[petsc-users] SLEPc EPSGD: too much time in single iteration
Runfeng Jin
jsfaraway at gmail.com
Wed Jun 15 01:58:32 CDT 2022
Sorry ,I miss the attachment.
Runfeng Jin
Runfeng Jin <jsfaraway at gmail.com> 于2022年6月15日周三 14:56写道:
> Hi! You are right! I try to use a SLEPc and PETSc version with nodebug,
> and the matrix B's solver time become 99s. But It is still a little higher
> than matrix A(8s). Same as mentioned before, attachment is log view of
> no-debug version:
> file 1: log of matrix A solver. This is a larger
> matrix(900,000*900,000) but solved quickly(8s);
> file 2: log of matix B solver. This is a smaller matrix(2,547*2,547)
> but solved much slower(99s).
> By comparing these two files, the strang phenomenon still exist:
> 1) Matrix A has more basis vectors(375) than B(189), but A spent less time
> on BVCreate(0.6s) than B(32s);
> 2) Matrix A spent less time on EPSSetup(0.015s) than B(0.9s)
> 3) In debug version, matrix B distribute much more unbalancedly storage
> among processors(memory max/min 4365) than A(memory max/min 1.113), but
> other metrics seems more balanced. And in no-debug version there is no
> memory information output.
> The significant difference I can tell is :1) B use preallocation; 2) A's
> matrix elements are calculated by CPU, while B's matrix elements are
> calculated by GPU and then transfered to CPU and solved by PETSc in CPU.
> Does this is a normal result? I mean, the matrix with less non-zero
> elements and less dimension can cost more epssolve time? Is this due to the
> structure of matrix? IF so, is there any ways to increase the solve speed?
> Or this is weired and should be fixed by some ways?
> Thank you!
> Runfeng Jin
> Jose E. Roman <jroman at dsic.upv.es> 于2022年6月12日周日 16:08写道:
>> Please always respond to the list.
>> Pay attention to the warnings in the log:
>> # WARNING!!! #
>> # This code was compiled with a debugging option. #
>> # To get timing results run ./configure #
>> # using --with-debugging=no, the performance will #
>> # be generally two or three times faster. #
>> With the debugging option the times are not trustworthy, so I suggest
>> repeating the analysis with an optimized build.
>> Jose
>> > El 12 jun 2022, a las 5:41, Runfeng Jin <jsfaraway at gmail.com> escribió:
>> > Hello!
>> > I compare these two matrix solver's log view and find some strange
>> thing. Attachment files are the log view.:
>> matrix(900,000*900,000) but solved quickly(30s);
>> , a little different from the matrix B that is mentioned in initial email,
>> but solved much slower too. I use this for a quicker test) but solved much
>> slower(1244s).
>> > By comparing these two files, I find some thing:
>> time on BVCreate(0.349s) than B(296s);
>> > 2) Matrix A spent less time on EPSSetup(0.031s) than B(10.709s)
>> > 3) Matrix B distribute much more unbalancedly storage among
>> processors(memory max/min 4365) than A(memory max/min 1.113), but other
>> > I don't do prealocation in A, and it is distributed across processors
>> by PETSc. For B , when preallocation I use PetscSplitOwnership to decide
>> which part belongs to local processor, and B is also distributed by PETSc
>> when compute matrix values.
>> > - Does this mean, for matrix B, too much nonzero elements are stored in
>> single process, and this is why it cost too much more time in solving the
>> matrix and find eigenvalues? If so, are there some better ways to
>> distribute the matrix among processors?
>> > - Or are there any else reasons for this difference in cost time?
>> > Hope to recieve your reply, thank you!
>> > Runfeng Jin
>> > Runfeng Jin <jsfaraway at gmail.com> 于2022年6月11日周六 20:33写道:
>> > Hello!
>> > I have try ues PETSC_DEFAULT for eps_ncv, but it still cost much time.
>> Is there anything else I can do? Attachment is log when use PETSC_DEFAULT
>> for eps_ncv.
>> > Thank you !
>> > Runfeng Jin
>> > Jose E. Roman <jroman at dsic.upv.es> 于2022年6月10日周五 20:50写道:
>> > The value -eps_ncv 5000 is huge.
