[petsc-users] set MUMPS OOC_TMPDIR
Jeremy Theler
jeremy at seamplex.com
Tue Mar 1 06:04:19 CST 2022
I've known at least one other person that had this very same confusion.
Maybe it's worth adding Barry's explanation to the manual page:
This function can be called BEFORE PetscInitialize(), but it does not
NEED to be called before PetscInitialize(). You should be able to call
PetscOptionsSetValue() anytime you want.
On Mon, 2022-02-28 at 16:39 -0800, Sam Guo wrote:
> Yes, " This function can be called BEFORE PetscInitialize()" confused
> me. Thanks for the clarification.
> On Mon, Feb 28, 2022 at 4:38 PM Barry Smith <bsmith at petsc.dev> wrote:
> > You should be able to call PetscOptionsSetValue() anytime you
> > want, as I said between different uses of MUMPS you can call it to
> > use different directories.
> > Perhaps this confused you?
> > Note:
> > It is one of the very few functions that can be called before
> > PetscInitialize() but it does not NEED to be called before
> > PetscInitialize().
> > Barry
