[petsc-users] Mat preallocation for adaptive grid
Samuel Estes samuelestes91 at gmail.com
Sat Jun 11 20:24:19 CDT 2022
Ok thanks so much for the help! It's nice that it coincides with the
easiest option!
On Sat, Jun 11, 2022 at 7:54 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jun 11, 2022 at 8:43 PM Samuel Estes <samuelestes91 at gmail.com>
> wrote:
>> I'm sorry, would you mind clarifying? I think my email was so long and
>> rambling that it's tough for me to understand which part was being
>> answered.
>> On Sat, Jun 11, 2022 at 7:38 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, Jun 11, 2022 at 8:32 PM Samuel Estes <samuelestes91 at gmail.com>
>>> wrote:
>>>> Hello,
>>>> My question concerns preallocation for Mats in adaptive FEM problems.
>>>> When the grid refines, I destroy the old matrix and create a new one of the
>>>> appropriate (larger size). When the grid “un-refines” I just use the same
>>>> (extra large) matrix and pad the extra unused diagonal entries with 1’s.
>>>> The problem comes in with the preallocation. I use the MatPreallocator,
>>>> MatPreallocatorPreallocate() paradigm which requires a specific sparsity
>>>> pattern. When the grid un-refines, although the total number of nonzeros
>>>> allocated is (most likely) more than sufficient, the particular sparsity
>>>> pattern changes which leads to mallocs in the MatSetValues routines and
>>>> obviously I would like to avoid this.
>>>> One obvious solution is just to destroy and recreate the matrix any
>>>> time the grid changes, even if it gets smaller. By just using a new matrix
>>>> every time, I would avoid this problem although at the cost of having to
>>>> rebuild the matrix more often than necessary. This is the simplest solution
>>>> from a programming perspective and probably the one I will go with.
>>>> I'm just curious if there's an alternative that you would recommend?
>>>> Basically what I would like to do is to just change the sparsity pattern
>>>> that is created in the MatPreallocatorPreallocate() routine. I'm not sure
>>>> how it works under the hood, but in principle, it should be possible to
>>>> keep the memory allocated for the Mat values and just assign them new
>>>> column numbers and potentially add new nonzeros as well. Is there a
>>>> convenient way of doing this? One thought I had was to just fill in the
>>>> MatPreallocator object with the new sparsity pattern of the coarser mesh
>>>> and then call the MatPreallocatorPreallocate() routine again with the new
>>>> MatPreallocator matrix. I'm just not sure how exactly that would work since
>>>> it would have already been called for the FEM matrix for the previous,
>>>> finer grid.
>>>> Finally, does this really matter? I imagine the bottleneck (assuming
>>>> good preallocation) is in the solver so maybe it doesn't make much
>>>> difference whether or not I reuse the old matrix. In that case, going with
>>>> option 1 and simply destroying and recreating the matrix would be the way
>>>> to go just to save myself some time.
>>>> I hope that my question is clear. If not, please let me know and I will
>>>> clarify. I am very curious if there's a convenient solution for the second
>>>> option I mentioned to recycle the allocated memory and redo the sparsity
>>>> pattern.
>>> I have not run any tests of this kind of thing, so I cannot say
>>> definitively.
>>> I can say that I consider the reuse of memory a problem to be solved at
>>> allocation time. You would hope that a good malloc system would give
>>> you back the same memory you just freed when getting rid of the prior
>>> matrix, so you would get the speedup you want using your approach.
>> What do you mean by "your approach"? Do you mean the first option where I
>> just always destroy the matrix? Are you basically saying that when I
>> destroy the old matrix and create a new one, it should just give me the
>> same block of memory that was just freed by the destruction of the previous
>> one?
> Yes.
>>> Second, I think the allocation cost is likely to pale in comparison to
>>> the cost of writing the matrix itself (passing all those indices and values
>>> through
>>> the memory bus), and so reuse of the memory is not that important (I
>>> think).
>> This seems to suggest that the best option is just to destroy and
>> recreate and not worry about "re-preallocating". Do I understand that
>> correctly?
> Yes.
>   Thanks,
>      Matt
>>>   Thanks,
>>>       Matt
>>>> Thanks!
>>>> Sam
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220611/b5b275dd/attachment-0001.html>
