[petsc-users] Sparse linear system solving
Lidia lidia.varsh at mail.ioffe.ru
Wed Jun 1 12:37:57 CDT 2022
Dear Matt,
Thank you for the rule of 10,000 variables per process! We have run ex.5
with matrix 1e4 x 1e4 at our cluster and got a good performance dynamics
(see the figure "performance.png" - dependency of the solving time in
seconds on the number of cores). We have used GAMG preconditioner
(multithread: we have added the option
"-pc_gamg_use_parallel_coarse_grid_solver") and GMRES solver. And we
have set one openMP thread to every MPI process. Now the ex.5 is working
good on many mpi processes! But the running uses about 100 GB of RAM.
How we can run ex.5 using many openMP threads without mpi? If we just
change the running command, the cores are not loaded normally: usually
just one core is loaded in 100 % and others are idle. Sometimes all
cores are working in 100 % during 1 second but then again become idle
about 30 seconds. Can the preconditioner use many threads and how to
activate this option?
The solving times (the time of the solver work) using 60 openMP threads
is 511 seconds now, and while using 60 MPI processes - 13.19 seconds.
ksp_monitor outs for both cases (many openMP threads or many MPI
processes) are attached.
Thank you!
Best,
Lidia
On 31.05.2022 15:21, Matthew Knepley wrote:
> I have looked at the local logs. First, you have run problems of size
> 12  and 24. As a rule of thumb, you need 10,000
> variables per process in order to see good speedup.
>   Thanks,
>      Matt
> On Tue, May 31, 2022 at 8:19 AM Matthew Knepley <knepley at gmail.com> wrote:
>     On Tue, May 31, 2022 at 7:39 AM Lidia <lidia.varsh at mail.ioffe.ru>
>     wrote:
>         Matt, Mark, thank you much for your answers!
>         Now we have run example # 5 on our computer cluster and on the
>         local server and also have not seen any performance increase,
>         but by unclear reason running times on the local server are
>         much better than on the cluster.
>     I suspect that you are trying to get speedup without increasing
>     the memory bandwidth:
>     https://petsc.org/main/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
>       Thanks,
>          Matt
>         Now we will try to run petsc #5 example inside a docker
>         container on our server and see if the problem is in our
>         environment. I'll write you the results of this test as soon
>         as we get it.
>         The ksp_monitor outs for the 5th test at the current local
>         server configuration (for 2 and 4 mpi processes) and for the
>         cluster (for 1 and 3 mpi processes) are attached .
>         And one more question. Potentially we can use 10 nodes and 96
>         threads at each node on our cluster. What do you think, which
>         combination of numbers of mpi processes and openmp threads may
>         be the best for the 5th example?
>         Thank you!
>         Best,
>         Lidiia
>         On 31.05.2022 05:42, Mark Adams wrote:
>>         And if you see "NO" change in performance I suspect the
>>         solver/matrix is all on one processor.
>>         (PETSc does not use threads by default so threads should not
>>         change anything).
>>         As Matt said, it is best to start with a PETSc example that
>>         does something like what you want (parallel linear solve, see
>>         src/ksp/ksp/tutorials for examples), and then add your code
>>         to it.
>>         That way you get the basic infrastructure in place for you,
>>         which is pretty obscure to the uninitiated.
>>         Mark
>>         On Mon, May 30, 2022 at 10:18 PM Matthew Knepley
>>             On Mon, May 30, 2022 at 10:12 PM Lidia
>>             <lidia.varsh at mail.ioffe.ru> wrote:
>>                 Dear colleagues,
>>                 Is here anyone who have solved big sparse linear
>>                 matrices using PETSC?
>>             There are lots of publications with this kind of data.
>>             Here is one recent one: https://arxiv.org/abs/2204.01722
>>                 We have found NO performance improvement while using
>>                 more and more mpi
>>                 processes (1-2-3) and open-mp threads (from 1 to 72
>>                 threads). Did anyone
>>                 faced to this problem? Does anyone know any possible
>>                 reasons of such
>>                 behaviour?
>>             Solver behavior is dependent on the input matrix. The
>>             only general-purpose solvers
>>             are direct, but they do not scale linearly and have high
>>             memory requirements.
>>             Thus, in order to make progress you will have to be
>>             specific about your matrices.
>>                 We use AMG preconditioner and GMRES solver from KSP
>>                 package, as our
>>                 matrix is large (from 100 000 to 1e+6 rows and
>>                 columns), sparse,
>>                 non-symmetric and includes both positive and negative
>>                 values. But
>>                 performance problems also exist while using CG
>>                 solvers with symmetric
>>                 matrices.
>>             There are many PETSc examples, such as example 5 for the
>>             Laplacian, that exhibit
>>             good scaling with both AMG and GMG.
>>                 Could anyone help us to set appropriate options of
>>                 the preconditioner
>>                 and solver? Now we use default parameters, maybe they
>>                 are not the best,
>>                 but we do not know a good combination. Or maybe you
>>                 could suggest any
>>                 other pairs of preconditioner+solver for such tasks?
>>                 I can provide more information: the matrices that we
>>                 solve, c++ script
>>                 to run solving using petsc and any statistics
>>                 obtained by our runs.
>>             First, please provide a description of the linear system,
>>             and the output of
>>               -ksp_view -ksp_monitor_true_residual
>>             -ksp_converged_reason -log_view
>>             for each test case.
>>               Thanks,
>>                  Matt
>>                 Thank you in advance!
>>                 Best regards,
>>                 Lidiia Varshavchik,
>>                 Ioffe Institute, St. Petersburg, Russia
>>             What most experimenters take for granted before they
>>             begin their experiments is infinitely more interesting
>>             than any results to which their experiments lead.
>>             -- Norbert Wiener
>>             https://www.cse.buffalo.edu/~knepley/
>>             <http://www.cse.buffalo.edu/~knepley/>
>     What most experimenters take for granted before they begin their
>     experiments is infinitely more interesting than any results to
>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220601/a441c088/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220601/a441c088/attachment-0001.png>
[lida at head1 tutorials]$ ./ex5 -m 10000 -ksp_monitor -ksp_monitor_true_residual -ksp_converged_reason -log_view -pc_type gamg -ksp_type gmres -pc_gamg_use_parallel_coarse_grid_solver
WARNING: No preset parameters were found for the device that Open MPI
detected:
  Local host:            head1
  Device name:           i40iw0
  Device vendor ID:      0x8086
  Device vendor part ID: 14290
Default device parameters will be used, which may result in lower
performance.  You can edit any of the files specified by the
btl_openib_device_param_files MCA parameter to set values for your
device.
NOTE: You can turn off this warning by setting the MCA parameter
      btl_openib_warn_no_device_params_found to 0.
No OpenFabrics connection schemes reported that they were able to be
used on a specific port.  As such, the openib BTL (OpenFabrics
support) will be disabled for this port.
