[petsc-users] On MatDestroy() in Fortran
Edoardo alinovi edoardo.alinovi at gmail.com
Sun Jul 31 04:22:32 CDT 2022
Hello Barry,
I tested what we discussed yesterday and I would say the KSPDestroy works
good, while the trick of setting the matrix to NULL in KSPSetOperators does
not.
I attach here the memory traces of my code:
- baseline (each equation keep the matrix and does not destroy KSP)
- With KSPSetOperators(ksp, PETSC_NULL_MAT,PETSC_NULL_MAT)
- With KSPDestroy() before MatDestroy()
Clearly, the last one is a winner, while the first two look pretty similar!
Any possible explanation? I can happily destroy KSP, but the other one is
cleaner to implement :)
Is there any way to get the reference count of an object just to double
check it is not referenced anymore?
Thank you
Il Sab 30 Lug 2022, 21:59 Barry Smith <bsmith at petsc.dev> ha scritto:
>   Yes, as you describe below.
> On Jul 30, 2022, at 4:31 PM, Edoardo alinovi <edoardo.alinovi at gmail.com>
> wrote:
> Hello Barry,
> * I assume you are calling KSPSetOperators() before each new KSPSolve() so
> that it knows to solve a new system?*
> Yes, I do.
> This looks like a good trick:
> KSPSetOperators(ksp,PETSC_NULL_MAT,PETSC_NULL_MAT)
> So you would do:
> 1) KSPSetOperators(ksp,A,A)
> 2) KSPSolve(myksp, myrhs, mysol)
> 3) KSPSetOperators(ksp,PETSC_NULL_MAT,PETSC_NULL_MAT)
> 4) MatDestroy(A)
> Am I right?
> I'll have a try and I'll try to destroy the ksp of each equation as well.
> The second is more tedious because I'll have to reconstruct it every time.
> I'll do some tests to see if that helps.
> Thanks a lot!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220731/dc8503ab/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220731/dc8503ab/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220731/dc8503ab/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220731/dc8503ab/attachment-0005.png>
