[petsc-users] Parallel matrix-vector product with Matrix Shell
Mario Rossi dfatiac at gmail.com
Sat Jun 18 01:13:55 CDT 2022
Dear Jose and Petsc users, I implemented the parallel matrix-vector product
and it works meaning that it produces a result but it is different from the
result produced with a single task.
Obviously, I could be wrong in my implementation but what puzzles me is
that the *input *vector (x) to the product is different running with one
and two tasks and this is from the very first iteration (so it can not be
due to a previous error in the product).
I checked that X is different with one and two tasks with the following
(naive) code
PetscErrorCode MatMult_TM(Mat A,Vec x,Vec y) {
  void              *ctx;
  PetscInt          nx /* ,lo,i,j*/;
  const PetscScalar *px;
  PetscScalar       *py;
  MPI_Comm          comm;
  PetscFunctionBeginUser;
  PetscCall(MatShellGetContext(A,&ctx));
  PetscCall(VecGetLocalSize(x,&nx));
  PetscCall(PetscObjectGetComm((PetscObject)A,&comm));
  //  nx = *(int*)ctx;
  PetscCall(VecGetArrayRead(x,&px));
  PetscCall(VecGetArray(y,&py));
  for(int i=0;i<nx;i++){ printf("task %d, px[%d]=%f,
w[%d]=%f\n",myrank,i+offset,px[i],i+offset,w[i+offset]); }
  PetscCall(MPI_Barrier(comm));
  exit(0);
Then I reordered the output obtained with one and two tasks. The first part
of the x vector is very similar (but not exactly the same) using one and
two tasks but the second part (belonging to the second task) is pretty
different
(here "offset" is   offset=(n/size)*myrank;)
I create the matrix shell with
PetscCall(MatCreateShell(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N,N,&n,&A));
I am sure I am doing something wrong but I don't know what I need to look
at.
Thanks in advance!
Mario
Il giorno ven 17 giu 2022 alle ore 17:56 Mario Rossi <dfatiac at gmail.com> ha
scritto:
> Thanks a lot, Jose!
> I looked at the eps folder (where I found the test8.c that has been my
> starting point) but I did not look at the nep folder (my fault!)
> Thanks again,
> Mario
> Il giorno ven 17 giu 2022 alle ore 17:34 Jose E. Roman <jroman at dsic.upv.es>
> ha scritto:
>> You can use VecGetOwnershipRange() to determine the range of global
>> indices corresponding to the local portion of a vector, and VecGetArray()
>> to access the values. In SLEPc, you can assume that X and Y will have the
>> same parallel distribution.
>> For an example of a shell matrix that implements the matrix-vector
>> product in parallel, have a look at this:
>> https://slepc.upv.es/documentation/current/src/nep/tutorials/ex21.c.html
>> It is a simple tridiagonal example, where neighborwise communication is
>> done with two calls to MPI_Sendrecv().
>> Jose
>> > El 17 jun 2022, a las 17:21, Mario Rossi <dfatiac at gmail.com> escribió:
>> > I need to find the largest eigenvalues (say the first three) of a very
>> large matrix and I am using
>> > a combination of PetSc and SLEPc. In particular, I am using a shell
>> matrix. I wrote a "custom"
>> > matrix-vector product and everything works fine in serial (one task)
>> mode for a "small" case.
>> > For the real case, I need multiple (at least 128) tasks for memory
>> reasons so I need a parallel variant of the custom matrix-vector product. I
>> know exactly how to write the parallel variant
>> > (in plain MPI) but I am, somehow, blocked because it is not clear to me
>> what each task receives
>> > and what is expected to provide in the parallel matrix-vector product.
>> > More in detail, with a single task, the function receives the full X
>> vector and is expected to provide the full Y vector resulting from Y=A*X.
>> > What does it happen with multiple tasks? If I understand correctly
>> > in the matrix shell definition, I can choose to split the matrix into
>> blocks of rows so that the matrix-vector function should compute a block of
>> elements of the vector Y but does it receive only the corresponding subset
>> of the X (input vector)? (this is what I guess happens) and in output, does
>> > each task return its subset of elements of Y as if it were the whole
>> array and then PetSc manages all the subsets? Is there anyone who has a
>> working example of a parallel matrix-vector product for matrix shell?
>> > Thanks in advance for any help you can provide!
>> > Mario
>> > i
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220618/c50f3142/attachment.html>