  Local host:           head1
  Local device:         i40iw0
  Local port:           1
  CPCs attempted:       rdmacm, udcm
[head1.hpc:274354] 1 more process has sent help message help-mpi-btl-openib.txt / no device params found
[head1.hpc:274354] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[head1.hpc:274354] 1 more process has sent help message help-mpi-btl-openib-cpc-base.txt / no cpcs for port
  0 KSP Residual norm 2.037538277184e+11
  0 KSP preconditioned resid norm 2.037538277184e+11 true resid norm 1.291188079508e+10 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP Residual norm 4.559847344082e+10
  1 KSP preconditioned resid norm 4.559847344082e+10 true resid norm 1.145337105566e+10 ||r(i)||/||b|| 8.870412635802e-01
  2 KSP Residual norm 1.458580410483e+10
  2 KSP preconditioned resid norm 1.458580410483e+10 true resid norm 6.820359295573e+09 ||r(i)||/||b|| 5.282235333346e-01
  3 KSP Residual norm 5.133668905377e+09
  3 KSP preconditioned resid norm 5.133668905377e+09 true resid norm 3.443273018496e+09 ||r(i)||/||b|| 2.666747837238e-01
  4 KSP Residual norm 1.822791754681e+09
  4 KSP preconditioned resid norm 1.822791754681e+09 true resid norm 1.429794150530e+09 ||r(i)||/||b|| 1.107347700325e-01
  5 KSP Residual norm 6.883552291389e+08
  5 KSP preconditioned resid norm 6.883552291389e+08 true resid norm 5.284618300965e+08 ||r(i)||/||b|| 4.092833867378e-02
  6 KSP Residual norm 2.738661252083e+08
  6 KSP preconditioned resid norm 2.738661252083e+08 true resid norm 2.298184687591e+08 ||r(i)||/||b|| 1.779899244785e-02
  7 KSP Residual norm 1.175295112233e+08
  7 KSP preconditioned resid norm 1.175295112233e+08 true resid norm 9.785469137958e+07 ||r(i)||/||b|| 7.578655110947e-03
  8 KSP Residual norm 4.823372166305e+07
  8 KSP preconditioned resid norm 4.823372166305e+07 true resid norm 4.288291058318e+07 ||r(i)||/||b|| 3.321197838159e-03
  9 KSP Residual norm 2.019815757215e+07
  9 KSP preconditioned resid norm 2.019815757215e+07 true resid norm 1.776678838786e+07 ||r(i)||/||b|| 1.376003129973e-03
 10 KSP Residual norm 8.776441360510e+06
 10 KSP preconditioned resid norm 8.776441360510e+06 true resid norm 7.333797620917e+06 ||r(i)||/||b|| 5.679883308489e-04
 11 KSP Residual norm 3.536170852140e+06
 11 KSP preconditioned resid norm 3.536170852140e+06 true resid norm 3.517014965376e+06 ||r(i)||/||b|| 2.723859537734e-04
 12 KSP Residual norm 1.369320429479e+06
 12 KSP preconditioned resid norm 1.369320429479e+06 true resid norm 1.434993628816e+06 ||r(i)||/||b|| 1.111374594910e-04
Linear solve converged due to CONVERGED_RTOL iterations 12
time 511.480000 m=10000 n=10000
Norm of error 4.8462e+06, Iterations 12
  0 KSP Residual norm 6.828607739124e+09
  0 KSP preconditioned resid norm 6.828607739124e+09 true resid norm 2.081798084592e+10 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP Residual norm 1.592108138342e+08
  1 KSP preconditioned resid norm 1.592108138342e+08 true resid norm 1.085557726631e+09 ||r(i)||/||b|| 5.214519768589e-02
  2 KSP Residual norm 4.713015543535e+06
  2 KSP preconditioned resid norm 4.713015543535e+06 true resid norm 2.310928708753e+07 ||r(i)||/||b|| 1.110063807752e-03
  3 KSP Residual norm 3.998043547851e+05
  3 KSP preconditioned resid norm 3.998043547851e+05 true resid norm 2.247029256835e+06 ||r(i)||/||b|| 1.079369451565e-04
  4 KSP Residual norm 3.507419330164e+04
  4 KSP preconditioned resid norm 3.507419330164e+04 true resid norm 2.008185753840e+05 ||r(i)||/||b|| 9.646400237870e-06
Linear solve converged due to CONVERGED_RTOL iterations 4
Norm of error 5.77295e+11, Iterations 4
***                                WIDEN YOUR WINDOW TO 160 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document                                 ***
------------------------------------------------------------------ PETSc Performance Summary: -------------------------------------------------------------------
./ex5 on a  named head1.hpc with 1 processor, by lida Wed Jun  1 20:35:41 2022
Using Petsc Release Version 3.17.1, unknown
                         Max       Max/Min     Avg       Total
Time (sec):           1.065e+03     1.000   1.065e+03
Objects:              7.090e+02     1.000   7.090e+02
Flops:                3.476e+11     1.000   3.476e+11  3.476e+11
Flops/sec:            3.263e+08     1.000   3.263e+08  3.263e+08
MPI Msg Count:        0.000e+00     0.000   0.000e+00  0.000e+00
MPI Msg Len (bytes):  0.000e+00     0.000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00     0.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 3.4957e-04   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:  Original Solve: 8.2717e+02  77.7%  2.5959e+11  74.7%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:    Second Solve: 2.3804e+02  22.3%  8.8003e+10  25.3%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: Original Solve
MatMult              460 1.0 1.5530e+02 1.0 1.05e+11 1.0 0.0e+00 0.0e+00 0.0e+00 15 30  0  0  0  19 40  0  0  0   676
MatMultAdd            91 1.0 1.7280e+01 1.0 8.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  3  0  0  0   463
MatMultTranspose      91 1.0 2.3679e+01 1.0 8.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   3  3  0  0  0   338
MatSolve              13 1.0 6.4134e-05 1.0 5.85e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     9
MatLUFactorSym         1 1.0 2.6981e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.5310e-05 1.0 7.30e+01 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     5
MatConvert             7 1.0 1.2939e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatScale              21 1.0 3.5806e+00 1.0 2.05e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   572
MatResidual           91 1.0 2.5775e+01 1.0 1.86e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  5  0  0  0   3  7  0  0  0   723
MatAssemblyBegin      36 1.0 1.7278e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        36 1.0 2.1752e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            1 1.0 5.9204e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 5.1203e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             7 1.0 3.5076e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
MatAXPY                7 1.0 8.9612e+00 1.0 1.17e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    13
MatMatMultSym          7 1.0 1.7313e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatMatMultNum          7 1.0 1.0714e+01 1.0 1.74e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   163
MatPtAPSymbolic        7 1.0 5.7167e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   7  0  0  0  0     0
MatPtAPNumeric         7 1.0 5.7185e+01 1.0 7.77e+09 1.0 0.0e+00 0.0e+00 0.0e+00  5  2  0  0  0   7  3  0  0  0   136
MatTrnMatMultSym       1 1.0 3.3972e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
MatGetSymTrans         7 1.0 3.8600e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               82 1.0 2.0620e+01 1.0 2.84e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  8  0  0  0   2 11  0  0  0  1378
VecNorm              105 1.0 1.4910e+00 1.0 8.16e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  3  0  0  0  5476
VecScale              90 1.0 8.9402e-01 1.0 2.58e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2888
VecCopy              294 1.0 1.4368e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
VecSet               236 1.0 7.5047e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY               21 1.0 9.9549e-01 1.0 3.03e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3047
VecAYPX              559 1.0 1.8945e+01 1.0 1.34e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  4  0  0  0   2  5  0  0  0   709
VecAXPBYCZ           182 1.0 7.3185e+00 1.0 1.52e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  6  0  0  0  2071
VecMAXPY             102 1.0 2.6425e+01 1.0 4.88e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2 14  0  0  0   3 19  0  0  0  1845
VecAssemblyBegin       1 1.0 5.1595e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 1.3132e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     441 1.0 2.1981e+01 1.0 7.34e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   3  3  0  0  0   334
VecNormalize          90 1.0 1.9910e+00 1.0 7.75e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  3  0  0  0  3891
KSPSetUp              16 1.0 7.4611e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPSolve               1 1.0 2.9415e+02 1.0 2.00e+11 1.0 0.0e+00 0.0e+00 0.0e+00 28 58  0  0  0  36 77  0  0  0   680
KSPGMRESOrthog        82 1.0 3.5705e+01 1.0 5.68e+10 1.0 0.0e+00 0.0e+00 0.0e+00  3 16  0  0  0   4 22  0  0  0  1592
PCGAMGGraph_AGG        7 1.0 7.8044e+01 1.0 1.43e+09 1.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   9  1  0  0  0    18
PCGAMGCoarse_AGG       7 1.0 1.2952e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 12  0  0  0  0  16  0  0  0  0     0
PCGAMGProl_AGG         7 1.0 5.1550e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   6  0  0  0  0     0
PCGAMGPOpt_AGG         7 1.0 1.0284e+02 1.0 4.90e+10 1.0 0.0e+00 0.0e+00 0.0e+00 10 14  0  0  0  12 19  0  0  0   476
GAMG: createProl       7 1.0 3.6476e+02 1.0 5.04e+10 1.0 0.0e+00 0.0e+00 0.0e+00 34 15  0  0  0  44 19  0  0  0   138
