.org/main/docs/manualpages/Mat/MatSeqAIJSetPreallocation.html#MatSeqAIJSetPreallocation>
>>>> I currently call MatCreateSBAIJ directly as follows:
>>>> MatCreateSBAIJ (with d_nnz and o_nnz)
>>>> MatSetValues (to add row by row)
>>>> MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>>> MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>>> MatSetOption(A, MAT_SYMMETRIC, PETSC_TRUE);
>>>> Two questions:
>>>> (1) I am wondering whether what I am doing is the most efficient.
>>>> (2) I try to find out how the matrix vector multiplication is
>>>> implemented in PETSc for SBAIJ storage.
>>>> Thanks,
>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220321/7344250b/attachment-0001.html>