>> > Better let SLEPc use the default value.
>> > Jose
>> > > El 10 jun 2022, a las 14:24, Jin Runfeng <jsfaraway at gmail.com>
>> escribió:
>> > > Hello!
>> > > I want to acquire the 3 smallest eigenvalue, and attachment is the
>> log view output. I can see epssolve really cost the major time. But I can
>> not see why it cost so much time. Can you see something from it?
>> > > Thank you !
>> > > Runfeng Jin
>> > > On 6月 4 2022, at 1:37 凌晨, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> > > Convergence depends on distribution of eigenvalues you want to
>> compute. On the other hand, the cost also depends on the time it takes to
>> build the preconditioner. Use -log_view to see the cost of the different
>> steps of the computation.
>> > > Jose
>> > > > El 3 jun 2022, a las 18:50, jsfaraway <jsfaraway at gmail.com>
>> escribió:
>> > > > hello!
>> > > > I am trying to use epsgd compute matrix's one smallest eigenvalue.
>> And I find a strang thing. There are two matrix A(900000*900000) and
>> B(90000*90000). While solve A use 371 iterations and only 30.83s, solve B
>> use 22 iterations and 38885s! What could be the reason for this? Or what
>> can I do to find the reason?
>> > > > I use" -eps_type gd -eps_ncv 300 -eps_nev 3 -eps_smallest_real ".
>> > > > And there is one difference I can tell is matrix B has many small
>> value, whose absolute value is less than 10-6. Could this be the reason?
>> > > > Thank you!
>> > > > Runfeng Jin
>> > > <log_view.txt>
>> > <File2_lower-But-Smaller-Matrix.txt><File1_fatesr-But-Larger-MATRIX.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220615/897e90a8/attachment-0001.html>
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/public/home/jrf/works/ecMRCI-shaula/MRCI on a named g16r3n07 with 256 processors, by jrf Wed Jun 15 10:04:00 2022
Using Petsc Release Version 3.15.1, Jun 17, 2021
Max Max/Min Avg Total
Time (sec): 1.029e+02 1.001 1.028e+02
Objects: 2.011e+03 1.146 1.761e+03
Flop: 1.574e+06 2.099 1.104e+06 2.827e+08
Flop/sec: 1.531e+04 2.099 1.074e+04 2.748e+06
MPI Messages: 3.881e+04 7.920 1.865e+04 4.773e+06
MPI Message Lengths: 1.454e+06 6.190 3.542e+01 1.691e+08
MPI Reductions: 1.791e+03 1.001
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flop
and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total Count %Total Avg %Total Count %Total
0: Main Stage: 1.0285e+02 100.0% 2.8266e+08 100.0% 4.773e+06 100.0% 3.542e+01 100.0% 1.769e+03 98.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
AvgLen: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event Count Time (sec) Flop --- Global --- --- Stage ---- Total
Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided 2 1.0 4.0572e-01 2.6 0.00e+00 0.0 3.7e+04 4.0e+00 2.0e+00 0 0 1 0 0 0 0 1 0 0 0
BuildTwoSidedF 1 1.0 2.0986e-01 2.6 0.00e+00 0.0 2.4e+04 1.1e+02 1.0e+00 0 0 1 2 0 0 0 1 2 0 0
MatMult 193 1.0 4.6531e+00 1.1 9.85e+05 4.3 4.7e+06 3.5e+01 1.0e+00 4 48 99 98 0 4 48 99 98 0 29
MatSolve 377 1.0 1.6183e-0288.8 7.16e+04 6.6 0.0e+00 0.0e+00 0.0e+00 0 6 0 0 0 0 6 0 0 0 982
MatLUFactorNum 1 1.0 5.7322e-05 2.8 6.21e+0222.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2177
MatILUFactorSym 1 1.0 8.5668e-03793.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 1 1.0 2.1006e-01 2.6 0.00e+00 0.0 2.4e+04 1.1e+02 1.0e+00 0 0 1 2 0 0 0 1 2 0 0