  Create Graph         7 1.0 1.2939e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
  Filter Graph         7 1.0 6.4028e+01 1.0 1.43e+09 1.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   8  1  0  0  0    22
  MIS/Agg              7 1.0 3.5146e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
  SA: col data         7 1.0 7.9635e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         7 1.0 4.7866e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   6  0  0  0  0     0
  SA: smooth           7 1.0 4.2317e+01 1.0 2.47e+09 1.0 0.0e+00 0.0e+00 0.0e+00  4  1  0  0  0   5  1  0  0  0    58
GAMG: partLevel        7 1.0 1.1435e+02 1.0 7.77e+09 1.0 0.0e+00 0.0e+00 0.0e+00 11  2  0  0  0  14  3  0  0  0    68
PCGAMG Squ l00         1 1.0 3.3972e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
PCGAMG Gal l00         1 1.0 6.8174e+01 1.0 4.45e+09 1.0 0.0e+00 0.0e+00 0.0e+00  6  1  0  0  0   8  2  0  0  0    65
PCGAMG Opt l00         1 1.0 2.1367e+01 1.0 1.24e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   3  0  0  0  0    58
PCGAMG Gal l01         1 1.0 3.6124e+01 1.0 2.30e+09 1.0 0.0e+00 0.0e+00 0.0e+00  3  1  0  0  0   4  1  0  0  0    64
PCGAMG Opt l01         1 1.0 5.1169e+00 1.0 3.61e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0    70
PCGAMG Gal l02         1 1.0 9.2202e+00 1.0 8.86e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    96
PCGAMG Opt l02         1 1.0 1.3495e+00 1.0 1.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    93
PCGAMG Gal l03         1 1.0 7.2320e-01 1.0 1.13e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   157
PCGAMG Opt l03         1 1.0 1.7474e-01 1.0 1.55e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    89
PCGAMG Gal l04         1 1.0 1.0741e-01 1.0 8.45e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    79
PCGAMG Opt l04         1 1.0 1.9007e-02 1.0 1.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    62
PCGAMG Gal l05         1 1.0 3.0491e-03 1.0 4.43e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   145
PCGAMG Opt l05         1 1.0 8.0217e-04 1.0 6.95e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    87
PCGAMG Gal l06         1 1.0 1.2688e-04 1.0 1.27e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   100
PCGAMG Opt l06         1 1.0 9.1779e-05 1.0 2.96e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    32
PCSetUp                1 1.0 4.8375e+02 1.0 5.82e+10 1.0 0.0e+00 0.0e+00 0.0e+00 45 17  0  0  0  58 22  0  0  0   120
PCApply               13 1.0 1.9865e+02 1.0 1.18e+11 1.0 0.0e+00 0.0e+00 0.0e+00 19 34  0  0  0  24 45  0  0  0   593
--- Event Stage 2: Second Solve
MatMult              160 1.0 5.5173e+01 1.0 3.60e+10 1.0 0.0e+00 0.0e+00 0.0e+00  5 10  0  0  0  23 41  0  0  0   652
MatMultAdd            25 1.0 1.4079e+00 1.0 5.61e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMultTranspose      25 1.0 1.1887e-02 1.0 5.61e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    47
MatSolve               5 1.0 3.1421e-05 1.0 1.94e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    62
MatLUFactorSym         1 1.0 4.1040e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 2.0536e-05 1.0 8.30e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    40
MatConvert             5 1.0 9.8007e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
MatScale              15 1.0 2.0833e+00 1.0 1.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0   480
MatResidual           25 1.0 7.8182e+00 1.0 5.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  6  0  0  0   640
MatAssemblyBegin      26 1.0 4.7507e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        26 1.0 6.1941e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            1 1.0 3.5968e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.4700e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 1.7509e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   7  0  0  0  0     0
MatZeroEntries         1 1.0 4.9738e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 3.0948e+00 1.0 2.54e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMatMultSym          5 1.0 4.4847e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatMatMultNum          5 1.0 3.2775e+00 1.0 2.86e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatPtAPSymbolic        5 1.0 1.2886e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatPtAPNumeric         5 1.0 2.4792e+00 1.0 8.02e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatTrnMatMultSym       1 1.0 3.0547e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetSymTrans         5 1.0 1.3340e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               54 1.0 9.7819e+00 1.0 1.30e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   4 15  0  0  0  1329
VecNorm               67 1.0 5.1862e-01 1.0 4.60e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  5  0  0  0  8870
VecScale              60 1.0 4.1836e-01 1.0 1.60e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0  3825
VecCopy               86 1.0 5.7537e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
VecSet                76 1.0 3.2515e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY               11 1.0 6.2773e-01 1.0 1.40e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0  2230
VecAYPX              155 1.0 7.3351e+00 1.0 4.50e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   3  5  0  0  0   614
VecAXPBYCZ            50 1.0 2.7304e+00 1.0 5.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  6  0  0  0  1831
VecMAXPY              64 1.0 1.0069e+01 1.0 1.78e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   4 20  0  0  0  1768
VecPointwiseMult     155 1.0 9.0886e+00 1.0 3.10e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   4  4  0  0  0   341
VecNormalize          60 1.0 7.8309e-01 1.0 4.80e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  5  0  0  0  6130
KSPSetUp              12 1.0 3.8298e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
KSPSolve               1 1.0 8.0642e+01 1.0 4.81e+10 1.0 0.0e+00 0.0e+00 0.0e+00  8 14  0  0  0  34 55  0  0  0   596
KSPGMRESOrthog        54 1.0 1.7151e+01 1.0 2.60e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  7  0  0  0   7 30  0  0  0  1516
PCGAMGGraph_AGG        5 1.0 2.7212e+01 1.0 1.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  11  1  0  0  0    37
PCGAMGCoarse_AGG       5 1.0 5.3094e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0  22  0  0  0  0     0
PCGAMGProl_AGG         5 1.0 6.3314e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
PCGAMGPOpt_AGG         5 1.0 5.8035e+01 1.0 3.76e+10 1.0 0.0e+00 0.0e+00 0.0e+00  5 11  0  0  0  24 43  0  0  0   648
GAMG: createProl       5 1.0 1.4493e+02 1.0 3.86e+10 1.0 0.0e+00 0.0e+00 0.0e+00 14 11  0  0  0  61 44  0  0  0   266
  Create Graph         5 1.0 9.8007e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
  Filter Graph         5 1.0 1.6596e+01 1.0 1.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   7  1  0  0  0    60
  MIS/Agg              5 1.0 1.7585e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   7  0  0  0  0     0
  SA: col data         5 1.0 6.9388e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         5 1.0 2.9984e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
  SA: smooth           5 1.0 1.3478e+01 1.0 4.24e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   6  0  0  0  0     0
GAMG: partLevel        5 1.0 3.7679e+00 1.0 8.02e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
PCGAMG Squ l00         1 1.0 3.0548e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
PCGAMG Gal l00         1 1.0 3.7665e+00 1.0 6.32e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
PCGAMG Opt l00         1 1.0 7.7613e+00 1.0 2.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
PCGAMG Gal l01         1 1.0 7.6855e-04 1.0 1.19e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   155
PCGAMG Opt l01         1 1.0 6.0377e-04 1.0 4.29e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    71
PCGAMG Gal l02         1 1.0 3.4782e-04 1.0 3.70e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   106
PCGAMG Opt l02         1 1.0 2.2165e-04 1.0 1.33e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    60
PCGAMG Gal l03         1 1.0 1.3189e-04 1.0 1.08e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    82
PCGAMG Opt l03         1 1.0 9.0454e-05 1.0 3.83e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    42
PCGAMG Gal l04         1 1.0 6.2573e-05 1.0 3.34e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    53
PCGAMG Opt l04         1 1.0 4.9897e-05 1.0 1.14e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    23
PCSetUp                1 1.0 1.5265e+02 1.0 3.86e+10 1.0 0.0e+00 0.0e+00 0.0e+00 14 11  0  0  0  64 44  0  0  0   253
PCApply                5 1.0 4.8881e+01 1.0 2.90e+10 1.0 0.0e+00 0.0e+00 0.0e+00  5  8  0  0  0  21 33  0  0  0   593
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     1              1          896     0.
           Container     7              0            0     0.
              Matrix    39             23  37853744688     0.
      Matrix Coarsen     7              7         4704     0.
