[petsc-users] TSBDF prr-load higher order solution
Jed Brown
jed at jedbrown.org
Fri Mar 11 12:48:59 CST 2022
They don't exist, but would be simple to implement. Is that something you might be able to contribute (we can advise) or that you want us to do?
Alfredo J Duarte Gomez <aduarteg at utexas.edu> writes:
> Thank you so much,
> This is exactly what I need. Just to clarify, these functions that you are
> mentioning already exist?
> Or you are simply sketching out what is going to be needed?
> Thank you,
> -Alfredo
> On Thu, Mar 10, 2022 at 3:40 PM Zhang, Hong <hongzhang at anl.gov> wrote:
>> > On Mar 10, 2022, at 2:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > Would the order be inferred by the number of vectors in
>> TSBDFSetStepVecs(TS ts, PetscInt num_steps, const PetscReal *times, const
>> Vec *vecs)?
>> Ah! Yes. num_steps could be used to set bdf->k which is the current order
>> of BDF.
>> Hong (Mr.)
>> > "Zhang, Hong" <hongzhang at anl.gov> writes:
>> >> It is clear to me now. You need TSBDFGetStepVecs(TS ts, PetscInt
>> *num_steps, const PetscReal **times, const Vec *vecs) as Jed suggested so
>> that you can access the work vectors for TSBDF. In addition, you need to
>> save the step size and the current order to jumpstart BDF (without starting
>> from BDF-1). Setting the step size is straightforward with TSSetTimeStep().
>> To access/recover the order, you need something like
>> TSBDF{Set|Get}CurrentOrder(TS ts, PetscInt **order).
>> >> Thanks,
>> >> Hong (Mr.)
>> >> On Mar 10, 2022, at 11:35 AM, Alfredo J Duarte Gomez <
>> aduarteg at utexas.edu<mailto:aduarteg at utexas.edu>> wrote:
>> >> Hello,
>> >> The solutions y_n and y_n-1 are the same ones as those saved internally
>> for the BDF-2.
>> >> The practical problem is for example: run a simulation with a BDF-2 for
>> 10 hrs, see that everything looks good and decide that this simulation is
>> worth continuing for another 10 hrs. Except now when I start from that last
>> solution, the TSBDF starts from a single solution and steps its way up to
>> the BDF-2 (numerical noise appears), instead of simply being able to load
>> the last two solutions from my HDF5 output file and continue as if it had
>> not stopped.
>> >> Maybe I confused you by referencing the TSBDF_Restart, instead of the
>> "starting" procedure for higher order BDFs, I thought they were the same
>> but maybe not.
>> >> Thank you,
>> >> -Alfredo
>> >> On Thu, Mar 10, 2022 at 11:04 AM Zhang, Hong <hongzhang at anl.gov<mailto:
>> hongzhang at anl.gov>> wrote:
>> >> On Mar 10, 2022, at 10:05 AM, Alfredo J Duarte Gomez <
>> >> Hello Zhang and Hong,
>> >> Thank you for your reply.
>> >> As I described, I simply wanted to be able to restart a higher order
>> BDF from a previous solution.
>> >> For example, if I want to restart a BDF-2 solution I can simply load
>> times (n is current time step ) t_n-1, t_n, load solutions y_n, and yn-1
>> from a restart file and continue integration with a BDF-2 formula as if it
>> never stopped.
>> >> Are y_n and yn-1 from the restart file different from the states saved
>> internally for BDF-2? Are you trying to modify these states yourself? A
>> restart is needed typically when you have discontinuities in the system, so
>> the solutions before the discontinuity point have to be discarded. If you
>> simply want to modify the states, there should be better ways than using
>> checkpoint-restart.
>> >> Hong (Mr.)
>> >> This would replace the current default approach, which starts from a
>> single time tn, solution yn and uses lower order BDF steps as you build up
>> to the selected order.
>> >> I am not sure why, but an abrupt change in integration order or time
>> step leads to unwanted numerical noise in my solution, which I blame on the
>> high nonlinearity of the system (I have tested extensively to rule out
>> bugs).
>> >> Thank you and let me know if you have any questions,
>> >> -Alfredo
>> >> On Wed, Mar 9, 2022 at 4:49 PM Zhang, Hong <hongzhang at anl.gov<mailto:
>> >> TSTrajectory supports checkpointing for multistage methods and can
>> certainly be extended to multistep methods. But I doubt it is the best
>> solution to Alfredo’s problem. Alfredo, can you elaborate a bit on what you
>> would like to do? TSBDF_Restart is already using the previous solution to
>> restart the integration with first-order BDF.
>> >> Hong(Mr.)
>> >>> On Mar 9, 2022, at 4:24 PM, Jed Brown <jed at jedbrown.org<mailto:
>> jed at jedbrown.org>> wrote:
>> >>> Can you restart using small low-order steps?
>> >>> Hong, does (or should) your trajectory stuff support an exact
>> checkpointing scheme for BDF?
>> >>> I think we could add an interface to access the stored steps, but
>> there are few things other than checkpointing that would make sense
>> mathematically. Would you be up for making a merge request to add
>> TSBDFGetStepVecs(TS ts, PetscInt *num_steps, const PetscReal **times, const
>> Vec *vecs) and the respective setter?
>> >>> Alfredo J Duarte Gomez <aduarteg at utexas.edu<mailto:aduarteg at utexas.edu>>
>> writes:
>> >>>> Good morning PETSC team,
>> >>>> I am currently using a TSBDF object, which is working very well.
>> >>>> However, I am running into trouble restarting higher order BDF
>> methods.
>> >>>> My problem is highly nonlinear, and when restarted for higher order
>> BDF
>> >>>> methods (using the TSBDF_Restart function), wiggles appear in a
>> specific
>> >>>> region of the solution.
>> >>>> Is there any way I can initialize the higher order BDF restart loading
>> >>>> previous solutions from a data file? I took a look at the code, but
>> there
>> >>>> is no obvious way to do this.
>> >>>> Thanks,
>> >>>> -Alfredo
>> >>>> Alfredo Duarte
>> >>>> Graduate Research Assistant
>> >>>> The University of Texas at Austin
>> >> Alfredo Duarte
>> >> Alfredo Duarte
> Alfredo Duarte