MatAssemblyEnd 1 1.0 3.0272e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 7.0000e-07 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 5.3758e-05 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatZeroEntries 98 1.0 9.0806e-0371.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNorm 3 1.0 1.8633e-01 1.8 6.00e+01 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecCopy 959 1.0 1.4909e-0275.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 387 1.0 9.8578e-04 8.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 3 1.0 1.6157e-023639.0 6.00e+01 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1
VecScatterBegin 196 1.0 3.7129e-01 1.5 0.00e+00 0.0 4.7e+06 3.5e+01 4.0e+00 0 0 99 98 0 0 0 99 98 0 0
VecScatterEnd 196 1.0 4.6171e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
VecSetRandom 3 1.0 3.5271e-0515.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecReduceArith 634 1.0 1.7589e-0265.9 1.20e+04 1.1 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 174
VecReduceComm 444 1.0 2.4972e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.4e+02 24 0 0 0 25 24 0 0 0 25 0
SFSetGraph 1 1.0 1.1170e-05 9.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetUp 4 1.0 2.3891e-01 1.3 0.00e+00 0.0 4.9e+04 1.1e+01 1.0e+00 0 0 1 0 0 0 0 1 0 0 0
SFPack 196 1.0 1.2023e-0291.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFUnpack 196 1.0 4.3491e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
EPSSetUp 1 1.0 9.6815e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.7e+01 1 0 0 0 1 1 0 0 0 1 0
EPSSolve 1 1.0 9.9906e+01 1.0 1.56e+06 2.1 4.7e+06 3.5e+01 1.7e+03 97 99 98 97 97 97 99 98 97 99 3
STSetUp 1 1.0 2.8679e-0450.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
STComputeOperatr 1 1.0 2.0985e-04223.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVCreate 194 1.0 3.2437e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.8e+02 31 0 0 0 33 31 0 0 0 33 0
BVCopy 386 1.0 1.7107e-02110.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMultVec 1090 1.0 1.8337e-0221.1 2.22e+05 1.1 0.0e+00 0.0e+00 0.0e+00 0 20 0 0 0 0 20 0 0 0 3080
BVMultInPlace 224 1.0 1.8273e-0218.4 1.06e+05 1.1 0.0e+00 0.0e+00 0.0e+00 0 10 0 0 0 0 10 0 0 0 1481
BVDot 319 1.0 1.7687e+01 1.1 1.11e+05 1.1 0.0e+00 0.0e+00 3.2e+02 17 10 0 0 18 17 10 0 0 18 2
BVDotVec 392 1.0 2.2083e+01 1.0 6.32e+04 1.1 0.0e+00 0.0e+00 3.9e+02 21 6 0 0 22 21 6 0 0 22 1
BVOrthogonalizeV 190 1.0 1.1538e+01 1.0 1.15e+05 1.1 0.0e+00 0.0e+00 2.0e+02 11 10 0 0 11 11 10 0 0 12 3
BVScale 254 1.0 1.7301e-02125.1 2.54e+03 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 37
BVSetRandom 3 1.0 3.6330e-0485.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMatProject 255 1.0 1.7707e+01 1.1 1.11e+05 1.1 0.0e+00 0.0e+00 3.2e+02 17 10 0 0 18 17 10 0 0 18 2
DSSolve 82 1.0 5.4953e-0215.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSVectors 380 1.0 9.7683e-0366.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSOther 179 1.0 1.7321e-0239.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSetUp 1 1.0 1.8680e-0574.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 377 1.0 1.8723e-0214.2 7.16e+04 6.6 0.0e+00 0.0e+00 0.0e+00 0 6 0 0 0 0 6 0 0 0 849
PCSetUp 2 1.0 8.8937e-0353.4 6.21e+0222.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 14
PCApply 377 1.0 3.0085e-0213.8 7.23e+04 6.6 0.0e+00 0.0e+00 0.0e+00 0 6 0 0 0 0 6 0 0 0 532
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 745 745 2664464 0.
Vector 793 793 1538360 0.
Index Set 10 10 10792 0.
Star Forest Graph 4 4 5376 0.
EPS Solver 1 1 3468 0.
Spectral Transform 1 1 908 0.
Basis Vectors 195 195 437744 0.
Region 1 1 680 0.
Direct Solver 1 1 20156 0.
Krylov Solver 2 2 3200 0.