              Vector   249            182  42116718600     0.
       Krylov Solver    16              7       217000     0.
      Preconditioner    16              7         6496     0.
              Viewer     1              0            0     0.
         PetscRandom     7              7         4970     0.
           Index Set    12              9         8584     0.
    Distributed Mesh    15              7        35896     0.
   Star Forest Graph    30             14        16464     0.
     Discrete System    15              7         7168     0.
           Weak Form    15              7         4648     0.
           Container     5             12         7488     0.
              Matrix    28             44  42665589712     0.
      Matrix Coarsen     5              5         3360     0.
              Vector   156            223  48929583824     0.
       Krylov Solver    11             20       200246     0.
      Preconditioner    11             20        23064     0.
         PetscRandom     5              5         3550     0.
           Index Set     8             11        11264     0.
    Distributed Mesh    10             18        92304     0.
   Star Forest Graph    20             36        42336     0.
     Discrete System    10             18        18432     0.
           Weak Form    10             18        11952     0.
Average time to get PetscTime(): 3.03611e-08
#PETSc Option Table entries:
-ksp_monitor
-ksp_type gmres
-log_view
-m 10000
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure options: --with-python --prefix=/home/lida -with-mpi-dir=/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4 LDFLAGS="-L/home/lida/lib64 -L/home/lida/lib -L/home/lida/jdk/lib" CPPFLAGS="-I/home/lida/include -I/home/lida/jdk/include -march=native -O3" CXXFLAGS="-I/home/lida/include -I/home/lida/jdk/include -march=native -O3" CFLAGS="-I/home/lida/include -I/home/lida/jdk/include -march=native -O3" --with-debugging=no --with-64-bit-indices FOPTFLAGS="-O3 -march=native" --download-make
Libraries compiled on 2022-05-25 10:03:14 on head1.hpc
Machine characteristics: Linux-3.10.0-1062.el7.x86_64-x86_64-with-centos-7.7.1908-Core
Using PETSc directory: /home/lida
Using PETSc arch:
Using C compiler: /opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpicc -I/home/lida/include -I/home/lida/jdk/include -march=native -O3 -fPIC -I/home/lida/include -I/home/lida/jdk/include -march=native -O3
Using Fortran compiler: /opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3 -march=native    -I/home/lida/include -I/home/lida/jdk/include -march=native -O3
Using include paths: -I/home/lida/include -I/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/include
Using C linker: /opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpicc
Using Fortran linker: /opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpif90
Using libraries: -Wl,-rpath,/home/lida/lib -L/home/lida/lib -lpetsc -Wl,-rpath,/home/lida/lib64 -L/home/lida/lib64 -Wl,-rpath,/home/lida/lib -L/home/lida/lib -Wl,-rpath,/home/lida/jdk/lib -L/home/lida/jdk/lib -Wl,-rpath,/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/lib -L/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/lib -Wl,-rpath,/opt/ohpc/pub/compiler/gcc/8.3.0/lib/gcc/x86_64-pc-linux-gnu/8.3.0 -L/opt/ohpc/pub/compiler/gcc/8.3.0/lib/gcc/x86_64-pc-linux-gnu/8.3.0 -Wl,-rpath,/opt/ohpc/pub/compiler/gcc/8.3.0/lib64 -L/opt/ohpc/pub/compiler/gcc/8.3.0/lib64 -Wl,-rpath,/home/lida/intel/oneapi/mkl/2022.0.2/lib/intel64 -L/home/lida/intel/oneapi/mkl/2022.0.2/lib/intel64 -Wl,-rpath,/opt/software/intel/compilers_and_libraries_2020.2.254/linux/tbb/lib/intel64/gcc4.8 -L/opt/software/intel/compilers_and_libraries_2020.2.254/linux/tbb/lib/intel64/gcc4.8 -Wl,-rpath,/opt/ohpc/pub/compiler/gcc/8.3.0/lib -L/opt/ohpc/pub/compiler/gcc/8.3.0/lib -lopenblas -lm -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
[lida at head1 tutorials]$ export OMP_NUM_THREADS=1
[lida at head1 tutorials]$ mpirun -n 60 ./ex5 -m 10000 -ksp_monitor -ksp_monitor_true_residual -ksp_converged_reason -log_view -pc_type gamg -ksp_type gmres -pc_gamg_use_parallel_coarse_grid_solver
There are not enough slots available in the system to satisfy the 60
slots that were requested by the application:
  ./ex5
Either request fewer slots for your application, or make more slots
available for use.
A "slot" is the Open MPI term for an allocatable unit where we can
launch a process.  The number of slots available are defined by the
environment in which Open MPI processes are run:
  1. Hostfile, via "slots=N" clauses (N defaults to number of
     processor cores if not provided)
  2. The --host command line parameter, via a ":N" suffix on the
     hostname (N defaults to 1 if not provided)
  3. Resource manager (e.g., SLURM, PBS/Torque, LSF, etc.)
  4. If none of a hostfile, the --host command line parameter, or an
     RM is present, Open MPI defaults to the number of processor cores
In all the above cases, if you want Open MPI to default to the number
of hardware threads instead of the number of processor cores, use the
--use-hwthread-cpus option.
Alternatively, you can use the --oversubscribe option to ignore the
number of available slots when deciding the number of processes to
launch.
[lida at head1 tutorials]$ mpirun --oversubscribe -n 60 ./ex5 -m 10000 -ksp_monitor -ksp_monitor_true_residual -ksp_converged_reason -log_view -pc_type gamg -ksp_type gmres -pc_gamg_use_parallel_coarse_grid_solver
detected:
  Local host:            head1
  Device name:           i40iw0
device.
  Local host:           head1
  Local port:           1
[head1.hpc:19648] 119 more processes have sent help message help-mpi-btl-openib.txt / no device params found
[head1.hpc:19648] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[head1.hpc:19648] 119 more processes have sent help message help-mpi-btl-openib-cpc-base.txt / no cpcs for port
  0 KSP Residual norm 4.355207026627e+09
  0 KSP preconditioned resid norm 4.355207026627e+09 true resid norm 1.823690908212e+09 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP Residual norm 1.208748211681e+09
  1 KSP preconditioned resid norm 1.208748211681e+09 true resid norm 6.155480046246e+08 ||r(i)||/||b|| 3.375286907736e-01
  2 KSP Residual norm 4.517088284383e+08
  2 KSP preconditioned resid norm 4.517088284383e+08 true resid norm 3.886324242477e+08 ||r(i)||/||b|| 2.131021339732e-01
