[petsc-users] Problem building petsc +rocm variant
Roskop, Luke B luke.roskop at hpe.com
Fri Mar 11 15:34:53 CST 2022
As requested, I attached the configure.log and make.log files
Thanks!
Luke
Date: Friday, March 11, 2022 at 2:47 PM
To: "Roskop, Luke B" <luke.roskop at hpe.com>
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Problem building petsc +rocm variant
  Please send configure.log and make.log to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>  For some reason PETSc's configure does not detect that the MPI does provide MPI_Type_dup() even though it is prototyped in the MPI include file.
On Mar 11, 2022, at 3:34 PM, Roskop, Luke B <luke.roskop at hpe.com<mailto:luke.roskop at hpe.com>> wrote:
Hi, I’m hoping you can help me figure out how to build PETSc targeting AMDGPUs (gfx90a GPU).
I’m attempting to build on the CrayEx ORNL system called crusher, using ROCmCC (AMD’s compiler), and cray-mpich. In case it helps, I’m using spack to build petsc with the “petsc at main%rocmcc+batch+rocm amdgpu_target=gfx90a” spec.
Spack ends up invoking the following configure for PETSc:
'/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/python-3.9.10-7y7mxajn5rywz5xdnba4azphcdodxiub/bin/python3.9' 'configure' '--prefix=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/petsc-main-mccbycx66la7rlx6jv44f6zd63cmdzm7' '--with-ssl=0' '--download-c2html=0' '--download-sowing=0' '--download-hwloc=0' 'CFLAGS=' 'FFLAGS=-fPIC' 'CXXFLAGS=' 'LDFLAGS=-Wl,-z,notext' '--with-cc=/opt/cray/pe/mpich/8.1.12/ofi/amd/4.4/bin/mpicc' '--with-cxx=/opt/cray/pe/mpich/8.1.12/ofi/amd/4.4/bin/mpicxx' '--with-fc=/opt/cray/pe/mpich/8.1.12/ofi/amd/4.4/bin/mpif90' '--with-precision=double' '--with-scalar-type=real' '--with-shared-libraries=1' '--with-debugging=0' '--with-openmp=0' '--with-64-bit-indices=0' 'COPTFLAGS=' 'FOPTFLAGS=' 'CXXOPTFLAGS=' '--with-blas-lapack-lib=/opt/cray/pe/libsci/21.08.1.2/AMD/4.0/x86_64/lib/libsci_amd.so' '--with-batch=1' '--with-x=0' '--with-clanguage=C' '--with-cuda=0' '--with-hip=1' '--with-hip-dir=/opt/rocm-4.5.0/hip' '--with-metis=1' '--with-metis-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/metis-5.1.0-zn5rn5srr7qzxyo5tq36d46adcsyc5a7/include' '--with-metis-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/metis-5.1.0-zn5rn5srr7qzxyo5tq36d46adcsyc5a7/lib/libmetis.so' '--with-hypre=1' '--with-hypre-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/hypre-develop-vgfx3lhhloq4cnethsrrpz7iez7x6wad/include' '--with-hypre-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/hypre-develop-vgfx3lhhloq4cnethsrrpz7iez7x6wad/lib/libHYPRE.so' '--with-parmetis=1' '--with-parmetis-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/parmetis-4.0.3-6jqxqmt7qqq73rxmx3beu5ba4vj3r253/include' '--with-parmetis-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/parmetis-4.0.3-6jqxqmt7qqq73rxmx3beu5ba4vj3r253/lib/libparmetis.so' '--with-superlu_dist=1' '--with-superlu_dist-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/superlu-dist-develop-mpiyhomp4k72bilqn6xk7uol36ulsdve/include' '--with-superlu_dist-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/superlu-dist-develop-mpiyhomp4k72bilqn6xk7uol36ulsdve/lib/libsuperlu_dist.so' '--with-ptscotch=0' '--with-suitesparse=0' '--with-hdf5=1' '--with-hdf5-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/hdf5-1.12.1-dp5vqo4tjh6oi7szpcsqkdlifgjxknzf/include' '--with-hdf5-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/hdf5-1.12.1-dp5vqo4tjh6oi7szpcsqkdlifgjxknzf/lib/libhdf5.so' '--with-zlib=1' '--with-zlib-include=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/zlib-1.2.11-2ciasfxwyxanyohroisdpvidg4gs2fdy/include' '--with-zlib-lib=/gpfs/alpine/ven114/scratch/lukebr/confidence/spack/install_tree/cray-sles15-zen3/rocmcc-4.5.0/zlib-1.2.11-2ciasfxwyxanyohroisdpvidg4gs2fdy/lib/libz.so' '--with-mumps=0' '--with-trilinos=0' '--with-fftw=0' '--with-valgrind=0' '--with-gmp=0' '--with-libpng=0' '--with-giflib=0' '--with-mpfr=0' '--with-netcdf=0' '--with-pnetcdf=0' '--with-moab=0' '--with-random123=0' '--with-exodusii=0' '--with-cgns=0' '--with-memkind=0' '--with-p4est=0' '--with-saws=0' '--with-yaml=0' '--with-hwloc=0' '--with-libjpeg=0' '--with-scalapack=1' '--with-scalapack-lib=/opt/cray/pe/libsci/21.08.1.2/AMD/4.0/x86_64/lib/libsci_amd.so' '--with-strumpack=0' '--with-mmg=0' '--with-parmmg=0' '--with-tetgen=0' '--with-cxx-dialect=C++11'
Using spack, I see this error at compile time:
/tmp/lukebr/spack-stage/spack-stage-petsc-main-5jlv6jcfdaa37iy5zm77umvb6uvgwdo7/spack-src/src/vec/is/sf/impls/basic/sfpack.c:463:19: error: static declaration of 'MPI_Type_dup' follows non-static declaration
static inline int MPI_Type_dup(MPI_Datatype datatype,MPI_Datatype *newtype)
/opt/cray/pe/mpich/8.1.12/ofi/cray/10.0/include/mpi.h:1291:5: note: previous declaration is here
int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype) MPICH_API_PUBLIC;
1 error generated.
To get around this error, I pass “-DPETSC_HAVE_MPI_TYPE_DUP” but then I see the following lining error:
CLINKER arch-linux-c-opt/lib/libpetsc.so.3.016.5
ld.lld: error: undefined hidden symbol: PetscSFCreate_Window
>>> referenced by sfregi.c
>>>               arch-linux-c-opt/obj/vec/is/sf/interface/sfregi.o:(PetscSFRegisterAll)
clang-13: error: linker command failed with exit code 1 (use -v to see invocation)
gmake[3]: *** [gmakefile:113: arch-linux-c-opt/lib/libpetsc.so.3.016.5] Error 1
gmake[2]: *** [/tmp/lukebr/spack-stage/spack-stage-petsc-main-5jlv6jcfdaa37iy5zm77umvb6uvgwdo7/spack-src/lib/petsc/conf/rules:56: libs] Error 2
Before I continue, is there a preferred way to build PETSc on an AMDGPU system? Could you share this?
Luke
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220311/c5a21c38/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220311/c5a21c38/attachment-0002.obj>
Desc: make.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220311/c5a21c38/attachment-0003.obj>
