[petsc-users] Two simple questions on building
Ernesto Prudencio
EPrudencio at slb.com
Wed Mar 16 00:03:41 CDT 2022
Hi.
I have an application that uses MKL for some convolution operations. Such MKL functionality uses, I suppose, BLAS/LAPACK underneath.
This same application of mine also uses PETSc for other purposes. I can supply blas and lapack to PETSc in two ways:
1. Using the configuration option--with-blaslapack-lib="-L${MKL_DIR}/lib/intel64 -lfile1 -lfile2 ... ". For reasons related to compilation environments + docker images + cloud, I am having issues with this option (a) _after_ PETSc builds successfully (both make and make install work fine).
2. Using the configuration option --download-fblaslapack=yes. This options works fine for the purpose of generating my application executable.
If I use option (b), I understand that I will have two different blas/lapack codes available during the execution of my application: one from MKL, the other being the one that PETSc downloads during its configuration.
Question 1) Do you foresee any potential run time issue with option (b)?
Question 2) In the case PETSc, is there any problem if run "make" and "make install" without specifying PETSC_ARCH?
Thank you in advance,
Ernesto.
Schlumberger-Private
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220316/cea79ddc/attachment.html>
