[petsc-users] Null space and preconditioners
Mon Mar 21 12:16:14 CDT 2022
On Mon, Mar 21, 2022 at 12:06 PM Mark Adams <mfadams at lbl.gov> wrote:
> The solution for Neumann problems can "float away" if the constant is not
> controlled in some way because floating point errors can introduce it even
> if your RHS is exactly orthogonal to it.
> You should use a special coarse grid solver for GAMG but it seems to be
> working for you.
> I have lost track of the simply way to have the KSP solver clean the
> constant out, which is what you want.
> can someone help Marco?
I have not had time to look at the code. However, here are two ways we use
to fix the pure Neumann solution:
1) Attach a null space to the operator using
https://petsc.org/main/docs/manualpages/Mat/MatSetNullSpace.html
2) Use a coarse grid solver that does least-squares
  -mg_coarse_pc_type svd
     Matt
> Mark
> On Mon, Mar 21, 2022 at 8:18 AM Marco Cisternino <
> marco.cisternino at optimad.it> wrote:
>> Good morning,
>> I’m observing an unexpected (to me) behaviour of my code.
>> I tried to reduce the problem in a toy code here attached.
>> The toy code archive contains a small main, a matrix and a rhs.
>> The toy code solves the linear system and check the norms and the mean of
>> the solution.
>> The problem into the matrix and the rhs is the finite volume
>> discretization of the pressure equation of an incompressible NS solver.
>> It has been cooked as tiny as possible (16 cells!).
>> It is important to say that it is an elliptic problem with homogeneous
>> Neumann boundary conditions only, for this reason the toy code sets a null
>> space containing the constant.
>> The unexpected (to me) behaviour is evident by launching the code using
>> different preconditioners, using -pc-type <pctype>
>> I tested using PCNONE (“none”), PCGAMG (“gamg”) and PCILU (“ilu”). The
>> default solver is KSPFGMRES.
>> Using the three PC, I get 3 different solutions. It seems to me that they
>> differ in the mean value, but GAMG is impressive.
>> PCNONE gives me the zero mean solution I expected. What about the others?
>> Asking for residuals monitor, the ratio ||r||/||b|| shows convergence for
>> PCNONE and PCILU (~10^-16), but it stalls for PCGAMG (~10^-4).
>> I cannot see why. Am I doing anything wrong or incorrectly thinking about
>> the expected behaviour?
>> Generalizing to larger mesh the behaviour is similar.
>> Thank you for any help.
>> Marco Cisternino
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220321/93a79e37/attachment.html>
