[petsc-users] Writing VTK output
Jed Brown
jed at jedbrown.org
Wed Jun 8 09:25:51 CDT 2022
Does the file load in paraview? When I load your *.msh in a tutorial with -dm_plex_filename sami.msh -dm_view vtk:sami.vtu, I get this good output.
Type: model/vnd.vtu
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220608/37baae18/attachment-0001.vtu>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220608/37baae18/attachment-0001.png>
Sami BEN ELHAJ SALAH <sami.ben-elhaj-salah at ensma.fr> writes:
> Hi Jed,
> Thank you for your answer.
> When I use a ??solution.vtu'', I obtain a wrong file.
> <?xml version="1.0"?>
> <VTKFile type="UnstructuredGrid" version="0.1" byte_order="LittleEndian">
> <UnstructuredGrid>
> <Piece NumberOfPoints="12" NumberOfCells="2">
> <Points>
> <DataArray type="Float64" Name="Position" NumberOfComponents="3" format="appended" offset="0" />
> </Points>
> <Cells>
> <DataArray type="Int32" Name="connectivity" NumberOfComponents="1" format="appended" offset="292" />
> <DataArray type="Int32" Name="offsets" NumberOfComponents="1" format="appended" offset="360" />
> <DataArray type="UInt8" Name="types" NumberOfComponents="1" format="appended" offset="372" />
> </Cells>
> <CellData>
> <DataArray type="Int32" Name="Rank" NumberOfComponents="1" format="appended" offset="378" />
> </CellData>
> <PointData>
> <DataArray type="Float64" Name="dU_x(null)" NumberOfComponents="3" format="appended" offset="390" />
> </PointData>
> </Piece>
> </UnstructuredGrid>
> <AppendedData encoding="raw">
> _ $@ $@ $@ $@ $@ $@ $@ $@ $@ $@ $@ $@ 4@ $@ $@ 4@ $@ 4@ 4@ $@ @
> ?p?O??=??sT?????sT????p?O??=??sT???=??sT????p?O??=??sT???=??sT???=?p?O??=??sT?????sT???=o_?????uP????uP??o_?????uP????uP??o_?????uP????uP??o_?????uP????uP??b#???????333????333??_#?????? ?333????333??b#??????(?333??'?333??a#???????333??>?333??
> </AppendedData>
> </VTKFile>
> If I understand your answer, to solve my problem, should just upgrade all my software ?
> Thanks,
> Sami,
> Dr. Sami BEN ELHAJ SALAH
> Ing?nieur de Recherche (CNRS)
> Institut Pprime - ISAE - ENSMA
> Mobile: 06.62.51.26.74
> Email: sami.ben-elhaj-salah at ensma.fr
> www.samibenelhajsalah.com <https://samiben91.github.io/samibenelhajsalah/index.html>
>> Le 8 juin 2022 ? 15:37, Jed Brown <jed at jedbrown.org> a ?crit :
>> You're using pretty old versions of all software; I'd recommend upgrading. I recommend choosing the file name "solution.vtu" to use the modern (non-legacy) format. Does that work for you?
>>> Dear Petsc Developer team,
>>> I solved a linear elastic problem in 3D using a DMPLEX. My system is converging, then I would like to write out my solution vector to a vtk file where I use unstructured mesh. Currently, I tried two algorithms and I have the same result.
>>> 1) Algorithm 1
>>> err = SNESSolve(_snes, bc_vec_test, solution);
>>> CHKERRABORT(FOX::Parallel::COMM_WORLD,err);
>>> PetscViewer vtk;
>>> PetscViewerVTKOpen(FOX::Parallel::COMM_WORLD,"solution.vtk",FILE_MODE_WRITE,&vtk);
>>> VecView(solution,vtk);
>>> PetscViewerDestroy(&vtk);
>>> 2) Algorithm 2
>>> PetscViewer vtk;
>>> PetscViewerCreate(FOX::Parallel::COMM_WORLD, &vtk);
>>> PetscViewerSetType(vtk, PETSCVIEWERVTK);
>>> PetscViewerFileSetName(vtk, "sol.vtk");
>>> VecView(solution, vtk);
>>> The result seems correct except for the rotation order of the nodes (see the red lines on gmsh and vtk file respectively). Then, I visualized my vtk file with paraview, and I remarked that my geometry is not correct and not conserved when comparing it with my gmsh file. So, I didn?t understand why the rotation order of nodes is not conserved when saving my result to a vtk file?