  3 KSP Residual norm 1.603295575511e+08
  3 KSP preconditioned resid norm 1.603295575511e+08 true resid norm 1.620131718656e+08 ||r(i)||/||b|| 8.883806523136e-02
  4 KSP Residual norm 5.544067857339e+07
  4 KSP preconditioned resid norm 5.544067857339e+07 true resid norm 6.120149859376e+07 ||r(i)||/||b|| 3.355914004843e-02
  5 KSP Residual norm 1.925294565414e+07
  5 KSP preconditioned resid norm 1.925294565414e+07 true resid norm 2.393555310461e+07 ||r(i)||/||b|| 1.312478611196e-02
  6 KSP Residual norm 5.919031529729e+06
  6 KSP preconditioned resid norm 5.919031529729e+06 true resid norm 6.600310389533e+06 ||r(i)||/||b|| 3.619204526277e-03
  7 KSP Residual norm 2.132637762468e+06
  7 KSP preconditioned resid norm 2.132637762468e+06 true resid norm 2.301013174864e+06 ||r(i)||/||b|| 1.261734192183e-03
  8 KSP Residual norm 7.288135118024e+05
  8 KSP preconditioned resid norm 7.288135118024e+05 true resid norm 8.376703989009e+05 ||r(i)||/||b|| 4.593269589318e-04
  9 KSP Residual norm 2.618419345570e+05
  9 KSP preconditioned resid norm 2.618419345570e+05 true resid norm 2.924464805008e+05 ||r(i)||/||b|| 1.603596745390e-04
 10 KSP Residual norm 9.736460918466e+04
 10 KSP preconditioned resid norm 9.736460918466e+04 true resid norm 1.093493729815e+05 ||r(i)||/||b|| 5.996047492975e-05
 11 KSP Residual norm 3.616464600646e+04
 11 KSP preconditioned resid norm 3.616464600646e+04 true resid norm 4.287951581559e+04 ||r(i)||/||b|| 2.351249086262e-05
time 13.250000 m=10000 n=10000
Linear solve converged due to CONVERGED_RTOL iterations 11
time 10.790000 m=10000 n=10000
time 14.340000 m=10000 n=10000
time 11.910000 m=10000 n=10000
time 12.670000 m=10000 n=10000
time 14.900000 m=10000 n=10000
time 13.860000 m=10000 n=10000
time 12.550000 m=10000 n=10000
time 12.610000 m=10000 n=10000
time 11.110000 m=10000 n=10000
time 11.640000 m=10000 n=10000
time 11.980000 m=10000 n=10000
time 14.820000 m=10000 n=10000
time 16.180000 m=10000 n=10000
time 14.330000 m=10000 n=10000
time 13.850000 m=10000 n=10000
time 13.220000 m=10000 n=10000
time 10.220000 m=10000 n=10000
time 12.680000 m=10000 n=10000
time 16.240000 m=10000 n=10000
time 12.490000 m=10000 n=10000
time 16.070000 m=10000 n=10000
time 12.870000 m=10000 n=10000
time 12.170000 m=10000 n=10000
time 15.960000 m=10000 n=10000
time 13.630000 m=10000 n=10000
time 11.530000 m=10000 n=10000
time 13.700000 m=10000 n=10000
time 14.360000 m=10000 n=10000
time 11.690000 m=10000 n=10000
time 13.610000 m=10000 n=10000
time 12.800000 m=10000 n=10000
time 10.350000 m=10000 n=10000
time 14.680000 m=10000 n=10000
time 12.640000 m=10000 n=10000
time 10.860000 m=10000 n=10000
time 13.650000 m=10000 n=10000
time 14.190000 m=10000 n=10000
time 12.620000 m=10000 n=10000
time 12.860000 m=10000 n=10000
time 13.640000 m=10000 n=10000
time 14.790000 m=10000 n=10000
time 11.720000 m=10000 n=10000
time 13.300000 m=10000 n=10000
time 12.990000 m=10000 n=10000
time 13.100000 m=10000 n=10000
time 14.630000 m=10000 n=10000
time 14.170000 m=10000 n=10000
time 13.830000 m=10000 n=10000
time 12.600000 m=10000 n=10000
time 12.500000 m=10000 n=10000
time 12.050000 m=10000 n=10000
time 13.430000 m=10000 n=10000
time 11.790000 m=10000 n=10000
time 12.900000 m=10000 n=10000
time 11.200000 m=10000 n=10000
time 14.120000 m=10000 n=10000
time 15.230000 m=10000 n=10000
time 14.020000 m=10000 n=10000
time 13.360000 m=10000 n=10000
Norm of error 126115., Iterations 11
  0 KSP Residual norm 1.051609452779e+09
  0 KSP preconditioned resid norm 1.051609452779e+09 true resid norm 2.150197987965e+09 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP Residual norm 1.140665240186e+07
  1 KSP preconditioned resid norm 1.140665240186e+07 true resid norm 7.877021908575e+07 ||r(i)||/||b|| 3.663393767766e-02
  2 KSP Residual norm 9.303562428258e+05
  2 KSP preconditioned resid norm 9.303562428258e+05 true resid norm 5.522945877123e+06 ||r(i)||/||b|| 2.568575502366e-03
  3 KSP Residual norm 7.562974008642e+04
  3 KSP preconditioned resid norm 7.562974008642e+04 true resid norm 4.308267545679e+05 ||r(i)||/||b|| 2.003660858113e-04
  4 KSP Residual norm 6.241321855425e+03
  4 KSP preconditioned resid norm 6.241321855425e+03 true resid norm 3.569774197924e+04 ||r(i)||/||b|| 1.660207207850e-05
Norm of error 9.5902e+09, Iterations 4
./ex5 on a  named head1.hpc with 60 processors, by lida Wed Jun  1 20:39:05 2022
Time (sec):           8.038e+01     1.001   8.036e+01
Objects:              1.450e+03     1.000   1.450e+03
Flops:                5.486e+09     1.002   5.485e+09  3.291e+11
Flops/sec:            6.827e+07     1.003   6.825e+07  4.095e+09
MPI Msg Count:        3.320e+03     2.712   2.535e+03  1.521e+05
MPI Msg Len (bytes):  5.412e+07     1.926   2.092e+04  3.183e+09
MPI Reductions:       1.547e+03     1.000
 0:      Main Stage: 2.1349e-01   0.3%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  2.000e+00   0.1%
 1:  Original Solve: 5.8264e+01  72.5%  2.4065e+11  73.1%  1.086e+05  71.4%  2.402e+04       82.0%  9.080e+02  58.7%
 2:    Second Solve: 2.1880e+01  27.2%  8.8426e+10  26.9%  4.348e+04  28.6%  1.318e+04       18.0%  6.190e+02  40.0%
Phase summary info:
BuildTwoSided         99 1.0 5.4267e+00 1.8 0.00e+00 0.0 5.5e+03 8.0e+00 9.9e+01  5  0  4  0  6   7  0  5  0 11     0
BuildTwoSidedF        59 1.0 4.8310e+00 2.2 0.00e+00 0.0 2.8e+03 7.3e+04 5.9e+01  4  0  2  6  4   6  0  3  8  6     0
MatMult              430 1.0 1.0317e+01 1.3 1.64e+09 1.0 5.2e+04 2.8e+04 7.0e+00 11 30 34 46  0  16 41 48 56  1  9505
MatMultAdd            84 1.0 1.1148e+00 1.8 1.23e+08 1.0 7.7e+03 8.8e+03 0.0e+00  1  2  5  2  0   2  3  7  3  0  6638
MatMultTranspose      84 1.0 1.9097e+00 1.7 1.24e+08 1.0 9.0e+03 8.2e+03 7.0e+00  2  2  6  2  0   2  3  8  3  1  3880
MatSolve              12 1.0 8.0690e-05 3.1 3.36e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   250
MatLUFactorSym         1 1.0 6.1153e-05 5.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 5.7829e-05 5.0 3.60e+01 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    37
MatConvert             8 1.0 7.6993e-01 1.9 0.00e+00 0.0 1.6e+03 1.3e+04 7.0e+00  1  0  1  1  0   1  0  1  1  1     0
MatScale              21 1.0 3.2515e-01 2.0 3.42e+07 1.0 8.1e+02 2.6e+04 0.0e+00  0  1  1  1  0   0  1  1  1  0  6310
MatResidual           84 1.0 1.8980e+00 1.5 2.87e+08 1.0 9.8e+03 2.6e+04 0.0e+00  2  5  6  8  0   3  7  9 10  0  9073
