[petsc-users] Question about SuperLU
Tang, Qi
tangqi at msu.edu
Fri Jun 10 09:43:43 CDT 2022
We use superlu_dist.
We have a 2 x 2 block where directly calling suplerlu_dist fails, but a pc based on a fieldsplit Schur complement + superlu_dist on the assembled Schur complement matrix converges. (All the converge criteria are default at this level)
I am having a hard time to understand what is going on. The B,V block is of size 240K, so it is also hard to analyze. And the mat is not something we explicitly formed. It is formed by finite difference coloring Jacobian + a few levels of Schur complement.
/ A 0 \
\ 0 I /
Matt, I do not see this can explain why the second pc with superlu on S = A would succeed, if A is not full rank.
I believe I found somewhere it says petsc’s pclu (or maybe superlu_dist) did reordering and it may introduce 0 pivoting. We are asking because it seems there is something we do not understand from pclu/superlu level.
Anyway, is there a way to output the mat before it fails? We have been struggling to do that. We have TSSolve->SNES->FDColoringJacobian->A few levels of fieldsplit->failed Subblock matrix, which we want to analyze. (Sometimes it even happens in the second Newton iteration as the first one works okay.)
Qi
On Jun 10, 2022, at 8:11 AM, Matthew Knepley <knepley at gmail.com> wrote:
On Thu, Jun 9, 2022 at 5:20 PM Jorti, Zakariae via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I am solving non-linear problem that has 5 unknowns {ni, T, E, B, V}, and for the preconditioning part, I am using a FieldSplit preconditioner. At the last fieldsplit/level, we are left with a {B,V} block that tried to precondition in 2 different ways:
a) SuperLU:
-fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_factor_mat_solver_type superlu_dist
b) a Schur-based fieldsplit preconditioner that uses SuperLU for both V and B blocks:
-fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type gmres -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type fieldsplit -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_type schur -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_schur_precondition selfp -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_factor_mat_solver_type superlu_dist -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_factor_mat_solver_type superlu_dist
Option a) yields the following error:
" Linear fieldsplit_ni_ solve converged due to CONVERGED_ATOL iterations 0
Linear fieldsplit_TEBV_fieldsplit_tau_ solve converged due to CONVERGED_RTOL iterations 1
Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_EP_ solve converged due to CONVERGED_RTOL iterations 5
Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ solve did not converge due to DIVERGED_PC_FAILED iterations 0
PC failed due to FACTOR_NUMERIC_ZEROPIVOT "
whereas options b) seems to be working well.
Is it possible that the SuperLU on the {V,B} block uses a reordering that introduces a zero pivot or could there be another explanation for this error?
I can at least come up with a case where this is true. Suppose you have
/ A 0 \
\ 0 I /
where A is rank deficient, but has a positive diagonal. SuperLU will fail since it is actually singular. However, your Schur complement might work since you use
'selfp' for the Schur preconditioner, and it just extracts the diagonal.
Matt
Many thanks.
Best,
Zakariae
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!3sg7TZfA3Z8m6foZ2wvm-LDZ6jI9C-kp1FVdsCbdXrDj--rBHyrWkz0akiZApgTAMNYce0yg5uta7w$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220610/563eb67b/attachment.html>