>>> Other information used:
>>> - gmsh format 2.2
>>> - Vtk version: 7.1.1
>>> - Petsc version: 3.13/opt
>>> Below my two files gmsh and vtk:
>>> Gmsh file:
>>> $MeshFormat
>>> 2.2 0 8
>>> $EndMeshFormat
>>> $Nodes
>>> 12
>>> 1 0.0 10.0 10.0
>>> 2 0.0 0.0 10.0
>>> 3 0.0 0.0 0.0
>>> 4 0.0 10.0 0.0
>>> 5 10.0 10.0 10.0
>>> 6 10.0 0.0 10.0
>>> 7 10.0 0.0 0.0
>>> 8 10.0 10.0 0.0
>>> 9 20.0 10.0 10.0
>>> 10 20.0 0.0 10.0
>>> 11 20.0 0.0 0.0
>>> 12 20.0 10.0 0.0
>>> $EndNodes
>>> $Elements
>>> 2
>>> 1 5 2 68 60 1 2 3 4 5 6 7 8
>>> 2 5 2 68 60 5 6 7 8 9 10 11 12
>>> $EndElements
>>> Vtk file :
>>> # vtk DataFile Version 2.0
>>> Simplicial Mesh Example
>>> ASCII
>>> DATASET UNSTRUCTURED_GRID
>>> POINTS 12 double
>>> 0.000000e+00 1.000000e+01 1.000000e+01
>>> 0.000000e+00 0.000000e+00 1.000000e+01
>>> 0.000000e+00 0.000000e+00 0.000000e+00
>>> 0.000000e+00 1.000000e+01 0.000000e+00
>>> 1.000000e+01 1.000000e+01 1.000000e+01
>>> 1.000000e+01 0.000000e+00 1.000000e+01
>>> 1.000000e+01 0.000000e+00 0.000000e+00
>>> 1.000000e+01 1.000000e+01 0.000000e+00
>>> 2.000000e+01 1.000000e+01 1.000000e+01
>>> 2.000000e+01 0.000000e+00 1.000000e+01
>>> 2.000000e+01 0.000000e+00 0.000000e+00
>>> 2.000000e+01 1.000000e+01 0.000000e+00
>>> CELLS 2 18
>>> 8 0 3 2 1 4 5 6 7
>>> 8 4 7 6 5 8 9 10 11
>>> CELL_TYPES 2
>>> 12
>>> 12
>>> POINT_DATA 12
>>> VECTORS dU_x double
>>> 2.754808e-10 -8.653846e-11 -8.653846e-11
>>> 2.754808e-10 8.653846e-11 -8.653846e-11
>>> 2.754808e-10 8.653846e-11 8.653846e-11
>>> 2.754808e-10 -8.653846e-11 8.653846e-11
>>> 4.678571e-01 -9.107143e-02 -9.107143e-02
>>> 4.678571e-01 9.107143e-02 -9.107143e-02
>>> 4.678571e-01 9.107143e-02 9.107143e-02
>>> 4.678571e-01 -9.107143e-02 9.107143e-02
>>> 1.000000e+00 -7.500000e-02 -7.500000e-02
>>> 1.000000e+00 7.500000e-02 -7.500000e-02
>>> 1.000000e+00 7.500000e-02 7.500000e-02
>>> 1.000000e+00 -7.500000e-02 7.500000e-02
>>> Thank you in advance and have a good day !
>>> Sami,