MatAssemblyBegin     117 1.0 4.0990e+00 2.4 0.00e+00 0.0 2.8e+03 7.3e+04 4.0e+01  3  0  2  6  3   5  0  3  8  4     0
MatAssemblyEnd       117 1.0 6.4010e+00 1.4 1.21e+05 2.3 0.0e+00 0.0e+00 1.4e+02  7  0  0  0  9   9  0  0  0 15     1
MatGetRowIJ            1 1.0 5.1278e-0513.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       1 1.0 2.7949e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        4 1.0 1.4416e-01 1.1 0.00e+00 0.0 2.9e+02 1.4e+03 5.6e+01  0  0  0  0  4   0  0  0  0  6     0
MatGetOrdering         1 1.0 1.2932e-02469.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             7 1.0 1.8915e+00 1.2 0.00e+00 0.0 2.0e+04 8.6e+03 9.5e+01  2  0 13  5  6   3  0 19  7 10     0
MatZeroEntries         7 1.0 2.4975e-02 6.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                7 1.0 1.1375e+00 1.2 1.95e+06 1.0 0.0e+00 0.0e+00 7.0e+00  1  0  0  0  0   2  0  0  0  1   103
MatTranspose          14 1.0 3.0706e-01 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultSym         21 1.0 3.4042e+00 1.1 0.00e+00 0.0 2.4e+03 2.6e+04 6.3e+01  4  0  2  2  4   5  0  2  2  7     0
MatMatMultNum         21 1.0 1.7535e+00 1.6 8.62e+07 1.0 8.1e+02 2.6e+04 7.0e+00  2  2  1  1  0   2  2  1  1  1  2946
MatPtAPSymbolic        7 1.0 3.8899e+00 1.0 0.00e+00 0.0 5.3e+03 4.9e+04 4.9e+01  5  0  3  8  3   7  0  5 10  5     0
MatPtAPNumeric         7 1.0 2.3929e+00 1.1 1.34e+08 1.0 1.9e+03 1.0e+05 3.5e+01  3  2  1  6  2   4  3  2  7  4  3361
MatTrnMatMultSym       1 1.0 5.1090e+00 1.0 0.00e+00 0.0 3.5e+02 1.9e+05 1.1e+01  6  0  0  2  1   9  0  0  3  1     0
MatRedundantMat        1 1.0 2.8010e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMPIConcateSeq       1 1.0 3.4418e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetLocalMat        22 1.0 1.1056e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetBrAoCol         21 1.0 2.0194e-01 2.8 0.00e+00 0.0 5.7e+03 4.7e+04 0.0e+00  0  0  4  8  0   0  0  5 10  0     0
MatGetSymTrans         2 1.0 2.8332e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               81 1.0 3.5909e+00 1.5 4.34e+08 1.0 0.0e+00 0.0e+00 8.1e+01  4  8  0  0  5   5 11  0  0  9  7248
VecNorm              103 1.0 2.5986e+00 1.5 1.29e+08 1.0 0.0e+00 0.0e+00 1.0e+02  3  2  0  0  7   4  3  0  0 11  2988
VecScale              89 1.0 1.6507e-01 1.8 4.14e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 15040
VecCopy              272 1.0 5.8546e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecSet               315 1.0 3.5993e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               20 1.0 1.9678e-01 2.2 4.72e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 14398
VecAYPX              516 1.0 8.4424e-01 1.9 2.07e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  5  0  0  0 14681
VecAXPBYCZ           168 1.0 3.6343e-01 2.1 2.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   0  6  0  0  0 38501
VecMAXPY             100 1.0 1.6303e+00 1.4 7.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2 13  0  0  0   2 18  0  0  0 26841
VecAssemblyBegin      21 1.0 7.7428e-01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.9e+01  1  0  0  0  1   1  0  0  0  2     0
VecAssemblyEnd        21 1.0 8.0603e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     413 1.0 8.0314e-01 1.5 1.15e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  3  0  0  0  8566
VecScatterBegin      650 1.0 5.5847e-01 2.3 0.00e+00 0.0 7.4e+04 2.4e+04 2.6e+01  1  0 49 57  2   1  0 68 69  3     0
VecScatterEnd        650 1.0 6.7772e+00 2.7 1.47e+05 2.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   8  0  0  0  0     1
VecNormalize          89 1.0 1.7682e+00 1.4 1.24e+08 1.0 0.0e+00 0.0e+00 8.9e+01  2  2  0  0  6   3  3  0  0 10  4212
SFSetGraph            52 1.0 4.5486e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp               40 1.0 1.0026e+00 2.2 0.00e+00 0.0 8.3e+03 1.4e+04 4.0e+01  1  0  5  4  3   1  0  8  4  4     0
SFBcastBegin         102 1.0 1.1024e-0214.9 0.00e+00 0.0 1.9e+04 7.7e+03 0.0e+00  0  0 12  5  0   0  0 17  6  0     0
SFBcastEnd           102 1.0 4.4157e-0110.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFPack               752 1.0 3.4799e-02 8.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFUnpack             752 1.0 1.5714e-03 2.5 1.47e+05 2.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5420
KSPSetUp              17 1.0 4.5984e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01  0  0  0  0  1   1  0  0  0  2     0
KSPSolve               1 1.0 1.7258e+01 1.0 3.02e+09 1.0 5.9e+04 2.3e+04 5.9e+01 21 55 39 43  4  30 75 55 52  6 10498
KSPGMRESOrthog        81 1.0 4.4162e+00 1.4 8.68e+08 1.0 0.0e+00 0.0e+00 8.1e+01  5 16  0  0  5   6 22  0  0  9 11787
PCGAMGGraph_AGG        7 1.0 6.6074e+00 1.0 2.39e+07 1.0 2.4e+03 1.7e+04 6.3e+01  8  0  2  1  4  11  1  2  2  7   217
PCGAMGCoarse_AGG       7 1.0 9.2609e+00 1.0 0.00e+00 0.0 2.2e+04 1.6e+04 1.2e+02 11  0 14 11  8  16  0 20 14 13     0
PCGAMGProl_AGG         7 1.0 3.7914e+00 1.1 0.00e+00 0.0 3.9e+03 2.2e+04 1.1e+02  5  0  3  3  7   6  0  4  3 12     0
PCGAMGPOpt_AGG         7 1.0 9.7580e+00 1.0 8.12e+08 1.0 1.3e+04 2.4e+04 2.9e+02 12 15  8 10 19  17 20 12 12 32  4991
GAMG: createProl       7 1.0 2.9629e+01 1.0 8.36e+08 1.0 4.1e+04 1.9e+04 5.8e+02 37 15 27 25 37  51 21 38 30 64  1692
  Create Graph         7 1.0 7.6994e-01 1.9 0.00e+00 0.0 1.6e+03 1.3e+04 7.0e+00  1  0  1  1  0   1  0  1  1  1     0
  Filter Graph         7 1.0 5.9877e+00 1.1 2.39e+07 1.0 8.1e+02 2.6e+04 5.6e+01  7  0  1  1  4  10  1  1  1  6   240
  MIS/Agg              7 1.0 1.8917e+00 1.2 0.00e+00 0.0 2.0e+04 8.6e+03 9.5e+01  2  0 13  5  6   3  0 19  7 10     0
  SA: col data         7 1.0 8.5757e-01 1.1 0.00e+00 0.0 3.0e+03 2.4e+04 4.8e+01  1  0  2  2  3   1  0  3  3  5     0
  SA: frmProl0         7 1.0 2.5043e+00 1.0 0.00e+00 0.0 9.2e+02 1.5e+04 3.5e+01  3  0  1  0  2   4  0  1  1  4     0
  SA: smooth           7 1.0 4.9217e+00 1.0 3.62e+07 1.0 3.3e+03 2.6e+04 9.4e+01  6  1  2  3  6   8  1  3  3 10   441
GAMG: partLevel        7 1.0 6.8353e+00 1.0 1.34e+08 1.0 7.9e+03 5.7e+04 1.9e+02  8  2  5 14 12  12  3  7 17 21  1177
  repartition          2 1.0 4.0880e-01 1.0 0.00e+00 0.0 7.0e+02 6.2e+02 1.1e+02  1  0  0  0  7   1  0  1  0 12     0
  Invert-Sort          2 1.0 6.3940e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.2997e-01 1.1 0.00e+00 0.0 2.9e+02 1.4e+03 3.0e+01  0  0  0  0  2   0  0  0  0  3     0
