[petsc-users] Fieldsplit for 4 fields
Matthew Knepley
knepley at gmail.com
Sat Mar 12 16:21:24 CST 2022
On Fri, Mar 11, 2022 at 3:32 PM Tang, Qi <tangqi at msu.edu> wrote:
> Hi,
> I am trying to solve a four field system with three nested fieldsplit (I
> am in petsc/dmstag directly). I think I have all the IS info in the
> original system. I am wondering how to set up IS for the split system.
Some questions first:
1) Are you using DMStag? If so, the field split might be able to be
automated.
2) Checking the division:
Schur complement {1, 2, 3} and {0}
Multiplicative {1,2} and {3}
Schur complement {1} and {2}
Matt
> More specifically, I would like to call something like this
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0
> -pc_fieldsplit_1_fields 1,2,3
> -fieldsplit_1_ksp_type fgmres -fieldsplit_1_pc_type fieldsplit
> -fieldsplit_1_pc_fieldsplit_type multiplicative
> -fieldsplit_1_fieldsplit_1_ksp_type fgmres
> -fieldsplit_1_fieldsplit_1_pc_type fieldsplit
> -fieldsplit_1_fieldsplit_1_pc_fieldsplit_type schur
> I know the first level probably would work. But the second and third
> levels would not.
> We have two components living on one type of dofs. So the natural split
> 0,1,2,3 do not work. Therefore, at the first level I am setting up split
> through
> PCFieldSplitSetIS(pc, “i", myis[i]);
> How could I know the sub ISs and set it up correctly? Thanks.
> Qi Tang
> T5 at LANL
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220312/f19bbd75/attachment.html>