Preconditioner 2 2 1936 0.
PetscRandom 1 1 670 0.
Viewer 1 0 0 0.
Average time to get PetscTime(): 4.7e-08
Average time for MPI_Barrier(): 0.0578456
Average time for zero size MPI_Send(): 0.00358668
#PETSc Option Table entries:
-eps_gd_blocksize 3
-eps_gd_initial_size 3
-eps_ncv PETSC_DEFAULT
-eps_type gd
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-blaslapack=1 --with-blaslapack-dir=/public/software/compiler/intel/oneapi/mkl/2021.3.0 --with-64-bit-blas-indices=0 --with-boost=1 --with-boost-dir=/public/home/jrf/tools/boost_1_73_0/gcc7.3.1 --prefix=/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug --with-valgrind-dir=/public/home/jrf/tools/valgrind --LDFLAGS=-Wl,-rpath=/opt/rh/devtoolset-7/root/usr/lib64 -Wl,-rpath=/opt/rh/devtoolset-7/root/usr/lib --with-64-bit-indices=0 --with-petsc-arch=gcc7.3.1-32indices-nodebug --with-debugging=no
Libraries compiled on 2022-06-14 01:43:59 on login05
Machine characteristics: Linux-3.10.0-957.el7.x86_64-x86_64-with-centos
Using PETSc directory: /public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug
Using PETSc arch:
Using C compiler: mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O
Using Fortran compiler: mpif90 -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O
Using include paths: -I/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/include -I/public/home/jrf/tools/boost_1_73_0/gcc7.3.1/include -I/public/home/jrf/tools/valgrind/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/lib -L/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/lib -lpetsc -Wl,-rpath,/public/software/compiler/intel/oneapi/mkl/2021.3.0/lib/intel64 -L/public/software/compiler/intel/oneapi/mkl/2021.3.0/lib/intel64 -Wl,-rpath,/opt/hpc/software/mpi/hwloc/lib -L/opt/hpc/software/mpi/hwloc/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/gcc-7.3.1/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/gcc-7.3.1/lib -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 -L/opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib64 -L/opt/rh/devtoolset-7/root/usr/lib64 -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/sharp/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/sharp/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/hcoll/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/hcoll/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/ucx_without_rocm/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/ucx_without_rocm/lib -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib -L/opt/rh/devtoolset-7/root/usr/lib -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lm -lX11 -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
/public/home/jrf/works/qubic/bin/pfci.x on a named h09r4n13 with 192 processors, by jrf Wed Jun 15 12:10:57 2022
Time (sec): 9.703e+02 1.000 9.703e+02
Objects: 2.472e+03 1.000 2.472e+03
Flop: 6.278e+09 1.064 6.012e+09 1.154e+12
Flop/sec: 6.470e+06 1.064 6.196e+06 1.190e+09
MPI Messages: 3.635e+04 1.947 2.755e+04 5.290e+06
MPI Message Lengths: 7.246e+08 1.742 2.052e+04 1.085e+11
MPI Reductions: 2.464e+03 1.000
0: Main Stage: 9.7032e+02 100.0% 1.1543e+12 100.0% 5.290e+06 100.0% 2.052e+04 100.0% 2.446e+03 99.3%
Phase summary info:
BuildTwoSided 2 1.0 1.9883e+029876.1 0.00e+00 0.0 2.1e+04 4.0e+00 2.0e+00 11 0 0 0 0 11 0 0 0 0 0
BuildTwoSidedF 1 1.0 1.9879e+021349804.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 11 0 0 0 0 11 0 0 0 0 0
MatMult 247 1.0 2.5963e+00 1.6 1.16e+09 1.2 5.3e+06 2.1e+04 1.0e+00 0 17100100 0 0 17100100 0 77449
MatSolve 479 1.0 3.2541e-01 2.3 3.89e+08 2.2 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 146312
MatLUFactorNum 1 1.0 4.3923e-02 7.0 2.24e+07 4.9 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 41413
MatILUFactorSym 1 1.0 2.5215e-03 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 1 1.0 1.9879e+02654719.8 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 11 0 0 0 0 11 0 0 0 0 0