  Move P               2 1.0 2.4461e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 3.2e+01  0  0  0  0  2   0  0  0  0  4     0
PCGAMG Squ l00         1 1.0 5.1090e+00 1.0 0.00e+00 0.0 3.5e+02 1.9e+05 1.1e+01  6  0  0  2  1   9  0  0  3  1     0
PCGAMG Gal l00         1 1.0 3.9555e+00 1.1 7.69e+07 1.0 9.4e+02 1.5e+05 1.3e+01  5  1  1  4  1   7  2  1  5  1  1167
PCGAMG Opt l00         1 1.0 2.4544e+00 1.1 1.67e+07 1.0 4.7e+02 8.0e+04 1.1e+01  3  0  0  1  1   4  0  0  1  1   407
PCGAMG Gal l01         1 1.0 1.6669e+00 1.0 3.97e+07 1.0 9.4e+02 1.8e+05 1.3e+01  2  1  1  5  1   3  1  1  6  1  1428
PCGAMG Opt l01         1 1.0 5.6540e-01 1.0 5.09e+06 1.0 4.7e+02 5.0e+04 1.1e+01  1  0  0  1  1   1  0  0  1  1   540
PCGAMG Gal l02         1 1.0 4.9954e-01 1.0 1.54e+07 1.1 9.4e+02 1.1e+05 1.3e+01  1  0  1  3  1   1  0  1  4  1  1829
PCGAMG Opt l02         1 1.0 2.3346e-01 1.1 1.91e+06 1.0 4.7e+02 3.2e+04 1.1e+01  0  0  0  0  1   0  0  0  1  1   488
PCGAMG Gal l03         1 1.0 2.1878e-01 1.0 2.19e+06 1.4 9.4e+02 3.6e+04 1.2e+01  0  0  1  1  1   0  0  1  1  1   567
PCGAMG Opt l03         1 1.0 1.3572e-01 1.1 2.49e+05 1.1 4.7e+02 1.1e+04 1.0e+01  0  0  0  0  1   0  0  0  0  1   108
PCGAMG Gal l04         1 1.0 1.1188e-01 1.2 1.95e+05 2.2 2.4e+03 3.6e+03 1.2e+01  0  0  2  0  1   0  0  2  0  1    93
PCGAMG Opt l04         1 1.0 1.3686e-01 1.1 2.16e+04 1.7 9.4e+02 1.6e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1     9
PCGAMG Gal l05         1 1.0 3.8335e-03 1.4 3.21e+04 0.0 9.5e+02 5.7e+02 1.2e+01  0  0  1  0  1   0  0  1  0  1   133
PCGAMG Opt l05         1 1.0 1.3979e-02 1.1 4.02e+03 0.0 4.3e+02 2.7e+02 1.0e+01  0  0  0  0  1   0  0  0  0  1     5
PCGAMG Gal l06         1 1.0 2.1886e-03 1.5 8.55e+03 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     4
PCGAMG Opt l06         1 1.0 1.5361e-02 1.0 2.63e+03 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  1   0  0  0  0  1     0
PCSetUp                1 1.0 3.7111e+01 1.0 9.70e+08 1.0 4.9e+04 2.5e+04 8.3e+02 46 18 32 39 54  64 24 45 47 92  1568
PCApply               12 1.0 1.1146e+01 1.1 1.82e+09 1.0 5.7e+04 2.0e+04 2.3e+01 13 33 37 36  1  18 45 52 44  3  9768
BuildTwoSided         73 1.0 1.9759e+00 1.9 0.00e+00 0.0 6.8e+03 8.0e+00 7.3e+01  2  0  4  0  5   7  0 16  0 12     0
BuildTwoSidedF        44 1.0 1.2189e+00 2.0 0.00e+00 0.0 8.6e+03 1.7e+04 4.4e+01  1  0  6  5  3   4  0 20 25  7     0
MatMult              160 1.0 4.2652e+00 1.4 6.02e+08 1.0 1.6e+04 2.3e+04 4.0e+00  5 11 11 12  0  17 41 38 67  1  8474
MatMultAdd            25 1.0 1.8994e-01 3.6 6.17e+05 1.0 2.1e+03 1.7e+02 0.0e+00  0  0  1  0  0   0  0  5  0  0   193
MatMultTranspose      25 1.0 7.2792e-0119.4 6.18e+05 1.0 2.9e+03 1.5e+02 5.0e+00  0  0  2  0  0   1  0  7  0  1    51
MatSolve               5 1.0 3.6131e-05 1.8 1.99e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3305
MatLUFactorSym         1 1.0 9.1382e-05 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 3.8696e-05 5.9 9.09e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1409
MatConvert             6 1.0 4.6379e-01 2.2 0.00e+00 0.0 9.6e+02 1.0e+04 5.0e+00  0  0  1  0  0   1  0  2  2  1     0
MatScale              15 1.0 2.0882e-01 2.2 1.69e+07 1.0 4.8e+02 2.0e+04 0.0e+00  0  0  0  0  0   1  1  1  2  0  4848
MatResidual           25 1.0 6.9403e-01 2.1 8.38e+07 1.0 2.4e+03 2.0e+04 0.0e+00  1  2  2  2  0   2  6  6  8  0  7240
MatAssemblyBegin      87 1.0 8.9302e-01 2.2 0.00e+00 0.0 8.6e+03 1.7e+04 3.0e+01  1  0  6  5  2   3  0 20 25  5     0
MatAssemblyEnd        87 1.0 2.6614e+00 1.3 9.98e+04 1.0 0.0e+00 0.0e+00 1.0e+02  3  0  0  0  7  11  0  0  0 16     2
MatGetRowIJ            1 1.0 1.2436e-021825.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       1 1.0 5.4925e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  1     0
MatCreateSubMat        4 1.0 3.1275e-01 1.1 0.00e+00 0.0 3.0e+02 2.0e+02 5.6e+01  0  0  0  0  4   1  0  1  0  9     0
MatGetOrdering         1 1.0 1.2514e-02516.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 1.0904e+00 1.8 0.00e+00 0.0 2.9e+03 6.3e+02 1.5e+01  1  0  2  0  1   4  0  7  0  2     0
MatZeroEntries         6 1.0 5.8985e-02 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 4.8172e-01 1.2 2.35e+04 1.0 0.0e+00 0.0e+00 5.0e+00  1  0  0  0  0   2  0  0  0  1     3
MatTranspose          10 1.0 3.2074e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultSym         15 1.0 1.1367e+00 1.0 0.00e+00 0.0 1.4e+03 7.0e+03 4.5e+01  1  0  1  0  3   5  0  3  2  7     0
MatMatMultNum         15 1.0 2.4953e-01 1.2 1.02e+06 1.0 4.8e+02 5.1e+02 5.0e+00  0  0  0  0  0   1  0  1  0  1   241
MatPtAPSymbolic        5 1.0 8.1101e-01 1.1 0.00e+00 0.0 2.9e+03 4.2e+03 3.5e+01  1  0  2  0  2   4  0  7  2  6     0
MatPtAPNumeric         5 1.0 3.9561e-01 1.2 1.58e+06 1.0 9.6e+02 2.2e+03 2.5e+01  0  0  1  0  2   2  0  2  0  4   235
MatTrnMatMultSym       1 1.0 9.9313e-01 1.0 0.00e+00 0.0 3.5e+02 2.2e+03 1.1e+01  1  0  0  0  1   4  0  1  0  2     0
MatRedundantMat        1 1.0 5.4990e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  1     0
MatMPIConcateSeq       1 1.0 5.8523e-05 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetLocalMat        16 1.0 5.0405e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatGetBrAoCol         15 1.0 1.0643e-01 2.6 0.00e+00 0.0 3.4e+03 6.5e+03 0.0e+00  0  0  2  1  0   0  0  8  4  0     0
MatGetSymTrans         2 1.0 7.1719e-02 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               54 1.0 1.5885e+00 1.7 2.17e+08 1.0 0.0e+00 0.0e+00 5.4e+01  2  4  0  0  3   6 15  0  0  9  8198
VecNorm               67 1.0 1.6017e+00 1.4 7.67e+07 1.0 0.0e+00 0.0e+00 6.7e+01  2  1  0  0  4   6  5  0  0 11  2875
VecScale              60 1.0 1.0996e-01 1.7 2.67e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0 14571
VecCopy               86 1.0 2.5385e-01 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet               106 1.0 1.8434e-01 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               11 1.0 9.2483e-02 2.2 2.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0 15142
VecAYPX              155 1.0 3.6418e-01 2.3 7.51e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  5  0  0  0 12379
VecAXPBYCZ            50 1.0 1.6760e-01 2.9 8.35e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  6  0  0  0 29894
