[petsc-users] PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
Barry Smith
bsmith at petsc.dev
Tue Jun 7 10:15:49 CDT 2022
That is an extremely old PETSc version. Unless you are using a package that only works with that version (and talk to the package's authors about upgrading) we recommend upgrading to the latest PETSc version.
Usually, there is more information in the error message, is there more in the message you can send?
> On Jun 7, 2022, at 10:00 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 7, 2022 at 9:51 AM wang yuqi <yu1299885905 at outlook.com <mailto:yu1299885905 at outlook.com>> wrote:
> Hi, Dear developer:
> I encountered the following problems when I run my code with PETSC-3.5.2:
> [46]PETSC ERROR: ------------------------------------------------------------------------
> [46]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [46]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [46]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [46]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors
> Could you please help me to fix this problem?
> It may not be a PETSc problem. Could you run in the debugger and get a stack trace?
> Thanks,
> Matt
> Thank you very much!
> Best Regards.
> Yuqi Wang
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220607/a064dd00/attachment.html>