MatAssemblyEnd 1 1.0 2.1247e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 8.3000e-07 5.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.0741e-04 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatZeroEntries 244 1.0 2.5375e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNorm 3 1.0 1.3600e-0125.4 2.83e+04 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 40
VecCopy 1214 1.0 6.8012e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 486 1.0 2.4261e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 3 1.0 1.5987e-04 3.8 2.83e+04 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 34009
VecScatterBegin 247 1.0 3.8039e-01 2.2 0.00e+00 0.0 5.3e+06 2.1e+04 1.0e+00 0 0100100 0 0 0100100 0 0
VecScatterEnd 247 1.0 1.3181e+00 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSetRandom 6 1.0 1.3014e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecReduceArith 723 1.0 5.9514e-03 2.1 6.82e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 220153
VecReduceComm 482 1.0 2.1629e-01 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.8e+02 0 0 0 0 20 0 0 0 0 20 0
SFSetGraph 1 1.0 1.3207e-03 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetUp 1 1.0 8.3540e-02 1.4 0.00e+00 0.0 4.2e+04 5.2e+03 1.0e+00 0 0 1 0 0 0 0 1 0 0 0
SFPack 247 1.0 2.3981e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFUnpack 247 1.0 1.8351e-04 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
EPSSetUp 1 1.0 1.5565e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.7e+01 0 0 0 0 1 0 0 0 0 1 0
EPSSolve 1 1.0 8.5090e+00 1.0 6.26e+09 1.1 5.2e+06 2.1e+04 2.4e+03 1100 99 99 99 1100 99 99 99 135365
STSetUp 1 1.0 1.3724e-04 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
STComputeOperatr 1 1.0 7.1348e-05 5.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVCreate 245 1.0 6.2414e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 7.4e+02 0 0 0 0 30 0 0 0 0 30 0
BVCopy 488 1.0 1.9780e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMultVec 1210 1.0 6.7882e-01 1.1 1.14e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 19 0 0 0 0 19 0 0 0 321786
BVMultInPlace 247 1.0 7.8465e-01 1.6 2.71e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 45 0 0 0 0 45 0 0 0 663459
BVDot 718 1.0 1.7888e+00 2.0 5.64e+08 1.0 0.0e+00 0.0e+00 7.2e+02 0 9 0 0 29 0 9 0 0 29 60566
BVDotVec 487 1.0 5.3124e-01 1.2 2.85e+08 1.0 0.0e+00 0.0e+00 4.9e+02 0 5 0 0 20 0 5 0 0 20 102853
BVOrthogonalizeV 244 1.0 5.6093e-01 1.0 5.62e+08 1.0 0.0e+00 0.0e+00 2.5e+02 0 9 0 0 10 0 9 0 0 10 192477
BVScale 482 1.0 2.0062e-03 1.7 2.28e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 217721
BVSetRandom 6 1.0 1.3480e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMatProject 480 1.0 1.8300e+00 2.0 5.64e+08 1.0 0.0e+00 0.0e+00 7.2e+02 0 9 0 0 29 0 9 0 0 29 59203
DSSolve 242 1.0 2.3012e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSVectors 482 1.0 4.5230e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSOther 485 1.0 2.4384e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSetUp 1 1.0 3.5111e-05 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 479 1.0 3.3062e-01 2.2 3.89e+08 2.2 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 144006
PCSetUp 2 1.0 4.6721e-02 6.0 2.24e+07 4.9 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 38932
PCApply 479 1.0 3.7933e-01 2.4 4.11e+08 2.3 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 130309
Matrix 1216 1216 91546008 0.
Vector 994 994 83668472 0.
Index Set 5 5 733636 0.
Star Forest Graph 1 1 1224 0.
EPS Solver 1 1 13512 0.
Basis Vectors 246 246 785872 0.
Region 1 1 680 0.
Direct Solver 1 1 3617024 0.
Viewer 1 0 0 0.
Average time to get PetscTime(): 5e-08
Average time for MPI_Barrier(): 1.90986e-05
Average time for zero size MPI_Send(): 3.44587e-06
-eps_ncv 300
-eps_nev 3
-eps_smallest_real
-eps_tol 1e-10
-eps_type gd
-log_view
Using PETSc arch:
