[petsc-users] [EXTERNAL] Re: DMPlex/PetscSF How to determine if local topology is other rank's ghost?
Ferrand, Jesus A.
FERRANJ2 at my.erau.edu
Fri Jun 24 12:52:27 CDT 2022
Toby and Matt:
Thank you for your helpful replies.
In principle, I have what I need, however, I ran into a bug with PetscSFReduce.
When I run the following on the pointSF from a distributed plex (2 MPI ranks on a small mesh).
PetscSFGetGraph(point_sf,&nroots,&nleaves,&ilocal,&iremote);
PetscCalloc2(nleaves,&leafdata,nroots,&rootdata);
\* Code that populates leafdata*/
PetscSFReduceBegin(point_sf,MPIU_INT,leafdata, rootdata,MPI_SUM);
PetscSFReduceEnd(point_sf,MPIU_INT,leafdata, rootdata,MPI_SUM);
PetscSFView(point_sf,0);
PetscViewerASCIIPrintf(PETSC_VIEWER_STDOUT_WORLD,"## Reduce Leafdata\n"); //I copied this from a PetscSF example.
PetscIntView(nleaves,leafdata,PETSC_VIEWER_STDOUT_WORLD);
PetscViewerASCIIPrintf(PETSC_VIEWER_STDOUT_WORLD,"## Reduce Rootdata\n");
PetscIntView(nroots,rootdata,PETSC_VIEWER_STDOUT_WORLD);
PetscFree2(leafdata,rootdata);
.... I get the following printout :
PetscSF Object: 2 MPI processes
type: basic
[0] Number of roots=29, leaves=5, remote ranks=1
[0] 9 <- (1,9)
[0] 11 <- (1,10)
[0] 12 <- (1,13)
[0] 20 <- (1,20)
[0] 27 <- (1,27)
[1] Number of roots=29, leaves=2, remote ranks=1
[1] 14 <- (0,13)
[1] 19 <- (0,18)
MultiSF sort=rank-order
## Reduce Leafdata
[0] 0: 2 2 2 0 0
[1] 0: 3 0
## Reduce Rootdata
[0] 0: 0 0 0 0 0 0 0 0 0 0 0 0 0 -686563120 0 0 0 0 0 0
[0] 20: 0 0 0 0 0 0 0 0 0
[1] 0: 0 0 0 0 0 0 0 0 0 0 0 0 0 128 0 0 0 0 0 0
[1] 20: -527386800 0 0 0 0 0 0 32610 0
The good news is that the rootdata on both processors has the correct number of nonzeros after reduction.
The bad news is that the nonzeros are garbage (like what one gets when a variable isn't initialized).
Any ideas as to what could cause this? Could something like a previous call to a PetscSF or DMPlex function do this?
I am still using PETSc version 3.16, but I looked at the patch notes of 3.17 and did not see any updates on PetscSFReduce().
Sent: Wednesday, May 18, 2022 2:09 AM
To: Toby Isaac <toby.isaac at gmail.com>
Cc: Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [EXTERNAL] Re: [petsc-users] DMPlex/PetscSF How to determine if local topology is other rank's ghost?
CAUTION: This email originated outside of Embry-Riddle Aeronautical University. Do not click links or open attachments unless you recognize the sender and know the content is safe.
On Tue, May 17, 2022 at 6:47 PM Toby Isaac <toby.isaac at gmail.com<mailto:toby.isaac at gmail.com>> wrote:
A leaf point is attached to a root point (in a star forest there are only leaves and roots), so that means that a root point would be the point that owns a degree of freedom and a leaf point would have a ghost value.
For a "point SF" of a DMPlex:
- Each process has a local numbering of mesh points (cells + edges + faces + vertices): they are all potential roots, so the number of these is what is returned by `nroots`.
- The number of ghost mesh points is `nleaves`.
- `ilocal` would be a list of the mesh points that are leaves (using the local numbering).
- For each leaf in `ilocal`, `iremote` describes the root it is attached to: which process it belongs to, and its id in *that* process's local numbering.
If you're trying to create dof numberings on your own, please consider PetscSectionCreateGlobalSection: <https://petsc.org/main/docs/manualpages/PetscSection/PetscSectionCreateGlobalSection/>. You supply the PetscSF and a PetscSection which says how many dofs there are for each point and whether any have essential boundary conditions, and it computes a global PetscSection that tells you what the global id is for each dof on this process.
Toby is exactly right. Also, if you want global numbering of points you can use
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreatePointNumbering/
and there is a similar thing for jsut cells or vertices.
Matt
On Tue, May 17, 2022 at 7:26 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>> wrote:
Dear PETSc team:
I am working with a non-overlapping distributed plex (i.e., when I call DMPlexDistribute(), I input overlap = 0), so only vertices and edges appear as ghosts to the local ranks.
For preallocation of a parallel global stiffness matrix for FEA, I want to determine which locally owned vertices are ghosts to another rank.
From reading the paper on PetscSF (https://ieeexplore.ieee.org/document/9442258) I think I can answer my question by inspecting the PetscSF returned by DMPlexDistribute() with PetscSFGetGraph(). I am just confused by the root/leaf and ilocal/iremote terminology.
I read the manual page on PetscSFGetGraph() (https://petsc.org/release/docs/manualpages/PetscSF/PetscSFGetGraph.html) and that gave me the impression that I need to PetscSFBcast() the point IDs from foreign ranks to the local ones.
Is this correct?
[https://ieeexplore.ieee.org/assets/img/ieee_logo_smedia_200X200.png]<https://ieeexplore.ieee.org/document/9442258>
The PetscSF Scalable Communication Layer | IEEE Journals & Magazine | IEEE Xplore<https://ieeexplore.ieee.org/document/9442258>
PetscSF, the communication component of the Portable, Extensible Toolkit for Scientific Computation (PETSc), is designed to provide PETSc's communication infrastructure suitable for exascale computers that utilize GPUs and other accelerators. PetscSF provides a simple application programming interface (API) for managing common communication patterns in scientific computations by using a star ...
ieeexplore.ieee.org<http://ieeexplore.ieee.org>
Sincerely:
J.A. Ferrand
Embry-Riddle Aeronautical University - Daytona Beach FL
M.Sc. Aerospace Engineering | May 2022
B.Sc. Aerospace Engineering
B.Sc. Computational Mathematics
Sigma Gamma Tau
Tau Beta Pi
Phone: (386)-843-1829
Email(s): ferranj2 at my.erau.edu<mailto:ferranj2 at my.erau.edu>
jesus.ferrand at gmail.com<mailto:jesus.ferrand at gmail.com>
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220624/f1187b95/attachment-0001.html>
