[petsc-users] TSBDF prr-load higher order solution
Zhang, Hong
hongzhang at anl.gov
Thu Mar 10 14:00:52 CST 2022
It is clear to me now. You need TSBDFGetStepVecs(TS ts, PetscInt *num_steps, const PetscReal **times, const Vec *vecs) as Jed suggested so that you can access the work vectors for TSBDF. In addition, you need to save the step size and the current order to jumpstart BDF (without starting from BDF-1). Setting the step size is straightforward with TSSetTimeStep(). To access/recover the order, you need something like TSBDF{Set|Get}CurrentOrder(TS ts, PetscInt **order).
Hong (Mr.)
On Mar 10, 2022, at 11:35 AM, Alfredo J Duarte Gomez <aduarteg at utexas.edu<mailto:aduarteg at utexas.edu>> wrote:
Hello,
The solutions y_n and y_n-1 are the same ones as those saved internally for the BDF-2.
The practical problem is for example: run a simulation with a BDF-2 for 10 hrs, see that everything looks good and decide that this simulation is worth continuing for another 10 hrs. Except now when I start from that last solution, the TSBDF starts from a single solution and steps its way up to the BDF-2 (numerical noise appears), instead of simply being able to load the last two solutions from my HDF5 output file and continue as if it had not stopped.
Maybe I confused you by referencing the TSBDF_Restart, instead of the "starting" procedure for higher order BDFs, I thought they were the same but maybe not.
Thank you,
-Alfredo
On Thu, Mar 10, 2022 at 11:04 AM Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
On Mar 10, 2022, at 10:05 AM, Alfredo J Duarte Gomez <aduarteg at utexas.edu<mailto:aduarteg at utexas.edu>> wrote:
Hello Zhang and Hong,
Thank you for your reply.
As I described, I simply wanted to be able to restart a higher order BDF from a previous solution.
For example, if I want to restart a BDF-2 solution I can simply load times (n is current time step ) t_n-1, t_n, load solutions y_n, and yn-1 from a restart file and continue integration with a BDF-2 formula as if it never stopped.
Are y_n and yn-1 from the restart file different from the states saved internally for BDF-2? Are you trying to modify these states yourself? A restart is needed typically when you have discontinuities in the system, so the solutions before the discontinuity point have to be discarded. If you simply want to modify the states, there should be better ways than using checkpoint-restart.
Hong (Mr.)
This would replace the current default approach, which starts from a single time tn, solution yn and uses lower order BDF steps as you build up to the selected order.
I am not sure why, but an abrupt change in integration order or time step leads to unwanted numerical noise in my solution, which I blame on the high nonlinearity of the system (I have tested extensively to rule out bugs).
Thank you and let me know if you have any questions,
-Alfredo
On Wed, Mar 9, 2022 at 4:49 PM Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
TSTrajectory supports checkpointing for multistage methods and can certainly be extended to multistep methods. But I doubt it is the best solution to Alfredo’s problem. Alfredo, can you elaborate a bit on what you would like to do? TSBDF_Restart is already using the previous solution to restart the integration with first-order BDF.
Hong(Mr.)
> On Mar 9, 2022, at 4:24 PM, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
> Can you restart using small low-order steps?
> Hong, does (or should) your trajectory stuff support an exact checkpointing scheme for BDF?
> I think we could add an interface to access the stored steps, but there are few things other than checkpointing that would make sense mathematically. Would you be up for making a merge request to add TSBDFGetStepVecs(TS ts, PetscInt *num_steps, const PetscReal **times, const Vec *vecs) and the respective setter?
> Alfredo J Duarte Gomez <aduarteg at utexas.edu<mailto:aduarteg at utexas.edu>> writes:
>> Good morning PETSC team,
>> I am currently using a TSBDF object, which is working very well.
>> However, I am running into trouble restarting higher order BDF methods.
>> My problem is highly nonlinear, and when restarted for higher order BDF
>> methods (using the TSBDF_Restart function), wiggles appear in a specific
>> region of the solution.
>> Is there any way I can initialize the higher order BDF restart loading
>> previous solutions from a data file? I took a look at the code, but there
>> is no obvious way to do this.
>> Thanks,
>> -Alfredo
>> Alfredo Duarte
>> Graduate Research Assistant
>> The University of Texas at Austin
Alfredo Duarte
Alfredo Duarte
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220310/d8a4dbdf/attachment.html>
