[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Zongze Yang
yangzongze at gmail.com
Thu Jun 16 10:11:32 CDT 2022
Hi, if I load a `gmsh` file with second-order elements, the coordinates
will be stored in a DG-P2 space. After obtaining the coordinates of a cell,
how can I map the coordinates to vertex and edge?
Below is some code load the gmsh file, I want to know the relation between
`cl` and `cell_coords`.
import firedrake as fd
import numpy as np
# Load gmsh file (2rd)
plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
cs, ce = plex.getHeightStratum(0)
cdm = plex.getCoordinateDM()
csec = dm.getCoordinateSection()
coords_gvec = dm.getCoordinates()
for i in range(cs, ce):
cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
print(f'coordinates for cell {i} :\n{cell_coords.reshape([-1, 3])}')
cl = dm.getTransitiveClosure(i)
print('closure:', cl)
break
Best wishes,
Zongze
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220616/21fb60a9/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220616/21fb60a9/attachment-0001.obj>
