[petsc-users] Null space and preconditioners
Barry Smith
bsmith at petsc.dev
Mon Mar 21 13:48:50 CDT 2022
Marco,
I have confirmed your results.
Urgg, it appears we do not have something well documented. The removal of the null space only works for left preconditioned solvers and FGMRES only works with right preconditioning. Here is the reasoning.
The Krylov space for left preconditioning is built from [r, BAr, (BA)^2 r, ...] and the solution space is built from this basis. If A has a null space of n then the left preconditioned Krylov methods simply remove n from the "full" Krylov space after applying each B preconditioner and the resulting "reduced" Krylov space has no components in the n directions hence the solution built by GMRES naturally has no component in the n.
But with right preconditioning the Krylov space is [s ABs (AB)^2 s, ....] We would need to remove B^-1 n from the Krylov space so that (A B) B^-1 n = 0 In general we don't have any way of applying B^-1 to a vector so we cannot create the appropriate "reduced" Krylov space.
If I run with GMRES (which defaults to left preconditioner) and the options ./testPreconditioners -pc_type gamg -ksp_type gmres -ksp_monitor_true_residual -ksp_rtol 1.e-12 -ksp_view -mg_coarse_pc_type svd
Then it handles the null space correctly and the solution has Solution mean = 4.51028e-17
Is there any reason to use FGMRES instead of GMRES? You just cannot use GMRES as the smoother inside GAMG if you use GMRES on the outside, but for pressure equations you don't want use such a strong smoother anyways.
Barry
I feel we should add some information to the documentation on the removal of the null space to the user's manual when using right preconditioning and maybe even have an error check in the code so that people don't fall into this trap. But I am not sure exactly what to do. When the A and B are both symmetric I think special stuff happens that doesn't require providing a null space; but I am not sure.
> On Mar 21, 2022, at 12:41 PM, Marco Cisternino <marco.cisternino at optimad.it> wrote:
> Thank you, Mark.
> However, doing this with my toy code
> mpirun -n 1 ./testpreconditioner -pc_type gamg -pc_gamg_use_parallel_coarse_grid_solver -mg_coarse_pc_type jacobi -mg_coarse_ksp_type cg
> I get 16 inf elements. Do I miss anything?
> Thanks again
> Marco Cisternino
> From: Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>>
> Sent: lunedì 21 marzo 2022 17:31
> To: Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Null space and preconditioners
> And for GAMG you can use:
> Note if you are using more that one MPI process you can use 'lu' instead of 'jacobi'
> If GAMG converges fast enough it can solve before the constant creeps in and works without cleaning in the KSP method.
> On Mon, Mar 21, 2022 at 12:06 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> The solution for Neumann problems can "float away" if the constant is not controlled in some way because floating point errors can introduce it even if your RHS is exactly orthogonal to it.
> You should use a special coarse grid solver for GAMG but it seems to be working for you.
> I have lost track of the simply way to have the KSP solver clean the constant out, which is what you want.
> can someone help Marco?
> Mark
> On Mon, Mar 21, 2022 at 8:18 AM Marco Cisternino <marco.cisternino at optimad.it <mailto:marco.cisternino at optimad.it>> wrote:
> Good morning,
> I’m observing an unexpected (to me) behaviour of my code.
> I tried to reduce the problem in a toy code here attached.
> The toy code archive contains a small main, a matrix and a rhs.
> The toy code solves the linear system and check the norms and the mean of the solution.
> The problem into the matrix and the rhs is the finite volume discretization of the pressure equation of an incompressible NS solver.
> It has been cooked as tiny as possible (16 cells!).
> It is important to say that it is an elliptic problem with homogeneous Neumann boundary conditions only, for this reason the toy code sets a null space containing the constant.
> The unexpected (to me) behaviour is evident by launching the code using different preconditioners, using -pc-type <pctype>
> I tested using PCNONE (“none”), PCGAMG (“gamg”) and PCILU (“ilu”). The default solver is KSPFGMRES.
> Using the three PC, I get 3 different solutions. It seems to me that they differ in the mean value, but GAMG is impressive.
> PCNONE gives me the zero mean solution I expected. What about the others?
> Asking for residuals monitor, the ratio ||r||/||b|| shows convergence for PCNONE and PCILU (~10^-16), but it stalls for PCGAMG (~10^-4).
> I cannot see why. Am I doing anything wrong or incorrectly thinking about the expected behaviour?
> Generalizing to larger mesh the behaviour is similar.
> Thank you for any help.
> Marco Cisternino
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220321/57c58617/attachment.html>