VecMAXPY              64 1.0 6.9542e-01 1.6 2.97e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   3 20  0  0  0 25634
VecAssemblyBegin      16 1.0 5.5466e-01 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  1   2  0  0  0  2     0
VecAssemblyEnd        16 1.0 7.5968e-05 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     155 1.0 3.8336e-01 1.8 5.18e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  4  0  0  0  8103
VecScatterBegin      242 1.0 3.2776e-01 2.7 0.00e+00 0.0 2.5e+04 1.6e+04 1.9e+01  0  0 17 12  1   1  0 58 69  3     0
VecScatterEnd        242 1.0 2.3472e+00 2.9 1.22e+03 3.5 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   7  0  0  0  0     0
VecNormalize          60 1.0 1.3091e+00 1.6 8.01e+07 1.0 0.0e+00 0.0e+00 6.0e+01  1  1  0  0  4   5  5  0  0 10  3672
SFSetGraph            39 1.0 8.6654e-04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp               29 1.0 8.1719e-01 2.8 0.00e+00 0.0 4.9e+03 2.2e+03 2.9e+01  1  0  3  0  2   3  0 11  2  5     0
SFBcastBegin          20 1.0 2.9462e-04 2.5 0.00e+00 0.0 1.9e+03 7.5e+02 0.0e+00  0  0  1  0  0   0  0  4  0  0     0
SFBcastEnd            20 1.0 2.5962e-01143.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFPack               262 1.0 1.7704e-02100.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFUnpack             262 1.0 1.3156e-02131.3 1.22e+03 3.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
KSPSetUp              13 1.0 1.7844e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  1   1  0  0  0  2     0
KSPSolve               1 1.0 5.4889e+00 1.0 8.05e+08 1.0 1.6e+04 1.7e+04 3.2e+01  7 15 11  9  2  25 55 37 48  5  8798
KSPGMRESOrthog        54 1.0 1.9637e+00 1.4 4.34e+08 1.0 0.0e+00 0.0e+00 5.4e+01  2  8  0  0  3   7 29  0  0  9 13263
PCGAMGGraph_AGG        5 1.0 2.2872e+00 1.0 1.68e+07 1.0 1.4e+03 1.3e+04 4.5e+01  3  0  1  1  3  10  1  3  3  7   439
PCGAMGCoarse_AGG       5 1.0 3.2731e+00 1.0 0.00e+00 0.0 4.3e+03 9.2e+02 3.7e+01  4  0  3  0  2  15  0 10  1  6     0
PCGAMGProl_AGG         5 1.0 1.2727e+00 1.0 0.00e+00 0.0 2.3e+03 4.5e+02 7.9e+01  2  0  1  0  5   6  0  5  0 13     0
PCGAMGPOpt_AGG         5 1.0 5.7655e+00 1.0 6.29e+08 1.0 7.4e+03 1.4e+04 2.0e+02  7 11  5  3 13  26 43 17 19 33  6544
GAMG: createProl       5 1.0 1.2524e+01 1.0 6.46e+08 1.0 1.5e+04 8.4e+03 3.7e+02 16 12 10  4 24  57 44 36 23 59  3093
  Create Graph         5 1.0 4.6379e-01 2.2 0.00e+00 0.0 9.6e+02 1.0e+04 5.0e+00  0  0  1  0  0   1  0  2  2  1     0
  Filter Graph         5 1.0 2.0622e+00 1.1 1.68e+07 1.0 4.8e+02 2.0e+04 4.0e+01  2  0  0  0  3   9  1  1  2  6   487
  MIS/Agg              5 1.0 1.0905e+00 1.8 0.00e+00 0.0 2.9e+03 6.3e+02 1.5e+01  1  0  2  0  1   4  0  7  0  2     0
  SA: col data         5 1.0 5.3167e-01 1.2 0.00e+00 0.0 1.7e+03 5.1e+02 3.4e+01  1  0  1  0  2   2  0  4  0  5     0
  SA: frmProl0         5 1.0 5.6108e-01 1.1 0.00e+00 0.0 6.0e+02 2.8e+02 2.5e+01  1  0  0  0  2   2  0  1  0  4     0
  SA: smooth           5 1.0 2.0259e+00 1.1 4.34e+05 1.0 1.9e+03 5.4e+03 6.6e+01  2  0  1  0  4   9  0  4  2 11    13
GAMG: partLevel        5 1.0 1.8885e+00 1.0 1.58e+06 1.0 4.5e+03 3.2e+03 1.7e+02  2  0  3  0 11   9  0 10  3 27    49
  repartition          2 1.0 7.2098e-01 1.0 0.00e+00 0.0 6.7e+02 1.0e+02 1.1e+02  1  0  0  0  7   3  0  2  0 17     0
  Invert-Sort          2 1.0 7.2351e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  2     0
  Move A               2 1.0 1.6566e-01 1.2 0.00e+00 0.0 3.0e+02 2.0e+02 3.0e+01  0  0  0  0  2   1  0  1  0  5     0
  Move P               2 1.0 1.9534e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.2e+01  0  0  0  0  2   1  0  0  0  5     0
PCGAMG Squ l00         1 1.0 9.9313e-01 1.0 0.00e+00 0.0 3.5e+02 2.2e+03 1.1e+01  1  0  0  0  1   4  0  1  0  2     0
PCGAMG Gal l00         1 1.0 7.0349e-01 1.0 9.22e+05 1.0 9.4e+02 1.2e+04 1.3e+01  1  0  1  0  1   3  0  2  2  2    78
PCGAMG Opt l00         1 1.0 1.1336e+00 1.1 2.00e+05 1.0 4.7e+02 2.1e+04 1.1e+01  1  0  0  0  1   5  0  1  2  2    11
PCGAMG Gal l01         1 1.0 1.3150e-01 1.1 4.76e+05 1.1 9.4e+02 2.1e+03 1.2e+01  0  0  1  0  1   1  0  2  0  2   210
PCGAMG Opt l01         1 1.0 1.3884e-01 1.1 6.11e+04 1.0 4.7e+02 6.0e+02 1.0e+01  0  0  0  0  1   1  0  1  0  2    26
PCGAMG Gal l02         1 1.0 1.7012e-01 1.1 1.76e+05 1.3 9.4e+02 1.2e+03 1.2e+01  0  0  1  0  1   1  0  2  0  2    57
PCGAMG Opt l02         1 1.0 3.7929e-02 1.0 2.31e+04 1.1 4.7e+02 3.9e+02 1.0e+01  0  0  0  0  1   0  0  1  0  2    35
PCGAMG Gal l03         1 1.0 1.2656e-01 1.1 1.65e+04 1.6 9.4e+02 2.8e+02 1.2e+01  0  0  1  0  1   1  0  2  0  2     7
PCGAMG Opt l03         1 1.0 1.6197e-03 1.3 2.75e+03 1.4 4.7e+02 1.4e+02 1.0e+01  0  0  0  0  1   0  0  1  0  2    90
PCGAMG Gal l04         1 1.0 7.2816e-02 1.4 4.91e+03 0.0 6.4e+01 6.3e+01 1.2e+01  0  0  0  0  1   0  0  0  0  2     0
PCGAMG Opt l04         1 1.0 1.1088e-01 1.2 1.50e+03 0.0 3.2e+01 5.5e+01 1.0e+01  0  0  0  0  1   0  0  0  0  2     0
PCSetUp                1 1.0 1.5702e+01 1.0 6.47e+08 1.0 2.0e+04 7.2e+03 5.8e+02 19 12 13  5 38  72 44 46 25 94  2473
PCApply                5 1.0 3.6198e+00 1.2 4.87e+08 1.0 1.5e+04 1.3e+04 1.7e+01  4  9 10  6  1  15 33 35 34  3  8064
              Viewer     1              1          896     0.
           Container    14              4         2496     0.
              Matrix   195            108   1577691960     0.
              Vector   352            266    734665864     0.
           Index Set   110             97       704896     0.
   Star Forest Graph    82             49        63224     0.
       Krylov Solver    17              7       217000     0.
      Preconditioner    17              7         6496     0.
              Viewer     1              0            0     0.
           Container    10             20        12480     0.
              Matrix   144            231   1909487728     0.
              Vector   237            323    870608184     0.
           Index Set    88            101       154152     0.
   Star Forest Graph    59             92       117152     0.
       Krylov Solver    12             22       203734     0.
      Preconditioner    12             22        25080     0.
Average time to get PetscTime(): 3.64147e-08
Average time for MPI_Barrier(): 0.00739469
Average time for zero size MPI_Send(): 0.000168472
-ksp_monitor
-ksp_type gmres
-log_view
-m 10000
-pc_type gamg
Using PETSc arch:
